作品名字:[pads VX.2.4][2层]MP3长条形山景6210(含解码、功放、电源板块)TDA1308+TDA7388+M358+PCB文件分享下载0 i$ v( _5 [* \
5 E0 P6 b a! r1 v: Y; V文件描述
& _# _; E2 \& O0 m: z8 X 3 X1 y* U( [; z0 I( e3 a! b. H1 E1 a
1.功能描述:MP3
# D8 j5 I4 L/ `9 n! N 1 K2 ]' J& T2 R/ T
2.软件版本:PADS VX.2.49 h0 P- W8 M# |( h4 h
( A) D8 o' O! R5 O. c3 y" i' ^
3.层数:2层板$ a( S W% U! h* Z
( e8 Y+ @* H+ U0 v; Q
4.用到的主要芯片:TDA1308+TDA7388 # q, L, \. K/ B! p/ B
5.PCB板尺寸:异形$ ?# I5 H4 L% n% I1 l" W1 S3 ^
; @) g# ]2 K( q. r8 y* |4 q
作品截图如下: 0 E$ q/ f$ v* e0 @1 Q' |
; u) m3 D: n2 Q$ |顶层截图:8 V. R9 ]" ]% A! [! p
+ t4 m7 k3 v$ O& q- O底层截图:( @/ k2 @. Q" }4 N: A5 ~1 m: P, F6 s
|4 u# I5 L) g6 T4 b% _全层截图:
& N2 I+ C% d9 N5 c. p& M
0 V$ ~- K* z: Q& h/ c叠层截图:; n( d* a- l& R) I- k! B0 P
BOM:
5 d1 l; \1 y# r1 X& bREFDES | COMP_DEVICE_TYPE | COMP_VALUE | 位号 | 类型 | 属性 | 1 | MICRO_USB_DIP | USB-ML | 1C1 | C-0603 | 104 | 1C2 | C0603 | 225 | 1C3 | PD4 | AUDIO OUT | 1C4 | C0603 | 225 | 1C5 | C0603 | 225 | 1LED2 | LED3 | | 1R1 | R-0603 | 1K | 1R2 | R-0603 | 1K | 1R3 | R-0603 | 1K | 1R4 | R-0603 | 1K | 1R5 | R-0603 | 1K | 1R6 | R-0603 | 1K | 1R7 | R-0603 | 1K | 1U1 | DIP8\SOA | 24C02 | 1U2 | SOT-23-6 | KX4002 | 3LED1 | LED_12PIN | | ANT-1 | A-1X2MMAA | ANT | ANT-2 | A-1X2MMAA | ANT | AU6210K | LQFP48-0.5MM | AU6210K | C1 | CE10 | 1000uF/10V | C1A | C-0603 | 104 | C2 | C-0603 | 104 | C3 | C-0603 | 104 | C4 | C-0805 | 104 | C5 | C-0603 | 105 | C6 | C-0603 | 105 | C7 | C-0603 | 225 | C8 | C-0603 | 105 | C9 | C-0805 | 106 | C10 | C-0805 | 106 | C11 | C-0603 | 104 | C12 | C-0603 | 104 | C13 | C-0603 | 102 | C14 | CE06 | 470uF/16V | C15 | C-0603 | 1uF | C16 | C-0603 | 105 | C17 | C-0603 | 102PF | C18 | C-0603 | 1uF | C19 | C-0603 | 104 | C20 | C-0603 | 104 | C21 | C-0603 | 331 | C22 | C-0603 | 104 | C23 | C-0603 | 104 | C24 | C-0805 | 10uF | C25 | C-0805 | 10uF | C26 | C-0603 | 104 | C27 | C-0603 | 100P | C28 | C-0805 | 10uF | C29 | C-0603 | 25PF | C30 | C-0603 | 25PF | C31 | C-0603 | 100P | C32 | C0603 | 7P | C34 | C-0603 | 104 | C38 | C-0603 | 105 | C39 | C-0603 | 105 | C40 | C-0603 | 104 | C41 | C-0603 | 225 | C42 | C-0603 | 225 | C43 | C-0805 | 106 | C44 | C0607 | 475 | C45 | C-0603 | 105 | C46 | C-0805 | 106 | C47 | C-0603 | 104 | C48 | C-0805 | 106 | C49 | C-0805 | 155 | C51 | C-0603 | 104 | C52 | C-0805 | 106 | C53 | C-0603 | 102 | C54 | C-0603 | 102 | C56 | C-0603 | 100P | C57 | C-0603 | 100P | C58 | C-0603 | 104 | C59 | C0603 | 225 | C60 | C0607 | 475 | C61 | C0607 | 475 | C62 | C-0603 | 105 | C63 | C0607 | 475 | C64 | C-0603 | 105 | C65 | CE08 | 1000uF/16V | C66 | C0603 | 7P | C67 | C-0603 | 104 | C68 | C0603 | 105 | C69 | C-0603 | 104 | C71 | C-0805 | 226 | C72 | C-0603 | 104 | C74 | C-0603 | 104 | C75 | C-0805 | 106 | C76 | CE05 | 100uF/10V | C77 | C-0603 | 331 | C78 | C-0603 | 332 | C79 | C-0603 | 104 | C80 | C-0603 | 104 | C81 | C-0805 | 106 | C82 | C-0805 | 106 | C83 | C-0603 | 47P | C84 | C-0603 | 47P | C85 | CE06 | 470uF/16V | C86 | CE05 | 1UF/25V | C87 | C-0603 | 104 | C88 | C-0805 | 106 | C89 | C05 | 104K | C90 | CE05 | 47UF/25V | C91 | CE05 | 0.47UF/25V | C92 | C-0603 | 47P | C93 | C-0603 | 47P | C94 | C0603 | 225 | C95 | C-0603 | 104 | C96 | C-0603 | 104 | C97 | C-0805 | 475 | C98 | R-0603 | 102 | C99 | C-0603 | 105 | C100 | C-0603 | 102 | C101 | C-0603 | 332 | C102 | C-0603 | 561 | C103 | C-0805 | 226 | C104 | C-0603 | 105 | C105 | CE20 | 3300uF/25V | C106 | C-0603 | 105 | C107 | C-0603 | 225 | C110 | C-0805 | 475 | C115 | CE20 | 3300uF/25V | C117 | CE20 | 3300uF/25V | C124 | C-0603 | 105 | C125 | C-0805 | 106 | C126 | C-0805 | 106 | C127 | C-0603 | 104 | C128 | C-0603 | 105 | C129 | CE05 | 100uF/16V | C130 | CE05 | 100uF/16V | C141 | CE20 | 3300uF/25V | C143 | C05 | 104 | C144 | C-0603 | 104 | C146 | C05 | 104 | C153 | CE06 | 470uF/16V | C201 | C-0805 | 10uF | C202 | C-0603 | 1uF | D1 | DIO_4.5 | 1N5819 | D2 | DIO_4.5 | 1N5819 | D3 | DIO_4.5 | 1N4001 | D4 | DD5.0-8A | RS1006 | EC1 | CE05 | 10uF/16V | EC2 | CE05 | 1uF/25V | FM_ANT | A-1X2MMAB | | J1 | PD2-4.0 | AC10 IN | J2 | USB-4LD | | J3 | PD2-4.0 | VOUT | J4 | PHONEJACK-5-2S | LINE IN | J5 | PD3-2.0 | KEY | J6 | TF_CARD | | J7 | SD/MMC | | J8 | PD2 | | J9 | PHONEJACK/S2/ST3.5-SW2 | HEADPHONE | J10 | PD2-4.0 | VIN | J11 | PD2-2.0 | BATT IN | J12 | PD2-4.0 | VIN | J13 | PD3-2.0 | AC9V IN | J14 | PD2-4.0 | VIN | J15 | PD4 | AUDIO IN | J16 | FFC0.5-18-SMT | | J17 | FFC0.5-18-SMT | | J18 | PHONEJACK-5-2S | MIC IN | J19 | CON2P2.0MM | BAT | J20 | PD2-4.0 | VOUT | J28 | USB2-8P | | J30 | PD2-4.0 | VIN | J31 | PD2-4.0 | VIN | J32 | PD2-4.0 | VIN | J33 | PD2-4.0 | VOUT | K1 | KEY_L6X6X7 | | L-SPK2 | CON2P2.0MM | 2.0X2P | L-SPK3 | CON2P2.0MM | 2.0X2P | L1 | L0805 | 47uH | L2 | R-0805 | 10UH | L3 | R-0603 | 330nH | L4 | R-0603 | 600R | LED1 | LED3 | | LED2 | LED3 | | LED3 | LED3 | | LED4 | LED3 | | LED5 | LED3 | | LED6 | LED3 | | LED7 | LED3 | | M1 | MIC-6MMAAA | MIC | MIC_IN | PHONE-CK3-6.5 | | MIC_IN1 | PHONE-CK3-6.5 | | Q2 | SOT-23 | S8550 | Q4 | SOT-23 | S8550D | Q5 | SOT-23 | 9014C | Q6 | SOT-23 | 9014C | R1 | R-0603 | 0R/NC | R2 | R-0603 | 10K | R3 | R-0603 | 1K | R4 | R-0603 | 1K | R5 | R-0603 | 91K | R6 | R-0603 | 0R | R7 | R-0603 | 10K | R8 | R-0603 | 10K | R9 | R-0603 | 15K | R10 | R-0603 | 100K | R11 | R-0603 | 100K | R12 | R0603A | 5.6K | R13 | R-0603 | 10K | R14 | R-0603 | 10K | R15 | R-0603 | 10K | R16 | R-0603 | 10K | R17 | R-0603 | 10K | R18 | R-0603 | 22K | R19 | R-0603 | 22R | R20 | R-0603 | 2K2 | R21 | R-0603 | 4.7K | R22 | R-0603 | 51K | R23 | R-0603 | 16K | R24 | R-0603 | 12M | R25 | R-0603 | 10K | R26 | R-0603 | 10K | R27 | R-0603 | 10R | R28 | R-0603 | 10K | R29 | R-0603 | 10K | R30 | R-0603 | 10K | R31 | R-0603 | 27K | R32 | R-0603 | 100K | R33 | R-0603 | 1k | R34 | R-0603 | 1k | R35 | R-0603 | 10K | R36 | R-0603 | 22K | R37 | R-0603 | 9.1K | R38 | R-0603 | 22K | R39 | R-0603 | 22K | R40 | R-0603 | 22K | R41 | R-0603 | 100K | R42 | R-0603 | 10R | R43 | R-0603 | 2.2R | R44 | R-0603 | 2.2R | R45 | R-0603 | 2K2 | R46 | R-0603 | 100K | R47 | R-0603 | 10R | R48 | R-0603 | 10K | R49 | R-0603 | 10K | R50 | R-0603 | 3K3 | R51 | R-0603 | 10K | R53 | R-0603 | 10K | R54 | R-0603 | 10K | R55 | R-0603 | 10K | R56 | R-0603 | 68K | R57 | R-0603 | 2K2 | R58 | R-0603 | 3K3 | R59 | R-0603 | 10K | R60 | R-0603 | 10K | R61 | R-0603 | 10K | R62 | R-0603 | 12K | R63 | R-0603 | 100K | R64 | R-0603 | 100K | R65 | R0603 | 68K | R66 | R-0603 | 2K2 | R67 | R-0603 | 2K2 | R68 | R0603 | 5.6K | R69 | R-0603 | 2K2 | R70 | R0603 | 68K | R71 | R-0603 | 10K | R72 | R-0603 | 1K | R73 | R-0603 | 4K7 | R74 | R-0603 | 5.1K | R75 | R-0603 | 10K | R76 | R-0603 | 10K | R77 | R-0603 | 10K | R78 | R-0603 | 10K | R79 | R-0603 | 10K | R80 | R-0603 | 2.2R | R81 | R-0603 | 4K7 | R82 | R-0603 | 10K | R84 | R-0603 | 4.7K | R85 | R-0603 | 10K | R86 | R-0603 | 10K | R87 | R-0603 | 22K | R88 | R-0603 | 22K | R89 | R-0603 | 10M | R90 | R0603 | 330K | R91 | R-0603 | 1K | R93 | R-0603 | 10K | R100 | R-0603 | 4K7 | R101 | R-0603 | 10K | R102 | R-0603 | 4K7 | R103 | R-0603 | 3.9K | R104 | R-0603 | 3.9K | R105 | R-0603 | 10K | R106 | R-0603 | 10K | R107 | R-0603 | 27K/NC | R108 | R-0603 | 3.9K | R109 | R-0603 | 27K/NC | R110 | R-0603 | 3.9K | R113 | R-0603 | 68K | R114 | R-0603 | 68K | R115 | R-0603 | 100K | R116 | R-0603 | 10R | R120 | R-0603 | 75K | R121 | R-0603 | 51K | R123 | R-0603 | 0R/NC | R136 | R-0603 | 43K | R137 | R-0603 | 51K | R138 | 1206 | 0R/NC | R142 | R-0603 | 10K | R143 | R-0603 | 0R/NC | R144 | R-0603 | 0R | R145 | R-0603 | 0R | R201 | R-0603 | 10K | R202 | R-0603 | 10K | SW1 | KEY5.2X5.2-SMT | | SW2 | KEY5.2X5.2-SMT | | SW3 | KEY5.2X5.2-SMT | | SW4 | KEY5.2X5.2-SMT | | SW5 | KEY5.2X5.2-SMT | | SW10 | KEY5.2X5.2-SMT | | U1 | SOP-8P-1.27MMB | AP1509/5V | U2 | TDA7388AA | TDA7388 | U3 | TO-220T1015 | LM7812 | U4 | SO16 | PT2399 | U5 | SOP-8P-1.27MMB | M358 | U6 | SOT-23 | LDO3.3V | U7 | SOP-8P-1.27MMB | LM358 | U8 | IR2.5 | | U9 | SOP-8P-1.27MMB | LM358 | U11 | SOT-89 | 78L12 | U12 | SOP-8P-1.27MMB | LM358 | U13 | SOP8_NORMAL | TDA1308 | U14 | SOT-89 | 78L05 | U15 | BC08-A | BC08-A-8645 | U16 | SOP-16P-1.27MMB | LM4863 | USB | USB-4LP | | USB1 | PD8_2.0 | | USB3 | P2 | | W1 | RV0921-SWAA | 50K | W2 | RV0921 | 50K | W3 | RV0921 | 50K | Y1 | Y3X8MM | 32.768KHz | Z1 | D-SOD-123 | 7.5V | + q2 t# \" O( j& }- i+ R
3 E- @# @7 K" N0 w* x0 x附件:
* b, ?9 [7 A! O6 G& i |
