查看: 1353|回复: 17
[allegro16.6][4层]海思HI3520D 开发板 (STC12C5A60S2+HI3520D+TW2964)原理图和p...
发表于 2020-3-4 14:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][4层]海思HI3520D 开发板 (STC12C5A60S2+HI3520D+TW2964)原理图和pcb文件
文件描述:
1. 作品用途:海思HI3520D 开发板
2. 软件版本:allegro16.6
3. 层数:4层
4. 用到的主要芯片:STC12C5A60S2+HI3520D+TW2964
5. PCB尺寸:7799*5040 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
1N4148-1206DIODE_1N4148-1206_1N41481N4148IC10D23; D43; D46; D47; D48; D50; D51; D54; D65; D86
8P4R0402YC124_JR_0733R51RIC5RN2; RN3; RN4; RN5; RN6
8P4R0603RESAR_IS_0_8P4R0603_33R33RDISCRETE2RN13; RN14
0521PRCLAMP0521P_0521P_RCLAMP0521PRCLamp0521PIC2D24; D25
1206DWDIODE SCHOTTKY_1206DW_27V27VIC2D52; D53
1206DWDIODE SCHOTTKY_1206DW_5V15V1IC1D61
1206DWDIODE SCHOTTKY_1206DW_6V86V8IC2D67; D70
1812BA201N_4_1812_BA201N-NCBA201N-NCIC2D79; D80
3520DQFPHI3520DHI3520DIC1U100
AXIAL0_4R2_AXIAL0_4_470/1W470/1WIC1R443
AXIAL0_4R2_AXIAL0_4_330R 1/4W330R 1/4WIC1R456
AXIAL0_4R2_AXIAL0_4_20K 1/4W20K 1/4WIC2R465; R466
AXIAL0_4R2_AXIAL0_4_180K 1/4W180K 1/4WIC1R523
AXIAL0_4R2_AXIAL0_4_NCNCIC1R593
BATTERY-CR1220BATTERY_BATTERY-CR1220_BATTERYBATTERYIC1BT1
BEEPERBELL_8_BEEPER_BEEPBEEPIC1BE1
BGA96-32-1609GH5TQ2G63BFR_PBCH5TQ2G63BFR-PBCIC1U10
BK16-500FUSE THERMAL_BK16-500_BK16-500BK16-500IC1F2
BK30-250FUSE THERMAL_BK30-250_BK30-250BK30-250IC1F6
BK60-135FUSE THERMAL_BK60-135_BK60-135BK60-135IC2F4; F5
BNC-2JL-12BNC_2_BNC-2JL-1_2BNC2BNCIC2JP46; JP47
C0402CAP NP_C0402_104104DISCRETE6C75; C250; C253; C254; C261; C264
C0402CAP_C0402_104104DISCRETE28C202; C203; C204; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C217; C218; C219; C224; C225; C226; C227; C228; C229; C230; C231; C232; C233; C235; C324
C0402CAP_0_C0402_103103DISCRETE4C257; C258; C259; C262
C0402CAP NP_C0402_104-NC104-NCIC1C439
C0402CAP NP_C0402_224224IC1C450
C0402CAP NP_C0402_1UF/16V1uF/16VIC1C453
C0402CAP_0_C0402_103-NC103-NCDISCRETE4C456; C457; C458; C459
C0603CAP NP_C0603_104104DISCRETE52C199; C256; C266; C267; C268; C278; C282; C284; C287; C290; C293; C298; C305; C306; C309; C313; C316; C318; C319; C320; C333; C335; C336; C337; C338; C339; C344; C345; C346; C347; C352; C353; C354; C355; C360; C361; C362; C363; C368; C370; C375; C376; C378; C381; C385; C415; C424; C433; C446; C454; C460; C463
C0603CAP_C0603_10UF/6.3V10uF/6.3VDISCRETE10C200; C201; C215; C216; C220; C222; C223; C234; C236; C296
C0603CAP NP_C0603_2.2UF2.2uFDISCRETE6C243; C247; C321; C322; C323; C431
C0603CAP NP_C0603_8.2NF8.2nFDISCRETE1C249
C0603CAP_C0603_22PF22pFDISCRETE2C251; C252
C0603CAP NP_C0603_103103IC3C281; C297; C308
C0603CAP NP_C0603_3300PF3300pFIC3C288; C307; C317
C0603CAP NP_C0603_5PF_NC5pF_NCIC1C289
C0603CAP NP_C0603_18PF18PFDISCRETE1C331
C0603CAP NP_C0603_330PF330pFIC1C382
C0603CAP_C0603_330PF330pFIC1C391
C0603CAP_C0603_103103IC1C393
C0603CAP_C0603_104104IC11C394; C395; C396; C397; C398; C399; C404; C405; C406; C411; C413
C0603CAP_C0603_20PF20PFIC2C401; C402
C0603CAP NP_C0603_104-NC104-NCIC1C432
C0603CAP NP_C0603_100PF100pFIC1C449
C0603CAP NP_C0603_2200PF2200pFIC1C451
C0603CAP NP_C0603_47PF47pFIC2C452; C455
C0805CAP NP_C0805_10UF/10V-NC10uF/10V-NCIC5C255; C263; C265; C304; C326
C0805CAP NP_C0805_22UF/6.3V22uF/6.3VDISCRETE6C285; C286; C291; C294; C314; C332
C0805CAP NP_C0805_22UF/6.3V-NC22uF/6.3V-NCIC4C292; C295; C315; C334
C0805CAP NP_C0805_10UF/10V10uF/10VDISCRETE9C302; C303; C327; C329; C330; C373; C374; C384; C421
C0805CAP_C0805_1UF/16V1uF/16VIC2C407; C412
C1210CAP NP_C1210_10UF/25V-NC10uF/25V-NCIC2C260; C325
C1210CAP NP_C1210_10UF/25V10uF/25VIC10C279; C280; C299; C300; C310; C311; C369; C445; C448; C461
C7343CAP POL_3_C7343_220UF/10V-NC220uF/10V-NCIC1C16
C7343CAP POL_3_C7343_220UF/10V220uF/10VDISCRETE1C32
DB15FL_VGA_DB15FL_VGA_0_DB15FL_VGA__DB15FLDB15FL_VGAIC1JP7
DGIND_DG_DR2W8X10-100KDR2W8X10-100KIC3L1; L2; L3
DGIND_DG_DR2W8X10-4R7KDR2W8X10-4R7KIC1L4
DIODE-SMCDIODE SCHOTTKY_DIODE-SMC_B360B360IC1D84
DIP4OPB700_0_DIP4_PC817CPC817CIC2U121; U122
DIP-7DVARISTOR_DIP-7D_7D2207D220IC13RV1; RV2; RV5; RV6; RV9; RV10; RV13; RV14; RV17; RV21; RV22; RV23; RV24
DIP-7DVARISTOR_DIP-7D_7D221K7D221KIC4RV18; RV19; RV20; RV25
DO-41DIODE_DO-41_1N58221N5822IC2D59; D66
DO-214ACDIODE_DO-214AC_1N40071N4007IC9D55; D56; D57; D58; D62; D68; D69; D71; D72
H1102H1102_1_H1102_H1102H1102IC1U103
HR219307TBY_0_HR219307_1:1
1:01
IC1TB1
JDQ5VRELAY SPST_0_JDQ5V_SIP-1A05SIP-1A05IC1JDQ2
JRC-23FJRC-23F_JRC-23F_HK23F-DC5V-SDGHK23F-DC5V-SDGIC2JDQ1; JDQ3
KST-RX709ACON7_KST-RX709A_KST_RX709AKST_RX709AIC1JP25
L0805INDUCTOR_L0805_SBY201209T-170Y-SBY201209T-170Y-NDISCRETE8LB17; LB18; LB19; LB20; LB21; LB22; LB29; LB30
LED-0805LED_LED-0805_LED(RED)LED(RED)IC5D1; D33; D41; D42; D64
LED-0805LED_LED-0805_LED(GREEN)LED(GREEN)IC1D26
LED-0805LED_LED-0805_LED(GREEN)-NCLED(GREEN)-NCIC1D85
LQFP128TW2968_0_LQFP128_TW2964TW2964IC1U23
MSOP-10-POWERPADTPS40210_MSOP-10-POWERPAD_TPS40TPS40210IC1U129
MTG150_PLATEDMOUNTING HOLE_PLATED_MTG150_PLADNEIC7MTG1; MTG2; MTG5; MTG6; MTG7; MTG8; MTG9
R0402R_R0402_33R33RDISCRETE4R36; R37; R54; R269
R0402R_R0402_4K74K7DISCRETE2R47; R52
R0402R_R0402_0R0RIC5R48; R339; R340; R341; R580
R0402R_R0402_1K-NC1K-NCIC1R53
R0402R_R0402_33R-NC33R-NCIC2R55; R271
R0402RES_R0402_0R0RDISCRETE4R278; R279; R285; R287
R0402RES_R0402_4K74K7IC2R288; R289
R0402R_R0402_10K10KIC1R304
R0402R_R0402_NCNCIC2R314; R319
R0402R_R0402_0R-NC0R-NCIC2R542; R545
R0402R_R0402_4K7-NC4K7-NCIC2R544; R548
R0603R_R0603_560R560RDISCRETE3R49; R322; R338
R0603R_R0603_75R75RDISCRETE5R258; R296; R324; R327; R328
R0603R_R0603_0R0RDISCRETE19R265; R300; R301; R302; R311; R317; R329; R331; R332; R412; R414; R431; R440; R487; R497; R521; R573; R584; R585
R0603R_R0603_4K74K7DISCRETE6R266; R330; R333; R334; R337; R552
R0603R_R0603_3.7K 1%3.7K 1%DISCRETE1R276
R0603RES_0_R0603_560R560RIC3R291; R294; R295
R0603R_R0603_0R-NC0R-NCIC6R292; R293; R343; R568; R586; R592
R0603R_R0603_3K9 1%3K9 1%IC1R305
R0603R_R0603_11K 1%11K 1%IC1R306
R0603R_R0603_6K8 1%6K8 1%IC3R307; R315; R321
R0603R_R0603_750R 1%750R 1%IC1R308
R0603R_R0603_158R 1%158R 1%IC1R309
R0603R_R0603_100K-NC100K-NCIC2R310; R316
R0603R_R0603_44.2K 1%44.2K 1%IC1R312
R0603R_R0603_10K 1%10K 1%IC2R313; R320
R0603R_R0603_26.1K 1%26.1K 1%IC1R318
R0603R_R0603_100K100KDISCRETE10R335; R336; R400; R427; R434; R435; R461; R464; R474; R475
R0603R_R0603_10K10KDISCRETE46R342; R346; R395; R396; R397; R402; R404; R405; R408; R409; R411; R415; R416; R417; R421; R428; R432; R436; R438; R439; R442; R446; R451; R457; R459; R462; R467; R468; R470; R471; R472; R477; R503; R505; R512; R515; R520; R522; R562; R572; R574; R576; R578; R587; R588; R590
R0603R_R0603_39K 1%39K 1%DISCRETE1R344
R0603R_R0603_56.2K 1%56.2K 1%DISCRETE1R345
R0603R_R0603_2K2KIC15R347; R348; R359; R360; R371; R372; R383; R384; R407; R455; R478; R480; R506; R507; R514
R0603R_R0603_20K20KIC20R351; R352; R363; R364; R375; R376; R387; R388; R406; R433; R441; R473; R498; R508; R513; R516; R519; R570; R579; R591
R0603R_R0603_12K12KIC8R355; R356; R367; R368; R379; R380; R391; R392
R0603R_R0603_1M1MIC7R401; R403; R423; R476; R500; R518; R571
R0603R_R0603_5K15K1IC10R410; R413; R447; R452; R454; R458; R460; R509; R510; R511
R0603R_R0603_1K1KIC5R426; R479; R501; R564; R577
R0603R_R0603_300K300KIC3R429; R453; R463
R0603R_R0603_150R150RIC1R430
R0603R_R0603_39K39KIC2R437; R481
R0603R_R0603_10R10RDISCRETE2R444; R445
R0603R_R0603_100R100RIC2R469; R589
R0603R_R0603_3K93K9IC4R484; R488; R491; R504
R0603R_R0603_22.6K 1%22.6K 1%IC1R496
R0603R_R0603_24.9K 1%24.9K 1%IC1R502
R0603R_R0603_20K-NC20K-NCIC1R517
R0603R_R0603_1K-NC1K-NCIC2R540; R547
R0603R_R0603_120R-NC120R-NCIC1R541
R0603R_R0603_100R-NC100R-NCIC2R543; R546
R0603R_R0603_261K 1%261K 1%IC1R561
R0603R_R0603_18.7K 1%18.7K 1%IC1R566
R0603R_R0603_1.2K 1%1.2K 1%IC1R567
R0603R_R0603_40.2K 1%40.2K 1%IC1R569
R0603R_R0603_10K-NC10K-NCIC1R575
R0603RES_0_R0603_560R-NC560R-NCIC1R583
R0805R_R0805_0R0RIC2R56; R57
R0805R_R0805_2R22R2IC2R493; R494
R1206R_R1206_3R33R3IC1R563
R2512R_R2512_10MR 1% 1W10mR 1% 1WIC1R565
RAD0_2CAP NP_RAD0_2_103/1KV103/1KVIC3C269; C383; C434
RAD0_4CAP NP_RAD0_4_0.22UF/250V0.22uF/250VIC1C400
RB1_25_4CAP_RB1_25_4_4.7UF/50V4.7uF/50VIC1C410
RB_1_2CAP POL_RB_1_2_100UF/16V100uF/16VDISCRETE6C283; C301; C312; C328; C380; C420
RB_2_4CAP POL_3_RB_2_4_470UF/25V-NC470uF/25V-NCIC1C277
RB_2_4CAP POL_3_RB_2_4_470UF/25V470uF/25VIC5C403; C418; C428; C444; C462
RCA-2X2RCA-2X2_1_RCA-2X2_RCA-2X2RCA-2X2IC1JP48
RCA-3BNC_0_RCA-3_RCARCAIC1JP16
RJ8-45RJ8-45_RJ8-45_RJ8-45RJ8-45IC1JP5
RLF12560TINDUCTOR_RLF12560T_RLF12560T-10RLF12560T-100M7R5IC1L6
SA07ASATA-CON_1_SA07A_SATA-CONSATA-CONIC1JP3
SA07ASATA-CON_1_SA07A_SATA-CON-NCSATA-CON-NCIC1JP39
SC0402CAP_SC0402_1UF1uFDISCRETE9C1; C2; C3; C4; C67; C85; C92; C93; C122
SC0402CAP_SC0402_474474IC2C5; C6
SC0402CAP_SC0402_224224IC4C9; C10; C11; C12
SC0402CAP_SC0402_104104DISCRETE68C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C52; C53; C54; C55; C56; C57; C58; C60; C61; C62; C63; C65; C66; C72; C73; C74; C76; C77; C79; C83; C86; C87; C88; C89; C90; C95; C96; C97; C98; C99; C100; C101; C103; C105; C110; C112; C113; C115; C123
SC0402CAP_SC0402_102102IC2C94; C109
SC0402CAP_SC0402_103103IC2C118; C121
SC0402RMEMK105BJ104KV_FR104IC1C124
SC0603CAP_SC0603_2.2UF2.2uFDISCRETE2C7; C8
SC0603CAP_SC0603_10UF/6.3V10uF/6.3VDISCRETE14C13; C14; C17; C18; C59; C80; C91; C102; C104; C106; C114; C116; C117; C120
SC0603CAP_SC0603_10UF/6.3V-NC10uF/6.3V-NCIC6C15; C19; C64; C78; C81; C84
SC0603CAP_SC0603_4.7UF/6.3V-NC4.7uF/6.3V-NCIC1C68
SC0603CAP_SC0603_4.7UF/6.3V4.7uF/6.3VIC3C69; C70; C82
SC0603CAP_SC0603_27PF27pFDISCRETE2C107; C108
SC0603C1608X5R0J106MT0A0E10UF/6.3VIC1C111
SC0603CAP_SC0603_30PF30pFIC2C377; C379
SC0805CAP_SC0805_22UF/6.3V22uF/6.3VIC1C71
SC1210CAP_SC1210_100UF/6.3V-NC100uF/6.3V-NCIC1C125
SC1210CAP_SC1210_100UF/6.3V100uF/6.3VDISCRETE1C126
SIP2-DCON2_SIP2-D_CON2CON2IC3JP21; JP22; JP42
SIP3-DCON3_SIP3-D_CON3CON3IC2JP40; JP41
SIP4-DCON4_SIP4-D_CON4CON4IC2JP1; JP19
SIP-2CON2_SIP-2_CON2CON2IC1JP38
SIP-3CON3_SIP-3_CON3CON3IC1JP20
SIP-5-2_0CON5_SIP-5-2_0_CON5CON5IC1JP6
SL0402INDUCTOR_SL0402_BLM15AG102SN1DBLM15AG102SN1DIC7LB11; LB12; LB13; LB14; LB25; LB26; LB27
SL0603INDUCTOR_SL0603_SBK160808T-300YSBK160808T-300Y-NIC1LB24
SL0805INDUCTOR_SL0805_BLM21AG601SN1BLM21AG601SN1IC2LB9; LB10
SMBSMBJ5.0CA_SMB_SMAJ15CASMAJ15CAIC9D18; D22; D34; D35; D36; D37; D38; D39; D40
SMBSMBJ5.0CA_SMB_TISP4350H3BJRTISP4350H3BJRIC1D27
SMBDIODE DIAC_SMB_SMBJ6.5CA-NCSMBJ6.5CA-NCIC2D77; D78
SMD1812FUSE_SMD1812_SMD1812P020TFSMD1812P020TFIC1F3
SMD1812R2_SMD1812_PTC-NCPTC-NCIC2F7; F8
SO8RC4558_6_SO8_RC4558RC4558IC1U109
SO8LM393_SO8_LM393LM393IC2U114; U130
SO824C16_SO8_24C0824C08IC1U116
SO8LM358_SO8_LM358LM358IC1U119
SO8HT9200A_SO8_HT9200AHT9200AIC1U123
SO8MC34119_SO8_MC34119MC34119IC1U124
SO8SP3485EN_SO8_SP3485EN-NCSP3485EN-NCIC1U127
SO8AO4443_SO8_AO4443AO4443IC1U132
SO8NMP1484EN_9_SO8N_MP1484ENMP1484ENIC3U105; U107; U108
SO14LM339A_SO14_LM339ALM339AIC1U117
SO16HCF4051_SO16_HCF4051HCF4051IC1U111
SOP18-300HT9172_SOP18-300_HT9172HT9172IC1U120
SOT23-3SI2305DS_T1_E3AO3401AIC1Q26
SOT23-3QPNP_SOT23-3Q_S8550S8550IC6Q1; Q2; Q5; Q6; Q7; Q9
SOT23-3QNPN_SOT23-3Q_S8050S8050IC11Q3; Q4; Q8; Q13; Q14; Q15; Q16; Q17; Q27; Q28; Q29
SOT23-574LVC1G07_SOT23-5_74LVC1G0774LVC1G07IC2U101; U102
SOT23-5RT8059_SOT23-5_RT8059RT8059IC1U110
SOT23-5SN74LVC1G02_SOT23-5_SN74LVC1G02SN74LVC1G02IC1U131
SOT143-4MAX811_SOT143-4_IMP811TEUSIMP811TEUSIC1U6
SOT-223LM1117-ADJ_SOT-223_LM1117-ADJLM1117-ADJIC1U106
SR0402RES_SR0402_120R 1%120R 1%DISCRETE2R8; R14
SR0402RES_SR0402_1K 1%1K 1%DISCRETE4R9; R11; R12; R13
SR0402RES_SR0402_10K10KDISCRETE5R10; R15; R16; R39; R46
SR0402RES_SR0402_240R 1%240R 1%DISCRETE1R17
SR0402RES_SR0402_43.2R 1%43.2R 1%IC1R21
SR0402RES_SR0402_75R 1%75R 1%IC4R23; R297; R298; R299
SR0402R_SR0402_4K7-NC4K7-NCIC1R27
SR0402R_SR0402_4K74K7DISCRETE3R28; R29; R30
SR0402RES_SR0402_4K74K7IC4R41; R43; R44; R59
SR0402RES_SR0402_4K7-NC4K7-NCIC2R42; R45
SR0402RES_SR0402_33R33RIC2R61; R303
SR0402RES_SR0402_0R0RIC3R69; R70; R71
SR0402RES_SR0402_1K1kDISCRETE2R73; R74
SR0402R_SR0402_51R51RIC4R86; R92; R93; R95
SR0402R_SR0402_0R0RIC1R290
SR0402RES_SR0402_0R-NC0R-NCIC2R581; R582
SR0603RES_SR0603_2.49K 1%2.49K 1%IC1R19
SR0603RES_SR0603_191R 1%191R 1%IC1R22
SR0603RES_SR0603_11K 1%11K 1%IC1R24
SR0603RES_SR0603_390R 1%390R 1%IC1R25
SR0603RES_SR0603_191R 1%191R 1%IC1R26
SR0603RES_SR0603_1M1MDISCRETE1R35
SR0603RES_SR0603_10R10RDISCRETE1R40
SR0603RES_SR0603_39K 1%39K 1%IC1R77
SR0603RES_SR0603_3.01K 1%3.01K 1%IC1R78
SR0603R_SR0603_0R-NC0R-NCIC1R79
SW4IDE-POW-CON_SW4_3.96PH-4PIN3.96PH-4PINIC1JP4
SW-PBSW SPST_3_SW-PB_SW SPSTSW SPSTIC1SW1
TO-220-DIPPNP_1_TO-220-DIP_TIP127TIP127IC2Q11; Q12
TO-220-DIPL7805_TO-220-DIP_L7805L7805IC1U133
TO-252AAIRFR3410_TO-252AA_IRFR3410IRFR3410IC1Q25
TP20RD10TP_TP20RD10_1.25V1.25VIC1TP1
TP20RD10TP_TP20RD10_1.5V1.5VIC1TP2
TP20RD10TP_TP20RD10_5.0V5.0VIC2TP3; TP6
TP20RD10TP_TP20RD10_3.3V3.3VIC1TP4
TP20RD10TP_TP20RD10_1.0V1.0VIC1TP5
TP20RD10TP_TP20RD10_13.8V13.8VIC1TP7
TQFP44STC12C5A60S2_TQFP44_STC12C5A60SSTC12C5A60S2IC1U115
USB-008USB-TYPEA1_USB-008_USB-TYPEA1USB-TYPEA1IC1JP2
WJ25S-02PCON2_WJ25S-02P_WJ25S-02PWJ25S-02PIC1JP27
WJ25S-02PCON2_WJ25S-02P_WJ25S-02P-NCWJ25S-02P-NCIC1JP45
WJ25S-03PCON3_WJ25S-03P_WJ25S-03PWJ25S-03PIC1JP26
WJ25S-04PCON4_WJ25S-04P_WJ25S-04PWJ25S-04PIC3JP28; JP43; JP44
WJ25S-12PCON12_WJ25S-12P_WJ25S-12PWJ25S-12PIC1JP17
WSOP8_200MX25L6406E/MX2512835F_WSOP8_200MX25L6406E/MX2512835FIC1U12
XTAL-49SCRYSTAL_2_XTAL-49S_24MHZ24MHZIC1X1
XTAL-49SCRYSTAL_2_XTAL-49S_11.0592MHZ11.0592MHZIC1X3
XTAL-49SCRYSTAL_2_XTAL-49S_3.5795MHZ3.5795MHZIC1X4
XTAL-ZXCRYSTAL_XTAL-ZX_32.768KHZ32.768KHZIC1X2
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
* V, U; `) e- t
    2023-6-25 15:00
  • 签到天数: 9 天
    [LV.3]偶尔看看II
    推荐
    发表于 2023-12-17 22:39 | 只看该作者
    差评,里面只有原理图,并且不是allegro16.6打不开
    推荐
    发表于 2020-11-19 14:23 | 只看该作者
    如果您要查看本帖隐藏内容请
    郁闷
    2020-11-24 15:01
    推荐
    发表于 2020-11-24 14:43 | 只看该作者
    看看是什么,感谢分享
    7 B( G2 y) l  N6 r( D; p
    2025-1-18 15:49
  • 签到天数: 68 天
    [LV.6]常住居民II
    发表于 2021-3-27 20:14 | 只看该作者
    11111111111& Q, A) i! Z2 A: u' U4 Z* ?
    发表于 2021-3-29 16:04 | 只看该作者
    感谢分享;谢谢
    2025-7-18 15:02
  • 签到天数: 557 天
    [LV.9]以坛为家II
    发表于 2021-3-30 18:06 | 只看该作者
    下载学习。看看。
    2025-7-18 15:02
  • 签到天数: 557 天
    [LV.9]以坛为家II
    发表于 2021-3-30 22:03 | 只看该作者
    没有原理图?
    2022-7-15 15:49
  • 签到天数: 215 天
    [LV.7]常住居民III
    发表于 2021-5-7 16:27 | 只看该作者
    下载学习。看看。
    “来自电巢APP”
    2024-8-26 15:16
    13#
    发表于 2023-10-16 14:20 | 只看该作者
    正好需要,下载看看
    : P5 `2 i& ~! ~5 J$ I. K( v8 y
    GMT+8, 2025-7-19 07:07 , Processed in 0.156250 second(s), 29 queries , Gzip On.
