查看: 241|回复: 0
[allegro16.6][6层]采用MK64FN1M0VMD12芯片设计的NXP Rapid IoT Prototyping Kit(...
发表于 2020-3-3 14:35 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][6层]采用MK64FN1M0VMD12芯片设计的NXP Rapid IoT Prototyping Kit(MK64FN1M0VMD12+DF12+FXAS21002CQ)原理图和pcb文件
文件描述:
1. 作品用途:采用MK64FN1M0VMD12芯片设计的NXP Rapid IoT Prototyping Kit
2. 软件版本:allegro16.6
3. 层数:6层
4. 用到的主要芯片:MK64FN1M0VMD12+DF12+FXAS21002CQ
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
ANTENNA_2P_3P4X1P8ANTENNA_WE-MCA_ANTENNA_2P_3P4X1AMCA31-2R450G-S1F-TIC1E1
BUZZER_4X4MM_SMSPEAKER_BUZZER_4X4MM_SM_IC_2.5MCMT-4023S-SMTIC1LS1
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uFDISCRETE35C1; C2; C3; C4; C5; C6; C7; C11; C12; C13; C21; C24; C25; C26; C27; C29; C30; C32; C33; C34; C36; C37; C38; C40; C41; C42; C43; C44; C57; C58; C59; C60; C62; C63; C72
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_718PFDISCRETE2C8; C9
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.642.2uFDISCRETE2C10; C51
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M12PFDISCRETE2C14; C15
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.9PFDISCRETE1C16
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uFDISCRETE6C18; C20; C45; C48; C52; C56
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_31uFDISCRETE5C19; C35; C50; C53; C61
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_43pFDISCRETE4C22; C23; C76; C77
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.74M15PFDISCRETE1C28
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_14.7uFDISCRETE2C31; C65
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_5100PFDISCRETE1C47
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M10pFDISCRETE1C66
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4522uFDISCRETE1C46
CON2X10_0P5_SM_DF12DPCON2X10_SFP_CON2X10_0P5_SM_DF12DF12(4.0)-20DP-0.5V(86)IO1J7
CON2X10_0P5_SM_DF12DSCON2X10_SFP_CON2X10_0P5_SM_DF_1CON2X10_SKTIO1J8
CON2X25_0P5_SM_DF12DPCONN_2X25_SH_DF12_CON2X25_0P5_SDF12(4.0)-50DP-0.5V(86)IO1J4
CON2_1MM_5P6X4P3CONN_2X1_SH_CON2_1MM_5P6X4P3_IOCON_1x2IO1J11
CON4_FPC_0P5_SMCONN_FPC_4P_CON4_FPC_0P5_SM_IO_CON_1X4_FPCIO1J6
CON5_MICROUSB_SKT_SMMICRO_USB_CON5_MICROUSB_SKT_SM_47346-0001IO1J3
DFN8_1P27_6X5MM_3P1MT25QL256ABA1EW9_9P_DFN8_1P27_6MT25QL128ABA1EW7-0SITIC1U3
DFN1616-6RCLAMP1654P_NEW_DFN1616-6_IC_0.PUSBM5V5X4-TLIC1U23
DFN_8_0P5_2X3MC34671AEP_DFN_8_0P5_2X3_IC_0.6MC34671AEPIC1U17
DSN1006-2DIODE_SCHTKY_DSN1006-2_IC_0.3MMPMEG3010AESBYLIC3D3; D4; D5
FFC1X10_0P5_9P9X5P45CONN_10X1_SH_FFC1X10_0P5_9P9X5PCON_1X10_FPCIO1J5
IC8_2P1X2P6_SMTXCL220B1_IC8_2P1X2P6_SMT_IC_1.0XCL210A321GR-GIC1U14
IND_0402INDUCTOR_IND_0402_DISCRETE_0.554.7nHDISCRETE1L8
IND_0603IND_FERRITE_IND_0603_DISCRETE_0330 OHM@100MHZDISCRETE2L6; L7
IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1600 OHMDISCRETE2L4; L5
LED_1X0P6_SMLED_LED_1X0P6_SM_IC_0.4MM_370-7BLUEIC1D7
LGA8_1P25_3X5_0P5PPL3115A2_LGA_8P_LGA8_1P25_3X5_MPL3115A2IC1U12
LGA10_0P6_2P7X4CCS811B_LGA_11P_LGA10_0P6_2P7X4CCS811B-JOPD500IC1U11
