查看: 755|回复: 8
[allegro16.6][6层]飞思卡尔PowerPC5口千兆以太网 芯片 开发板(JFM4VSX55+MPC8349...
发表于 2020-3-3 18:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][6层]飞思卡尔PowerPC5口千兆以太网 芯片 开发板(JFM4VSX55+MPC8349E + VSC7385)原理图和pcb文件
文件描述:
1. 作品用途:飞思卡尔PowerPC5口千兆以太网 芯片 开发板
2. 软件版本:allegro16.6
3. 层数:6层
4. 用到的主要芯片:JFM4VSX55+MPC8349E + VSC7385
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
176TQFPSII3114_176TQFP_IC_SII3114sIi3114IC1U20
184_DDR_DIMMDDR_DIMM_0_184_DDR_DIMM_IO_DDR_DDR_DIMMIO1U1
ATXPOWER_10X239-29-9202atxpower_10X2IO1P18
BATT_WIN_VBATTERY_1_BATT_WIN_V_IC_MAXELL_MAXELL_T25IC1BT1
BGA100VSC8021BGA100_BGA100_IC_VSC8201VSC8201BGA100IC1U33
BGA364_P1MM_23MMVSC7385_BGA364_P1MM_23MM_IC_VSCVSC7385, SparX-G5IC1U35
BGA672MPC8349E_2_BGA672_IC_MPC8349E_2MPC8349E_2IC1U2
CASE457-04SS12/SM_0_CASE457-04_DISCRETE_MMBRM140DISCRETE5D10; D11; D12; D15; D16
CASE_ECAP_CASEE_CASE_E_DISCRETE_470UF470uF_6V3DISCRETE4C78; C256; C300; C538
CC0402CAP_NP_1_CC0402_DISCRETE_10NF10nFDISCRETE190C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C46; C47; C48; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C75; C76; C77; C79; C80; C81; C84; C85; C86; C87; C88; C89; C90; C92; C94; C95; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C112; C113; C114; C115; C116; C117; C118; C119; C123; C124; C125; C126; C128; C129; C130; C131; C133; C134; C135; C136; C138; C139; C141; C142; C143; C144; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C183; C184; C187; C188; C189; C190; C267; C290; C293; C294; C295; C299; C301; C310; C319; C320; C321; C364; C365; C444; C445; C447; C453; C471; C490; C491; C497; C498; C499; C500; C501; C502; C503; C504; C513; C514; C515; C516; C517; C518; C519; C523; C524; C525; C562; C563; C564; C565; C572; C573; C574; C575; C576; C577; C578; C579
CC0402CAP_NP_1_CC0402_DISCRETE_10NF-N10nF-NPDISCRETE6C93; C96; C454; C455; C456; C566
CC0402CAP NP_0_CC0402_DISCRETE_10NF10nFDISCRETE52C140; C145; C146; C147; C148; C149; C150; C151; C152; C155; C156; C159; C160; C161; C162; C163; C164; C165; C166; C169; C170; C315; C317; C318; C323; C324; C326; C328; C330; C331; C335; C339; C343; C344; C345; C346; C457; C459; C460; C461; C462; C463; C464; C465; C469; C473; C479; C481; C482; C483; C485; C486
