Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BATHOLDER-KB6810AP2L | BATHOLDER-KB6810AP2L | KB6810AP2L/X | DISCRETE | 1 | BAT1 |
BEAD0603 | BEAD0603 | BLM18PG600SN1D | DISCRETE | 13 | FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB11; FB12; FB13 |
BEAD0603 | BEAD0603 | CB-82CJ02103 | DISCRETE | 3 | L4; L5; L6 |
CAP0402 | CAP0402 | 0.1uF/X | DISCRETE | 1 | C173 |
CAP0603 | CAP0603 | 0.1uF | DISCRETE | 78 | C3; C7; C19; C25; C30; C32; C34; C36; C37; C40; C43; C44; C45; C46; C47; C50; C51; C52; C54; C55; C56; C61; C62; C65; C66; C67; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C81; C82; C84; C86; C87; C89; C90; C91; C92; C103; C109; C110; C111; C112; C113; C114; C116; C117; C118; C119; C127; C128; C129; C130; C131; C134; C136; C140; C141; C142; C143; C144; C146; C147; C148; C149; C150; C151; C152; C153; C154; C156 |
CAP0603 | CAP0603 | 0.01uF | DISCRETE | 4 | C4; C16; C26; C31 |
CAP0603 | CAP0603 | 0.1uF/X | DISCRETE | 1 | C5 |
CAP0603 | CAP0603 | 1uF | DISCRETE | 19 | C8; C9; C11; C12; C42; C49; C58; C59; C83; C85; C88; C93; C94; C95; C99; C104; C105; C138; C139 |
CAP0603 | CAP0603 | 0.022uF | DISCRETE | 1 | C13 |
CAP0603 | CAP0603 | 47pF | DISCRETE | 1 | C20 |
CAP0603 | CAP0603 | 1500pF | DISCRETE | 1 | C21 |
CAP0603 | CAP0603 | 33pF | DISCRETE | 1 | C23 |
CAP0603 | CAP0603 | 22pF | DISCRETE | 3 | C28; C57; C126 |
CAP0603 | CAP0603 | 20pF | DISCRETE | 2 | C33; C35 |
CAP0603 | CAP0603 | 12pF/X | DISCRETE | 2 | C38; C39 |
CAP0603 | CAP0603 | 1000pF | DISCRETE | 4 | C63; C64; C106; C107 |
CAP0603 | CAP0603 | 2.2uF | DISCRETE | 1 | C98 |
CAP0603 | CAP0603 | 0.015uF | DISCRETE | 2 | C100; C101 |
CAP0603 | CAP0603 | 100pF | DISCRETE | 1 | C102 |
CAP0603 | CAP0603 | 5pF | DISCRETE | 3 | C120; C122; C124 |
CAP0603 | CAP0603 | 3.3pF | DISCRETE | 3 | C121; C123; C125 |
CAP0805 | CAP0805 | 10uF | DISCRETE | 13 | C1; C2; C15; C17; C18; C24; C29; C53; C108; C137; C145; C155; C179 |
CAP0805 | CAP0805 | 4.7uF | DISCRETE | 15 | C10; C14; C22; C27; C41; C48; C60; C68; C69; C80; C96; C97; C115; C132; C135 |
CHOKE-CDRH3D16-4R7Y | CHOKE-CDRH3D16-4R7Y | CDRH3D16-4R7Y | IO | 2 | L9; L11 |
CHOKE-SDR-54 | CHOKE-SDR-54 | SDR-54-3R3M | IC | 1 | L1 |
CON-C022034 | CON-C022034 | HDMI-0002 | IO | 1 | J7 |
DIP_CONN_2RJ12R-05070-XX2-PL | DIP_CONN_2RJ12R-05070-XX2-PL | 2RJ12R-05070-XX2 | IO | 1 | J6 |
DIP_CONN_2RJ13R-050XX-XX31-PL | DIP_CONN_2RJ13R-050XX-XX31-PL | 2RJ13R-050XX-XX31 | IO | 1 | J8 |
DIP_JW-RJ45-001-PL | DIP_JW-RJ45-001-PL | JW-RJ45-001 | IO | 1 | J9 |
DIP_XTAL-32K768_CYLINDRICAL | DIP_XTAL-32K768_CYLINDRICAL | 32.768KHz/X | DISCRETE | 1 | X4 |
DIP_XTAL_ELLIPTIC | DIP_XTAL_ELLIPTIC | 27MHZ | DISCRETE | 1 | X1 |
