1. 作品用途:
2. 软件版本:allegro16.3
3. 层数:16层
5. PCB尺寸:异形
Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
5MMX3_2MM | ECS-3525_5MMX3_2MM | 32.000MHZ | IC | 1 | U28 |
5X3_2MM | 12MHZ_5X3_2MM | 12_000MHZ | IC | 1 | X1 |
6VLX240TFF1156 | 6VLX240TFF1156 | 6VLX240TFF1156 | IC | 1 | U1 |
20-VQFN | UCD7230RGWR_20-VQFN | UCD7230RGWR | IC | 2 | U35; U36 |
32K10K-400 | SMA_32K10K-400 | 32K10K-400E3 | IC | 10 | J26; J27; J28; J29; J30; J31; J55; J56; J57; J58 |
402 | 0_1UF_0402 | 0.1UF | DISCRETE | 141 | C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C364; C365; C370; C371; C372; C373; C378; C379; C380; C381; C382; C383; C390; C391; C392; C393; C394; C395; C396; C397; C398; C399; C420; C422; C423; C424; C425; C426; C427 |
402 | 0_01UF_0402 | 0.01UF | IC | 30 | C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C172; C175; C178; C179; C180; C181; C182; C374; C375; C384; C385; C386; C387; C388; C389 |
402 | 1UF_0402 | 1UF | IC | 13 | C183; C184; C185; C186; C187; C188; C189; C190; C191; C192; C195; C198; C199 |
402 | 0_22UF_0402 | 0.22UF | IC | 25 | C202; C203; C204; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C224; C225; C226 |
402 | 0_068UF_0402 | 0.068UF | IC | 5 | C250; C251; C253; C254; C411 |
402 | 1000PF_0402 | 1000PF | IC | 1 | C256 |
402 | 4700PF_0402 | DNP | IC | 1 | C314 |
402 | 820PF_0402 | 820PF | IC | 7 | C315; C316; C318; C319; C327; C328; C409 |
402 | 6800PF_0402 | 6800PF | IC | 3 | C321; C322; C410 |
402 | 11PF_0402 | 11PF | IC | 2 | C330; C331 |
402 | 22PF_0402 | 22PF | IC | 12 | C332; C333; C334; C335; C336; C337; C338; C339; C340; C341; C342; C343 |
402 | 33PF_0402 | 33PF | IC | 5 | C344; C345; C346; C347; C348 |
402 | 270PF_0402 | 270PF | IC | 2 | C349; C350 |
402 | 33_2K_0402 | 33.2K | IC | 1 | R2 |
402 | 27_4_0402 | 27.4 | IC | 18 | R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R19; R20; R21 |
402 | 4_7K_0402 | 4.7K | IC | 76 | R22; R23; R24; R25; R26; R27; R28; R29; R30; R33; R34; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R53; R54; R55; R56; R58; R59; R60; R61; R66; R67; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R97; R98; R342; R343; R344; R345; R401; R402; R403; R404; R405; R406 |
402 | 510_0402 | 510 | IC | 7 | R51; R52; R57; R62; R63; R64; R65 |
402 | NS_0402 | DNP | IC | 21 | R68; R122; R127; R128; R129; R130; R131; R132; R134; R135; R136; R137; R138; R139; R162; R163; R305; R347; R410; R411; R412 |
