查看: 316|回复: 0
[allegro16.6][6层]可通过云连接到 IBM Watson 的语音触发和处理参考设计(BGA118+...
发表于 2020-3-4 15:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][6层]可通过云连接到 IBM Watson 的语音触发和处理参考设计(BGA118+CAP0402+C5545)原理图和pcb文件
文件描述:
1. 作品用途:可通过云连接到 IBM Watson 的语音触发和处理参考设计
2. 软件版本:allegro16.6
3. 层数:6层
4. 用到的主要芯片:BGA118+CAP0402+C5545
5. PCB尺寸:1493*4583 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
BGA118_19-68_280X280TMS320C5545A_BGA118_BGA118_19-6TMS320C5545AZQW 10IC1U1
CAP0402CAP_CAP0402_0.01UF0.01uFIC21C1;  C10;  C11;  C12;  C13;  C14;  C15;  C16;  C23;  C26;  C27;  C28;  C29;  C33;  C34;  C53;  C54;  C80;  C84;  C117;  C158
CAP0402CAP_CAP0402_0.1UF0.1uFIC72C2;  C3;  C4;  C6;  C17;  C18;  C24;  C30;  C31;  C36;  C37;  C38;  C42;  C43;  C45;  C46;  C47;  C48;  C49;  C52;  C56;  C59;  C60;  C64;  C65;  C67;  C70;  C71;  C72;  C73;  C74;  C76;  C78;  C83;  C85;  C86;  C87;  C89;  C96;  C97;  C98;  C99;  C100;  C102;  C104;  C106;  C107;  C108;  C109;  C112;  C113;  C114;  C115;  C116;  C118;  C119;  C120;  C121;  C123;  C125;  C127;  C129;  C130;  C131;  C132;  C133;  C140;  C142;  C147;  C148;  C149;  C150
CAP0402CAP_CAP0402_10UF10uFIC12C5;  C20;  C22;  C41;  C51;  C69;  C75;  C81;  C88;  C101;  C122;  C126
CAP0402CAP_CAP0402_22PF22pFIC4C7;  C8;  C156;  C157
CAP0402CAP_CAP0402_1UF1uFIC11C9;  C25;  C32;  C35;  C39;  C44;  C63;  C66;  C95;  C141;  C145
CAP0402CAP_CAP0402_4.7UF4.7uFIC5C57;  C61;  C62;  C103;  C105
CAP0402CAP_CAP0402_2.2UF2.2uFIC1C68
CAP0402CAP_CAP0402_15PF15pFIC2C93;  C94
CAP0402CAP_CAP0402_1.2PF1.2pFIC2C137;  C146
CAP0402CAP_CAP0402_12PF12pFIC1C139
CAP0402CAP_CAP0402_0.47UF0.47uFIC2C143;  C144
CAP0402CAP_CAP0402_3.3UF3.3uFIC1C151
CAP0603CAP_CAP0603_2.2UF2.2uFIC2C79;  C82
CAP0805CAP_CAP0805_22UF22uFIC2C124;  C128
CAP0805CAP_CAP0805_1UF1uFIC2C134;  C135
CAP0805CAP_CAP0805_4.7UF4.7uFIC1C136
CON_AV4_SJ-43514_S_R_TCON_AUDIOJACK4_SJ-43514_CON_AV4CON_AUDIOJACK4_SJ-43514IC2J5;  J6
CON_FLEX1X14_10051922_S_R_SCON_FLEX_14X1_FH19_CON_FLEX1X14CON_FLEX_1X14_10051922IC1J11
CON_SD_8_DM3AT-SF-PEJM_S_R_SCON_SDCARD_8_DM3AT-SF-PEJM_0_COCON_SDCARD_8_DM3AT-SF-PEJM5IC1J3
CON_USBB5_10118194_S_R_SCON_USB_MINI-B11_CON_USBB5_1011CON_MUSB-B_5_FIC2J1;  J9
DIO_1-1L1ADIODE_SCHOTTKY_DIO_1-1L1A_1SS411SS416IC1D1
DIO_DFN0402DIODE_PESD_DIO_DFN0402_TPD1E10BTPD1E10B06DPYIC3D6;  D9;  D10
DIO_TUMD2MDIODE_SCHOTTKY_DIO_TUMD2M_RB578RB578VAM100TRIC3D2;  D3;  D4
