查看: 300|回复: 2
[allegro16.6][12层]采用 ADC12DJ3200的直接射频采样雷达接收器参考设计(ON+SMVT+...
发表于 2020-3-3 11:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][12层]采用 ADC12DJ3200的直接射频采样雷达接收器参考设计(ON+SMVT+HS)原理图和pcb文件
文件描述:
1. 作品用途:采用 ADC12DJ3200的直接射频采样雷达接收器参考设计
2. 软件版本:allegro16.6
3. 层数:12层
4. 用到的主要芯片:CON+SMVT+HS
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
201CAP_0402_0.1UF_H_0201_.1UF_10%.1uFIC35C5; C6; C7; C8; C9; C10; C11; C12; C13; C15; C16; C18; C19; C21; C22; C23; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C138; C144; C149
201CAPACITOR_NP_1_0201_.1UF_10%.1uFIC19C20; C24; C100; C101; C103; C104; C106; C107; C109; C113; C133; C135; C142; C143; C146; C151; C153; C249; C250
201CAP0402_0_0201_.1UF_10%_.1uFIC34C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C84; C85; C86; C87; C88; C89; C90; C91; C92; C96
201CAP_0603_100PF_H_0201_100PF100pFIC4C99; C105; C108; C110
201CAP NP_0_0201_560PF_10%_560pFIC1C119
201CAP NP_0_0201_.047UF_10%_.047uFIC1C120
201CAP NP_0_0201_6800PF_10%_6800pFIC2C121; C122
201CAP NP_0_0201_.1UF_10%_.1uFIC1C130
201CAP NP_0_0201_3900PF_10%_3900pFIC1C131
201CAP NP_0_0201_47PF_5%_47pFIC1C132
201CAP_0402_0.01UF_H_0201_.01UF_10.01uFIC2C134; C136
201CAP_0402_0.1UF_0201_.1UF_10%.1uFIC1C137
201CAP NP_0_0201_.1UF_10%__1.1uFIC2C145; C150
201CAPACITOR_NP_1_0201_12PF_2%12pFIC1C152
201CAP_0201_0.1UF_0201_.1UF.1uFIC10C169; C171; C176; C181; C182; C183; C186; C187; C188; C189
201CAP0402_0_0201_.01UF_10V_.01uFIC3C234; C245; C248
201RES_0201_ZERO_H_0201_00IC8R1; R4; R6; R9; R151; R162; R179; R180
201RES_0402_ZERO_H_DNI_0201_00IC12R22; R24; R54; R59; R60; R76; R77; R126; R127; R128; R129; R186
201RES_0402_49.9_0201_680_680IC2R50; R51
201RES_0402_49.9_0201_49.9_49.9IC3R52; R53; R68
201RES_0402_18_0201_1212IC1R55
201R_1_0201__150__150IC1R56
201RES_0402_249_0201_240240IC14R57; R58; R61; R62; R64; R65; R86; R87; R89; R90; R94; R95; R188; R189
201R_1_0201__39K__39kIC1R63
201R_1_0201__620__620IC1R66
201RES_0402_249_0201_120120IC4R74; R75; R78; R79
201RES_0603_100_0201_100100IC2R80; R81
201RESISTOR_0_0201__130_130IC1R82
201RES_0402_100_H_0201_100100IC2R83; R91
201RESISTOR_0_0201__82_1%82IC2R84; R92
201RESISTOR_0_0201__49.9_1%49.9IC2R85; R93
201RESISTOR_0_0201__130_1%130IC1R88
201RES_0201_100_0201_100100IC1R108
201RES_0201_51_1%_0201_5151IC1R187
402CAP_0402_4700PF_H_0402_.1UF.1uFIC5C3; C4; C14; C45; C47
402CAP_0603_100PF_0402_100PF100pFIC3C41; C44; C46
402CAP_0603_0.1UF_0402_.1UF.1uFIC1C42
402CAP_0402_4700PF_H_0402_4700PF4700pFIC6C48; C49; C50; C51; C52; C53
402CAP NP_1_0402_1UF_10%1uFIC10C66; C67; C81; C82; C93; C94; C201; C205; C220; C224
402CAP NP_0_0402_1UF_10%_1uFIC11C102; C111; C114; C117; C210; C213; C214; C227; C235; C240; C246