402 | 36_5K_0402 | 36.5K | IC | 1 | R99 |
402 | 47_5_0402 | 47.5 | IC | 15 | R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114 |
402 | 4_22K_0402 | 4.22K | IC | 4 | R117; R119; R390; R397 |
402 | 0_0402 | 0 | IC | 9 | R133; R304; R312; R413; R414; R415; R416; R417; R418 |
402 | 10_0402 | 10 | IC | 1 | R140 |
402 | 20_5K_0402 | 20.5K | IC | 1 | R141 |
402 | 1_80K_0402 | 1.80K | IC | 1 | R142 |
402 | 1_60K_0402 | 1.60K | IC | 1 | R144 |
402 | 15_0402 | 15 | IC | 4 | R148; R149; R150; R151 |
402 | 2_43K_0402 | 2.43K | IC | 6 | R152; R153; R154; R155; R156; R157 |
402 | 6_81K_0402 | 6.81K | IC | 2 | R158; R159 |
402 | 2_15K_0402 | 2.15K | IC | 1 | R160 |
402 | 4_75K_0402 | 4.75K | IC | 18 | R161; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R358; R359; R360; R361; R362; R363; R364 |
402 | 49_9_0402 | 49.9 | IC | 14 | R164; R165; R166; R167; R168; R169; R348; R349; R350; R351; R354; R355; R356; R357 |
402 | 51K_0402 | 51K | IC | 2 | R172; R173 |
402 | 27_4K_0402 | 27.4K | IC | 3 | R174; R271; R272 |
402 | 10_0_0402 | 10 | IC | 4 | R175; R176; R179; R180 |
402 | 33_0_0402 | 33 | IC | 2 | R197; R198 |
402 | 1K_0402 | 1K | IC | 1 | R201 |
402 | 49_9K_0402 | 49.9K | IC | 2 | R203; R204 |
402 | 75_0_0402 | 75 | IC | 3 | R205; R206; R207 |
402 | 100_0402 | 100 | DISCRETE | 28 | R213; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R233; R235; R236; R237; R238; R239; R240; R408; R409 |
402 | 33_0402 | 33 | IC | 1 | R214 |
402 | 200_0402 | 200 | IC | 2 | R241; R378 |
402 | 2_0K_0402 | 2.0K | IC | 8 | R242; R243; R244; R299; R300; R301; R379; R380 |
402 | 10_0K_0402 | 10.0K | IC | 30 | R245; R246; R247; R248; R249; R250; R251; R252; R254; R255; R256; R257; R258; R259; R260; R262; R263; R264; R265; R266; R267; R268; R269; R367; R368; R369; R381; R382; R383; R407 |
402 | 10K_0402 | 10K | IC | 18 | R273; R275; R276; R277; R278; R279; R280; R281; R282; R283; R284; R285; R286; R287; R288; R289; R290; R291 |
402 | 140_0402 | 140 | IC | 3 | R292; R293; R294 |
402 | 20K_0402 | 20K | IC | 4 | R295; R296; R297; R298 |
402 | 100K_0402 | 100K | IC | 1 | R302 |
402 | 100K_0402 | 100K | IC | 1 | R303 |
402 | 1_00K_0402 | 1.00K | IC | 20 | R306; R311; R317; R318; R322; R323; R324; R325; R330; R331; R370; R371; R372; R373; R374; R375; R376; R396; R399; R400 |
402 | 2_21K_0402 | 2.21K | IC | 2 | R320; R328 |
