查看: 2894|回复: 39
[allegro16.6][12层]ZYNQ XC7Z030-1FBG676I板子(XC7Z030-1FBG676I+MT7603EN+MT766...
发表于 2020-3-2 16:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][12层]ZYNQ XC7Z030-1FBG676I板子(XC7Z030-1FBG676I+MT7603EN+MT7662E )原理图和pcb文件
文件描述:
1. 作品用途:ZYNQ XC7Z030-1FBG676I板子
2. 软件版本:allegro16.6
3. 层数:12层
4. 用到的主要芯片:XC7Z030-1FBG676I+MT7603EN+MT7662E
5. PCB尺寸:150*100 mm
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
805LED_0805_LEDLEDIC1D5
805RESISTOR_0805_RFBB 1.07KRFBB 1.07kIC1R240
805RESISTOR_0805_RFBT 5.62KRFBT 5.62kIC1R241
1210CAP NON-POL_1210_10UF10uFIC3C283; C284; C285
7343CAP POL_7343_250UF250uFIC1C282
7343CAP POL_7343_330UF330uFIC2C291; C292
B-43DK4B_B-4_3DK4B3DK4BIC2Q1; Q2
BATTERYSMALLBATTERY_BATTERYSMALL_BATTERYBATTERYIC1P1
BGA_96P_31_524X295_C14MT41K128M16JT_BGA_96P_31_524X29MT41K128M16JTIC2UM1; UM2
C0402CAP NON-POL_C0402_0.01U0.01uIC2C2; C80
C0402CAP NON-POL_C0402_0.1U0.1uIC11C3; C5; C6; C7; C8; C9; C10; C11; C12; C13; C81
C0402CAP NON-POL_C0402_10NF10nFIC6C14; C15; C16; C17; C88; C201
C0402CAP NON-POL_C0402_0.01UF0.01uFIC1C48
C0402CAP NON-POL_C0402_0.1UF0.1uFIC37C55; C56; C59; C60; C61; C63; C64; C65; C66; C67; C68; C69; C70; C71; C74; C75; C76; C83; C84; C87; C89; C217; C218; C225; C226; C227; C228; C230; C232; C233; C234; C235; C236; C237; C238; C239; C242
C0402CAP NON-POL_C0402_1NF1nFIC1C78
C0402CAP NON-POL_C0402_470NF470nFIC2C82; C132
C0402CAP NON-POL_C0402_47NF47nFIC1C137
C0402CAP NON-POL_C0402_3.3NF3.3nFIC4C213; C214; C223; C224
C0402CAP NP_C0402_0.47UF0.47ufIC1CF2
C0402RESISTOR_C0402_100K100kIC4R1; R6; R92; R93
C0402BGACAP NON-POL_C0402BGA_470NF470nFIC19C91; C95; C96; C97; C103; C110; C111; C112; C119; C145; C158; C165; C176; C182; C197; C204; C274; C275; C276
C0402BGACAP NON-POL_C0402BGA_47NF47nFIC54C104; C105; C106; C120; C121; C122; C123; C124; C133; C134; C135; C136; C146; C147; C148; C149; C150; C159; C160; C161; C162; C166; C167; C168; C177; C183; C184; C185; C186; C187; C191; C192; C198; C200; C205; C206; C249; C250; C251; C252; C253; C254; C258; C259; C260; C261; C262; C263; C267; C268; C269; C270; C271; C272
C0402BGACAP NON-POL_C0402BGA_10NF10nFIC30C107; C108; C125; C126; C127; C138; C139; C140; C151; C152; C153; C169; C170; C171; C172; C188; C189; C190; C193; C194; C207; C246; C247; C248; C255; C256; C257; C264; C265; C266
C0603CAP NON-POL_C0603_4.7UF4.7uFIC62C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C49; C54; C98; C99; C101; C102; C113; C114; C116; C117; C118; C129; C130; C131; C142; C143; C144; C155; C156; C157; C164; C174; C175; C179; C180; C181; C196; C203; C241; C244; C277; C278
C0603CAP NON-POL_C0603_18PF18pFIC4C72; C73; C243; C245
C0603CAP NON-POL_C0603_1UF1uFIC1C77
C0603CAP NON-POL_C0603_22UF22uFIC4C211; C216; C221; C222
C0603CAP NP_C0603_4.7UF4.7ufIC1CF1
C0805CAP NON-POL_C0805_10UF10uFIC11C50; C51; C52; C90; C212; C215; C219; C220; C229; C231; C240
C0805CAP NON-POL_C0805_22UF22uFIC3C57; C58; C62
C0805CAP POL_C0805_10UF10uFIC2C85; C86
C0805CAP NON-POL_C0805_0.47UF0.47uFIC1C286