CC0402CAP_NP_1_CC0402_DISCRETE_100NF100nFDISCRETE100C191; C192; C193; C199; C200; C202; C204; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C215; C222; C223; C227; C228; C230; C232; C234; C235; C236; C237; C238; C239; C240; C243; C348; C350; C351; C352; C353; C354; C355; C357; C358; C359; C360; C362; C363; C366; C367; C368; C369; C370; C371; C372; C373; C374; C375; C376; C377; C378; C379; C380; C381; C382; C383; C384; C385; C386; C387; C388; C389; C390; C391; C392; C433; C434; C435; C436; C437; C438; C439; C440; C441; C442; C452; C478; C488; C489; C521; C522; C537; C554; C555; C556; C557; C558; C559; C560; C567; C570; C580; C581
CC0402CAP_NP_1_CC0402_DISCRETE_100NF-100nF-NPDISCRETE22C194; C195; C196; C197; C198; C201; C203; C218; C219; C220; C221; C224; C225; C226; C229; C231; C233; C494; C511; C529; C532; C561
CC0402CAP NP_2_CC0402_DISCRETE_100NF100nFDISCRETE22C245; C246; C253; C254; C268; C269; C270; C271; C272; C273; C274; C275; C276; C277; C279; C280; C281; C282; C288; C289; C296; C297
CC0402CAP_NP_1_CC0402_DISCRETE_20PF20pFDISCRETE2C284; C285
CC0402CAP NP_0_CC0402_DISCRETE_0.047U0.047uDISCRETE2C313; C314
CC0402CAP NP_2_CC0402_DISCRETE_10NF10nFDISCRETE24C395; C396; C397; C399; C401; C402; C404; C405; C407; C408; C409; C410; C413; C415; C416; C417; C422; C423; C424; C425; C428; C429; C431; C432
CC0402CAP NP_0_CC0402_DISCRETE_10NF-N10nF-NPDISCRETE3C443; C446; C458
CC0603CAP_NP_1_CC0603_DISCRETE_27PF-N27pF-NPDISCRETE4C185; C186; C337; C338
CC0603CAP_NP_1_CC0603_DISCRETE_100PF100pFDISCRETE8C259; C263; C264; C266; C302; C306; C307; C309
CC0603CAP NP_2_CC0603_DISCRETE_27PF27pFDISCRETE4C260; C261; C303; C304
CC0603CAP_NP_1_CC0603_DISCRETE_100NF100nFDISCRETE2C322; C448
CC0603CAP_NP_1_CC0603_DISCRETE_120PF120pF 10VDISCRETE1C333
CC0603CAP_NP_1_CC0603_DISCRETE_1UF1uFDISCRETE13C361; C487; C505; C506; C507; C508; C520; C545; C546; C547; C552; C553; C582
CC0603CAP NP_0_CC0603_DISCRETE_10PF10pFDISCRETE4C418; C419; C420; C421
CC0603CAP_NP_1_CC0603_DISCRETE_22PF22pFDISCRETE2C476; C477
CC0603CAP_NP_1_CC0603_DISCRETE_2.2UF2.2uFDISCRETE9C492; C493; C509; C510; C526; C527; C528; C531; C590
CC0603CAP_NP_1_CC0603_DISCRETE_1UF-NP1uF-NPDISCRETE1C548
CC0805CAP_NP_1_CC0805_DISCRETE_22UF_622uF_6V3DISCRETE89C44; C45; C49; C73; C74; C82; C83; C91; C110; C111; C120; C121; C122; C127; C132; C137; C153; C154; C157; C158; C167; C168; C171; C172; C216; C217; C241; C242; C244; C247; C248; C249; C250; C251; C252; C255; C257; C258; C262; C265; C278; C283; C286; C287; C291; C292; C298; C305; C308; C311; C312; C316; C325; C327; C329; C332; C334; C336; C340; C341; C342; C347; C349; C356; C393; C449; C450; C451; C466; C467; C484; C535; C536; C539; C540; C549; C550; C551; C568; C569; C571; C583; C584; C585; C586; C587; C588; C589; C591