402 | 1_3K_0402 | 1.3K | IC | 1 | R329 |
402 | 360_0402 | 360 | IC | 1 | R332 |
402 | 270_0402 | 270 | IC | 1 | R333 |
402 | 470_0402 | 470 | IC | 1 | R334 |
402 | 1_0M_0402 | 1.0M | IC | 1 | R335 |
402 | 4_99K_0402 | 4.99K | IC | 1 | R336 |
402 | 215_0402 | 215 | IC | 2 | R337; R338 |
402 | 1_21K_0402 | 1.21K | IC | 3 | R339; R340; R341 |
402 | 100_0402 | 100 | DISCRETE | 1 | R366 |
402 | 150_0402 | 150 | IC | 6 | R384; R385; R386; R387; R388; R389 |
402 | 787_0402 | 787 | IC | 1 | R392 |
402 | 330_0402 | 330 | IC | 1 | R419 |
603 | 100PF_0603 | 100PF | IC | 2 | C140; C141 |
603 | 1UF_0603 | 1UF | IC | 1 | C143 |
603 | 0_1UF_0603 | 0.1UF | IC | 12 | C173; C176; C304; C305; C306; C307; C308; C309; C310; C311; C312; C421 |
603 | 4_7UF_0603 | 4.7UF | IC | 9 | C200; C351; C352; C353; C354; C355; C356; C357; C358 |
603 | 0_22UF_0603 | 0.22UF | IC | 4 | C257; C258; C259; C260 |
603 | 1000PF_0603 | 1000PF | IC | 5 | C267; C268; C269; C270; C271 |
603 | 2700PF_0603 | 2700PF | IC | 2 | C325; C326 |
603 | 1800PF_0603 | 1800PF | IC | 1 | C329 |
603 | 0_47UF_0603 | 0.47UF | IC | 1 | C362 |
603 | FERRITE-220_0603 | FERRITE-220 | IC | 21 | F4; F5; F6; F7; F8; F9; F10; F12; F13; F14; F15; F18; F1009; F1029; F1030; F1032; F1033; F1111; F1112; F1113; F1114 |
603 | 1_0_0603 | 1 | IC | 4 | R193; R194; R195; R196 |
603 | 2_2_0603 | 2.2 | IC | 2 | R199; R200 |
603 | 24K_0603 | 24K | IC | 1 | R377 |
0603-A4 | 47X4_0603X4 | 47 | IC | 2 | RP2; RP3 |
0603_SHORT | 0603_SHORT | | IC | 11 | Z1; Z2; Z3; Z4; Z5; Z6; Z7; Z8; Z9; Z10; Z11 |
612 | 1UF_0612 | 1UF | IC | 1 | C313 |
805 | 2_2UF_0805 | 2.2UF | IC | 21 | C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139 |
805 | 10UF_0805 | 10UF | IC | 17 | C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C376; C377 |
805 | 10UF_0805 | 10UF | IC | 5 | C243; C244; C245; C246; C247 |
805 | 22UF_0805 | 22UF | IC | 6 | C261; C262; C263; C264; C265; C266 |
805 | NS_0805 | DNP | IC | 1 | C320 |
805 | HZ0805E601R-10_0805 | HZ0805E601R-10 | IC | 2 | F2; F3 |
805 | 82NH_0805 | 82NH | IC | 6 | L1; L2; L3; L4; L5; L6 |
805 | 10_0805 | 10 | IC | 1 | R202 |
0805-A4 | 0_1UF_0805 | 0.1UF | IC | 15 | CP1; CP2; CP3; CP4; CP5; CP6; CP7; CP8; CP9; CP10; CP11; CP12; CP13; CP14; CP17 |
0805_A4 | 0_01UF_0805 | 0.01UF | IC | 2 | CP15; CP16 |
1206 | 4_7UF_1206 | 4.7UF | IC | 2 | C248; C249 |
1206 | 10UF_1206 | 10UF | IC | 1 | C363 |
