查看: 268|回复: 0
[allegro16.6][2层]分享一份allegro画的单面板,全部铺铜无走线,很少见。(SM9614...
发表于 2020-3-4 10:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][2层]分享一份allegro画的单面板,全部铺铜无走线,很少见。(SM9614_SOP-28+TDA1517P_DIP-18+SP3769F_SOP-16/FM)原理图和pcb文件
文件描述:
1. 作品用途:分享一份allegro画的单面板,全部铺铜无走线,很少见。
2. 软件版本:allegro16.6
3. 层数:2层
4. 用到的主要芯片:SM9614_SOP-28+TDA1517P_DIP-18+SP3769F_SOP-16/FM
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
6K66K6_6K6_32.768KHZ/FM32.768KHz/FMIC1Y1
AV4-8_4-13AV4-8_4-13_AV4-8_4-13_AV4-8_4-1AV4-8_4-13/OUTIC1JK4
CAP-104C0603_CAP-104_0.1UF/25V_Z0.1uF/25V_ZIC7C1; C4; C10; C11; C12; C13; C14
CAP-104C0603_CAP-104_2700PF/25V_M2700pF/25V_MIC2C2; C3
CAP-104C0603_CAP-104_0.47UF/25V_Z/FM0.47uF/25V_Z/FMIC2C5; C15
CAP-104C0603_CAP-104_2000PF/25V_M/FM2000pF/25V_M/FMIC1C6
CAP-104C0603_CAP-104_1000PF/25V_M/FM1000pF/25V_M/FMIC1C7
CAP-104C0603_CAP-104_0.015UF/25V_M/FM0.015uF/25V_M/FMIC1C8
CAP-104C0603_CAP-104_0.15UF/25V_M/FM0.15uF/25V_M/FMIC1C9
CAP-104C0603_CAP-104_0.1UF/25V_Z/TV0.1uF/25V_Z/TVIC1C16
CAP-104CAP104_CAP-104_0.47UF/25V_Z0.47uF/25V_ZIC2C17; C20
CAP-104CAP104_CAP-104_4700PF/25V_M4700pF/25V_MIC2C18; C19
CAP-104CAP-104_CAP-104_0.1UF/25V_Z0.1uF/25V_ZIC2C21; C22
CAP-104CAP104_CAP-104_102/1KV102/1KVIC1C23
CAP-104CAP-104_CAP-104_CAP-47PF/1KV_JCAP-47PF/1KV_JIC1C24
CAP-104CAP-104_CAP-104_CAP-0.1UF/50V_JCAP-0.1uF/50V_JIC1C25
CAP-104CAP104_CAP-104_0.1UF/25V_Z0.1uF/25V_ZIC1C26
CDT-6EPNCDT-6EPN_CDT-6EPN_CDT-6EPN/TVCDT-6EPN/TVIC1TV1
DIP-4PC817_DIP-4_BPC817CBPC817CIC1U5
DIP-18TDA1517P_DIP-18_TDA1517P_DIP-18TDA1517P_DIP-18IC1U3
DO-27DO-27_DO-27_HER303_DO-27HER303_DO-27IC1D5
DO-27DO-27_DO-27_IN5822_DO-27IN5822_DO-27IC1D12
DO-35DO-35_DO-35_9.1V/1/2W_DO-359.1v/1/2W_DO-35IC1D1
DO-35SOD-80_DO-35_3.3V/1/2W_DO-35/FM3.3V/1/2W_DO-35/FMIC1D2
DO-35DO-35_DO-35_22V/1/2W_DO-3522V/1/2w_DO-35IC1DW1
DO-35DO-35_DO-35_5.1V/1/2W_DO-35/NC5.1V/1/2w_DO-35/NCIC1DW2
DO-41DO-41_DO-41_1N4007_DO-411N4007_DO-41IC5D3; D4; D7; D11; D13
DO-41DO-41_DO-41_FR104_DO-41FR104_DO-41IC3D6; D9; D10
DOL-41DO-41_DOL-41_FR107_DO-41FR107_DO-41IC1D8
DR6-8DR6-8_DR6-8_10UH/2A_DR6X810uH/2A_DR6x8IC1L2
E5CD11-8_E5_100UF/16V(5X11MM)100uF/16V(5x11mm)IC1E1
E5CD11-5_E5_100UF/16V(5X11MM)100uF/16V(5x11mm)IC1E2