CC0805CAP NP_0_CC0805_DISCRETE_22UF_622uF_6V3DISCRETE7C468; C470; C472; C541; C542; C543; C544
CC0805CAP_NP_1_CC0805_DISCRETE_22UF_122uF_6V3-NPDISCRETE6C495; C496; C512; C530; C533; C534
CC1210CAP NP_0_CC1210_DISCRETE_10UF_210uF_25VDISCRETE2C474; C480
CC1812CAP NP_1_CC1812_DISCRETE_1NF 1K1nF 1kVDISCRETE6C398; C403; C411; C414; C426; C430
CONN6CON6_CONN6_2.54MM 2X3 HEADER2.54mm 2x3 headerIC1J4
CONN8CON8_CONN8_IO_2.54MM 2X4 HEADER2.54mm 2x4 headerIO2J6; J7
CONN10HEADER 5X2_CONN10_2X5 HEADER DI2x5 Header DIP 2.54IC1P16
CONN14CON7X2_CONN14_IO_2.54MM 2X7 HEA2.54mm 2x7 headerIO1J12
CONN50HEADER 25X2/SM_CONN50_IO_2.54MM2.54mm 2x25 headerIO1J2
DB9ACONNECTOR DB9_3_DB9A_IO_DB9_FEMDB9_FemaleIO1P15
GBE_MAG24PG243002_0_GBE_MAG24_IC_PG24300PG243002IC6U36; U37; U38; U39; U40; U41
HC49_SMDCRYSTAL_3_HC49_SMD_IC_25MHZ-NP25MHz-NPIC2Y1; Y5
HC49_SMDCRYSTAL_3_HC49_SMD_IC_24MHZ_CRY24MHz_crystalIC2Y2; Y4
HC49_SMDCRYSTAL_3_HC49_SMD_IC_12MHZ12MHzIC1Y3
L2525INDUCTOR_L2525_DISCRETE_1UH IHL1uH IHLP-2525DISCRETE1L4
LED_0805LED0805_LED_0805_DISCRETE_G_LEDG_LED0805DISCRETE4D1; D7; D8; D9
LED_0805LED0805_LED_0805_DISCRETE_Y_LEDY_LED0805DISCRETE1D2
LED_0805LED_4_LED_0805_DISCRETE_R_LED08R_LED0805DISCRETE4D3; D4; D5; D6
LL0805INDUCTOR_0_LL0805_DISCRETE_BEADBEADDISCRETE17L1; L2; L3; L5; L6; L7; L8; L9; L10; L11; L12; L13; L14; L17; L18; L19; L21
LQFP48GLI8024-48_0_LQFP48_IC_GL850A-4GL850A-48IC1U26
M4T POINT F_3_M4_IO_MOUNTING HOLEMounting hole 1IO1MH1
M4T POINT F_3_M4_IO_MOUNTING HO_1Mounting hole 2IO1MH2
M4T POINT F_3_M4_IO_MOUNTING HO_2Mounting hole 3IO1MH3
M4T POINT F_3_M4_IO_MOUNTING HO_3Mounting hole 4IO1MH4
MINI_PCI_TYPE3MINIPCI_TYPE3_MINI_PCI_TYPE3_IOMINIPCI_TYPE3IO1P2
OSC_SMTOSC_0_OSC_SMT_IC_66MHZ_OSC66MHz_OSCIC1U19
OSC_SMTOSC_0_OSC_SMT_IC_25MHZ_OSC25MHz_OSCIC1U34
OSC_SMTOSC_0_OSC_SMT_IC_32.768KHZ_OSC-32.768KHz_OSC-NPIC1U44
OSC_SMTOSC_0_OSC_SMT_IC_125MHZ_OSC-NP125MHz_OSC-NPIC1U50
PCI_HT120PCI CONNECTOR_1_PCI_HT120_IO_PCPCIIO1P1
QFN32USB3300USB3300-EZKIC2U25; U31
