查看: 304|回复: 0
[allegro16.6][8层]分享TI TSW3085EVM八层高频板(TSW3085EVM+HEADER+ SMT)原理...
发表于 2020-3-4 09:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][8层]分享TI  TSW3085EVM八层高频板(TSW3085EVM+HEADER+ SMT)原理图和pcb文件
文件描述:
1. 作品用途:分享TI  TSW3085EVM八层高频板
2. 软件版本:allegro16.6
3. 层数:8层
4. 用到的主要芯片:TSW3085EVM+HEADER+ SMT
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
201CAP NP_0_0201_.22UF_20%.22uFIC19C5; C6; C15; C17; C19; C20; C21; C22; C23; C24; C25; C26; C27; C29; C38; C41; C42; C43; C49
201CAP0402_0201_.1UF_-20%/+80%.1uFIC1C48
201RES_0603_0201_49.9_1%49.9IC4R42; R99; R100; R101
201R_0_0201_30.1_1%_30.1IC1R53
402CAP NP_0_0402_.01UF_5%_.01uFIC5C1; C2; C3; C4; C302
402CAP NP_0_0402_.1UF_10%.1uFIC5C34; C36; C253; C254; C337
402CAP NP_0_0402_1000PF_5%1000pFIC4C35; C47; C288; C289
402CAP NP_1_0402_1000PF_5%1000pFIC1C50
402CAPACITOR_NP_1_0402_.1UF_10%.1uFIC23C52; C60; C77; C78; C79; C80; C81; C82; C83; C84; C86; C87; C88; C89; C90; C99; C100; C101; C102; C117; C135; C138; C139
402CAP NP_0_0402_100PF_5%_100pFIC2C64; C110
402CAP NP_0_0402_.1UF_10%_.1uFIC8C65; C177; C182; C250; C251; C300; C301; C303
402CAP0201_0402_.01UF_5%_.01uFIC1C75
402CAPACITOR_NP_1_0402_4.7UF_20%4.7uFIC1C85
402CAP0603_0402_47PF_2%47pFIC2C95; C96
402CAP NP_1_0402_.1UF_10%.1uFIC1C97
402CAP NP_0_0402_8.2PF_10%_8.2pFIC1C107
402CAP NP_0402_.1UF_10%_.1uFIC4C112; C113; C119; C153
402CAP NP_2_0402_.5PF_.25PF.5pFIC4C121; C122; C131; C132
402CAP_0402_0402_1.0PF1.0pFIC2C125; C126
402CAP NP_0_0402_1500PF_5%_1500pFIC1C127
402CAP NP_1_0402_1UF_10%1uFIC1C154
402CAP NP_1_0402_.01UF_5%.01uFIC1C155
402CAP NP_2_0402_.2PF_.1PF.2pFIC1C156
402CAP NP_2_0402_.5PF_.1PF.5pFIC1C157
402CAPACITOR_NP_4_0402_.01UF_5%_.01uFIC3C162; C243; C307
402CAP NP_1_0402_33PF_2%33pFIC1C166
402CAP NP_0_0402_1000PF_5%_1000pFIC1C175
402CAP NP_1_0402_3.3PF_.25PF_3.3pFIC8C184; C185; C186; C190; C204; C205; C206; C222
402CAP NP_2_0402_100PF_5%100pFIC1C187
402CAP NP_1_0402_CAP NP_1_.25PF_CAP NP_1IC16C191; C192; C193; C194; C195; C196; C197; C198; C199; C200; C216; C217; C218; C219; C220; C221
402CAP NP_0_0402_1UF_10%_1uFIC4C214; C227; C228; C229
402CAPACITOR_NP_4_0402_.01UF_5%__1.01uFIC1C215
402CAPACITOR_NP_4_0402_.01UF_5%.01uFIC6C233; C234; C237; C242; C245; C247
402CAP NP_0_0402_20PF_5%_20pFIC2C249; C257
402CAP0402_0402_3.3PF3.3pFIC2C252; C255
402CAP NP_1_0402_6.8PF_.25PF6.8pFIC1C258