DSBGA4_19-68_40X40TPS22934YZVR_DSBGA4_DSBGA4_19-6TPS22913BYZVTIC2U24;  U25
EMIFIL_BLM15A_0402EMIFILTER_IND_EMIFIL_BLM15A_040220EIC2FL9;  FL10
EMIFIL_BLM18R_0603EMIFILTER_IND_EMIFIL_BLM18R_060600EIC6FL1;  FL2;  FL3;  FL4;  FL5;  FL6
EMIFIL_BLM18R_0603EMIFILTER_IND_EMIFIL_BLM18R_0_11.5KEIC1FL7
HDR_1X2_146278_S_THEADER_2X1_HDR_1X2_146278_S_T_HHDR_1X2IC1J2
HDR_2X2_146258_S_THEADER_2X2_HDR_2X2_146258_S_T_HHDR_2X2IC2JP2;  JP3
HDR_2X5_20021121_P_S_SHEADER_5X2_HDR_2X5_20021121_P_SHDR_2X5IC1J12
IND0402INDUCTOR_FERRITE_IND0402_120E120EIC6FB1;  FB3;  FB5;  FB6;  FB7;  FB8
IND0402INDUCTOR_IND0402_15NH15nHIC1L3
IND0402INDUCTOR_IND0402_2NH2nHIC1L4
IND0603INDUCTOR_FERRITE_IND0603_220E220EIC1FB4
IND_VLS252012T_105X85_SMDINDUCTOR_IND_VLS252012T_105X85_2.2uHIC2L1;  L2
LED_0402DIODE_LED_LED_0402_SML-P11MTT86SML-P11MTT86IC5LD1;  LD2;  LD3;  LD4;  LD5
LQFP64_19-68_400X400FT2232H_LQFP64_LQFP64_19-68_400FT2232HLIC1U15
MIC2_CMC2242PBL_240_THMICROPHONE_MIC2_CMC2242PBL_240_CMC-2242PBL-AIC1MK1
MLP8_AT93C46DY6_120X80AT93C46DY6_MLP8_MLP8_AT93C46DY6AT93C46DY6-YH-TIC1U16
OSC4_ASDMB_100X85_SMDOSC4_ASDMB_OSC4_ASDMB_100X85_SM12.00MHzIC2U10;  U17
QFN24_19-68_220X140SN74AVC8T245RHL_QFN24_QFN24_19-SN74AVC8T245RHLIC1U18
QFN32_19-68_200X200CC2650F128RHBT_VQFN32_QFN32_19-CC2650F128RHBTIC1U11
QFN40_15-74_200X200TLV320AIC3206IRSBT_WQFN40_QFN40TLV320AIC3206IRSBTIC1U9
RCPT_2X10_100_S_TRECP_10X2_RCPT_2X10_100_S_T_RECRECP_2X10IC2J7;  J8
RES0402RESISTOR_RES0402_100K100KIC15R1;  R2;  R4;  R5;  R30;  R31;  R34;  R36;  R38;  R59;  R110;  R112;  R121;  R125;  R140
RES0402RESISTOR_RES0402_4.7K4.7KIC8R7;  R8;  R20;  R21;  R26;  R27;  R143;  R148
RES0402RESISTOR_RES0402_8.06K_1%8.06K_1%IC1R9
RES0402RESISTOR_RES0402_0E_1%0E_1%DISCRETE19R10;  R11;  R12;  R13;  R14;  R15;  R16;  R40;  R41;  R42;  R43;  R46;  R48;  R62;  R63;  R82;  R90;  R118;  R147
RES0402RESISTOR_RES0402_10K_1%10K_1%DISCRETE46R17;  R18;  R23;  R28;  R47;  R52;  R53;  R54;  R56;  R57;  R58;  R60;  R61;  R64;  R65;  R66;  R67;  R77;  R78;  R79;  R80;  R83;  R87;  R88;  R92;  R94;  R95;  R97;  R99;  R101;  R104;  R105;  R107;  R108;  R109;  R111;  R113;  R117;  R119;  R126;  R127;  R134;  R135;  R136;  R141;  R144
RES0402RESISTOR_RES0402_6.8K_1%6.8K_1%IC1R19
RES0402RESISTOR_RES0402_20K_1%20K_1%IC1R22
RES0402RESISTOR_RES0402_0E0EIC11R29;  R35;  R91;  R123;  R124;  R128;  R129;  R130;  R131;  R132;  R133