R0402R_0_R0402_DISCRETE_51R51RDISCRETE50R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R14; R16; R17; R21; R22; R23; R26; R28; R29; R31; R33; R34; R37; R39; R42; R43; R44; R47; R48; R53; R54; R59; R62; R65; R66; R70; R72; R75; R77; R80; R81; R256; R257; R259; R260; R262; R263; R267; R269; R320
R0402R_0_R0402_DISCRETE_22R22RDISCRETE60R13; R15; R18; R19; R20; R24; R25; R27; R30; R32; R35; R36; R38; R40; R41; R45; R46; R51; R52; R57; R58; R61; R64; R67; R68; R69; R71; R73; R74; R76; R78; R79; R82; R83; R85; R88; R90; R93; R94; R95; R96; R97; R98; R99; R100; R101; R102; R103; R130; R141; R143; R185; R186; R187; R188; R212; R229; R230; R231; R321
R0402R_4_R0402_DISCRETE_4K7-NP4K7-NPDISCRETE7R49; R56; R60; R189; R190; R196; R284
R0402R_4_R0402_DISCRETE_4K74K7DISCRETE26R50; R55; R63; R105; R113; R114; R148; R153; R159; R177; R191; R194; R195; R197; R210; R211; R280; R281; R282; R283; R285; R286; R290; R293; R336; R342
R0402R_0_R0402_DISCRETE_51R-NP51R-NPDISCRETE6R84; R86; R87; R89; R91; R92
R0402R_4_R0402_DISCRETE_22R22RDISCRETE5R116; R133; R134; R164; R183
R0402R_0_R0402_DISCRETE_4K74K7DISCRETE22R126; R127; R128; R129; R131; R132; R202; R216; R217; R218; R219; R220; R224; R225; R226; R227; R228; R297; R298; R300; R318; R337
R0402R_0_R0402_DISCRETE_22R-NP22R-NPDISCRETE2R144; R207
R0402R_0_R0402_DISCRETE_1K1KDISCRETE1R149
R0402R_4_R0402_DISCRETE_10R10RDISCRETE6R192; R198; R199; R200; R203; R204
R0402R_0_R0402_DISCRETE_4K7-NP4K7-NPDISCRETE3R201; R340; R341
R0402R_0_R0402_DISCRETE_75R75RDISCRETE24R234; R237; R238; R239; R240; R241; R242; R243; R244; R249; R250; R251; R252; R253; R254; R255; R265; R273; R274; R275; R276; R277; R278; R279
R0402R_0_R0402_DISCRETE_150R150RDISCRETE4R258; R261; R264; R268
R0402R_0_R0402_DISCRETE_10K10kDISCRETE2R301; R302
R0402R_0_R0402_DISCRETE_0R0RDISCRETE1R339
R0603R_4_R0603_DISCRETE_4K74K7DISCRETE1R162
R0603AR_4_R0603A_DISCRETE_4K74K7DISCRETE5R104; R109; R115; R117; R119
R0603AR_4_R0603A_DISCRETE_220R220RDISCRETE3R107; R108; R296
R0603AR_4_R0603A_DISCRETE_4K7-NP4K7-NPDISCRETE3R111; R112; R118
R0603AR_4_R0603A_DISCRETE_0R0RDISCRETE1R121
R0603AR_4_R0603A_DISCRETE_0R-NP0R-NPDISCRETE3R122; R123; R124
R0603AR_4_R0603A_DISCRETE_330R330RDISCRETE11R125; R146; R158; R175; R289; R294; R299; R313; R314; R316; R331
R0603AR_0_R0603A_DISCRETE_0R0RDISCRETE5R135; R288; R308; R309; R343
R0603AR_0_R0603A_DISCRETE_330R330RDISCRETE20R136; R137; R138; R139; R140; R208; R214; R232; R233; R235; R236; R245; R246; R247; R248; R266; R270; R271; R272; R319