402CAP NP_1_0402_47PF_2%47pFIC2C259; C260
402CAP NP_0_0402_22PF_2%22pFIC1C299
402IND0603_0_0402_33NH_2%_33nHIC4L1; L2; L3; L4
402IND0603_0_0402_5.6NH_1%_5.6nHIC1L5
402RES_0402_ZERO_H_DNI_0402_00IC11R1; R2; R3; R4; R50; R58; R59; R273; R274; R275; R276
402R_0_0402_100_1%_100IC2R5; R15
402R_5_0402_0__0IC13R6; R25; R26; R27; R28; R93; R94; R103; R106; R136; R137; R175; R177
402RES_0402_ZERO_0402_00IC3R7; R18; R133
402R_0402_330K_1%330KIC2R10; R12
402RES_0402_4.75K_0402_4.75K4.75KIC8R16; R17; R19; R20; R21; R22; R23; R24
402R_0402_3.01K_5%3.01KIC1R40
402R_0_0402_1K_1%1KIC1R43
402R_0_0402_1.27K_1%1.27KIC1R44
402R_0_0402_10_1%10IC1R45
402R_0_0402_1K_1%_PANASONIC ERJ-2R1KIC2R46; R122
402R_0_0402_30.1_1%_30.1IC2R48; R49
402RES_0402_249_0402_240240IC8R51; R52; R55; R56; R57; R60; R91; R92
402RES_0402_22.1_H_0402_22.122.1IC1R54
402RES_0402_22.1_H_0402_1K1KIC2R61; R62
402RES_0402_22.1_H_0402_1818IC1R63
402R_1_0402_DISCRETE_10K_1%_10KDISCRETE3R70; R72; R90
402R_1_0402_DISCRETE_15K_1%_15KDISCRETE1R89
402R_0402_DISCRETE_150K_1%150KDISCRETE2R95; R151
402R_0402_DISCRETE_750K_1%750KDISCRETE2R104; R148
402RES_0402_49.9_0402_270_1%270IC2R105; R130
402R_5_0402_4.75K_1%_4.75KIC1R107
402R_0402_0_5%0IC13R108; R161; R163; R165; R167; R277; R278; R279; R280; R296; R297; R302; R303
402R_0_0402_4.75K_1%_4.75KIC1R120
402R_0_0402_DISCRETE_10K_1%_10KDISCRETE3R121; R125; R129
402R_0402_DISCRETE_191K_1%191KDISCRETE1R150
402R_0402_DISCRETE_182K_1%182KDISCRETE1R153
402R_0402_DISCRETE_31.6K_1%31.6KDISCRETE1R157
402R_0402_DISCRETE_10K_1%10KDISCRETE2R159; R171
402R_5_0402_0_5%_0IC4R169; R174; R181; R185
402R_0402_DISCRETE_53.6K_1%53.6KDISCRETE1R176
402R_5_0402_49.9_1%_49.9IC8R198; R199; R200; R201; R206; R207; R225; R226
402R_0_0402_0_5%0IC4R208; R210; R212; R214
402R_5_0402_2.74K_1%_2.74KIC4R209; R211; R213; R215
402R_0402_174K_1%174KIC2R221; R257
402R_0402_49.9_1%49.9IC1R313
603CAP_0603_0.01UF_0603_0.01UF0.01uFIC1C7
603CAP_0603_4.7UF_0603_4.7UF4.7uFIC1C8
603CAP NP_0_0603_1UF_10%1uFIC1C76
603CAP NP_2_0603_1UF_10%1uFIC5C111; C114; C115; C120; C174
603CAP NP_1_0603_1UF_10%1uFIC5C164; C170; C238; C244; C246
603CAP NP_1_0603_2.2UF_10%2.2uFIC2C169; C240
603CAP NP_0_0603_1UF_10%_1uFIC1C176
603FERRITE_BEAD_0603_0603_600 OHMS600 OHMS @ 100MHzIC1FB23
603RESISTOR_0603_DISCRETE_750_750DISCRETE3R8; R9; R11
603R_0603_0_5%0IC9R88; R96; R115; R118; R289; R290; R291; R292; R293