402CAP NP_0_0402_.68UF_10%_.68uFIC1C128
402CAP_0603_100PF_H_0402_100PF100pFIC1C139
402CAP_0402_2200PF_H_0402_2200PF2200pFIC1C140
402CAP_0402_10PF_H_0402_10PF10pFIC1C141
402CAPACITOR_NP_1_0402_1UF_10%1uFIC7C154; C157; C158; C159; C160; C165; C166
402CAPACITOR_NP_1_0402_.1UF_10%.1uFIC3C155; C161; C163
402CAPACITOR_NP_1_0402_0.01UF_10%0.01uFIC2C156; C162
402CAP NP_1_0402_1UF_1uFIC1C167
402CAP_0402_18PF_0402_18PF18pFIC2C184; C185
402CAP0603_0402_.1UF_10%_.1uFIC6C203; C226; C233; C237; C239; C244
402RES_0402_10K_0402_10K10kIC15R11; R12; R17; R18; R21; R23; R27; R28; R29; R114; R115; R123; R124; R125; R132
402RES_0402_1K_H_0402_1K1kIC4R13; R14; R15; R16
402RES_0402_1K_0402_1K1kIC3R19; R20; R25
402RES_0402_2.1K_0402_2.1K2.1kIC1R26
402RES_0402_8.06K_0402_8.06K8.06kIC1R30
402RES_0402_1M_0402_1M1MIC2R31; R184
402RES_0402_1.2K_0402_1.2K1.2kIC2R32; R185
402RES_0402_1.33K_0402_1.33K1.33kIC1R33
402RES_0402_ZERO_H_0402_00IC8R34; R35; R36; R38; R40; R42; R97; R98
402RES_0603_750_H_0402_750750IC1R37
402RES_0603_1.3K_H_0402_1.3K1.3kIC2R39; R41
402RES_0402_100_H_0402_100100IC2R43; R47
402RES_0402_49.9_0402_49.9_49.9IC4R44; R45; R48; R49
402RES_0402_18_0402_12K12kIC1R46
402R_0402_0_0IC9R67; R170; R171; R172; R173; R174; R175; R176; R177
402RES_0402_18_0402_1818IC1R70
402RES_0402_270_0402_292292IC2R71; R72
402RES_0603_100_0402_100100IC1R73
402RES_0402_2.32K_H_0402_2.32K2.32kIC1R96
402RES_0402_1.3K_0402_10K10kIC1R99
402RES_0402_4.99K_0402_4.99K4.99kIC1R104
402RES_0402_ZERO_0402_00IC2R105; R107
402RES_0402_270_0402_270270IC1R109
402RES_0603_100_H_0402_100100IC15R110; R112; R113; R118; R119; R120; R121; R133; R134; R135; R136; R137; R142; R147; R178
402RES_0603_1K_H_0402_1K1kIC8R138; R139; R140; R141; R143; R144; R145; R146
402RES_0402_1K_0402_1K_1%1KIC1R148
402RES_0402_ZERO_H_0402_36.5K36.5kIC1R149
402R_0402_1M_1%1MIC2R150; R164
402RES_0603_ZERO_H_0402_287K287kIC1R152
402R_0402_162K_1%162kIC1R153
402R_0402_0_5%0IC5R154; R155; R156; R157; R183
402RES_0603_ZERO_H_0402_124K124kIC1R160
402RES_0603_12.4K_0402_2.4K2.4kIC1R165
402R_0402_162K_162kIC1R166
402RES_0603_10K_0402_4.75K4.75kIC1R169
603CAP_0603_0.1UF_0603_0.1UF0.1uFIC9C1; C172; C177; C190; C191; C192; C193; C194; C195
603CAP_0603_1UF_0603_1UF1uFIC4C2; C173; C175; C180
603CAP NP_1_0603_10UF_10%10uFIC9C112; C115; C116; C118; C198; C208; C217; C225; C238
603CAP NP_2_0603_DISCRETE_10UF_10%10uFDISCRETE1C164
603CAP_0603_10UF_0603_10UF10uFIC3C168; C170; C179
603CAP0201_0_0603_10UF_20%_10uFIC4C200; C202; C219; C223
603CAP_0603_2.2UF_0603_2.2UF2.2uFIC1C212
603CAP_0603_.47UF_0603_.47UF.47uFIC1C216
603CAP_0603_1000PF_0603_1000PF1000pFIC1C221
603CAP0201_0_0603_10UF_10%_10uFIC4C230; C236; C243; C247
