查看: 583|回复: 6
[allegro16.6][8层]开源开发板Intel Minnowboard Minnow Original(Atom E6xx+EG20...
发表于 2020-3-4 15:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][8层]开源开发板Intel Minnowboard Minnow Original(Atom E6xx+EG20T+INTEL_ATOM_Processor_E6XX)原理图和pcb文件
文件描述:
1. 作品用途:开源开发板Intel Minnowboard Minnow Original
2. 软件版本:allegro16.6
3. 层数:8层
4. 用到的主要芯片:Atom E6xx+EG20T+INTEL_ATOM_Processor_E6XX
5. PCB尺寸:4200*4200 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
2-SMDCRYSTAL_SMT_32_768KHZ_2-SMD_32.32.768KHz, CITIZENIC1Y6
402CAP NP_0402_1UF1uFIC80C6; C18; C19; C47; C50; C56; C80; C140; C158; C168; C169; C170; C178; C187; C191; C193; C194; C195; C196; C197; C198; C199; C200; C201; C234; C237; C238; C240; C241; C242; C243; C244; C245; C246; C248; C249; C250; C251; C252; C253; C254; C255; C256; C257; C258; C259; C260; C261; C262; C264; C265; C287; C288; C289; C291; C292; C293; C294; C295; C296; C314; C315; C316; C317; C318; C319; C320; C321; C322; C342; C351; C352; C356; C357; C370; C373; C400; C401; C402; C1044
402CAP NP_0402_2700PF2700pFIC8C7; C13; C34; C35; C117; C137; C266; C268
402CAP NP_0402_0.1UF0.1uFIC114C8; C14; C15; C23; C24; C33; C46; C48; C57; C59; C60; C62; C73; C76; C77; C78; C83; C84; C85; C94; C96; C97; C98; C99; C101; C102; C114; C116; C133; C134; C136; C172; C173; C176; C177; C179; C184; C190; C192; C207; C209; C210; C211; C214; C215; C216; C217; C220; C221; C224; C225; C227; C229; C230; C233; C267; C269; C270; C273; C274; C277; C278; C299; C300; C301; C302; C304; C305; C308; C309; C311; C312; C313; C324; C325; C326; C327; C328; C329; C330; C331; C332; C333; C334; C335; C339; C340; C353; C354; C355; C358; C359; C364; C366; C367; C368; C369; C371; C374; C375; C382; C385; C387; C392; C393; C399; C404; C410; C411; C414; C415; C423; C424; C1043
402CAP_0.1UF_X5R_6.3V_20% 0201 _040.1ufIC42C9; C27; C28; C29; C30; C31; C36; C37; C38; C39; C40; C42; C43; C44; C45; C52; C53; C54; C55; C103; C105; C124; C127; C128; C129; C130; C131; C145; C146; C147; C150; C153; C154; C164; C167; C188; C189; C235; C236; C285; C286; C420
402CAP NP_0402_2.2UF2.2uFIC13C16; C25; C135; C171; C203; C204; C206; C213; C218; C219; C223; C226; C228
402CAP_0.1UF_X5R_6.3V_20% 0201 __21uFIC3C17; C125; C163
402CAP NP_0402_100PF100pFIC5C49; C51; C61; C63; C64
402CAP NP_0402_18PF18pFIC2C72; C74