603R_0603_0_5%_NU PANASONIC ERJ-3G0IC1R117
603RES0603_0603_DISCRETE_10K_1%10KDISCRETE1R143
805CAP_0805_10UF_10V_0805_DISCRETE10uFDISCRETE1C9
805CAP NP_2_0805_DISCRETE_10UF_10%10uFDISCRETE1C59
805CAP NP_0805_DISCRETE_10UF_10%10uFDISCRETE9C133; C134; C143; C144; C145; C146; C147; C148; C149
805CAP0201_0805_DISCRETE_10UF_10%10uFDISCRETE6C150; C171; C172; C173; C304; C305
805CAP NP_0805_DISCRETE_10UF_10%_10uFDISCRETE1C161
805CAP NP_0_0805_2.2UF_10%_2.2uFIC1C256
8050805FERRITE_0805_31 OHM @ 100MH31 OHM @ 100MHzIC1FB8
805RES0603_0805_0_5%0IC2R127; R128
1206CAP NP_1_1206_DISCRETE_10UF_10%10uFDISCRETE2C63; C312
1206CAP NP_2_1206_DISCRETE_10UF_10%10uFDISCRETE7C72; C128; C178; C179; C180; C181; C298
1206CAP POL-B_1206_2.2UF_10%_2.2uFIC1C163
1206CAP NP_1_1206_22UF_10%22uFIC2C165; C167
1206FUSE/SM_1206_2 AMP 63V FAST SMD2 AMP 63V FAST SMDIC1F2
1206FERRITE_BEAD_0402_H_1206_68 OHM68 OHM @ 100MHzIC4FB10; FB12; FB18; FB19
1206FERRITE_BEAD_1206_68 OHM @ 100M68 OHM @ 100MHzIC1FB20
1206FERRITE_BEAD_0402_H_1206_120 OH120 OHM @ 100MHzIC1FB26
1206_BEAD_NFM31PBEAD_NFM31P_1206_BEAD_NFM31P_2727uFIC3FB28; FB30; FB31
1806FERRITE_BEAD_0402_H_1806_1K OHM1K OHM @ 100MHzIC2FB1; FB2
1810FERRITE_BEAD_0402_H_1810_1K OHM1K OHM @ 100MHzIC8FB22; FB24; FB33; FB34; FB35; FB36; FB39; FB40
CON_RAPC722_JACK_THVT_3CONN JACK PWR_CON_RAPC722_JACK_CONN JACK PWRIC1J4
CON_SMRT_USBMNE20_FUSB_MINI_AB_MNE20-5G5P10_CON_SMUSB_MINI_ABIC1J14
CON_SMVT_180POS_QTH_SAMTEC_RT1CON_SMVT_180POS_QTH_SAMTEC_CON_HEADER, SMT, 180POS, HS GND PLANEIC1J13
DBV5TPS2400_DBV5_TPS2400TPS2400IC1U21
HDR_THVT_1X3_100_MJUMPER_1X3_100_0_HDR_THVT_1X3_1HEADER, 3POSIC4JP1; JP2; JP3; JP5
HDR_THVT_1X3_100_MSMD_JUMPER_1X3_HDR_THVT_1X3_100HEADER, 3POSIC1JP4
HDR_THVT_2X5_100_MHEADER_2X5_100_HDR_THVT_2X5_100HTSW-105-07-G-DIC1J15
JUMPER_SMD_3POS_0402JUMPER_SMD_3POS_0402_JUMPER_SMDSOLDER JUMPER, 0603IC4SJP1; SJP6; SJP7; SJP8
JUMPER_SMD_L_0603JUMPER_1X3_100_430L_JUMPER_SMD_SOLDER JUMPER, 0603IC1SJP3
LED_0805LED_LED_0805_LED GREENLED GREENIC3D1; D4; D5
LED_0805LED_LED_0805_LED BLUELED BLUEIC1D2
LED_0805LED_LED_0805_DISCRETE_LED AMBERLED AMBERDISCRETE1D3
LPS3015IND1206_LPS3015_2.2UH2.2uHIC3L7; L25; L26
MFG053_PTHMOUNTING_HOLE_MFG053_PTH_RF SHIRF SHIELDIC6SH1; SH2; SH3; SH4; SH5; SH6
NANO_SMFLITTELFUSE_0154007_NANO_SMF_1 A1 AMP FUSEIC1F1
OSC_6_SM_295X205_100_CUSTOMOSC_6_SM_FOX_HCMOS_OSC_6_SM_29510.000MHzIC1Y1
