查看: 253|回复: 0
[PADS VX.2.4][2层]RS6002车载DVD主板(SC7312+BA7626F+CD4094+PCF8563+AT24C02+M...
发表于 2020-3-3 10:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名字:[pads  VX.2.4][2层]RS6002车载DVD主板(SC7312+BA7626F+CD4094+PCF8563+AT24C02+MP1410+BA3121)PCB文件/ |/ l5 _# l% y: M) V
$ U8 B3 T: \/ `9 c5 ~8 T5 n文件描述& @: z9 M8 x' \4 ~
7 U0 b" I/ P0 _" p  |1.功能描述:车载DVD主板
0 p# d+ _  R- | 5 ]3 h$ Q$ t6 N, z, c+ F$ v: k
2.软件版本:PADS  VX.2.4
0 E1 y/ h3 h/ [, w % A7 v/ @: w$ {* E- t$ V* s/ L, Y
3.层数:2层板
5 f  D/ D7 _' i: g& Y* ~2 R. ^/ [
4 b8 Q& N7 A0 t/ K
4.用到的主要芯片:SC7312
' {* f2 e$ n( j1 W7 }5.PCB板尺寸:异形
8 z: y) r- l9 Y3 J0 o1 V% K ) m. \0 V7 V5 K! G& H2 l" t# D6 J( J
作品截图如下:
& u" Q- A2 @( X* O; ]& d- m; z ' e2 \' A" y7 m1 l( K
顶层截图:
2 F$ c, q9 ]3 v2 y: ^& m2 P 2 \5 l# ~6 T% D6 u
底层截图:% O1 L: m/ r9 y- X9 p
" h3 f6 b# [( ?# V全层截图:
  h; I( N' |4 X1 }1 T! I . Q! y! V1 N8 g: D, Z  G; ]
叠层截图:
: u+ A2 ^$ c5 x5 N' D9 A
BOM:
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
AGNDJUMP-PAD2.0JUMP
AMP_GNDJUMP-PAD2.0JUMP
ANT1CON-3PIN-TUNER-A
ANT2ANT-RADIO
BT_GNDJUMP-PAD2.0JUMP
C1CAP-060310nF
C2CAP-0603NC\100nF
C3CAP-06031uF
C4CAP-06032n2
C5CAP-0603NC/10pF
C6CAP-06032n2
C7CAP-0603100nF
C8CAP-06031uF
C9CAP-06031uF
C10CAP-0805NC/2u2/16V
C11RES-06030R
C12CAP-0603100nF
C13RES-06030R
C14CAP-0603100nF
C15CAP-06035n6
C16CAP-06031uF
C17CAP-06031uF
C18CAP-080510uF
C19CAP-0603100nF
C20CAP-06031uF
C21CAP-0603100nF
C22CAP-06031uF
C23CAP-0603NC
C24CAP-080510uF
C25CAP-080510uF
C26CAP-06030.1uF
C27CAP-0603100nF
C28CAP-0603NC\100pF
C29CAP-06031uF
C30CAP-0603100n
C31CAP-06031uF
C32CAP-06031uF
C33CAP-060310n
C34CAP-08052u2
C35CAP-0603NC\100pF
C37CAP-06031uF
C38CAP-0603100pF
C39CAP-0603100pF
C40CAP-06031uF
C41CAP-08052u2
C42CAP-080510uF
C43CAP-080510uF
C44CAP-080510uF
C45CAP-06031uF
C46CAP-080510uF
C47CAP-060327nF
C48CAP-080510uF
C49CAP-080510uF
C51CAP-06035n6
C52CAP-080510uF
C53CAP-08052U2/10V
C57CAP-06031uF
C58CAP-060310nF
C59CAP-06031uF
C60CAP-060310nF
C61CAP-06031uF
C62CAP-080510uF/10V
C64CAP-0603120pF
C66CAP-06031uF
C68ECAP-SMD-6.5100u/16V
C74CAP-06032n2
C75CAP-0603100nF
C77CAP-0603470nF
C78CAP-0603470nF
C79CAP-060327nF
C82CAP-0603100nF
C86CAP-0603100nF
C88CAP-06035n6
C89CAP-0603150pF
C90CAP-060310nF
C91CAP-0603100nF
C92CAP-0603NC
C93CAP-06031uF
C95CAP-0603100n
C100CAP-06031uF
C108CAP-06030.1uF
C109CAP-080510uF
C111CAP-080510uF
C114CAP-080510uF
C124CAP-0603100n
C126CAP-0603100nF
C132CAP-0603100nF
C133CAP-0603100nF
C135CAP-0603100nF
C136CAP-060322pF
C137CAP-060322pF
C138CAP-0603100nF
C139CAP-0603100nF
C140CAP-06038n2
C141CAP-0603100nF
C142CAP-0603100nF
C143CAP-06038n2
C144CAP-06031uF
C152CAP-08052u2
C153CAP-06031nF
C154CAP-060368nF
C158CAP-06038n2
C159CAP-06038n2