1206 | 1UF_1206 | 1UF | IC | 4 | C414; C415; C416; C417 |
1206 | 1M_1206 | 1M | IC | 1 | R1 |
1210 | 10UF_1210 | 10UF | IC | 2 | C117; C118 |
1210 | 22UF_1210 | 22UF | IC | 11 | C144; C145; C147; C148; C149; C150; C151; C152; C153; C154; C400 |
2512_SMT | RES_CUR_SENSE_2512_SMT | 0.005R | IC | 2 | R395; R398 |
3352W | 2K_POT-3352W | 0-2K | IC | 1 | R270 |
3637_SMT | RES_CUR_SENSE_3637_SMT | 0.005R | IC | 2 | R208; R365 |
3637_SMT | RES_CUR_SENSE_3637_SMT | 0.001R | IC | 1 | R346 |
1108800 | SK_DIP8_4 | 110880 | IC | 1 | X5 |
1367073-1 | SFP-1367073-1 | SFP_CONN_CASE | IC | 1 | P4 |
ABLS | XTAL-SMD_ABLS | 25.000MHZ | DISCRETE | 1 | X3 |
ASP_134486_01 | ASP_134486_01 | ASP_134486_01 | IC | 1 | J64 |
ASP_134603_01 | ASP_134603_01 | ASP_134603_01 | IC | 1 | J63 |
CAPAE430 | 1UF_ELECT_B | 1UF | IC | 2 | C412; C413 |
CAP_F | 330UF_5_3MMX5_3MM | 330UF | IC | 6 | C277; C278; C280; C281; C282; C405 |
CONN_USB_B | USB_MINI_B | | IC | 3 | J20; J21; J22 |
CON_MOL_5569_6P | 39-30-1060_JACK_500X540 | 39-30-1060 | IC | 1 | J60 |
CON_TYCO_350211 | 350211-1_ATX_JACK_1000X375 | 350211-1 | IC | 1 | J25 |
DCU_R-PDSO-G8 | SN74LVC2G08DCU_DCU_R-PDSO-G8 | SN74LVC2G08DCU | IC | 3 | U12; U13; U86 |
DDR3_SO-DIMM | DDR3_SO-DIMM | | IC | 1 | J1 |
DPAK5 | TL1963_DPAK5 | TL1963AKTTR | IC | 1 | U8 |
DPAK_369_51 | MJD200_TO-252 | MJD200 | IC | 1 | Q1 |
EGP_R-PDSS-T12 | PTD08A020W_EGP_R-PDSS-T12 | PTD08A020W | IC | 2 | U42; U43 |
EGS_R-PDSS-T12 | PTD08A010W_EGS_R-PDSS-T12 | PTD08A010W | IC | 3 | U20; U21; U91 |
EXBE-1608 | RP4_7K_EXBE-1608 | 4.7K | IC | 4 | RP4; RP5; RP7; RP8 |
FANHDR3 | FANHDR3 | | IC | 2 | J33; J59 |
FBGA64 | XCF128X_FBGA64 | XCF128X-FTG64C | IC | 1 | U27 |
FMC_15 | FMC_15 | DNP | IC | 4 | J43; J44; J47; J48 |
HC-49 | 2200072 | 24MHZ | IC | 1 | Y1 |
HDR-1X1 | CON1 | H-1X1 | IC | 5 | J15; J16; J51; J52; J53 |
HDR-1X2 | HRD_1X2 | H-1X2 | IC | 7 | J37; J38; J39; J40; J65; J68; J69 |
HDR-1X3 | HRD_1X3 | H-1X3 | IC | 6 | J17; J18; J19; J54; J66; J67 |
HDR-1X4 | HRD_1X4 | DNP | IC | 2 | J6; J7 |
HDR-1X5 | HRD_1X5 | DNP | IC | 1 | J36 |
HDR-2X3 | HDR_2X3 | H-2X3 | IC | 1 | J42 |
HDR_1X2 | HDR_1X2 | | IC | 7 | J8; J9; J10; J11; J12; J13; J14 |
HDR_2X6 | H-2X6_HDR-6X2 | H-2X6 | IC | 1 | J35 |
HDR_2X7 | HEADER_7X2_LCD | SSW-107-01-T-D | IC | 1 | J41 |
HDR_BOX_2X5 | HDR-2X5-SHR_HDR-2X5-SHR | HDR_BOX_2X5 | IC | 1 | J3 |