DLW21S | DLW21S | DLW21SN900SQ2/X | IC | 1 | L7 |
DLW21S | DLW21S | DLW21SN900SQ2 | IC | 1 | L8 |
EC5X7-80 | EC5X7-80 | 100uF | DISCRETE | 5 | CE1; CE2; CE3; CE4; CE5 |
FBGA84-MT47H128M16HG-37EA | FBGA84-MT47H128M16HG-37EA | HY5PS121621CFP-Y5 | IC | 2 | U7; U8 |
FM-9038LM-5CN | FM-9038LM-5CN | FM-9038LM-5CN | DISCRETE | 1 | IR1 |
FPC1P0-SMT11-5WX-1A-PL | FPC1P0-SMT11-5WX-1A-PL | FPC1-SMT11-5WX-1A | IO | 1 | J3 |
FUSE1206 | FUSE1206 | SMD1206P050TF | DISCRETE | 3 | F2; F3; F4 |
LED-KTL-44EGW-1 | LED-KTL-44EGW-1 | LED-KTL-44EGW-1 | DISCRETE | 1 | D7 |
LFBGA625-31P5 | LFBGA625-31P5 | WM8435 | IC | 1 | U6 |
LQFP48-19P7 | LQFP48-19P7 | VT6103X_LQFP | IC | 1 | U16 |
OPTIC-DLT1111A-PL | OPTIC-DLT1111A-PL | DLT1111A | IO | 1 | U13 |
P25X35BAA | P25X35BAA | MH5_3 | IO | 2 | MH4; MH5 |
P25X35BAC | P25X35BAC | MH5_3 | IO | 3 | MH1; MH2; MH3 |
P25X35BAEA | P25X35BAEA | MH5_3 | IO | 1 | MH6 |
QFN72-19P7-TH | QFN72-19P7-TH | SiI9022A QFN | IC | 1 | U21 |
RES0402 | RES0402 | MLVS0402E10 | DISCRETE | 15 | ESD1; ESD2; ESD3; ESD4; ESD5; ESD6; ESD7; ESD8; ESD9; ESD10; ESD11; ESD12; ESD13; ESD14; ESD15 |
RES0603 | RES0603 | 10K/X | DISCRETE | 10 | R3; R5; R11; R16; R19; R57; R69; R77; R81; R139 |
RES0603 | RES0603 | 0/X | DISCRETE | 11 | R4; R101; R107; R110; R111; R128; R133; R145; R146; R159; R160 |
RES0603 | RES0603 | 1K/X | DISCRETE | 4 | R6; R14; R18; R32 |
RES0603 | RES0603 | 100K/X | DISCRETE | 2 | R7; R113 |
RES0603 | RES0603 | 1K | DISCRETE | 7 | R8; R9; R13; R21; R26; R29; R93 |
RES0603 | RES0603 | 4.7K/X | DISCRETE | 11 | R10; R73; R115; R116; R117; R118; R120; R121; R122; R123; R124 |
RES0603 | RES0603 | 10K | DISCRETE | 16 | R15; R20; R23; R37; R38; R55; R56; R58; R59; R61; R62; R63; R67; R68; R76; R109 |
RES0603 | RES0603 | 100 | DISCRETE | 3 | R17; R78; R79 |
RES0603 | RES0603 | 21K_1% | DISCRETE | 1 | R22 |
RES0603 | RES0603 | 24K_1% | DISCRETE | 1 | R24 |
RES0603 | RES0603 | 680K_1% | DISCRETE | 1 | R25 |
RES0603 | RES0603 | 150K_1% | DISCRETE | 1 | R27 |
RES0603 | RES0603 | 200K_1% | DISCRETE | 1 | R28 |
RES0603 | RES0603 | 100K_1% | DISCRETE | 2 | R30; R156 |
RES0603 | RES0603 | 0 | DISCRETE | 18 | R31; R33; R34; R35; R65; R66; R99; R125; R130; R131; R134; R135; R136; R137; R138; R140; R150; R161 |
RES0603 | RES0603 | 4.7K | DISCRETE | 7 | R36; R64; R75; R80; R82; R83; R92 |
RES0603 | RES0603 | 120_1% | DISCRETE | 1 | R39 |
RES0603 | RES0603 | 301_1% | DISCRETE | 1 | R40 |
RES0603 | RES0603 | 3.16K_1% | DISCRETE | 2 | R41; R43 |
RES0603 | RES0603 | 22 | DISCRETE | 12 | R42; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54 |
RES0603 | RES0603 | 5.62K_1% | DISCRETE | 1 | R60 |
