1. 作品用途:高通物联网WIFI 控制方案QCA4004(QCA4004G)无线模块
2. 软件版本:allegro16.6
3. 层数:2层
Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CAP-0201 | CAP_CAP-0201_NO LOAD | No Load | IC | 5 | C1; C10; C78; C84; C312 |
CAP-0201 | CAP_CAP-0201_470PF | 470pF | IC | 1 | C4 |
CAP-0201 | CAP_CAP-0201_22PF | 22pF | IC | 3 | C11; C322; C325 |
CAP-0201 | CAP_CAP-0201_0.22UF | 0.22uF | IC | 2 | C16; C17 |
CAP-0201 | CAP_CAP-0201_1.8PF | 1.8pF | IC | 5 | C18; C21; C23; C302; C303 |
CAP-0201 | CAP_CAP-0201_8.2PF | 8.2pF | IC | 2 | C19; C20 |
CAP-0201 | CAP_CAP-0201_2.2PF | 2.2pF | IC | 2 | C22; C24 |
CAP-0201 | CAP_CAP-0201_0.6PF | 0.6pF | IC | 2 | C25; C301 |
CAP-0201 | CAP_CAP-0201_1PF | 1pF | IC | 1 | C26 |
CAP-0201 | CAP_CAP-0201_1.5PF | 1.5pF | IC | 3 | C27; C51; C53 |
CAP-0201 | CAP_CAP-0201_10PF | 10pF | IC | 8 | C49; C50; C305; C310; C311; C313; C316; L33 |
CAP-0201 | CAP_CAP-0201_0.1UF | 0.1uF | IC | 15 | C62; C79; C80; C81; C82; C83; C85; C88; C89; C91; C92; C276; C286; C287; C321 |
CAP-0201 | CAP_CAP-0201_1.2PF | 1.2pF | IC | 1 | C298 |
CAP-0201 | CAP_CAP-0201_NO LAOD, 100PF | No Laod, 100pF | IC | 1 | C332 |
CAP-0201 | CAP_CAP-0201_NO LOAD, 100PF | No Load, 100pF | IC | 1 | C333 |
CAP-0402 | CAP_CAP-0402_10UF | 10uF | IC | 2 | C2; C3 |
CAP-0402 | CAP_CAP-0402_10PF | 10pF | IC | 2 | C58; C328 |
CAP-0402 | CAP_CAP-0402_0.7PF | 0.7pF | IC | 2 | C282; C285 |
CAP-0402 | CAP_CAP-0402_NO LOAD | No Load | IC | 2 | C283; C284 |
CAP-0402 | CAP_CAP-0402_0.1UF | 0.1uF | IC | 1 | C314 |
CAP-0402 | CAP_CAP-0402_2.2UF | 2.2uF | IC | 2 | C335; C336 |
CAP-0603 | CAP_CAP-0603_2.2UF | 2.2uF | IC | 1 | C9 |
CAP-0603 | CAP_CAP-0603_22UF | 22uF | IC | 1 | C12 |
CON-HRS-UFL | CON RF 3PIN_CON-HRS-UFL_NO LOAD | No Load | IC | 2 | J10; J14 |
CRY-SMD4-CX101F | XTAL-SMD4-40MHZ-CX-101F_CRY-SMD | 40MHz | IC | 1 | Y1 |
HX-4A-TS | HX-4A-TS | CON6 | IC | 1 | J1 |
IND-0201 | IND_5_IND-0201_2.4NH | 2.4nH | IC | 8 | L4; L5; L6; L7; L22; L23; L30; L31 |
IND-0201 | IND_3_IND-0201_NO LOAD | No Load | IC | 1 | L32 |
IND-0201 | IND_6_IND-0201_2.0NH | 2.0nH | IC | 1 | L34 |
IND-0201 | IND_8_IND-0201_2.2NH | 2.2nH | IC | 1 | L35 |
IND-0402 | IND_12_IND-0402_1.0NH | 1.0nH | IC | 1 | L26 |
IND-0402 | IND_12_IND-0402_1.2NH | 1.2nH | IC | 1 | L27 |
IND-0402 | IND_9_IND-0402_10NH | 10nH | IC | 1 | L28 |
IND-0402 | IND_5_IND-0402_NO LOAD | No Load | IC | 1 | L29 |
IND-0402 | IND_12_IND-0402_600 | 600 | IC | 1 | L36 |
IND-2520 | IND_11_IND-2520_4.7UH | 4.7uH | IC | 1 | L1 |
JS-1252-04K | JS-1125-04K_3_JS-1252-04K_NO LO | no load, JS-1252-04 | IC | 1 | CN3 |
LED-0603 | LED-0603-LTST-C190GKT_LED-0603_ | LED | IC | 1 | DS3 |
LED-0603 | LED-ANODE1_LED-0603_RED | RED | IC | 1 | DS4 |
M4004B | M4004B | CON3 | DISCRETE | 1 | J2 |
MLPS-3030 | IND_2_MLPS-3030_4.7UH | 4.7uH | IC | 1 | L3 |
MM8430-2610 | MM8430-2610_MM8430-2610_MM8430- | MM8430-2610 | IC | 2 | J12; J13 |
QFN-68-EP-8X8-OFFS | QCA4004_2_QFN-68-EP-8X8-OFFS_QC | QCA4004G | IC | 1 | U19 |
RES-0201 | RES_RES-0201_4.7K | 4.7K | IC | 17 | R1; R5; R8; R11; R74; R75; R76; R305; R307; R317; R318; R326; R329; R330; R437; R446; R455 |
RES-0201 | RES_RES-0201_100K | 100K | IC | 2 | R2; R21 |
RES-0201 | RES_RES-0201_22.1K | 22.1K | IC | 1 | R3 |
RES-0201 | RES_RES-0201_1K | 1K | IC | 3 | R9; R367; R456 |
RES-0201 | RES_RES-0201_120 | 120 | IC | 1 | R10 |
RES-0201 | RES_RES-0201_NO LOAD | No Load | IC | 13 | R304; R311; R319; R320; R321; R322; R323; R327; R328; R406; R436; R444; R445 |
RES-0201 | RES_RES-0201_NP | NP | IC | 1 | R306 |
RES-0402 | ES0402V014CT_RES-0402_ES0402V01 | ES0402V014CT | IC | 2 | Q9; Q10 |
RES-0402 | RES_RES-0402_0 | 0 | IC | 3 | R6; R7; R435 |
RES-0402 | RES_RES-0402_49.9 | 49.9 | IC | 2 | R447; R449 |
SIP2PB-78 | SIP2PB-78 | | DISCRETE | 1 | J15 |
SO8NB | W25Q40BV-SO_SO8NB_W25Q16CVSSIG | W25Q16CVSSIG | IC | 1 | U18 |
SOT23-6 | SY8120B_0_SOT23-6_SY8120B | SY8120B | IC | 1 | U20 |
SR-0805 | SR-0805 | 0 | DISCRETE | 1 | R4 |
TESTPAD40 | TP SMD_TESTPAD40_40MIL | 40MIL | IC | 35 | TP4; TP5; TP6; TP7; TP8; TP9; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP28; TP30; TP31; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43 |
TRA-SOT23 | TRA-SOT23-2N7002_TRA-SOT23_LBSS | LBSS138LT1G | IC | 4 | Q1; Q2; Q3; Q4 |
VIA-3P3 | VIA-3P3 | CON1 | DISCRETE | 1 | J3 |