603RES_0603_ZERO_DNI_0603_00IC1R69
603RESISTOR_0_0603_DISCRETE_750_750DISCRETE4R100; R101; R102; R103
603RES_0201_100_0603_100100IC1R106
603RES_0603_ZERO_0603_00IC1R111
603RES_0603_10_0603_1010IC2R116; R117
603RES_0603_12K_0603_12K12kIC1R122
603RES_0603_1K_H_0603_1K1kIC1R130
603RES_0603_2.2K_0603_2.2K2.2kIC1R131
603RES_0603_1.87K_0603_2K2kIC1R161
603RES_0603_47K_0603_47K47kIC1R167
603RES_0603_4.99K_0603_4.99K4.99kIC1R168
805CAP0201_0_0805_33UF_20%_33uFIC5C204; C218; C222; C229; C242
805CAP NP_1_0805_10UF_10%10uFIC2C209; C215
805RES_0402_ZERO_H_DNI_0805_00IC3R158; R159; R163
1206CAP_1206_100UF_6.3V_1206_100UF100uFIC2C174; C178
1206CAP_1206_22UF_10%22uFIC2C206; C211
1206CAP NP_0_1206_47UF_20%47uFIC3C207; C228; C241
1206FUSE_0_1206_FUSE 10A 63V FASTFUSE 10A 63V FASTIC1F1
1206FERRITE_BEAD_0402_H_1206_120 OH120 OHM @ 100MHzIC4FB20; FB21; FB22; FB23
1206_BEAD_NFM31PBEAD_NFM31P_1206_BEAD_NFM31P_2727uFIC4FB16; FB17; FB18; FB19
BALUN_320X320_MARKI_0006SMGBALUN_MARKI_SMG_320X320_BALUN_3BALUN, HIGH POWER, SMTIC2BALUN1; BALUN2
BGA_144_10MMX10MM_0P80MMADC12DJXX00_BGA_144_10MMX10MM_0ADC12DJXX00IC1U1
CON_RAPC722_JACK_THVT_3CONN JACK PWR_CON_RAPC722_JACK_CONN, JACK, PWR, MINI, R/A, THIC1J37
CON_SMRT_USBMNE20_FUSB_MINI_AB_MNE20-5G5P10_CON_SMCON, USB, MINI, AB, SMTIC1J31
CON_SMVT_40X14_50_M_MTGCON_SMVT_40X14_50_M_CON_SMVT_40CON, SMVT, HS, FIELD ARRAY, FMC, MALEIC1J25
DBV5TPS2400_DBV5_TPS2400TPS2400IC1U13
DIODE_MBRB2515LDIODE_MBRB2515L_DIODE_MBRB2515LMBRB2515LIC1D13
DIODE_SM_1N4148WDIODE_1N4148W_DIODE_SM_1N4148W_1N4148WIC2D9; D12
HDR_THVT_1X2_100_MHEADER_1X2_100_HDR_THVT_1X2_100HDR, THVT, 2POS, .100, GOLDIC3J8; J9; J17
HDR_THVT_1X2_100_MJUMPER_1X2_100_HDR_THVT_1X2_100HDR, THVT, 2POS, .100, GOLDIC6J26; J27; J30; JP7; JP8; JP9
HDR_THVT_1X2_100_MHDR_2X1_100_HDR_THVT_1X2_100_M_HDR, THVT, 2POS, .100, GOLDIC1JP5
HDR_THVT_1X3_100_MJUMPER_1X3_100_HDR_THVT_1X3_100HDR, THVT, 3POS, .100, GOLDIC1JP6
HDR_THVT_1X4_100_MHEADER_1X4_100_HDR_THVT_1X4_100HDR, THVT, 4POS, .100, GOLDIC1J28
HDR_THVT_2X4_100_MHEADER_2X4_100_HDR_THVT_2X4_100HDR, THVT, 8POS, .100, GOLDIC1J7
IND_0603FERRITE_BEAD_0402_H_IND_0603_12120 OHM @ 100MHzIC11FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB11
IND_0603FERRITE_BEAD_0603_120_H_IND_060120 OHM @ 100MHzIC2FB12; FB13
IND_0603FERRITE_BEAD_0603_26_H_IND_060326 OHM @ 100MHzIC1FB14
IND_SM_XFL4015CHOKE_IND_SM_XFL4015_.47UH.47uHIC2L3; L4
LED_0603LED_ORANGE_0603_LED_0603_LED ORLED ORANGEIC2D10; D11
LED_0805LED_RED_0_LED_0805_LED REDLED REDIC1D1
LED_0805LED_LED_0805_LED GREENLED GREENIC5D2; D3; D4; D5; D6
LED_0805LED_GREEN_0_LED_0805_LED GREENLED GREENIC2D7; D8
MFG125_PLATEDMOUNTING_HOLE_MFG125_PLATED_STASTANDOFF, FEMALE, 4-40 X 1 3/16", ALIC2MT1; MT2