C1206CAP NON-POL_C1206_100UF100uFIC19C53; C92; C93; C94; C100; C109; C115; C128; C141; C154; C163; C173; C178; C195; C199; C202; C273; C279; C280
C1206CAP NON-POL_C1206_0.047UF 50V0.047uF 50VIC1C281
C1206CAP NON-POL_C1206_0.047UF0.047uFIC2C287; C290
CDRH6D38NP_5RL680_CDRH6D38NP_5R_2.2UH 5000MA2.2uH 5000mAIC3L5; L6; L8
CDRH6D38NP_5RL680_CDRH6D38NP_5R_2.2UF 5000MA2.2uF 5000mAIC1L7
CRYSTALCRYSTAL_CRYSTAL_25MHZ25MHzIC1Y1
CRYSTALCRYSTAL_CRYSTAL_24MHZ24MhzIC1Y2
DB15_TCONNECTOR DB15_DB15_T_CONNECTORCONNECTOR DB15IC2P3; P4
DIP8_3HCPL-5631_DIP8_3_HCPL-5631HCPL-5631IC3P2; P5; P6
DIP8_3HPL-263L_DIP8_3_HPL-263LHPL-263LIC1P7
FBG676XC7Z030-1FBG676I_FBG676_(S1+S2+XC7Z030-1FBG676IIC1U7
GE_RJ45GE_RJ45_GE_RJ45_GE_RJ45GE_RJ45IC1J2
HEADER4X2CON8_HEADER4X2_CON8CON8IC2J6; J8
HEADER8X2CON16A_HEADER8X2_CON16ACON16AIC1J1
JTAG-XFPGA_JTAG_JTAG-X_FPGA_JTAGFPGA_JTAGIC1J3
JUMP3CONN SOCKET 3_JUMP3_CONN SOCKETCONN SOCKET 3IC1J9
KEY8X2CON16B_KEY8X2_CON16BCON16BIC4SW2; SW3; SW4; SW5
L0603INDUCTOR TORROID_L0603_120OHM@1120ohm@100MHzIC1FB1
L0603L680_L0603_120OHM@100MHZ120OHM@100MHzIC1L2
L0603INDUCTOR FERRITE_L0603_CIZHUCIZHUIC1L3
L0603INDUCTOR FERRITE_L0603_ FERRITEFERRITEIC1L9
LCC20DS96F175ME_LCC20_DS96F175MEDS96F175MEIC1U19
LCC20DS96F174ME_LCC20_DS96F174MEDS96F174MEIC1U20
LED10X2CON20A_LED10X2_CON20ACON20AIC2J4; J5
LVS303010L680_LVS303010_2.2UH2.2uHIC1L1
MLP8W25Q256FV_0_MLP8_W25Q256FVW25Q256FVIC1U21
OSC5X7OSC_OSC5X7_50MHZ50MHzIC1X1
OSC5X7OSC_OSC5X7_33.33MHZ33.33MHzIC1X2
POWER2ECON2_POWER2E_CON2CON2IC1J7
R0402RESISTOR_R0402_4040IC21R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R46; R48; R49; R52
R0402RESISTOR_R0402_240240IC2R50; R51
R0402RESISTOR_R0402_100K100kIC1R55
R0402RESISTOR_R0402_1M1MIC1R237
R0603RESISTOR_R0603_5.1K5.1kIC2R2; R7
R0603RESISTOR_R0603_3333DISCRETE12R3; R4; R5; R8; R60; R61; R62; R63; R64; R166; R167; R235
R0603RESISTOR_R0603_10K10kIC13R9; R13; R14; R15; R44; R45; R53; R54; R89; R104; R162; R210; R214
R0603RESISTOR_R0603_4.7K4.7kIC60R10; R11; R12; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R58; R59; R72; R73; R74; R75; R76; R77; R78; R79; R81; R82; R90; R91; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R160; R161
R0603RESISTOR_R0603_80.680.6IC3R47; R175; R176
R0603RESISTOR_R0603_750750IC2R56; R57
R0603RESISTOR_R0603_00IC15R65; R66; R69; R80; R204; R205; R213; R219; R223; R239; R243; R244; R245; R246; R247
R0603RESISTOR_R0603_330R330RIC26R67; R68; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129
R0603RESISTOR_R0603_1.5K1.5kIC2R70; R234
R0603RESISTOR_R0603_2.49K 1%2.49k 1%IC1R71
R0603R_R0603_5.1K5.1KIC8R83; R84; R85; R86; R87; R88; R96; R98
R0603RESISTOR_R0603_100100IC4R94; R100; R101; R102
R0603R_R0603_00IC1R95
R0603RS2_R0603_5.1K5.1KIC1R97
R0603R_R0603_NCNCIC1R99
R0603RESISTOR_R0603_5050IC1R103
R0603RESISTOR_R0603_33R33RIC1R105
R0603RESISTOR_R0603_NCNCIC10R163; R222; R225; R226; R228; R229; R230; R231; R232; R233
R0603RESISTOR_R0603_10K 1%10k 1%IC2R164; R165
R0603RESISTOR_R0603_20K20kIC7R168; R169; R170; R171; R172; R173; R174
