查看: 284|回复: 0
[allegro15.2][2层] wifi插座(远程控制)(54D+EE10+MT7682)原理图和pcb文件
发表于 2020-2-28 19:35 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
+ n6 a) |7 M" V# p) H7 b
[allegro15.2][2层] wifi插座(远程控制)(54D+EE10+MT7682)原理图和pcb文件2 \5 j/ ?" G" H$ B" x/ W/ b1 d" A
5 T( I5 g: g# Z9 m# o- [" [
文件描述:' a- {# ]1 ]: f
1. 作品用途:wifi插座(远程控制)
7 B8 P+ P. r- U6 v* Z, t2. 软件版本:allegro15.2
0 x% H; C& O3 r" o. {6 P' X3. 层数:2层
8 F: s% ]# Z" p' I. P" i! R- t4. 用到的主要芯片:54D+EE10+MT7682
' |7 d9 w; M% ?: u" |5. pcb尺寸:异形
6 v& x: U. t+ C$ o! R
( g( x4 F$ b. s! [! F7 X) ?1 b: O# M+ z$ f作品截图如下:7 P' N7 g  s* Z; b8 u2 D
顶层截图:
$ h4 \( p+ J% D- a9 F6 M' R 0 v8 Q  B% C/ i: u
底层截图:  7 Y1 R3 B  c3 j  k) l1 ~( a& d
2 y! e) ^/ ~! E( r2 b
全层截图:7 O% \# C7 J  p: h6 _
* ^8 w7 L3 [& l4 ]. E
叠层阻抗信息如下:
- N& |- w6 r, DBOM:
  X2 Q& i" v  K8 z) P; {) v' O
Bill of Material Report (Condensed)
名称类型属性类别数量位号
54DINDUCTOR_54D_22UH22uHIC1L3
ABS10BR84D_ABS10_ABS10ABS10IC1D1
C0603CAP_C0603_0.1UF0.1uFIC3C11; C13; C17
C0603CAP_C0603_100NF100NFIC1C16
C0805CAP_C0805_0.1UF/NC0.1UF/NCIC1C4
C0805CAP_C0805_0.1UF0.1uFIC2C6; C9
C0805CAP_C0805_10UF10uFIC1C10
CAP_D5_D0_5_F2_0CAP POL_CAP_D5_D0_5_F2_0_220UF/220UF/25VIC1C8
CAP_D5_D0_5_F2_0CAP POL_CAP_D5_D0_5_F2_0_10UF10uFIC1C12
CAP_D6_3_D0_5_F2_5CAP POL_CAP_D6_3_D0_5_F2_5_10UF10UF/50VIC1C1
CAP_D6_3_D0_5_F2_5CAP POL_CAP_D6_3_D0_5_F2_5_22_1220UF/25VIC1C7
CAP_D6_3_D0_5_F2_5CAP POL_CAP_D6_3_D0_5_F2_5_100U100UF/25VIC1C14
CAP_D6_3_D0_5_F2_5CAP POL_CAP_D6_3_D0_5_F2_5_220U220UF/10VIC1C18
CAP_D6_3_D0_5_F2_5INDUCTOR_CAP_D6_3_D0_5_F2_5_1MH1mH/NCIC1L1
CAP_D8_D0_6_F3_5CAP POL_CAP_D8_D0_6_F3_5_10UF/410UF/400VIC2C2; C3
CY_L10CAP_CY_L10_CCIC1CY1
DO-214ACDIODE_DO-214AC_SS26SS26IC2D5; D6
EE10TRAN_ISDN_5_EE10_TRAN_ISDN_06TRAN_ISDN_06IC1T1
EL817_DIPEL817_EL817_DIP_EL817EL817IC1U2
FUSE_4X8FUSE_FUSE_4X8_3.15A 250V3.15A 250VIC1F1
H1_5D2_5T POINT A_H1_5D2_5_T+T+IC1T+
H1_5D2_5T POINT A_H1_5D2_5_GNDGNDIC1T-
H2_5D4_5T POINT S_H2_5D4_5_NNIC1TP1
H2_5D4_5T POINT S_H2_5D4_5_LLIC1TP2
H2_5D4_5T POINT S_H2_5D4_5_L_OUTL_OUTIC1TP3
HF115F_012_1HS3AFRELAY SPDT_2_HF115F_012_1HS3AF_HF115F_012_1HS1AFIC1LS1
LED_2PINLED_LED_2PIN_LEDLEDIC4D8; D9; D11; D12
MT7682MT7682_0_MT7682_MT7682MT7682IC1U3
PH2_0_3PINHEADER 3_PH2_0_3PIN_HEADER 3HEADER 3IC1J1
PH2_0_4PINHEADER 4_PH2_0_4PIN_HEADER 4HEADER 4IC1J2
R0603R_R0603_10K10KIC13R14; R15; R16; R17; R18; R19; R20; R22; R23; R26; R27; R28; R29
R0603R_R0603_1K1KIC4R24; R25; R30; R32
R0603R_R0603_27K27KIC2R31; R35
R0805R_R0805_10R10RIC1R1
R0805R_R0805_43K43KIC1R3
R0805R_R0805_43K/NC43K/NCIC1R4
R0805R_R0805_4.3K4.3KIC1R5
R0805R_R0805_51R51RIC1R8
R0805R_R0805_1K1KIC2R11; R12
R0805R_R0805_10K10KIC2R13; R21
R1206CAP_R1206_2.2NF/500V2.2nF/500VIC1C5
R1206R_R1206_10K10kIC1R2
R1206R_R1206_3R33R3IC2R6; R7
R1206R_R1206_300K300KIC2R9; R33
R1206R_R1206_200K200KIC1R10
SMD_KEY_4PSW PUSHBUTTON-SPST-2/SM_SMD_KEYSW PUSHIC1SW1
SOD_123DIODE_SOD_123_RSIMRSIMIC2D2; D3
SOD_123DIODE_SOD_123_A7A7IC1D4
SOD_123DIODE_SOD_123_FIMFIMIC1D7
SOD_123DIODE_SOD_123_IN4148IN4148IC1D10
SOP_7PN8370_SOP_7_PN8370pn8370IC1U1
SOT23NPN BCE_1_SOT23_J3YJ3YIC1Q1
SOT23_6AH8310_0_SOT23_6_AH8310AH8310IC1U4
SW_SMD2PINSW KEY-SPST_SW_SMD2PIN_SW KEY-SSW KEY-SPSTIC1SW2
附件:0 P6 E# |6 ~8 U
原理图和PCB文件如下:
8 R8 e: h9 h5 G
游客,如果您要查看本帖隐藏内容请回复
; T: Y8 ]. y# o4 |. V4 Q. J( s) o4 q0 \9 t  U; }
+ [% {, u4 f& C# z' V7 D
GMT+8, 2025-7-27 20:35 , Processed in 0.125000 second(s), 28 queries , Gzip On.