R0603AR_0_R0603A_DISCRETE_10M-NP10M-NPDISCRETE2R145; R215
R0603AR_4_R0603A_DISCRETE_100K100KDISCRETE3R147; R156; R176
R0603AR_4_R0603A_DISCRETE_4.7K4.7KDISCRETE2R154; R338
R0603AR_4_R0603A_DISCRETE_10K10KDISCRETE1R157
R0603AR_0_R0603A_DISCRETE_1M1MDISCRETE2R161; R182
R0603AR_4_R0603A_DISCRETE_15K15kDISCRETE8R165; R166; R167; R168; R169; R170; R171; R172
R0603AR_4_R0603A_DISCRETE_1M1MDISCRETE1R174
R0603AR_4_R0603A_DISCRETE_470470DISCRETE2R205; R206
R0603AR_0_R0603A_DISCRETE_4K74K7DISCRETE2R209; R213
R0603AR_4_R0603A_DISCRETE_1K1KDISCRETE1R287
R0603AR_4_R0603A_DISCRETE_330R-NP330R-NPDISCRETE1R295
R0603AR_0_R0603A_DISCRETE_0R-NP0R-NPDISCRETE3R306; R307; R322
R0603AR_0_R0603A_DISCRETE_1.5K1.5kDISCRETE1R311
R0603AR_0_R0603A_DISCRETE_10M10MDISCRETE1R315
R0603AR_4_R0603A_DISCRETE_1.5K1.5KDISCRETE1R317
R0603AR_4_R0603A_DISCRETE_10R10RDISCRETE4R323; R324; R327; R328
R0603AR_4_R0603A_DISCRETE_680R-NP680R-NPDISCRETE2R325; R329
R0603AR_4_R0603A_DISCRETE_2K-NP2K-NPDISCRETE2R326; R330
R0805R_4_R0805_DISCRETE_150R150RDISCRETE2R1; R2
R0805R_4_R0805_DISCRETE_47K47KDISCRETE1R106
R0805R_4_R0805_DISCRETE_11K 1%11K 1%DISCRETE1R110
R0805R_4_R0805_DISCRETE_20K 1%20K 1%DISCRETE1R120
R0805R_0_R0805_DISCRETE_1K 1%1K 1%DISCRETE1R142
R0805R_4_R0805_DISCRETE_10K 1%10K 1%DISCRETE3R150; R334; R335
R0805R_4_R0805_DISCRETE_20K20KDISCRETE2R160; R178
R0805R_4_R0805_DISCRETE_12K, 1%12K, 1%DISCRETE2R163; R184
R0805R_4_R0805_DISCRETE_681, 1%681, 1%DISCRETE1R173
R0805R_4_R0805_DISCRETE_2.26K 1%2.26k 1%DISCRETE1R193
R0805R_0_R0805_DISCRETE_2K 1%2K 1%DISCRETE2R221; R223
R0805R_0_R0805_DISCRETE_1K1kDISCRETE2R222; R304
R0805R_4_R0805_DISCRETE_1K1KDISCRETE2R291; R292
R0805R_4_R0805_DISCRETE_100100DISCRETE1R332
R0805R_4_R0805_DISCRETE_2020DISCRETE1R333
RJ45X2_LEDRJ45X2_NEW_LED_RJ45X2_LED_IO_RJRJ45X2_LEDIO3P12; P13; P14
RN0804RN0804_0_RN0804_DISCRETE_RN-22RRN-22RDISCRETE20RN1; RN2; RN6; RN8; RN11; RN12; RN13; RN17; RN19; RN21; RN23; RN25; RN27; RN33; RN35; RN36; RN56; RN57; RN62; RN63
RN0804RN0804_0_RN0804_DISCRETE_RN-51RRN-51RDISCRETE16RN7; RN9; RN10; RN14; RN15; RN16; RN18; RN20; RN22; RN24; RN26; RN28; RN29; RN30; RN31; RN34
RN0804RN0804_0_RN0804_DISCRETE_RN-4K7RN-4K7DISCRETE4RN37; RN46; RN64; RN65
RN0804RN0804_0_RN0804_DISCRETE_RN-330RN-330RDISCRETE1RN38