R0603RESISTOR_R0603_51K51kIC1R178
R0603RESISTOR_R0603_100K100kIC4R179; R180; R186; R187
R0603RESISTOR_R0603_300K300kIC1R181
R0603RESISTOR_R0603_200K200kIC1R182
R0603RESISTOR_R0603_240K240kIC2R183; R189
R0603RESISTOR_R0603_130K130kIC1R184
R0603RESISTOR_R0603_750K750kIC1R185
R0603RESISTOR_R0603_150K150kIC1R188
R0603RESISTOR_R0603_120120IC4R190; R192; R194; R195
R0603RESISTOR_R0603_NULLNULLIC2R191; R193
R0603RESISTOR_R0603_510510IC6R196; R197; R200; R201; R206; R207
R0603RESISTOR_R0603_200200IC8R198; R199; R202; R203; R208; R209; R220; R221
R0603RESISTOR_R0603_270270IC3R211; R215; R242
R0603RESISTOR_R0603_2.2K2.2kIC2R212; R218
R0603RESISTOR_R0603_430430IC2R216; R217
R0603RESISTOR_R0603_470470IC1R227
R0603RESISTOR_R0603_1K1kIC1R236
R0603RESISTOR_R0603_8K068k06IC1R238
RET_CCAP POL_RET_C_10U10uIC2C1; C79
RET_CCAP POL_RET_C_4.7U4.7uIC1C4
RET_D1N5408_RET_D_1N54011N5401IC1D3
RET_D1N5408_RET_D_1N54081N5408IC1D4
RTL8211_QFN48RTL8211E_RTL8211_QFN48_8169SB8169SBIC1U5
SBSW_SB_SWSWIC3SW1; SW6; SW7
SO16WDS3231_SO16W_DS3231DS3231IC1U4
SOIC8CA3140_SOIC8_CA3140CA3140IC2U2; U8
SOIC_8MAX3490_SOIC_8_MAX3490MAX3490IC2U17; U18
SOT-23-5SPX3819M5-3-3_SOT-23-5_SPX3819MSPX3819M5-1-8IC1U15
SOT-23-5SPX3819M5-3-3_SOT-23-5_SPX381_1SPX3819M5-3-0IC1U16
SSOP28MAX1270AEAI_SSOP28_MAX1270AEAIMAX1270AEAIIC1U1
TCM811TERCTRTCM811TERCTR_TCM811TERCTR_TCM81TCM811TERCTRIC1U9
TLV62130RGTTLV62130RGT_TLV62130RGT_TLV6213TLV62130RGTIC4U11; U12; U13; U14
TPS51200DRCRTPS51200DRCR_TPS51200DRCR_TPS51TPS51200DRCRIC1U3
TSSOP8TXS0102DCU_TSSOP8_TXS0102DCUTXS0102DCUIC1U23
TSSOP16MAX3232_TSSOP16_MAX3232max3232IC1U22
TZA11ALMZ13608_TZA11A_LMZ13608LMZ13608IC1U25
USB3320CUSB3320C-EZK_6_USB3320C_USB3320USB3320C-EZK_6IC1U24
USBPORTUSBCON_USBPORT_USBCONUSBCONIC1XS1
VBGA100MT29F32G08AECBBH1_VBGA100_MT29FMT29F32G08AECBBH1IC1U6
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
6 I3 K2 m( o1 M9 [- \* Y8 _$ }8 l
    2025-8-11 15:01
  • 签到天数: 566 天
    [LV.9]以坛为家II
    推荐
    发表于 2021-4-15 15:04 | 只看该作者
    不是16.6版本。楼主。要用17版本才能打开。能不能上传16.6版本的文件。
    头像被屏蔽
    推荐
    发表于 2021-4-29 17:27 | 只看该作者
    提示: 作者被禁止或删除 内容自动屏蔽
    推荐
    发表于 2023-2-10 21:09 | 只看该作者
    111111111111111111111111111111111111111
    发表于 2020-3-13 12:04 | 只看该作者
    无聊
    2021-4-13 15:30
  • 签到天数: 67 天
    [LV.6]常住居民II
    发表于 2021-4-6 08:17 | 只看该作者
    谢谢分享,好东西。
    发表于 2021-4-6 16:17 | 只看该作者
    11111111111111
    7 s, K/ [% q  A7 }! I$ [  K
    发表于 2021-4-10 15:09 | 只看该作者
    12层,牛,多谢
    8 C& Z# E4 z  N; ]% `
    2025-8-11 15:01
  • 签到天数: 566 天
    [LV.9]以坛为家II
    发表于 2021-4-15 14:47 | 只看该作者
    下载学习。看看。
    擦汗
    2020-1-14 15:59
    发表于 2021-4-26 15:20 | 只看该作者
    是否跟7020兼容
    郁闷
    2019-11-19 15:05
    14#
    发表于 2021-4-27 13:41 | 只看该作者
    太烂,不是16.6的吗?怎么变成17了
    15#
    发表于 2021-4-28 00:20 | 只看该作者
    很好,下载来看看( V! h  _0 f  B. F4 d/ B- q1 {
    16#
    发表于 2021-9-15 12:11 | 只看该作者
    非常迫切的需要,非常感谢作者!# J1 x( N* @6 n$ \' B1 u
    GMT+8, 2025-8-12 04:56 , Processed in 0.156250 second(s), 29 queries , Gzip On.