C162CAP-0603100nF
C172CAP-0603100nF
C173CAP-0603100nF
C185CAP-0603100nF
C233CAP-0603100nF
C241CAP-0603100nF
C242CAP-0603100nF
C243CAP-06031uF
C244CAP-06031uF
C245CAP-06031uF
C246CAP-06031uF
C247CAP-0603120pF
C248CAP-0603120pF
C249CAP-0603120pF
C250CAP-0603120pF
C252CAP-06031uF
C288CAP-0603100nF
CN2CON-SMT-4PIN-1.25MMNC/SMT-4PIN-1.25MM
CN3CON-DIP-11PIN-2.0MM
CON1FPC-60PIN-0.5MMSMT-60PIN-0.5MM
CON2CON20-20-BY46A0
CON3CON-SMT-5PIN-1.25MMNC/CON-SMT-5PIN-1.25MM
CON4SOCKET-DSW-8-101DSMT-8PIN-1.25MM
CON5FPC-12PIN-1.0MMNC//SMT-12PIN-0.5MM
CON6RCA-24PINAV12PIN
CON7FPC-50PIN-0.5MM50PIN-0.5MM
CON8CON-DIP-4PIN-2.0MMNC/CON-DIP-4PIN-2.0MM
D1SOD-80+323-ARB551V
D2SOD-80+323-ARB551V
D3BAV99BAV99
D4SOD-80+323-ARB551V
D5SOD-80+323-AIN4148
D6SOD-80+323-AIN4148
D7SOD-80+323-ARB551V
D8SOD-80+323-ARB551V
D9SOD-106IN4001
D10SOD-106IN4001
D11SMC/DO-214ABSK34
D12SOD-80+323-AIN4148
D13DIP/DO-214ABAIN5404
D14SOD-80+323-AIN4148
D15SOD-106IN4001
D16SOD-80+323-AIN4148
D17SOD-80+323-AIN4148
D18SOD-80+323-AIN4148
D19SOD-106IN4001
D20BAV99BAV99
D21SOD-80+323-AIN4148
D22BAV99BAV99
D28SOD-80+323-AIN4148
D37SOD-80+323-AIN4148
D38SOD-80+323-AIN4148
DGNDJUMP-PAD2.0JUMP
F3FUSE-12060.2A
IC1FLEXWATT25TDA7388
IC2TO-25278M05
IC4TO-25278D09
J1CON-SMT-4PIN-1.25MMNC/SMT-4PIN-0.5MM
J2JUMP-PAD1.0JUMP
L2IND-SMD-CDH8B28/38/43/5815u
L3TC-28A35mH非晶呃流线圈
L5IND-SMT-CD4347uH
L6IND-SMT-CD7547u
L7IND-SMT-CD75100u
L8IND-SMT-CD54330u
L9IND-SMT-CD54330uH
L13IND-SMD-CDH8B28/38/43/5815u
L17IND-SMT-CD7547u
L22IND-SMT-CD75100u
MGNDJUMP-PAD1.0JUMP
NAVI_GNDJUMP-PAD2.0JUMP
P1TP-1.0
P3TP-1.0
P4TP-1.0
P36TP-1.0
PUMP_GNDJUMP-PAD2.0JUMP
Q1SOP8-5.5X1.27MMIRF7205
Q2SC-702SK3018
Q3SOT-232N3904
Q4SOT-232SC3265
Q5SOT-232N3904
Q6SOT-23IRLML6402
Q7SOT-232N3904
Q8SOT-232N3906S
Q10SOT-232N3904
Q11SOP8-5.5X1.27MMIRF7205
Q12SOT-232N3904
Q13SOT-232N3906
Q16SOT-232SC3265
Q19SOT-232SC3265
Q20SOT-232N3906
Q21SOT-232SC3265
Q22SOT-232N3906
Q23SOT-232SC3265
Q24SOT-23NC/2N3906
Q25SOT-232N3906
Q26SOT-23IRLML6402
Q28SOT-232N3904S
Q29SOT-23NC/2N3904S
Q30SOT-23MMBT3904
Q31SOT-232N3904
Q32SOT-232N3906
Q33SOT-232N3906
Q35SOT-23MMBT3904
Q40SOT-232N3904
Q52SOT-232N3904
Q55SOT-232N3904
Q58SOT-23NC/2N3904
Q60SOT-232N3904
Q61SOT-232N3904
Q1001SOT-232N3906
R1RES-12062R
R2RES-1206100K
R3RES-06031K
R4RES-06030R
R5RES-06031K
R6RES-0603100R
R7RES-0603NC
R8RES-060310K
R9RES-06030R
R10RES-060347K
R11RES-0603NC/300K
R12RES-060351K
R13RES0603100R
R14RES-060310K
R15RES-060310R
R16RES-060310K
R17RES-1206100K
R18RES-0603NC/0R
R19RES-060320K
R20RES-060320K
R21RES-060310K
R22RES-0603470K
R23RES-0603470K
R24RES-060351K
R25RES-060310K
R26RES-0603470K
R27RES-0603470K
R28RES-0603NC/20K
R29RES-1206NC/2R
R30RES-060320K
R31RES-060310K