MSOP_8_118X118_0P65MMEEPROM_93LC46B_MSOP_8_118X118_093LC46B-IIC1U9
PROBE_POINT_30PADPROBE_POINT_0_PROBE_POINT_30PADPROBE POINTIC16TP5; TP6; TP7; TP10; TP11; TP14; TP17; TP19; TP20; TP22; TP23; TP24; TP27; TP31; TP32; TP33
QFN40_RTA_RTB_RHALMX2582_LM2592_QFN40_RTA_RTB_RHLMX2582IC1U3
QFN_7_2MMX2MMTPS62085/62086/62087_QFN_7_2MMXTPS62085IC2U14; U17
QFN_20_197X197_0P65_RGWTPS74401_QFN_20_197X197_0P65_RGTPS74401MRGWREPIC1U20
QFN_20_199X199_0P65MMTPS7A7300_QFN_20_199X199_0P65MMTPS7A7200IC1U16
QFN_20_199X199_0P65MMTPS7A4700_QFN_20_199X199_0P65MMTPS7A4700IC2U21; U22
QFN_64_0P50MM_RGC_FT2232HQFT4232HQ_QFN_64_0P50MM_RGC_FT22FT4232HQIC1U8
QFN_64_360X360_0P50MM_PWRPADLMK04828_QFN_64_360X360_0P50MM_LMK04828IC1U4
SMA_SMEL_373X312SMA_END_HIGH_FREQ_PSF-S01_0_SMASMA, JACK, 50 OHM, EDGE MNTIC5J2; J5; J14; J15; J18
SMA_THVT_312X312SMA-THVT_142-0701-201_REC_0_SMASMA_THVT_RECIC2J22; J38
SMA_THVT_SMT_250X250SMA_THVT_SMA_CENTER_PIN_SMA_THVSMA, THVT, SMT CENTER PINIC6J1; J3; J4; J6; J23; J24
SMD_JUMPER_L_0402SMD_JUMPER_1X3_SMD_JUMPER_L_040SOLDER JUMPER, 0402IC4SJP1; SJP2; SJP3; SJP4
SMP_B120SMP_PLUG_SMT_0_SMP_B120_SMP, PCSMP, PCB, SMTIC1J20
SOIC_8_197X157_50LMC6762_SOIC_8_197X157_50_LMC67LMC6762IC1U15
SON_Q5B_8CSD18532Q5B_SON_Q5B_8_CSD18532QCSD18532Q5IC1Q3
SOT_5_120X69_37TLV702_SOT_5_120X69_37_TLV70233TLV70233IC1U6
SOT_5_120X69_57SN74LVC1G125DBVR_SOT_5_120X69_5SN74LVC1G125DBVRIC1U7
SOT_23_MMBT3904NPN_MMBT3904_SOT_23_MMBT3904_NPNPN, MMBT3904IC1Q1
SO_8_207X207_5024LC65_SO_8_207X207_50_24LC6524LC65IC1U5
TANT_BCAP_TANT_B_10UF_10V_TANT_B_10UF10uFIC4C43; C68; C83; C95
TANT_BCAP POL-B_0_TANT_B_47UF_10%_47uFIC1C196
TFMR_5_150X150_50TFMR_5_TC1-1-13M+_TFMR_5_150X15TC1-1-13M+IC1T1
TFMR_5_150X150_50TFMR_5_TC1-1-43X+_TFMR_5_150X15TC1-1-43X+IC1T2
TP_THVT_100_RNDTESTPOINT_ORANGE_TP_THVT_100_RNORNIC5TP1; TP2; TP3; TP25; TP26
TP_THVT_100_RNDTESTPOINT_BLUE_TP_THVT_100_RND_ORNIC1TP4
TP_THVT_100_RNDTESTLOOP_RED_TP_THVT_100_RND_REREDIC1TP15
TP_THVT_100_RNDTESTPOINT_BLK_TP_THVT_100_RND_BBLKIC6TP16; TP18; TP21; TP28; TP29; TP30
TP_THVT_100_RNDTESTPOINT_GRN_TP_THVT_100_RND_GGRNIC1TP36
TP_THVT_125_RND_063DTESTLOOP_BLACK_TP_THVT_125_RND_REDIC1TP12
TP_THVT_125_RND_063DTESTLOOP_BLACK_TP_THVT_125_RN_1BLKIC1TP13
TSSOP_16_201X177_26SN74AVC4T774_TSSOP_16_201X177_2SN74AVC4T774IC3U10; U11; U12
VCXO_6_CUSTOMOSC_SM_6_TCO-2100-SERIES_2_VCXO100.00MHzIC1Y1
WSON_14_4MMX4MM_0P5LM95233_WSON_14_4MMX4MM_0P5_LM9LM95233IC1U2
XTAL_2_SM_126X197CRYSTAL_ABM3_0_XTAL_2_SM_126X1912MHz, 18pFIC1Y2
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
; o! }  G* Z" s
发表于 2021-10-11 14:57 | 只看该作者
发表于 2021-10-11 15:07 | 只看该作者
骗人的,板子全是乱的
“来自电巢APP”
GMT+8, 2025-7-3 15:44 , Processed in 0.093750 second(s), 28 queries , Gzip On.