E5CD11-5_E5_2.2UF/50V_K2.2uF/50V_KIC9E3; E4; E5; E6; E7; E8; E9; E12; E15
E5CD11-6_E5_100UF/10V(5X11MM)/FM100uF/10V(5x11mm)/FMIC1E10
E5CD11-5_E5_2.2UF/50V_K/AUX2.2uF/50V_K/AUXIC1E11
E5CD11-5_E5_2.2UF/50V_K/TV2.2uF/50V_K/TVIC1E13
E5CD11-5_E5_2.2UF/50V_K/FM2.2uF/50V_K/FMIC1E14
E5CD11-5_E5_100U/10V(5X11MM)/TV100U/10V(5X11MM)/TVIC1E16
E5E_E5_100UF/16V_M(5X11MM)/1517100uF/16V_M(5x11mm)/1517IC1E19
E5E5_E5_10UF/50V_M(5X11MM)/151710uF/50V_M(5x11mm)/1517IC1E20
E5E5_E5_47UF/50V_M(5X11MM)47uF/50V_M(5x11mm)IC1E31
E5E5_E5_47UF/16V_M(5X11MM)47uF/16V_M(5x11mm)IC1E32
E6E6_E6_100UF/25V_M(6X12MM)100uF/25V_M(6x12mm)IC1E21
E6E6_E6_220UF/16V_M(6X12MM)220uF/16V_M(6x12mm)IC2E24; E27
E8E8_E8_470UF/16V_M(8X12MM)470uF/16V_M(8x12mm)IC2E17; E18
E8E8_E8_1000UF/16V_M(8X14MM)1000uF/16V_M(8x14mm)IC3E25; E28; E30
E10E10_E10_470UF/25V_M(10X14MM)470uF/25V_M(10x14mm)IC1E23
E10E10_E10_NCNCIC2E26; E29
E16CD11-16_E16_47UF/400V47uF/400VIC1E22
EE25-5-8EE25-5-7_EE25-5-8_EE25-5-7EE25-5-7IC1T1
F3-10F3-10_F3-10_T1AL250VT1AL250vIC1F1
J5J5_J5_D0_5X5MMD0_5x5mmIC2J6; J22
J5J8_J5_D0_5X5MMD0_5x5mmIC1J7
J6J15_J6_D0_5X6MMD0_5x6mmIC1J4
J6J5_J6_D0_5X6MM/FMD0_5x6mm/FMIC1J9
J6J10_J6_D0_5X6MMD0_5x6mmIC1J18
J8J10_J8_D0_5X8MM/NCDVDD0_5x8mm/NCDVDIC1J1
J8J10_J8_D0_5X8MM/NCD0_5x8mm/NCIC1J2
J8J8_J8_D0_5X8MM/DVDD0_5x8mm/DVDIC1J8
J8J10_J8_D0_5X8MMD0_5x8mmIC1J20
J8J5_J8_D0_5X8MMD0_5x8mmIC1J21
J8J8_J8_D0_5X8MMD0_5x8mmIC3J27; J28; J29
J10J10_J10_D0_5X10MMD0_5x10mmIC7J11; J12; J14; J15; J17; J23; J26
J15J15_J15_D0_5X15MMD0_5x15mmIC3J5; J10; J24
J15J10_J15_D0_5X15MMD0_5x15mmIC2J13; J19
J17J15_J17_D0_5X17MMD0_5x17mmIC2J3; J25
L0603L0603_L0603_56NH@800MHZ/DCR<1R/56nH@800MHz/DCR<1R/Q>8/FMIC1L1
PH-4PH-4_PH-4_PH-2_0-4P-WHITEPH-2_0-4P-WhiteIC1CN5
PH-5PH-5_PH-5_PH-2_0-5P-WHITEPH-2_0-5P-WhiteIC1CN6
PH-6PH-6_PH-6_PH2.0-6P_WHITE_STANDPH2.0-6P_white_standIC1CON1
PH-13PH-13_PH-13_PH-2_0-13P-WHITEPH-2_0-13P-WhiteIC1CN4
R4R4_R4_330K_1/4W_J330K_1/4W_JIC1R38
R8R8_R8_22D-722D-7IC1NTC1
R8R4_R8_100R_1/8W_J100R_1/8W_JIC1R1
R8R0603_R8_1K_1/8W_J1K_1/8W_JIC2R2; R4
R8R4_R8_2.2K_1/8W_J2.2K_1/8W_JIC1R3
R8R0603_R8_15K_1/8W_J/FM15K_1/8W_J/FMIC1R5
R8R0603_R8_22K_1/8W_J/TV22K_1/8W_J/TVIC2R6; R9
R8R0603_R8_10K_1/8W_J/FM10K_1/8W_J/FMIC4R7; R10; R48; R51