IND300X300 | 2_2UH_IND_CT_DR74-2R2 | 2.2UH | IC | 2 | L7; L8 |
KUSBX-SLAS1N-B | USB_A_KUSBX-SLAS1N-B | USB_A_VERT_TH | IC | 1 | J5 |
KVIX-DA29S-N-W | DVI_KVIX-DA29S-N-W | DVI_CONN | IC | 1 | P3 |
LED-0603 | LED-GRN-SMT_LED_0603 | LED-GRN-SMT | IC | 15 | DS1; DS9; DS10; DS11; DS12; DS13; DS14; DS15; DS16; DS17; DS18; DS19; DS20; DS21; DS22 |
LED-0603 | LED-GRN-SMT_LED_0603 | LED-GRN-SMT | IC | 2 | DS2; DS32 |
LED-0603 | LED-RED-SMT_LED_0603 | LED-RED-SMT | IC | 2 | DS30; DS31 |
LED-1206 | LED-GRN-SMT_LED_1206 | LED-GRN-SMT | IC | 4 | DS25; DS27; DS28; DS29 |
LED_GRN_SMALL_DUAL_STACK | LED_GRN_SMALL_DUAL_STACK | LED_GRN_SMALL_DUAL_STACK | IC | 3 | DS33; DS34; DS35 |
MH_125_250 | HOLE_MH_125_250 | MH_125_250 | IC | 5 | MH1; MH2; MH3; MH4; MH6 |
MINIMELF | 1N4148_MINIMELF | 1N4148 | IC | 1 | D16 |
ML621S_F9DE | ML621S_F9DE | BATTERY_ML621S | IC | 1 | B1 |
MSOP-8 | INA333_MSOP-8 | INA333 | IC | 4 | U74; U76; U93; U94 |
N7E50-7516PG-20 | N7E50-7516PG-20_CF-50PIN | N7E50-7516PG-20 | IC | 1 | U73 |
OSC_EG2121CA_6P | EG2121CA | 200MHZ | IC | 1 | U11 |
OSC_SI500D_6P | SI500D | DNP | IC | 1 | U89 |
PCIE_8LANE_EDGE | PCIE_8LANE_EDGE | PCI_E-FINGER-8X | IC | 1 | P1 |
PFC_S-PQFP-G80 | UCD9240PFC_QFP50P14X14-80 | UCD9240PFC | IC | 2 | U24; U25 |
PQFP50P1720X2320-128R | M88E1111_PQFP128R | M88E1111 | IC | 1 | U80 |
QFN50P500X500_28 | CP2103GM_MLP-28 | CP2103GM | IC | 1 | U34 |
QFP50P1200X1200-64 | CH7301C_LQFP64 | CH7301C-TF | IC | 1 | U38 |
RJ45_HFJ11-1G01E | RJ45_HFJ11-1G01E | RJ45 | IC | 1 | P2 |
SC70-6 | INA213 | | IC | 1 | U85 |
SDMX-4-X | SWDIP_SW-12_SDMX-4-X | SDMX-4-X | IC | 1 | S1 |
SDMX-6-X | SWDIP_SW-12_SDMX-6-X | SDMX-6-X | IC | 1 | S2 |
SDMX-8-X | SWDIP_SW-16_SDMX-8-X | SDMX-8-X | IC | 1 | SW1 |
SIPTML_8008 | H-1X8_SIPTML_8008 | H-1X8 | IC | 1 | J62 |
SIT8102_5X7 | SIT8102 | 47MHZ | IC | 1 | X4 |
SMA_3P_MOLEX_73251185 | CON_SMA_SCREW_ON | DNP | IC | 2 | J45; J46 |
SO-8 | DUAL-FET-8PIN | VAL | IC | 2 | Q3; Q4 |
SO-8 | 1310333 | | IC | 1 | U39 |
SOD123 | MBR0520LT1G_SOD123 | MBR0520LT1G | IC | 4 | D10; D11; D12; D13 |
SOD-123 | BZX84C4V7_SOT23 | BZT52C5V1-TP | IC | 2 | D14; D15 |
SON-10 | TPS51100_SON-10 | TPS51200DRCT | IC | 1 | U17 |
SOP127P500X600-8 | MIC2025-2B_SOP8 | MIC2025 | IC | 1 | U16 |
SOT23-3 | REF3012AIDBZT_SOT23-3 | REF3012AIDBZT | IC | 1 | U23 |
SOT23-5 | TPS73633_SOT23-5 | TPS73633DBVT | IC | 1 | U15 |
SOT23-5 | 1310447 | | IC | 1 | U40 |