402CAP NP_0402_20PF20pFIC2C75; C86
402CAP NP_0402_470PF470pFIC3C89; C93; C95
402CAP NP_0402_0.01UF0.01uFIC4C100; C281; C282; C283
402CAP_2.2UF_X5R_6.3V_10%_0402_0402.2uFIC4C104; C106; C421; C422
402CAP_0.1UF_X7R_16V_10% 0402 _04047pFIC2C107; C108
402CAP_0.1UF_X5R_6.3V_20% 0201 __10.01ufIC16C118; C119; C126; C132; C138; C139; C144; C149; C152; C155; C162; C166; C180; C181; C182; C183
402CAP_0402_47PF_COG_50V_0402_47NF47nFIC4C120; C121; C141; C143
402CAP_0.1UF_X7R_16V_10% 0402 _0_10.1ufIC8C122; C123; C142; C159; C407; C408; C412; C413
402CAP_0.1UF_X5R_6.3V_20% 0201 __3100pFIC4C148; C151; C161; C165
402CAP NP_0402_12PF12pFIC2C156; C157
402CAP NP_0402_820PF820pFIC3C185; C202; C212
402CAP NP_0402_200PF200pFIC3C205; C208; C222
402CAP NP_0402_47PF47pFIC2C239; C290
402CAP NP_0402_0.22UF0.22uFIC4C247; C263; C378; C403
402CAP_470PF_X7R_25V_10%_0402_04021000pFIC1C388
402CAP_470PF_X7R_25V_10%_0402_04_1470pFIC1C419
402RESISTOR_0402_56.256.2IC31R1; R2; R3; R4; R5; R6; R7; R8; R9; R15; R16; R17; R18; R19; R21; R22; R23; R24; R35; R36; R39; R40; R43; R66; R67; R84; R86; R332; R333; R334; R340
402RESISTOR_0402_10K10KIC104R10; R11; R25; R31; R32; R46; R50; R51; R61; R62; R70; R75; R92; R106; R108; R118; R119; R122; R143; R144; R164; R165; R171; R178; R182; R188; R198; R213; R214; R215; R216; R223; R224; R229; R231; R239; R240; R242; R243; R244; R245; R246; R247; R248; R256; R260; R274; R278; R279; R280; R281; R287; R295; R297; R299; R301; R302; R303; R314; R315; R316; R321; R322; R323; R324; R327; R328; R339; R345; R347; R348; R349; R350; R372; R374; R375; R377; R386; R387; R388; R393; R411; R415; R416; R417; R420; R422; R430; R431; R432; R433; R444; R445; R446; R449; R451; R452; R453; R454; R455; R456; R457; R476; R629
402RESISTOR_0402_51K51KIC1R12
402RES_4.75K_1/16W_1%_0402_0402_4.4.7KIC3R13; R14; R465
402RESISTOR_0402_39.239.2IC6R20; R33; R34; R37; R38; R55
402RESISTOR_0402_49.949.9IC12R26; R74; R97; R112; R116; R117; R145; R146; R364; R365; R391; R392
402RESISTOR_0402_20K20KIC1R28
402RESISTOR_0402_510510IC2R29; R48
402RESISTOR_0402_1K1KIC61R30; R44; R45; R49; R52; R63; R71; R76; R77; R89; R90; R101; R107; R114; R115; R130; R131; R132; R133; R135; R172; R181; R183; R193; R209; R228; R236; R261; R262; R267; R270; R271; R272; R310; R311; R317; R320; R337; R368; R369; R394; R395; R396; R397; R398; R399; R403; R410; R447; R450; R473; R474; R475; R618; R619; R620; R623; R624; R625; R627; R628