RES0603 | RES0603 | 110 | DISCRETE | 2 | R70; R71 |
RES0603 | RES0603 | 80.6_1% | DISCRETE | 1 | R74 |
RES0603 | RES0603 | 75 | DISCRETE | 7 | R86; R87; R88; R96; R97; R102; R104 |
RES0603 | RES0603 | 1.5K | DISCRETE | 1 | R90 |
RES0603 | RES0603 | 33 | DISCRETE | 4 | R91; R98; R112; R114 |
RES0603 | RES0603 | 1M | DISCRETE | 3 | R94; R95; R119 |
RES0603 | RES0603 | 49.9_1% | DISCRETE | 4 | R100; R103; R105; R106 |
RES0603 | RES0603 | 6.2K_1% | DISCRETE | 1 | R108 |
RES0603 | RES0603 | 2.2K | DISCRETE | 5 | R126; R127; R162; R163; R164 |
RES0603 | RES0603 | 330 | DISCRETE | 2 | R129; R132 |
RES0603 | RES0603 | 47K | DISCRETE | 2 | R151; R158 |
RES0603 | RES0603 | 49.9K_1% | DISCRETE | 1 | R157 |
RES0603 | RES0603 | 4.3K | DISCRETE | 1 | R165 |
RES0603 | RES0603 | 10 | DISCRETE | 1 | R166 |
RES1206 | RES1206 | 0 | DISCRETE | 2 | R1; R2 |
RN-8P4R-19P7X50 | RN-8P4R-19P7X50 | 10K | DISCRETE | 2 | RN1; RN2 |
SMD_101-00402XX-PL | SMD_101-00402XX-PL | 101-00402XX | IO | 1 | J10 |
SMD_APW7145KAITRL_SOP8-PL | SMD_APW7145KAITRL_SOP8-PL | APW7145KAITRL | IC | 1 | U3 |
SMD_AT25FS040N-SH27_W600-PL | SMD_AT25FS040N-SH27_W600-PL | EN25F40-75GCP | IC | 1 | U10 |
SMD_CONN_1226-08-02-PL | SMD_CONN_1226-08-02-PL | 1226-08-02 | IC | 1 | J2 |
SMD_DC003-PL | SMD_DC003-PL | DC-003 | IO | 1 | J1 |
SMD_DOIDE_BZT52C-SOD123-PL | SMD_DOIDE_BZT52C-SOD123-PL | BZT52C5V1/X | IC | 1 | D1 |
SMD_RT8008PB_SOT23-5-PL | SMD_RT8008PB_SOT23-5-PL | PAM2301CAABADJ | IC | 2 | U4; U5 |
SMD_TP_1 | SMD_TP_1 | PLLTP | IO | 2 | 1P8V; 3P3V |
SMD_TP_1MM | SMD_TP_1MM | TestPoint_1mm | IO | 15 | 1P5V; 27M1; 32K1; DCIN_T1; RES2; RES3; RES4; RES5; SPICLK1; SPIMISO1; SPIMOSI1; SPISS1; VIN_T1; VSUS15; VSUS33 |
SMD_TS-A87-PL | SMD_TS-A87-PL | TS-A87/X | IO | 1 | SW2 |
SMD_USBAS-T04-PL | SMD_USBAS-T04-PL | USBAS-T04 | IO | 2 | J4; J5 |
SMD_WM8524_TSSOP16-PL | SMD_WM8524_TSSOP16-PL | WM8524GEDT | IC | 1 | U12 |
SOD-523 | SOD-523 | RB520S-30 | DISCRETE | 1 | D3 |
SOIC8-50X204 | SOIC8-50X204 | APM9435KC-TRL/X | IC | 1 | Q1 |
SOIC8-50X288 | SOIC8-50X288 | AT25DF041A-SH/X | IC | 1 | U11 |
SOT23-5 | SOT23-5 | RT9193-33PB | DISCRETE | 1 | U2 |
SOT23-5 | SOT23-5 | APL5315-BI-TRL | DISCRETE | 1 | U22 |
SOT23-6 | SOT23-6 | AZC199-04S.R7F | DISCRETE | 2 | U24; U25 |
SOT23-132 | SOT23-132 | BAT54C/X | DISCRETE | 1 | D2 |
SOT23-132 | SOT23-132 | BAV99 | DISCRETE | 3 | D4; D5; D6 |
SOT23-132 | SOT23-132 | LY6206A15M | DISCRETE | 1 | U1 |
SOT23-GDS | SOT23-GDS | 2N7002LT1/X | DISCRETE | 4 | Q3; Q4; Q6; Q7 |
SOT23-GDS | SOT23-GDS | APM2301CAC-TRL | DISCRETE | 1 | Q8 |
SW-DTSA-62N-S-V | SW-DTSA-62N-S-V | DTSA-63N-V | IO | 1 | SW1 |
TSOP48-19P7X768 | TSOP48-19P7X768 | HY27UT088G2M-TPCB | IC | 1 | U9 |
附件:
