1. 作品用途:海思Hi3516C PCB文件共享下载,可以做远程视频监控
2. 软件版本:allegro16.6
3. 层数:4层
5. PCB尺寸:异形
Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
C0402 | CAP NP_2_C0402_0.1UF | 0.1uF | IC | 82 | C2; C4; C5; C14; C16; C19; C22; C24; C28; C35; C37; C41; C42; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C69; C70; C71; C72; C74; C75; C76; C77; C81; C87; C88; C91; C93; C95; C96; C101; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C119; C120; C121; C125; C126; C127; C128; C129; C130; C131; C132; C133; C136; C137; C138; C139; C140; C141; C142; C145; C147 |
C0402 | CAP NP_2_C0402_22PF | 22pF | IC | 1 | C9 |
C0402 | CAP NP_2_C0402_27PF | 27pF | IC | 2 | C33; C34 |
C0402 | CAP NP_2_C0402_20PF | 20pF | IC | 2 | C39; C40 |
C0402 | CAP NP_2_C0402_1NF/NC | 1nF/NC | IC | 1 | C73 |
C0402 | CAP NP_2_C0402_10NF | 10nF | IC | 2 | C82; C83 |
C0402 | CAP NP_2_C0402_15PF | 15pF | IC | 1 | C98 |
C0402 | CAP NP_2_C0402_10PF/NC | 10pF/NC | IC | 1 | C99 |
C0402 | CAP NP_1_C0402_22PF | 22pF | IC | 1 | C102 |
C0402 | CAP NP_1_C0402_0.1UF | 0.1uF | IC | 2 | C148; C151 |
C0603 | CAP NP_2_C0603_1UF | 1uF | IC | 7 | C10; C68; C79; C86; C97; C107; C124 |
C0603 | CAP NP_2_C0603_2.2UF | 2.2uF | IC | 1 | C84 |
C0603 | CAP NP_1_C0603_10UF | 10uF | IC | 2 | C103; C150 |
C0603 | CAP NP_2_C0603_10UF | 10uF | IC | 2 | C149; C152 |
C0805 | CAP NP_2_C0805_10UF | 10uF | IC | 34 | C1; C3; C11; C12; C13; C15; C17; C18; C20; C21; C23; C26; C27; C36; C38; C43; C66; C67; C78; C80; C92; C94; C100; C104; C105; C106; C118; C122; C123; C134; C135; C143; C144; C146 |
C0805 | CAP NP_2_C0805_4.7UF | 4.7uF | IC | 2 | C89; C90 |
C1206 | CAP NP_2_C1206_100UF | 100uF | IC | 1 | C85 |
CK-1_25X1-P1_35-H0_82-1T2 | COMMON CHOKE_1_CK-1_25X1-P1_35- | common choke/NC | IC | 1 | L5 |
CON40-P0_5-H2 | SENSOR CONNECTOR_1_CON40-P0_5-H | Sensor Board Connector | IC | 1 | J6 |
CSP9-1_4X1_4-P0_5-H0_7 | AUDIO AMPLIFIER_1_CSP9-1_4X1_4- | Audio Amplifier BL6311 | IC | 1 | U10 |
DFN8-2X2-P0_5-H0_8 | BL8076_DFN8-2X2-P0_5-H0_8_BL807 | BL8076CKBTR | IC | 1 | U2 |
DO-214AC | 95SQ015/TO_2_DO-214AC_3A | 3A | IC | 1 | SD1 |
FBGA96-8X14-P0_8-H1_2 | DDRIII DRAM_3_FBGA96-8X14-P0_8- | DDR3 SDRAM | IC | 1 | U9 |
GD25-SOP8 | NORFLASH_2_GD25-SOP8_MX25L12835 | MX25L12835F | IC | 1 | U8 |
KFC-015B | RESET KEY_0_KFC-015B_RESET KEY | Reset Key | IC | 1 | J11 |
L-4X4-P3-H3 | INDUCTOR_L-4X4-P3-H3_2.2UH/3A | 2.2uH/3A | IC | 1 | L1 |
L-4X4-P3-H3 | INDUCTOR_L-4X4-P3-H3_2.2UH | 2.2uH | IC | 2 | L2; L4 |
LED3-3_2X1_5-P3-H1 | LED_3_LED3-3_2X1_5-P3-H1_GREEN | GREEN | IC | 2 | LED1; LED3 |
LED3-3_2X1_5-P3-H1 | LED_3_LED3-3_2X1_5-P3-H1_BLUE | BLUE | IC | 1 | LED2 |
LGA12-2X2-P0_5-H1 | G-SENSOR_1_LGA12-2X2-P0_5-H1_BM | BMA223 | IC | 1 | U11 |
M2_D2_2 | NPTH_0_M2_D2_2_HOLE | HOLE | IC | 2 | H1; H2 |
MICRO-USB | MICRO USB_B CONNECTOR_4_MICRO-U | Micro USB_B CN | IC | 1 | J1 |
M_SD8-2CA-0005-001-H1_83 | SD CARD_T1_15_M_SD8-2CA-0005-00 | SD CARD_T1 | IC | 1 | J4 |
PJ-218 | PHONOJACK STEREO-14_3_PJ-218_GP | GPS JACK | IC | 1 | J10 |
R0402 | R_R0402_0R | 0R | IC | 10 | FB1; FB2; FB3; FB7; FB8; R81; R87; R94; R103; R104 |
R0402 | R_R0402_2.2K | 2.2K | IC | 3 | R1; R86; R106 |