PROBE_POINT_30PADPROBE_POINT_PROBE_POINT_30PAD_PPROBE POINTIC1PP1
QFN_24_163X163_0P50MM_PWRPADTRF3705_0_QFN_24_163X163_0P50MMTRF3705IC1U23
QFN_32_197X197_20_PWRPADPE43701_QFN_32_197X197_20_PWRPAPE43701IC1U7
QFN_64_360X360_0P50MM_SQA64LMK04806B_QFN_64_360X360_0P50MMLMK04806BIC1U16
SC70_DCK_G5TPS79633DCQ_2_SC70_DCK_G5_TPS71TPS71701IC2U13; U22
SMA_SMEL_DUAL_PSF-S01_250X215SMA-END_JACK_142-0761-801_ROUNDSMA END LAUNCHIC2J1; J7
SMA_THRT_276X276SMA_PCB_THVT_142-0701-201_REC_SSMA THRU HOLE R/AIC5J2; J3; J5; J6; J11
SMA_THVT_320X320SMA_PCB_THVT_142-0701-201_REC_1SMA THRU HOLEIC1J12
SMD_JUMPER_L_0402SMD_JUMPER_L_0402_SMD_JUMPER_L_SOLDER JUMPER, 0402IC1SJP2
SMD_JUMPER_L_0402JUMPER_SMD_1X3_SMD_JUMPER_L_040SOLDER JUMPER, 0402IC2SJP4; SJP5
SMP_B120SMP_PLUG_SMT_SMP_B120_SMP_PCB_SSMP_PCB_SMTIC1J10
SON_8_2MMX2MM_0P65MMPWR_MOSFET_CSD17313Q2_SON_8_2MMCSD17313Q2IC1Q1
SON_8_124X124_PWRPAD_DRBTPS7A8001_SON_8_124X124_PWRPAD_TPS7A8001DRBIC2U14; U18
SON_DRC_10TPS62420_SON10_1_SON_DRC_10_TPSTPS62420IC1U11
SON_DRV_6TPS79633DCQ_3_SON_DRV_6_TPS6229TPS62290IC1U2
SOT_5_120X69_37LP2985_0_SOT_5_120X69_37_LP2985LP2985-50IC1U6
SOT_89_4321SGA-7489_SOT_89_4321_MGA-30689_MGA-30689IC1U8
SOT_223_6_TGTPS79633DCQ_1_SOT_223_6_TG_TPS7TPS79633IC2U12; U15
SO_8_210X212_5025AA080A_0_SO_8_210X212_50_25AA25AA512IC1U5
SSOP_28_413X220_26FT245RL_0_SSOP_28_413X220_26_FTFT245RLIC1U3
SW_RESET_PTS635SW PUSHBUTTON_1_SW_RESET_PTS635SW PUSHBUTTONDISCRETE2SW1; SW2
TANT_ACAP POL-B_10UF_10V_TANT_A_DISCR10uFDISCRETE4C13; C30; C40; C53
TANT_ACAP POL-B_10UF_10V_TANT_A_4.7UF4.7uFIC2C290; C291
TANT_ACAP POL-B_TANT_A_2.2UF_10%_2.2uFIC1C306
TANT_BCAP POL_TANT_B_47UF_10%47uFIC1C152
TESTPOINT_62DIATESTLOOP_BLACK_TESTPOINT_62DIA_TEST POINT, REDIC14TP1; TP2; TP3; TP4; TP5; TP10; TP12; TP15; TP16; TP17; TP18; TP19; TP20; TP21
TESTPOINT_62DIATESTLOOP_BLACK_TESTPOINT_62DI_1TEST POINT, BLKIC5TP6; TP7; TP8; TP9; TP13
TQFP_44_39X39_32EPM3032A_TQFP_44_39X39_32_EPM30EPM3064AIC1U4
TSSOP_8_177X122_26CDCV304PW_4_TSSOP_8_177X122_26_CDCV304PWIC1U26
WQFN_88_354X354_0P60MMDAC3482_WQFN_88_354X354_0P60MM_DAC3482IC1U1
XFMR_MINICIRCUITS_AT224_1TFMR_5_ETC1-1-13_5_XFMR_MINICIRTC1-1-13MIC2T1; T2
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
8 \7 L0 R- I1 ?% c( o: S. T' I% o1 |
GMT+8, 2025-7-27 23:21 , Processed in 0.140625 second(s), 28 queries , Gzip On.