R8R0603_R8_13K_1/8W_J13K_1/8W_JIC2R8; R11
R8R0603_R8_22K_1/8W_J/AUX22K_1/8W_J/AUXIC2R12; R13
R8R0603_R8_5.6K_1/8W_J5.6K_1/8W_JIC2R14; R16
R8R0603_R8_1K_1/8W_J/FM1K_1/8W_J/FMIC2R15; R17
R8R0603_R8_1K_1/8W_J/IP1K_1/8W_J/IPIC2R18; R20
R8R0603_R8_68R_1/8W_J/FM68R_1/8W_J/FMIC1R19
R8R0603_R8_100R_1/8W_J/FM100R_1/8W_J/FMIC2R21; R23
R8R0603_R8_15K_1/8W_J15K_1/8W_JIC2R22; R24
R8R8_R8_1K_1/8W_J/TV1K_1/8W_J/TVIC4R25; R26; R27; R28
R8R8_R8_2.2K_1/8W_J2.2K_1/8W_JIC2R29; R30
R8R8_R8_6.8K_1/8W_J6.8K_1/8W_JIC2R31; R32
R8R8_R8_100K_1/8W_J100K_1/8W_JIC1R33
R8R8_R8_47K_1/8W_J47K_1/8W_JIC1R34
R8R8_R8_10K_1/8W_J10K_1/8W_JIC2R35; R36
R8R8_R8_22R_1/8W_J22R_1/8W_JIC1R39
R8R8_R8_6.8R_1/8W_J6.8R_1/8W_JIC2R40; R41
R8R8_R8_220R_1/8W_J220R_1/8W_JIC1R42
R8R8_R8_100R_1/8W_J/NC100R_1/8W_J/NCIC1R43
R8R8_R8_5.6K_1/8W_J5.6K_1/8W_JIC1R44
R8R8_R8_5.1K_1/8W_J5.1K_1/8W_JIC1R45
R8R0603_R8_1K_1/8W_J/TV1K_1/8W_J/TVIC1R46
R8R0603_R8_220R_1/8W_J/DVD220R_1/8W_J/DVDIC1R47
R8R0603_R8_10K_1/8W_J/TV10K_1/8W_J/TVIC1R49
R8R0603_R8_10K_1/8W_J/DVD10K_1/8W_J/DVDIC1R50
RL1WRL1W_RL1W_220K/1/2W_J220K/1/2W_JIC1R37
S15-25S15-25_S15-25_S15-25S15-25IC1S1
SOIC-16SP3769F_SOIC-16_SP3769F_SOP-16/SP3769F_SOP-16/FMIC1U2
SOP-28PT2314_SOP-28_SM9614_SOP-28SM9614_SOP-28IC1U1
TO-92S8050-TO92_TO-92_S8050_TO92S8050_TO92IC2Q1; Q2
TO-92S8550_TO92_TO-92_S8550_TO92/TVS8550_TO92/TVIC1Q3
TO-92S8550_TO92_TO-92_S8550_TO92/FMS8550_TO92/FMIC1Q5
TO-92S8050-TO92_TO-92_S8050_TO92/TVS8050_TO92/TVIC1Q6
TO-92S8050-TO92_TO-92_S8050_TO92/DVDS8050_TO92/DVDIC1Q7
TO-92S8050-TO92_TO-92_S8050_TO92/FMS8050_TO92/FMIC1Q8
TO-92AZ431_TO-92_AZ431AZ431IC1U6
TO-126B772_TO126_TO-126_B772_TO126/DVB772_TO126/DVDIC1Q4
TO-220LP2550_TO-220_LP2550_TO220LP2550_TO220IC1U4
UU9_8UU9_8_UU9_8_UU9.8/40MHUU9.8/40mHIC1T2
VH-3-2VH-3-2_VH-3-2_VH-2VH-2IC2CN2; SW1
WP2-16AWP2-16A_WP2-16A_WP2-16A/FMWP2-16A/FMIC1JK2
WP4-3WP4-3_WP4-3_WP4-3WP4-3IC1JK1
X1-Y1Y222_X1-Y1_222/400V222/400VIC1CY3
X2-224X104_X2-224_0.22UF/275V0.22uf/275VIC1CX1
XH-3XH-3_XH-3_XH-2_5-3P-WHITEXH-2_5-3P-WhiteIC1CN1
XH-8XH-8_XH-8_XH-2_5-8P-WHITEXH-2_5-8P-WhiteIC1CN3
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
1 t3 B# N  L# P- i
GMT+8, 2025-7-27 23:20 , Processed in 0.171875 second(s), 28 queries , Gzip On.