RES0402RESISTOR_RES0402_1K1KIC8R32;  R37;  R45;  R49;  R50;  R51;  R68;  R145
RES0402RESISTOR_RES0402_2.7K2.7KIC3R39;  R44;  R138
RES0402RESISTOR_RES0402_47E_1%47E_1%DISCRETE9R69;  R70;  R71;  R72;  R73;  R74;  R75;  R89;  R98
RES0402RESISTOR_RES0402_12K_1%12K_1%IC1R76
RES0402RESISTOR_RES0402_2.2K_1%2.2K_1%IC1R81
RES0402RESISTOR_RES0402_100E100EIC1R85
RES0402RESISTOR_RES0402_820K_1%820K_1%IC1R116
RES0402RESISTOR_RES0402_169K_1%169K_1%IC1R120
RES0402RESISTOR_RES0402_10.7K_1%10.7K_1%IC1R122
RES0402RESISTOR_RES0402_6.2K_1%6.2K_1%IC1R142
RES0603RESISTOR_RES0603_1E_1%1E_1%IC4R24;  R25;  R137;  R139
RESA_0402-4RESARR_ISO4_RESA_0402-4_0E0EIC1RA9
SC70-5SN74LVC1G08DCKT_SC70_SC70-5_SN7SN74LVC1G08IC1U143
SC70-6SN74LVC1G11DCKR_SC70-6_SC70-6_SSN74LVC1G11DCKRIC2U26;  U31
SOIC8MX25R1635FM1IL0_SOP8_SOIC8_MX25MX25R1635FM1IL0IC1U8
SOIC8TPS766_SOIC8_SOIC8_TPS76601DTPS76601DIC1U22
SOT23-5TPS3125J18DBVT_SOT23-5_SOT23-5_TPS3125J18DBVTIC1U29
SOT23-8INA219AIDCNR_SOT23-8_SOT23-8_ININA219AIDCNRIC4U4;  U5;  U23;  U30
SOT-3TPD2EUSB30D_SOT-3_SOT-3_TPD2EUSTPD2EUSB30DRTRIC2D7;  D8
SW3_98-42_460X160_THSW3_SLIDE_EG1218_SW3_98-42_460XEG-1218IC1SW6
SW4_PTS820_150X110_SMDSW4_PTS820_SW4_PTS820_150X110_SPTS820 J20M SMTR LFSIC4SW1;  SW2;  SW3;  SW4
TO_SOT23-123MOSFET_BSS138_TO_SOT23-123_BSS1BSS138IC3Q1;  Q2;  Q3
TP40_SMDTESTPOINT_TP40_SMD_SMDSMDIC3TP1;  TP2;  TP9
TP_40X65TESTPOINT_TP_40X65_THRU HOLETHRU HOLEIC6TP3;  TP4;  TP5;  TP6;  TP7;  TP8
TSSOP20_25-59_260X180TXS0108EPW_TSSOP20_TSSOP20_25-5TXS0108EPWRIC1U142
UQFN8_19-68_60X60SN74AUP1G74RSER_UQFN8_UQFN8_19-SN74AUP1G74RSERIC1U27
UQFN16_15-74_105X75SN74AVC4T245RSV_UQFN16_UQFN16_1SN74AVC4T245RSVRIC3U12;  U13;  U19
VSSOP8_25-59_120X120TCA9517DGKR_VSSOP8_VSSOP8_25-59TCA9517DGKRIC1U6
WSON8_19-68_80X80TPS62162DSGT_WSON8_WSON8_19-68_TPS62162DSGTIC1U20
WSON8_19-68_80X80TPS62162DSGT_WSON8_WSON8_19-6_1TPS62161DSGTIC1U21
XTAL4_86-61X62-99_130X105_SMDCRY4_13_XTAL4_86-61X62-99_130X124.0000MHzIC1Y2
XTAL4_ABM8G_130X105_SMDCRY4_13_XTAL4_ABM8G_130X105_SMD12.000MHzIC1Y6
XTAL_ABS06_85X50_SMDCRY_XTAL_ABS06_85X50_SMD_32.76832.768KHzIC1Y3
XTAL_NX3215SA_130X60_SMDCRY_XTAL_NX3215SA_130X60_SMD_3232.768 KhzIC1Y1
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
" [! [. t7 w3 ?! y- S
GMT+8, 2025-7-27 23:13 , Processed in 0.140625 second(s), 28 queries , Gzip On.