RN0804RN0804_0_RN0804_DISCRETE_RN-33RRN-33RDISCRETE7RN39; RN40; RN41; RN42; RN43; RN44; RN47
RN0804R-PACK_2_RN0804_DISCRETE_RN-4K7RN-4K7DISCRETE7RN45; RN48; RN49; RN50; RN51; RN52; RN53
RN0804RN0804_0_RN0804_DISCRETE_RN-4_1RN-4K7DISCRETE2RN54; RN55
RN0804RN0804_0_RN0804_DISCRETE_RN-10RRN-10RDISCRETE4RN58; RN59; RN60; RN61
RN0804RN0804_0_RN0804_DISCRETE_RN-4_2RN-4K7DISCRETE5RN66; RN67; RN68; RN76; RN78
RN0804RN0804_0_RN0804_DISCRETE_RN-0R_RN-0RDISCRETE7RN69; RN70; RN71; RN72; RN73; RN74; RN75
RN0804RRN0804_0_RN0804_DISCRETE_RN-51RRN-51RDISCRETE2RN3; RN5
RN0804RRN0804_0_RN0804_DISCRETE_RN-22RRN-22RDISCRETE2RN4; RN32
SIP14HEADER 14_SIP14_IO_2.54MM 1X142.54mm 1x14 headerIO1J11
SIP15HEADER 15_SIP15_IO_2.54MM 1X152.54mm 1x15 headerIO1J10
SIP_2PCON2_SIP_2P_IO_2.54MM 1X2 HEADE2.54mm 1x2 headerIO7J5; J9; J13; J15; J16; J17; J18
SIP_3PACON3_SIP_3PA_IO_2.54MM 1X3 HEAD2.54mm 1x3 headerIO5J1; J14; J19; J20; J21
SMD_CFC50PCOMPACT FLASH CONNECTOR_SMD_CFCCF_ConnectorIO1U55
SMD_JP2X8HEADER 8X2_SMD_JP2X8_SMD HEADERSMD HEADER 8X2IC1J22
SMD_JP2X8CON16AP_1_SMD_JP2X8_IO_HEADER_8HEADER_8X2IO1P17
SMD_SATA_VSATA CONNECTOR_SMD_SATA_V_IO_SASata Connector-internalIO4P3; P4; P6; P8
SMD_SWSW PUSHBUTTON_0_SMD_SW_IO_SW PUSW PUSHBUTTONIO2S3; S4
SMD_SWSW PUSHBUTTON_0_SMD_SW_IO_POWERPower SW PUSHBUTTONIO1S5
SMD_TPT_POINT_SMD_SMD_TP_IO_TPTPIO47TP1; TP2; TP3; TP4; TP5; TP6; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP51; TP52; TP53; TP54; TP55; TP56; TP57; TP58
SMD_TPT_POINT_SMD_SMD_TP_IO_MPH1_PCTLMPH1_PCTL0IO1TP7
SMD_TPT_POINT_SMD_SMD_TP_IO_MPH1_PC_1MPH1_PCTL1IO1TP8
SMD_TPT_POINT_SMD_SMD_TP_IO_MPH0_PC_1MPH0_PCTL1IO1TP9
SMD_TPT_POINT_SMD_SMD_TP_IO_MPH0_PCTLMPH0_PCTL0IO1TP10
SMD_TPT_POINT_SMD_SMD_TP_IO_QUIESCE#QUIESCE#IO1TP11
SMD_VR1RESISTOR VAR_SMD_VR1_DISCRETE_55kDISCRETE1VR1
SO8AT25080A_SO8_25LC640-NP25LC640-NPIC1U23
SO8FDS6898A_SO8_IC_FDS6898A-NPFDS6898A-NPIC1U29
SO8FDS6898A_SO8_IC_FDS6898AFDS6898AIC1U30
SO8M24256-BWMN6PM24256-BWMN6PIC1U64
SO8LP2994_SO8_IC_LP2994MLP2994MIC1U71
SOP8MIC2505-2BMMIC2505-2YMIC2U22; U28
SOT23MMBT4401LT1_SOT23_DISCRETE_MMBTMMBT4401LT1DISCRETE2Q2; Q3
SOT143AMAX811TEUS_SOT143A_IC_MAX811TEUMAX811TEUSIC1U46
SOT35374VHC1G04DF_SOT353_IC_74VHC1G0474VHC1G04DFIC7U11; U13; U27; U32; U56; U59; U68
SOT35374VHC1G125_SOT353_IC_74VHC1G12574VHC1G125DFIC4U12; U15; U17; U18
SOT35374VHC1G32_SOT353_IC_74VHC1G32DF74VHC1G32DFIC5U14; U16; U57; U58; U60