SOT23-5 | TS321I_SOT-23-5 | TS321IDBVR | IC | 1 | U41 |
SOT23-6 | SN74LVC1G18_SOT23-6 | SN74LVC1G18 | IC | 1 | U10 |
SOT23_LUMEX | 1700020 | | IC | 1 | DS23 |
SOT143 | SP0503BAHT_SOT143 | SP0503BAHT | IC | 1 | X6 |
SOT223-4 | SOT223_SOT223-4 | NDT3055L | IC | 1 | Q24 |
SOT223-6 | TL1963A_18DCQR_SOT223-6 | | IC | 1 | U79 |
SOT-23 | BAV40-04_SOT23 | BAS40-04 | IC | 9 | D1; D2; D3; D4; D5; D6; D7; D8; D9 |
SOT-23 | NDS331N_SOT23 | NDS331N | IC | 18 | Q2; Q5; Q6; Q9; Q10; Q11; Q15; Q16; Q17; Q18; Q19; Q20; Q21; Q22; Q23; Q25; Q26; Q27 |
SOT-23 | FET-3PIN | | IC | 1 | Q14 |
SOT-23-6 | TPS3808G25DBVT_SOT-23-6 | TPS3808G25DBVT | IC | 1 | U7 |
SOT_89 | FCX491A_SOT_89 | FCX491A | IC | 2 | Q12; Q13 |
SW_450_500 | 1201M2S3ABE2_SLIDE_2POS | 1201M2S3ABE2 | IC | 1 | SW2 |
TANT-A | 1550061 | 3.3UF | IC | 1 | C142 |
TANT-B | 330UF_TANT_B | 33UF | IC | 1 | C201 |
TANT-B | 47UF_TANT_B | 47UF | IC | 21 | C283; C284; C285; C286; C287; C288; C289; C290; C291; C292; C293; C294; C295; C296; C297; C298; C299; C301; C302; C303; C407 |
TANT-C | 3_3UF_TANT_C | 3.3UF | IC | 1 | C227 |
TANT-C | 150UF_TANT_C | 150UF | IC | 1 | C255 |
TANT-D | 330UF_TANT_D | 330UF | IC | 7 | C272; C274; C275; C276; C403; C418; C419 |
TANT-V | 330UF_TANT_V | 330UF | IC | 3 | C359; C360; C361 |
THTL3301EF100QG | PUSHBUTTON_4 | TL3301EF100QG | IC | 8 | SW3; SW4; SW5; SW6; SW7; SW8; SW9; SW10 |
TQFP50P1600X1600-100 | CY7C67300-TQFP100 | CYP_USB_HOST | IC | 1 | U81 |
TQFP100 | 1310404 | | IC | 1 | U26 |
TQFP144 | XCCACE-TQ144I_TQFP144 | XCCACE-TQ144I | IC | 1 | U19 |
TSM_107_01_L_DV | TSM_107_01_L_DV | DNP | IC | 1 | J24 |
TSOC_6 | 1310353 | | IC | 1 | U18 |
TSOP50P2000X1400-56 | JS28F256P30_TSOP50P2000X140056 | JS28F256P30 | IC | 1 | U4 |
TSSOP65P640X300-8 | M24128-BWDW6TP | M24128-BWDW6TP | IC | 1 | U5 |
TSSOP65P640X300-8 | M24C08-WDW6TP | M24C08-WDW6TP | IC | 1 | U6 |
TSSOP65P640X300-8 | ICS844021I_TSSOP8 | ICS844021I | IC | 1 | U82 |
TSSOP-16 | CD74HC4051_TSSOP-16 | CD74HC4051 | IC | 2 | U2; U3 |
TSSOP-16 | ICS854104_TSSOP16 | ICS854104 | IC | 3 | U14; U83; U84 |
TSSOP-20 | ICS874001_TSSOP20 | ICS874001 | IC | 1 | U9 |
TSSOP-20 | ST2378E | ST2378E | IC | 5 | U29; U30; U31; U32; U33 |
TSSOP-20 | SN74LV541APWR | | IC | 1 | U88 |
VQFP100 | 1310301 | | IC | 1 | U22 |
WSL2010-2 | 0_006_WSL2010-2 | 0.006 | IC | 2 | R115; R116 |
XTAL_MA506 | XTAL_MA506 | 25.00MHZ | IC | 1 | X2 |