MAPBGA144_1_13X13PK64FN1M0VMD12_BGA_144P_MAPBGA1MK64FN1M0VMD12IC1U1
MAPLGA48_7X7_0P5MMKW41Z512_64P_MAPLGA48_7X7_0P5MMMKW41Z512VHT4IC1U2
QFN4_0P95_2X2ENS210-LQFM_QFN4_0P95_2X2_IC_0.ENS210-LQFMIC1U8
QFN5X3_0P5_3X3FXOS8700CQ_QFN_16P_QFN5X3_0P5_3FXOS8700CQIC1U6
QFN8_1P6X1P6MMNT3H2211W0FHK_QFN8_1P6X1P6MM_ICNT3H2211W0FHKIC1U5
QFN16_0P5_3X3MMPCF2123BS_QFN16_QFN16_0P5_3X3MMPCF2123BS/1,518IC1U21
QFN24_0P5_4X4_ASYM_EXPFXAS21002CQ_QFN_24P_QFN24_0P5_4FXAS21002CQIC1U7
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_10KDISCRETE7R1; R2; R3; R26; R27; R28; R52
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110MDISCRETE9R4; R17; R18; R21; R23; R72; R73; R74; R75
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_14.7KDISCRETE4R7; R8; R49; R50
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100KDISCRETE14R9; R10; R12; R14; R16; R20; R22; R24; R31; R32; R33; R34; R54; R55
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_41.0MDISCRETE7R13; R15; R30; R42; R44; R45; R53
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__218KDISCRETE1R19
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_133KDISCRETE1R25
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_468DISCRETE1R36
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_282KDISCRETE1R38
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__333DISCRETE2R39; R40
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__4150KDISCRETE1R41
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_447DISCRETE1R43
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__51KDISCRETE5R46; R47; R65; R66; R67
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__6150DISCRETE1R64
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_40DISCRETE3R51; R68; R70
SC70_3MOSFET_P_SC70_3_IC_1.1MM_480-79SI1317DL-T1-GE3IC2Q1; Q2
SOT-23MOSFET_N_SOT-23_IC_1.2MM_480-79Si2302CDSIC1Q3
SOT-563_6P_0P5_SMTNX3008_SOT666_6PIN_SOT-563_6P_0DMG1016V-7IC1U19
SPRINGCLIP_2P4X1P3SPRING_SOCKET_SPRINGCLIP_2P4X1P105439-0005IO2J9; J10
SW4_4P2X2P8_SMSW4_PB_SPST_4P_SW4_4P2X2P8_SM_IKMR231NG LFSIC1SW5
SW_SIDE_PUSH_SKRT_SMSW_SPST_3P_PB_SW_SIDE_PUSH_SKRTSKRTLBE010IC4SW1; SW2; SW3; SW4
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030IO34TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP34; TP35; TP36
T_POINT0_7MM_R_1_2MMT POINT TH_T_POINT0_7MM_R_1_2MMTESTPOINTIC2TP32; TP33
USPN4_0P55_1P2X0P9XC8102AA017R-G_4P_USPN4_0P55_1PXC8102AA017R-GIC1U13
WLCSP4_0P4_0P8X0P8_SMDPADP172_CSP_4P_WLCSP4_0P4_0P8X0PNX3P191UKIC3U15; U16; U18
WLCSP4_0P4_0P97X1P06A1006UK_WLCSP4_WLCSP4_0P4_0P97XA1006UKIC1U25
XQFN10_0P5_1P65X2P1NX3L2267GM_QFN10_XQFN10_0P5_1P6NX3L2267GM,115IC2U4; U10
XTAL2-3P2X1P5-SMXTAL_XTAL2-3P2X1P5-SM_IC_0.9MM_32.768KHzIC1Y3
XTAL2_2P15X1P3_SMXTAL_XTAL2_2P15X1P3_SM_IC_0.6 M32.768 KHZIC1Y4
XTAL4_2P1X1P7MM_SMXTAL_13_XTAL4_2P1X1P7MM_SM_IC_032MHZIC1Y2
XTAL_4_3P3X2P6MMXTAL_13_XTAL_4_3P3X2P6MM_IC_1MM12MHzIC1Y1
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
3 Q" f1 y5 V9 K
GMT+8, 2025-7-29 14:44 , Processed in 0.156250 second(s), 28 queries , Gzip On.
