查看: 453|回复: 2
[allegro16.6][4层]富瀚方案500W摄像头方案(IMX326+FH8538M+W25Q16DVSSIG)原理图...
发表于 2020-3-4 10:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][4层]富瀚方案500W摄像头方案(IMX326+FH8538M+W25Q16DVSSIG)原理图和pcb文件
文件描述:
1. 作品用途:富瀚方案500W摄像头方案
2. 软件版本:allegro16.6
3. 层数:4层
4. 用到的主要芯片:IMX326+FH8538M+W25Q16DVSSIG
5. PCB尺寸:1496*1496 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
C0402CAP NP_C0402_0.1UF0.1uFIC41C3; C12; C13; C14; C16; C17; C19; C20; C22; C23; C25; C26; C28; C30; C31; C36; C44; C47; C50; C52; C53; C58; C59; C78; C79; C81; C82; C85; C86; C89; C90; C91; C93; C97; C99; C101; C110; C117; C118; C195; C196
C0402CAP NP_C0402_1UF1uFIC2C9; C182
C0402CAP NP_C0402_2.2UF2.2uFIC1C10
C0402CAP NP_C0402_10UF10uFIC7C11; C15; C18; C21; C119; C197; C198
C0402CAP NP_C0402_0.01UF0.01uFIC3C43; C95; C181
C0402CAP NP_C0402_22PF22pFIC2C49; C56
C0402CAP NP_C0402_30PF30pFIC2C115; C116
C0402CAP NP_C0402_4.7UF4.7uFIC1C190
C0402CAP NP_C0402_NC/0.01UFNC/0.01uFIC1C193
C0603CAP_C0603_10UF/10V10uF/10VIC3C84; C92; C94
C0805CAP_C0805_47UF/6.3V47uF/6.3VIC1C35
C0805CAP_0_C0805_47UF/6.3V47uF/6.3VIC7C48; C51; C54; C55; C57; C62; C194
C1206CAP_0_C1206_47UF/16V47uF/16VIC1C46
CRSTALY_3225DIP8_2_CRSTALY_3225_27MHZ_20PF27MHz_20pFIC1Y1
DE8MM_H12CAP_DE8MM_H12_100UF/25V100uF/25VIC1C45
DO-214AASMBJ8.0CA_DO-214AA_DISCRETE_SMBSMBJ15CADISCRETE1D2
DO-214AASMBJ8.0CA_DO-214AA_DISCRETE_BS0BS0060N-CDISCRETE1D3
HEADER2X1_127MM4 HEADER_0_HEADER2X1_127MM_CON2CON2_1.27mmIC2CN1; CN2
HEADER3_125MM4 HEADER_4_HEADER3_125MM_NCNCIC1CN3
HEADER4X1_125MM4 HEADER_4_HEADER4X1_125MM_1.251.25-1-4AIC1CN6
HEADER6X1_125MM4 HEADER_25_HEADER6X1_125MM_1.21.25-1-6AIC1CN5
IMX326IMX326_IMX326_IMX326IMX326IC1U13
L0603INDUCTOR_L0603_0R0RIC4L3; L9; L20; L21
L0603INDUCTOR_L0603_10UH10uHIC1L5
L0603INDUCTOR_L0603_1R1RIC1L7
L0603INDUCTOR_L0603_2.2R2.2RIC1L14
L0603INDUCTOR_L0603_NCNCIC1L19
L3015INDUCTOR_L3015_SWPA3015S100MTSWPA3015S100MTIC1L6
L3015INDUCTOR_L3015_SWPA3015S4R7MTSWPA3015S4R7MTIC1L8
MTG250TEST_POINT_0_MTG250_GNDGNDIC4T1; T2; T3; T4
PC_LENS_SOCKET_20MMCMOS SENSOR OV9710-LEN_0_PC_LENLens Socket-17mmx17mmx20mmIC1J1
QFN56_THPUXIAN2_MIPI_1_QFN56_TH_FH8538MFH8538MIC1U2
R0402RESISTOR_0_R0402_10K10KIC6R1; R39; R87; R107; R108; R110
R0402RESISTOR_0_R0402_NCNCIC6R2; R72; R100; R101; R102; R103
R0402RESISTOR_0_R0402_37.4R37.4RIC1R18
R0402RESISTOR_0_R0402_100K_1%100K_1%IC3R36; R40; R41
R0402RESISTOR_0_R0402_43K_1%43K_1%IC1R37
R0402RESISTOR_0_R0402_14.3K_1%14.3K_1%IC1R38
R0402RESISTOR_0_R0402_2.4K2.4KIC1R67
R0402RESISTOR_0_R0402_2K2KIC1R69
R0402RES_R0402_27K27KIC1R73
R0402RESISTOR_0_R0402_1K1KIC1R76
R0402RESISTOR_0_R0402_2.7K2.7KIC1R81
R0402RESISTOR_0_R0402_22K22KIC1R85
R0402RESISTOR_0_R0402_120K120KIC1R86
R0402RESISTOR_0_R0402_47K47KIC2R88; R109
R0402RESISTOR_0_R0402_1M1MIC1R89
R0402RES_R0402_10K10KIC6R90; R91; R92; R93; R94; R95
R0402RESISTOR_0_R0402_00IC1R96
R0402RES_R0402_4.7K4.7KIC2R105; R106
R0603RESISTOR_0_R0603_1K1KIC1R77
R0603RESISTOR_0_R0603_75R75RIC1R98
SO8_200MIL_114024_2_SO8_200MIL_1_W25Q16DVSSW25Q16DVSSIGIC1U4
SOD323MAZ8056_2_SOD323_DISCRETE_BAT76BAT760-7DISCRETE1D4
SOD-123MAZ8056_5_SOD-123_DISCRETE_B130B130LAW-7DISCRETE1D1
SOP8_127-620X500CS4334_0_SOP8_127-620X500_AZ620AZ6208BMIC1U3
SOT23NPN BCE_0_SOT23_MMBT3904MMBT3904IC1Q1
SOT23A52815_9_SOT23_SGM809RSGM809RIC1U5
SOT23-6A52815_8_SOT23-6_TPF141TPF141IC1U9
SOT23_5A52815_8_SOT23_5_SY8088AACSY8088AACIC1U8
SOT23_5A52815_4_SOT23_5_TPS79328TPS79328IC1U11
SOT23_5A52815_4_SOT23_5_BU18TD3WG/TPS7BU18TD3WG/TPS79318IC1U12
SOT23_6A52815_5_SOT23_6_MP2359MP2359IC1U7
TP_C36D24TESTPOINT_0_TP_C36D24_TESTPOINTTestPointIC2TP1; TP2
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
7 I. u0 M( }2 B" m8 Y6 s
    2021-8-19 15:42
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    发表于 2021-5-24 08:38 | 只看该作者
    专业点 尺寸是不是38*38通用板型?
    GMT+8, 2025-7-5 23:10 , Processed in 0.125000 second(s), 27 queries , Gzip On.
