查看: 319|回复: 0
[allegro16.6][2层]创龙TL-S6BOX-Spartan-6 底板(ADC7606+ISO3082DW+HD7279A-SP)...
发表于 2020-3-3 15:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][2层]创龙TL-S6BOX-Spartan-6 底板(ADC7606+ISO3082DW+HD7279A-SP)原理图和pcb文件
文件描述:
1. 作品用途:创龙TL-S6BOX-Spartan-6 底板
2. 软件版本:allegro16.6
3. 层数:2层
4. 用到的主要芯片:ADC7606+ISO3082DW+HD7279A-SP
5. PCB尺寸:7283*5314 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
C0603CAPACITOR NON-POL_C0603_100NF100nFIC25C1; C3; C5; C8; C11; C15; C16; C19; C20; C21; C22; C23; C36; C39; C40; C41; C42; C46; C47; C49; C50; C63; C64; C65; C66
C0603CAPACITOR NON-POL_C0603_4.7UF4.7uFIC1C6
C0603CAPACITOR NON-POL_C0603_22PF22pFIC2C12; C13
C0603CAP NP_C0603_100NF100nFIC14C24; C25; C26; C31; C32; C34; C52; C53; C57; C58; C59; C60; C61; C62
C0603CAP NP_C0603_1UF1uFIC2C27; C28
C0603CAP NP_C0603_15PF15pFIC1C38
C0603CAPACITOR NON-POL_C0603_18PF18pFIC1C72
C0805CAPACITOR NON-POL_C0805_10UF_2510uF_25VIC8C7; C9; C10; C14; C17; C18; C37; C48
C0805CAP NP_C0805_10UF_25V10uF_25VIC7C29; C30; C33; C35; C54; C55; C56
C1210CAPACITOR NON-POL_C1210_22UF_2522uF_25VIC6C2; C4; C67; C68; C69; C70
C1812CAPACITOR NON-POL_C1812_10NF_2K10nF_2KVIC2C51; C71
CON_1X4P_2D54_DHT11HEADER 4_CON_1X4P_2D54_DHT11_DHDHT11IC1J2
CON_2D00_2X7_TH_BOXHEADER 2X7 2.0MM_CON_2D00_2X7_TIDC3 2x7PIN 2.0mmIC1CON5
CON_2P_5MMLED_CON_2P_5MM_RED_LEDRED_LEDIC4LED3; LED6; LED9; LED12
CON_2P_5MMLED_CON_2P_5MM_YELLOW_LEDYELLOW_LEDIC4LED4; LED7; LED10; LED13
CON_2P_5MMLED_CON_2P_5MM_GREEN_LEDGREEN_LEDIC4LED5; LED8; LED11; LED14
CON_3P_3D81_90_MALECON3_CON_3P_3D81_90_MALE_CON_3PCON_3P_3D81_90_MALEIC1CON3
CON_B3F_4055SW TACT-SPST-2_CON_B3F_4055_B3FB3F-4055IC16SW2; SW3; SW4; SW5; SW6; SW7; SW8; SW9; SW10; SW11; SW12; SW13; SW14; SW15; SW16; SW17
CON_BTB_SOM-TLS6_60X4SOM-TLS6_CON_BTB_SOM-TLS6_60X4_SOM-TLS6IC1CON0
CON_DB9DB9_CON_DB9_DB9DB9IC1CON4
CON_DC005_NEWDC-005_CON_DC005_NEW_DC-005DC-005IC1CON2
CON_DG141R_1X2P_2D54CONN PLUG 4_CON_DG141R_1X2P_2D5DG141R_2P_2.54mm_V_DIPIC1J12
CON_DG141R_1X16P_2D54CONN FLEX 32_CON_DG141R_1X16P_2DG141R_16P_2.54mm_V_DIPIC1J4
CON_IDC3_2X25P_2D54_V_M_DIPCONN PCB 25X2-P_CON_IDC3_2X25P_IDC3_2x25P_2.54mm_V_M_DIPIC1J11
CON_NIXIE_12PIN5461_CON_NIXIE_12PIN_HS420561K-HS420561K-32IC1U9
CON_TH_2X8P_2D54_V_DIPCON16A_CON_TH_2X8P_2D54_V_DIP_TTH_2x8P_2.54mm_V_DIPIC1J3
CON_TH_2X10P_2D54_V_DIPCON20A_CON_TH_2X10P_2D54_V_DIP_TH_2x10PIN_2.54mm _V_DIPIC1J1
CON_TH_2X10P_2D54_V_DIPHEADER 10X2_CON_TH_2X10P_2D54_VTH_2x10P_2.54mm_V_DIPIC1J8
CON_TH_TJC3_1X2P_2D54_V_DIPCON2_CON_TH_TJC3_1X2P_2D54_V_DITH_TJC3_1x2P_2.54mm_V_DIPIC3J7; J9; J10
CON_TH_TJC3_1X5P_2D54_V_DIPCON5_CON_TH_TJC3_1X5P_2D54_V_DITH_TJC3_1x5P_2.54mm _V_DIPIC1J6
D0603LED_D0603_RED_LEDRED_LEDIC1LED1
D0603LED_D0603_GREEN_LEDGREEN_LEDIC1LED2
DIP4_B0505S_1WB_S-2W_0_DIP4_B0505S_1W_B0505S-B0505S-1WIC1U5
F1206FUSE_F1206_2A2AIC1F1