R32RES-060310K
R33RES-0603100K
R34RES-0603100K
R35RES-06031M
R36RES-06034K7
R37RES-060320K
R38RES-06032K2
R39RES-060320K
R40RES-0603NC/300K
R41RES-0603NC/10K
R42RES-0603100R
R43RES-0603100R
R44RES-060320K
R45RES-06031k
R46RES-0603200R
R47RES-06034K7
R48RES-0603NC/0R
R49RES-06031k
R50RES-0603100R
R51RES-06033K3
R52RES-0603220K
R53RES-0603180K
R54RES-06034K7
R55RES-0603100R
R56RES-0603NC/20K
R57RES-060320K
R58RES-06030R
R59RES-1206NC/0R
R60RES-12062R
R62RES-060310K
R63RES-060339K
R64RES-0603100K
R65RES-0603NC
R66RES-06031K
R67RES-060310K
R68RES-0603100K
R70RES-06031R
R71RES-0603100K
R72RES-0603NC/75R
R73RES-12062R
R74RES-1206NC/2R
R75RES-0603NC
R76RES-060375R
R77RES-0603NC/75R
R78RES-0603680R
R79RES-0603NC/75R
R80RES-060310K
R82RES-0603200R
R84RES-060310K
R85RES-0603180K
R86RES-06031K
R87RES-060310K
R88RES-0603100R
R91RES-0603NC
R93RES-060320K
R94RES-060310K
R95RES-0603180K
R96RES-06033K3
R97RES-060310K
R98RES-0603100R
R99RES-06031K3
R100RES-0603100R
R101RES-060310K
R102RES-0603NC
R104RES-06033K3
R106RES-0603NC\100K
R107RES-0603100R
R108RES-06030R
R109RES-06030R
R110RES-0603180K
R111RES-0603NC/10K
R112RES-06031K
R114RES-0603100R
R115RES-060320K
R116RES-060351R
R117RES-0603NC
R118RES-060310K
R119RES-060310K
R121RES-060375R
R122RES-0603NC/47K
R123RES-0603NC/0R
R124RES-0603NC/0R
R125RES-0603NC/0R
R131RES-0603NC
R132RES-0603NC/0R
R133RES-0603100K
R134RES-0603220K
R135RES-060318K
R136RES-060320K
R137RES-06031K
R138RES-0603200R
R142RES-0603100R
R143RES-06033K3
R144RES-0603100R
R148RES-060347K
R150RES-0603100R
R151RES-060375R
R154RES-060375R
R155RES-060375R
R156RES-060375R
R157RES-060375R
R158RES-060375R
R161RES-0603100R
R162RES-0603100R
R163RES-060375R
R166RES-060375R
R167RES-0603200R
R169RES-06033K3
R170RES-0603100K
R171RES-060310K
R172RES-060320K
R173RES-060320K
R174RES-0603100R
R175RES-0603100R
R176RES-06034R3
R183RES-060310K
R187RES-0603NC
R188RES-06033K9
R191RES-0603100R
R192RES-0603NC
R198RES-06034K7
R199RES-060310K
R200RES-060310K
R212RES-0603100K
R213RES-0603100K
R217RES-060375R
R221RES-060375R
R223RES-0603100R
R230RES-06031K3
R231RES-060310K
R232RES-060310K
R233RES-060310K
R236RES-0603NC
R239RES-06032K2
R242RES-06030R
R243RES-0603NC
R245RES-060310K
R246RES-060310K
R247RES-0603100R
R248RES-0603100R
R252RES-0603100R
R261RES-060310K
R267RES-06033K9
R271RES-060310K
R272RES-060310K
0 i3 v9 U  }) ^2 `3 k& g7 G2 F# H, x3 [  P
6 G& U: Q- @3 F; w, q0 b7 R
' u* Q2 D% ?( \7 v' ~7 D' I
# V' J$ n0 c, A4 G! Z
$ ]) N- E+ b7 G* s1 V7 v
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
( ~, r5 U4 |( ~* @  P. M# f% U/ B  _3 p' Q/ l! g8 g9 ]0 S
GMT+8, 2025-7-29 14:52 , Processed in 0.125000 second(s), 28 queries , Gzip On.