SOT35374VHC1G08_SOT353_IC_74VHC1G08DF74VHC1G08DFIC3U47; U48; U75
SOT35374VHC1G14DF_SOT353_74VHC1G14DF74VHC1G14DFIC1U77
SOT_223_4PN DGS_0_SOT_223_4P_DISCRETE_FDTFDT439N-NPDISCRETE1Q1
SOT_223_4PIRU1206_SOT_223_4P_IC_MIC39100-MIC39100-3.3WSIC1U61
SOT_223_4PIRU1206_0_SOT_223_4P_IC_NCP1117NCP1117ST50T3GIC1U72
SOT_223_4PIRU1206_SOT_223_4P_IC_MIC3910_1MIC39100-1.8WSIC1U73
SPAK5MIC49300BRMIC49300BR-NPIC1U69
SPAK5MIC49150BRMIC49300BR-NPIC1U70
SSOP16AMAX3232CUE_SSOP16A_IC_MAX3232ECMAX3232ECAEIC2U42; U43
SSOP20PCF8574_SSOP20_SSOP20_PCF8574_SPCF8574_SSOP20IC2U8; U10
TO263_5MIC29302BU_TO263_5_IC_MIC29502WMIC29502WUIC1U74
TSOP48MX29LV640BT_TSOP48_IC_MX29LV640MX29LV640MTCIC2U4; U7
TSSOP14MC74LCX74DTMC74LCX74DTIC1U21
TSSOP1474LVX08_TSSOP14_IC_MC74LVX08DTMC74LVX08DTIC1U45
TSSOP1474LVX08_TSSOP14_IC_MC74LVX08DT-MC74LVX08DT-NPIC2U51; U52
TSSOP1474HC125_TSSOP14_IC_MC74HC125ADTMC74HC125ADTIC1U66
TSSOP1474ACT74_0_TSSOP14_IC_MC74AC74DTMC74AC74DTIC1U67
TSSOP16MC9S08QG8_TSSOP16_IC_MC9S08QG8CMC9S08QG8CDTEIC1U63
TSSOP20A74LCX245_TSSOP20A_IC_MC74LCX245MC74LCX245DTIC2U6; U9
TSSOP20A74LCX374_TSSOP20A_IC_MC74LCX374MC74LCX374DT-NPIC1U49
TSSOP20A74LCX244DT_TSSOP20A_IC_74LCX24474LCX244DTIC1U65
TSSOP4874ALVCH16373DT_TSSOP48_IC_MC74LMC74LCX16373DTRIC2U3; U5
USB-MINI-ABUSB-MINI-AB_USB-MINI-AB_IO_USB-USB-mini-abIO1P11
USBX2USBX2_USBX2_USBX2USBX2IC2P19; P20
USOP8DS1339_USOP8_IC_DS1339U-33DS1339U-33IC1U62
USOP10MAX1953_USOP10_IC_MAX1953MAX1953IC1U24
WATCH_ABCRYSTAL_7_WATCH_AB_IC_32.768KHZ32.768kHz_crystalIC2Y6; Y7
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
9 s5 O* x8 H! T3 M% y& Z2 @( |
    2024-8-26 15:16
    发表于 2020-7-11 12:29 | 只看该作者
    多谢楼主无私分享
    8 G6 H" f# |- [  I( A6 n% h  ]
    发表于 2020-9-28 16:09 | 只看该作者
    这个太赞了,谢谢楼主分享。
    发表于 2020-9-30 13:06 | 只看该作者
    谢谢分享,太赞了
    发表于 2021-5-28 00:02 | 只看该作者
    学习 学习 谢谢分享
    " j. R! b6 f  y: ]+ q/ b+ T# f/ \& \
    发表于 2021-5-28 00:08 | 只看该作者
    威望值不够 下载不了
    7 H9 g  ~( T+ E: W. e3 l亲 能发我一份吗
    2 v& X' K5 P1 I1 O9 t5 H& S0 I谢谢
    ( ~4 j! S* d& ?% W! U- y/ F  Vpengfei_f@163.com
    2025-7-3 15:00
  • 签到天数: 742 天
    [LV.9]以坛为家II
    发表于 2021-7-5 10:55 | 只看该作者
    DDDDDDDDDDDDDDDDDDDDDDDDDDD
    6 n) _/ Q: R, p% F! Z9 {
    2020-5-27 15:44
    发表于 2021-11-25 15:56 | 只看该作者
    学习,谢谢分享联系; W5 g; O( J9 d8 ?2 ^. _2 O
    GMT+8, 2025-7-3 23:20 , Processed in 0.125000 second(s), 27 queries , Gzip On.