R0402 | R_R0402_100K | 100K | IC | 8 | R2; R3; R10; R11; R14; R31; R116; R117 |
R0402 | R_R0402_1K | 1K | IC | 8 | R4; R5; R16; R44; R76; R85; R97; R110 |
R0402 | R_R0402_10K | 10K | IC | 15 | R6; R9; R29; R33; R38; R66; R73; R75; R78; R90; R102; R105; R107; R108; R118 |
R0402 | R_R0402_470K | 470K | IC | 4 | R8; R13; R99; R114 |
R0402 | R_R0402_51K_1% | 51K_1% | IC | 3 | R12; R82; R84 |
R0402 | R_R0402_30K_1% | 30K_1% | IC | 1 | R15 |
R0402 | R_R0402_4.7K | 4.7K | IC | 13 | R20; R24; R42; R43; R48; R49; R50; R51; R67; R68; R69; R70; R71 |
R0402 | R_R0402_274K_1% | 274K_1% | IC | 1 | R25 |
R0402 | R_R0402_90.9K_1% | 90.9K_1% | IC | 1 | R26 |
R0402 | R_R0402_60.4K_1% | 60.4K_1% | IC | 4 | R27; R28; R30; R32 |
R0402 | R_R0402_1MOHM | 1Mohm | IC | 1 | R34 |
R0402 | R_R0402_10R | 10R | IC | 1 | R35 |
R0402 | R_R0402_30K | 30K | IC | 3 | R37; R40; R41 |
R0402 | R_R0402_51K | 51K | IC | 3 | R39; R45; R46 |
R0402 | R_R0402_33R | 33R | IC | 10 | R47; R62; R63; R64; R65; R77; R91; R92; R93; R98 |
R0402 | R_R0402_1K_1% | 1K_1% | IC | 6 | R52; R53; R54; R55; R60; R61 |
R0402 | R_R0402_60.4R_1% | 60.4R_1% | IC | 2 | R56; R57 |
R0402 | R_R0402_240R_1% | 240R_1% | IC | 2 | R58; R59 |
R0402 | R_R0402_4.7K/NC | 4.7K/NC | IC | 1 | R79 |
R0402 | R_R0402_43.2R | 43.2R | IC | 1 | R80 |
R0402 | R_R0402_10K/NC | 10K/NC | IC | 1 | R83 |
R0402 | R_R0402_1.5K | 1.5K | IC | 2 | R88; R89 |
R0402 | R_R0402_0R/NC | 0R/NC | IC | 1 | R101 |
R0603 | R_R0603_0R | 0R | IC | 4 | FB4; FB5; FB13; R96 |
R0603 | R_R0603_0R/NC | 0R/NC | IC | 1 | R95 |
R0805 | R_R0805_0R | 0R | IC | 3 | FB10; FB11; FB12 |
RN-8 | YC124_JR_0733R | 33R | IC | 3 | RN1; RN2; RN3 |
SMD2_P1_25 | SPEAKER CONNECTOR_SMD2_P1_25_SP | Speaker Connector | IC | 1 | J5 |
SMD2_P2 | MIC_SMD2_P2_MIC | MIC | IC | 1 | MIC1 |
SMD4_P1_25 | UART_SMD4_P1_25_UART CONNECTOR/ | UART Connector/NC | IC | 1 | J7 |
SMD10_P1_27_F | RL-UM12BT_3_SMD10_P1_27_F_RL-UM | RL-UM12BT | IC | 1 | J8 |
SMD10_P1_27_F | NB CN_7_SMD10_P1_27_F_2.4G NB M | 2.4G NB Module | IC | 1 | J9 |
SOD523 | 95SQ015/TO_5_SOD523_50MA | 50mA | IC | 1 | SD6 |
SOD523 | BZX84C20/SOT_1_SOD523_5.6V | 5.6V | IC | 1 | ZD1 |
SOD523 | BZX84C20/SOT_1_SOD523_3.6V/NC | 3.6V/NC | IC | 2 | ZD3; ZD4 |
SOT23-123 | BL919818AAPRN_2_SOT23-123_BL805 | BL8056D-33NRM | IC | 1 | U12 |
SOT23-BEC | FMMT4403/SOT_0_SOT23-BEC_PNP | PNP | IC | 1 | Q5 |
SOT23-BEC | 2N1470_5_SOT23-BEC_NPN | NPN | IC | 2 | Q6; Q14 |
SOT23-BEC | 2N1470_4_SOT23-BEC_NPN | NPN | IC | 2 | Q7; Q10 |
SOT23-BEC | 95SQ015/TO_7_SOT23-BEC_BAT54C | BAT54C | IC | 1 | SD7 |
SOT23-GDS | PWRMOSFET_EP_GSD_1_SOT23-GDS_AO | AO3401A | IC | 6 | Q1; Q2; Q4; Q9; Q11; Q13 |
SOT235 | BL3406B_SOT235_HD3110 | HD3110 | IC | 2 | U3; U5 |
SOT235 | BL919818AAPRN_SOT235_BL919818AA | BL919818AAPRN | IC | 1 | U4 |
SOT235 | BL919818AAPRN_0_SOT235_BL9193-A | BL9193-ADJ | IC | 1 | U6 |
SWITCH | POWER KEY_3_SWITCH_POWER KEY | Power Key | IC | 1 | J2 |
TFBGA293-13X13-P0_65-H1_4 | HI3516C_11_TFBGA293-13X13-P0_65 | Hi3516C | IC | 1 | U7 |
XTAL4-3_2X2_5-P1_2X1_4-H0_9 | 24MHZ CRYSTAL_0_XTAL4-3_2X2_5-P | 24MHz | IC | 1 | Y1 |
XTAL_32-768 | C001R12520 | 32_0.768KHz | IC | 1 | Y2 |