L0603FERRITE BEAD_L0603_220R_100MHZ220R_100MHz 2AIC3FB1; FB3; FB5
LPS3010-H30D30INDUCTOR_LPS3010-H30D30_LPS3010LPS3010-222MRCIC1L1
LQFP64ADC7606_LQFP64_AD7606BSTZAD7606BSTZIC1U7
MHOLE_C90D95HOLE_MHOLE_C90D95_HOLEHOLEIC1H6
MHOLE_C110D140HOLE_MHOLE_C110D140_HOLEHOLEIC2H1; H2
MHOLE_C150D90HOLE_MHOLE_C150D90_HOLEHOLEIC2H3; H4
MHOLE_C200D125HOLE_MHOLE_C200D125_HOLEHOLEIC4H7; H8; H9; H10
MHOLE_C380D390HOLE_MHOLE_C380D390_HOLEHOLEIC1H5
R0603R_R0603_4K74K7IC2R1; R3
R0603R_R0603_1K51K5IC2R2; R47
R0603R_R0603_73K2_1%73K2_1%IC1R4
R0603R_R0603_1K_1%1K_1%IC2R5; R74
R0603R_R0603_53K6_1%53K6_1%IC1R6
R0603RESISTOR_R0603_10K10KIC7R7; R10; R59; R63; R64; R65; R98
R0603R_R0603_536K_1%536K_1%IC1R8
R0603R_R0603_118K_1%118K_1%IC1R9
R0603RESISTOR_R0603_22R22RIC2R11; R82
R0603RESISTOR_R0603_1K_1%1K_1%IC2R12; R16
R0603RESISTOR_R0603_10R10RIC2R13; R15
R0603RESISTOR_R0603_120R120RIC1R14
R0603RESISTOR_R0603_DNP_1K_1%DNP_1K_1%IC1R17
R0603R_R0603_DNP_10KDNP_10KIC6R20; R21; R24; R90; R92; R94
R0603R_R0603_10K10KIC16R29; R30; R31; R32; R33; R48; R67; R69; R70; R71; R72; R75; R76; R91; R93; R95
R0603R_R0603_0R0RIC8R34; R35; R36; R37; R41; R68; R79; R96
R0603R_R0603_DNP_0RDNP_0RIC1R49
R0603R_R0603_560R560RIC12R50; R51; R52; R53; R54; R55; R56; R57; R58; R60; R61; R62
R0603RESISTOR_R0603_0R0RIC3R66; R78; R80
R0603RESISTOR_R0603_DNP_0RDNP_0RIC1R77
R0805RESISTOR_R0805_1M1MIC2R73; R97
RJ_3P_R0902NPOT_R_S_1_RJ_3P_R0902N_10K10KIC1VR1
RP4_0603RESARR_IS_4/SO_RP4_0603_200R200RIC2RN1; RN2
SC70-5-43M1A_SN74LVC1G04_SC70-5-43M_SN74LSN74LVC1G04DCKIC1U4
SC70-5-43M1A_SN74LVC1G07_SC70-5-43M_SN74LSN74LVC1G07DCKIC1U15
SMBDIODE-TRIG_SMB_P6SMB6.8CAP6SMB6.8CAIC1D1
SMBDIODE TVS BI-DIR_SMB_P6SMB6.8CAP6SMB6.8CAIC2D2; D3
SOD123WMA739/TO_SOD123W_PTVS5V0S1URPTVS5V0S1URIC1D4
SOIC8_D8TLC5615I_SOIC8_D8_TLC5615CDTLC5615CDIC1U18
SOIC14SN74LV164AD_SOIC14_SN74LV164ADSN74LV164ADIC2U10; U11
SOIC16ISO3082_SOIC16_ISO3082DWISO3082DWIC1U3
SOIC24-DWSN74LVC4245A_SOIC24-DW_SN74LVC4SN74LVC4245ADWIC1U13
SOP8L9110_SOP8_L9110L9110IC3U12; U14; U16
SOP28HD7279_SOP28_HD7279A-SPHD7279A-SPIC1U8
SOT23-3MOSFET P SOT_SOT23-3_BSS84BSS84IC1Q1
SOT23-3TL431A_0_SOT23-3_TL431AIDBZTTL431AIDBZTIC1U1
SOT23-5XRP6658_0_SOT23-5_TLV62565DBVTTLV62565DBVTIC1U17
SSOP8_DCTTXS0102DCUR_SSOP8_DCT_TXS0102DCTXS0102DCTTG4IC4U19; U20; U21; U22
SW-SPDT_POWERSWITCH_1_SW-SPDT_POWER_T103MH9AT103MH9ABEIC1SW1
TO252AA_094SUD45P03-15_TO252AA_094_DMP4051DMP4051LK3-13IC1Q2
TO-92UAA3144_TO-92UA_A3144EA3144EIC1Q3
TP-S4000_TP-S40_0_TP-S40_TEST POINTTest PointIC1TP1
TP_DIP00_TP-S40_0_TP_DIP_BLACK TEST PBlack Test PointIC1TP2
TSSOP16_PW16MAX232A_0_TSSOP16_PW16_SP3232EESP3232EEY-L/TRIC1U6
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
2 h; I/ O. o6 w# y. `, s1 v
GMT+8, 2025-7-29 14:47 , Processed in 0.156250 second(s), 28 queries , Gzip On.