402RESISTOR_0402_00IC28R41; R42; R58; R64; R65; R73; R79; R82; R85; R105; R166; R273; R276; R282; R305; R306; R370; R379; R381; R400; R419; R424; R440; R441; R458; R459; R460; R621
402RESISTOR_0402_18.218.2IC2R47; R360
402RESISTOR_0402_3.16K3.16KIC2R53; R54
402RESISTOR_0402_220220IC4R59; R60; R237; R238
402RESISTOR_0402_100100IC13R72; R111; R194; R283; R288; R296; R300; R307; R308; R309; R331; R401; R448
402RESISTOR_0402_2K2KIC4R88; R134; R336; R404
402RESISTOR_0402_3333IC20R140; R142; R284; R285; R286; R289; R290; R291; R292; R293; R294; R298; R312; R313; R355; R358; R413; R414; R438; R439
402RESISTOR_0402_249249IC1R141
402RESISTOR_0402_24.924.9IC5R167; R168; R169; R425; R426
402RESISTOR_0402_330330IC4R173; R174; R195; R210
402RESISTOR_0402_0R560R56IC6R175; R185; R186; R196; R197; R212
402RESISTOR_0402_2222IC14R179; R180; R189; R190; R191; R192; R329; R330; R338; R346; R351; R352; R353; R354
402RES_470_1/10W_5%_0402_0402_470470IC1R184
402RESISTOR_0402_49.9K49.9KIC5R199; R202; R203; R206; R207
402RESISTOR_0402_499499IC5R200; R201; R204; R205; R208
402RES_33_1/16W_5%_0402_0402_00IC4R225; R373; R376; R463
402RESISTOR_0402_39K39KIC1R234
402RESISTOR_0402_68K68KIC1R235
402RES_33_1/16W_5%_0402_0402_5.1K5.1KIC2R249; R257
402RESISTOR_0402_300300IC5R250; R251; R252; R253; R263
402RESISTOR_0402_2.2K2.2KIC3R254; R255; R626
402RES_33_1/16W_5%_0402_0402_100100IC2R258; R259
402RESISTOR_0402_5050IC2R264; R265
402RES_4.75K_1/16W_1%_0402_0402_2020KIC1R266
402RESISTOR_0402_5.6K5.6KIC2R268; R269
402RESISTOR_0402_35.735.7IC2R275; R361
402RESISTOR_0402_191191IC1R277
402RESISTOR_0402_750750IC1R304
402RESISTOR_0402_12K12KIC7R341; R344; R371; R378; R380; R382; R383
402RESISTOR_0402_54.954.9IC2R356; R363
402RESISTOR_0402_27.427.4IC2R357; R362
402RESISTOR_0402_2.43K2.43KIC1R359
402RESISTOR_0402_60.460.4IC3R367; R389; R390
402RESISTOR_0402_10R10RIC4R406; R407; R408; R409
402RESISTOR_0402_4.7K4.7KIC3R412; R436; R437
402RESISTOR_0402_1.5K1.5KIC1R421
402RESISTOR_0402_100K100KIC2R427; R428
402RESISTOR_0402_2.37K2.37KIC1R435
402RES_470_1/10W_5%_0402_0402_10R10RIC1R442
402RES_470_1/10W_5%_0402_0402_374374IC1R443
402RES_4.75K_1/16W_1%_0402_0402_00IC1R466
402RES_4.75K_1/16W_1%_0402_0402_1010KIC1R467
402RES_4.75K_1/16W_1%_0402_0402_1K1KIC1R468
402RES_33_1/16W_5%_0402_0402_2727IC2R469; R470
402RES_470_1/10W_5%_0402_0402_470K470KIC1R471
402RES_470_1/10W_5%_0402_0402_280K280KIC1R472
0402-SRESISTOR_0402-S_00IC80R56; R57; R68; R69; R78; R80; R81; R83; R87; R91; R93; R94; R95; R96; R98; R99; R100; R102; R103; R104; R109; R110; R113; R120; R121; R123; R124; R125; R126; R127; R128; R129; R136; R137; R138; R139; R147; R148; R149; R150; R151; R152; R154; R155; R156; R157; R158; R159; R160; R161; R162; R163; R170; R177; R217; R218; R219; R220; R221; R222; R230; R232; R233; R318; R319; R325; R326; R335; R342; R343; R366; R384; R385; R402; R418; R423; R429; R434; R461; R622
0402-SRES_33_1/16W_5%_0402_0402-S_00IC2R226; R227
603CAP 0603 0_0.1UF/25V_0603_0.1UF0.1uFIC1C3
603CAP NP_0603_4.7UF4.7uFIC14C10; C20; C26; C109; C160; C376; C377; C379; C381; C386; C389; C397; C398; C409
603KE32_3_1.15A_0603_0467002_NR_2A0467002_NR_2A_LFIC1F1
603BEAD_0603_BEADBEADIC11FB1; FB2; FB3; FB4; FB5; FB8; FB9; FB10; FB11; FB12; FB13
603RESISTOR_0603_10M10MIC1R27
805CAP NP_0805_10UF10uFIC41C1; C2; C22; C32; C41; C65; C66; C67; C68; C69; C70; C79; C81; C82; C88; C90; C115; C271; C272; C275; C276; C279; C280; C284; C297; C298; C303; C306; C307; C310; C323; C336; C337; C347; C348; C349; C361; C365; C380; C390; C391
805CAP NP_0805_22UF22uFIC11C71; C87; C91; C92; C186; C231; C232; C360; C362; C405; C406
805L_SMALL_0805_MLB_201209-0030P-NMLB_201209-0030P-N1IC1L1
805RESISTOR_0805_00IC3R153; R405; R462
805RESISTOR_0805_0.01R0.01RIC4R176; R187; R211; R241
805RES_470_1/10W_5%_0402_0805_00IC1R464
805THERMISTOR_0805_PTC,0ZCE0010FF2PTC,0ZCE0010FF2GIC1RT1
1206NANO-SMF_1206_0.75A (1206L075WR0.75A (1206L075WRT)IC1F2
1206PCAP POL_1206P_1UF, TANTALUM1uF, TANTALUMIC1C58
1210INDUCTOR_1210_4.7UH4.7uHIC1L21
1411_THTCAP POL_1411_THT_47UF47uFIC8C174; C175; C338; C341; C343; C344; C345; C346
1808CAP NP_0_1808_8200PF8200pFIC5C4; C21; C110; C111; C113
1808CAP NP_0_1808_150PF150pFIC2C5; C112
3528CAPACITOR POL_4_3528_100UF100uFIC2C11; C12
6605814-6CONNECTORRJ45_GIGABIT_6605814-6RJ-45 GigabitIC1J12
BATT3_190X610BATTERY_2_BATT3_190X610_BATT HOBATT HOLDER, BS-1225-PCIC1BH1
BGA6_C2_P5MMTPS22922_0_BGA6_C2_P5MM_TPS2292TPS22922IC1U29
BGA169_N13_P8DA6011_1_BGA169_N13_P8_DA6011DA6011IC1U13
BGA676_22X22_8MM_MPI_ISO_BKPLTINTEL_ATOM_PROCESSOR_E6XX_2_BGAINTEL_ATOM_Processor_E6XXIC1U5
BGA_376PPCH EG20T_BGA_376P_(S1+S2+S3+S4PCH EG20TIC1U6
CHOKE_QTC24CGPLW3216S_0_CHOKE_QTC24CG_EXC24CEXC24CG900UIC4L2; L3; L4; L5
COIL5MMSMD_6SQINDUCTOR_COIL5MMSMD_6SQ_1.5UH1.5uHIC2L15; L16
CON2X50SMD_P8MMLS-1CONN SOCKET 50X2/SM_1_CON2X50SMCONN PLUG 50x2/SMIC1J8
CONN60_ITP_XDP_VRCONN PCB 30X2_CONN60_ITP_XDP_VRCONN_ITP_XDPIC1J7
CUI-SJ1-3515-SMTCONN_STEREO_BLUE_CUI-SJ1-3515-SSJ1-3515-SMT-TR-BEIC1P2
CUI-SJ1-3515-SMTCONN_STEREO_GREEN_CUI-SJ1-3515-SJ1-3515-SMT-TR-GRIC1P3
DBV-5TPS71718_DBV-5_TPS79318TPS79318IC1U35
DCK5SN74LVC1G06DCK_1_DCK5_SN74LVC1GSN74LVC1G06IC1U12
DDR2_FBGA60PINMT47H256M8_DDR2_FBGA60PIN_MT47HMT47H256M8IC4U1; U4; U26; U27
ECX-53CRYSTAL_SMT_14_3MHZ_ECX-53_ECS-ECS-143-20-30-TRIC1Y2
ECX-53CRYSTAL_SMT_25_0MHZ_ECX-53_ECS-ECS-250-20-30-TRIC1Y4
F603-41X39PGB0010603MR_F603-41X39_PGB0010PGB0010603MRIC4D2; D3; D4; D5
HC-46XCRYSTAL_THT_14_3MHZ_HC-46X_ECS-ECS-143-20-46XIC1Y1
HC-46XCRYSTAL_THT_25_0MHZ_HC-46X_ECS-ECS-250-20-46X-TRIC1Y3
HDR2X4HEADER 4X2_1_HDR2X4_HEADER 4X2HEADER 4x2IC1J11
HDR2X5HEADER 5X2_0_HDR2X5_HEADER 5X2HEADER 5X2IC1J9
IND2P9SMD_4SQINDUCTOR_IND2P9SMD_4SQ_4.7UH4.7uHIC1L12
IND2P75SMD_2P6X2P8INDUCTOR_IND2P75SMD_2P6X2P8_1UH1uHIC1L19
IND3P4SMD_5SQINDUCTOR_IND3P4SMD_5SQ_1.8UH1.8uHIC1L20
IND3P6SMD_4P9SQINDUCTOR_IND3P6SMD_4P9SQ_1.5UH1.5uHIC3L13; L14; L17
IND603-24X32FER_MMZ1608R301A_IND603-24X32_FFERRITE, MMZ1608R301AIC7L6; L7; L8; L9; L10; L11; L18
LED_LTST-S270GKT_RALED_LTST-S270GKT_0_LED_LTST-S27LTST-S270GKTDISCRETE4D11; D12; D13; D15
LED_LTST-S270GKT_RALED_LTST-S270KRKT_2_LED_LTST-S2LTST-S270KRKTDISCRETE1D14
MTGH200C125D_PLMHOLE_MTGH200C125D_PL_MHOLEMHOLEIC4MTG1; MTG2; MTG3; MTG4
PWRPAK_SO-8SI7540DP_16_PWRPAK_SO-8_SI7540DSI7540DPIC3U31; U32; U33
QFN48S6X6P4AR8031-AL1A_QFN48_QFN48S6X6P4_AAR8031_AL1AIC1U9
QFP48S7X7P5LS7P87SIL1162_0_QFP48S7X7P5LS7P87_SIISII1362IC1U2
QFP48S7X7P5LS7P87IC_TLV320AIC3104_0_QFP48S7X7P5LALC262IC1U3
RAPC712CONN_PWRJACK_RAPC712_RAPC712_RARAPC712IC1J15
RD205SMD_THT_250DCAP POL_220UF_RD205SMD_THT_250D220uFIC8C350; C372; C384; C394; C395; C396; C417; C418
SATA_RASATA_HEADER_RA_SATA_RA_04708040470804005IC1J3
SC70-574LVC1G08_0_SC70-5_74LVC1G07DCK74LVC1G07DCKIC2U7; U8
SD-MICRO-SCHA5B0300MICROSD_CONN_8_SD-MICRO-SCHA5B0SCHA5B0200IC1P1
SIP2JUMPER_SIP2_JUMPERJUMPERIC3J2; J5; J13
SIP3HEADER 3_1_SIP3_HEADER 3HEADER 3IC1J10
SIP4HEADER_4_SIP4_HEADER_4HEADER_4IC1J4
SM-7351-IND-0805FER_180_200_0805_SM-7351-IND-08150OHM800mAIC2FB6; FB7
SMCDIODE_SMCJ36CA_SMC_SMCJ5.0CASMCJ5.0CAIC1D7
SMCDIODE_SMCJ36CA_SMC_MBRS410LT3GMBRS410LT3GIC1D8
SMD_HDMIA_RACONN_HDMI_TYPEA_SMD_HDMIA_RA_HDHDMIConnAIC1J1
SMINI6-F3-BRN1907_SMINI6-F3-B_DMC56404DMC56404IC3Q1; Q2; Q8
SO8-25X75PWR_TLV70233DBV_0_SO8-25X75_TL5TL5209IC1U34
SO16-25X75TPS2054BD_SO16-25X75_TPS2054BDTPS2054BDIC1U10
SOD123_146LS1/4M8.2Z10_SOD123_146LS_MMSZ522MMSZ5226B-7-FIC1D6
SOD-123DIODE_7_SOD-123_SCS0520PSCS0520PIC1D1
SOIC8_260-1W25Q64_SOIC8_260-1_W25Q32CVW25Q32CVIC1U11
SOT23-5SN74LVC1G06DCK_1_SOT23-5_SN74LVSN74LVC1G14DBVRIC2U15; U16
SOT23-5TPS73633DBVT_1_SOT23-5_TPS73633TPS73633DBVRIC1U17
SOT23-574LVC1G08_SOT23-5_74LVC1G08DBVR74LVC1G08DBVRIC3U18; U19; U30
SOT23ABAT54C/SOT_3_SOT23A_BAT54C, SOTBAT54C, SOT23IC1D9
SOT23_GSDMOSFET_NCHAN_BSS138_SOT23_GSD_BBSS138IC5Q3; Q4; Q5; Q6; Q7
SOT23_GSDMOSFET_PCHAN_DMG1013T_SOT23_GSDDMG1013TIC1Q9
SSOP8_0256P_146LM95245_SSOP8_0256P_146_LM95245LM95245CIMMIC1U28
SSOP16_025P_186FT232RL_1_SSOP16_025P_186_FT230FT230XSIC1U22
SW3SMD_D320000G_RA3-POS SW_3_SW3SMD_D320000G_RA_TTL3320AF100QIC6S1; S2; S3; S4; S5; S6
TP40-SMTTEST_PAD_1_TP40-SMT_TEST_PAD_1TEST_PAD_1IC24TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25
TP135X185R_SMDTEST_PAD_0_TP135X185R_SMD_TEST_TEST_PAD_1IC4GH1; GH2; GH3; GH4
TSSOP14TXS0104EPW_TSSOP14_TXS0104EPWTXS0104EPWIC2U14; U36
TSSOP14GTL2005_TSSOP14_GTL2005PWGTL2005PWIC1U37
UMD3DIODE_DUAL_UMD3_RB717FRB717FIC1D10
USB5MINI_4SHIELDED_SMDMINI-USB-AB-SOCKET_USB5MINI_4SHmini USB-BIC1P4
USB5_FCI-10103594CONN_MICROUSBAB_USB5_FCI-101035USB_MicroBIC1J14
USB_STACKED2CONN_54819-0578_0_USB_STACKED2_USB-A Conn.IO1P5
U_5_DRLTPD2E001DRL_U_5_DRL_TPD2E001TPD2E001IC1U25
U_6_DRYPROT_TPD4S012_U_6_DRY_TPD4S012TPD4S012IC3U20; U21; U23
U_10_RSETPD6E001RSE_U_10_RSE_TPD6E001TPD6E001IC1U24
XTAL_CFS-145CRYSTAL_THT_32_768KHZ_XTAL_CFS-32.768KHz, CITIZENIC1Y5
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
* J0 Z* J- J' ]* f/ y" S
发表于 2020-7-28 23:25 | 只看该作者
发表于 2021-9-20 10:53 | 只看该作者
发表于 2022-10-5 16:48 | 只看该作者
谢谢楼主分享
“来自电巢APP”
发表于 2022-10-5 18:34 | 只看该作者
好东西,谢谢楼主分享
GMT+8, 2025-6-29 09:25 , Processed in 0.125000 second(s), 27 queries , Gzip On.
