查看: 313|回复: 1
[allegro15.2][6层] 开发板 PCB(VS100TX+EP9142+EPF025A+IP175D+MAX8505EEE )原...
发表于 2020-2-28 18:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1 N& F, s6 |6 q) [
[allegro15.2][6层] 开发板 PCB(VS100TX+EP9142+EPF025A+IP175D+MAX8505EEE )原理图和pcb文件
8 m; r) b! `; Y' P- [  q. W
3 q* O# h% h$ j! @文件描述:( t  a* R0 }. w! z9 R
1. 作品用途:开发板 PCB
# P4 _; j2 m, w2. 软件版本:allegro15.2
8 A* n+ W  {) k& p# _3. 层数:6层
7 q, I" Q$ ?$ \4 w+ P4 S4. 用到的主要芯片:VS100TX+EP9142+EPF025A+IP175D+MAX8505EEE 2 ^* z$ T* ]! j, E
5. pcb尺寸: 5463*2952 MIL  F5 ~- g. ?  Y+ A& P- Z0 Z
: R7 D# C/ ~; `8 Q: e9 q. E
作品截图如下:
" H2 i. x7 B7 y4 H' f: w顶层截图:
- n# n% {! r, _' a* I5 L
8 {/ w4 |, X; I) r# p# C底层截图:
, O8 K' B. |4 J" r8 m   w) {* ]2 D# G$ W; Z0 }4 h' b
全层截图:- J0 q/ ^" m1 @: d8 G: B; S
# y( H( R5 g$ V" F' `' e7 Z
叠层阻抗信息如下:
5 e# E( R' D; x: C# f: A5 w. z
1 ?# @# f, o4 x4 B5 IBOM:" V  K: c( i% _# p2 h
Bill of Material Report (Condensed)
名称类型属性类别数量位号
5X7OSC8/SM_0_5X7_125MHZ CMOS125MHz CMOSIC1X1
6X11CAPACITOR POL_6X11_10UF/100V10uF/100VIC1C500
402CAP NP_0402_100NF100nFDISCRETE95C2; C3; C4; C5; C6; C7; C8; C9; C22; C23; C26; C29; C45; C46; C48; C49; C50; C51; C53; C54; C55; C56; C68; C69; C70; C71; C72; C73; C98; C99; C100; C101; C102; C103; C104; C107; C108; C109; C110; C111; C112; C119; C126; C128; C129; C130; C131; C140; C143; C144; C145; C146; C147; C148; C149; C150; C152; C155; C158; C159; C177; C502; C503; C504; C506; C507; C513; C516; C518; C519; C522; C523; C526; C527; C530; C532; C537; C539; C554; C561; C563; C564; C565; C566; C702; C801; C802; C803; C809; C810; C811; C815; C816; C818; C819
402CAP NP_0402_10NF/100V10nF/100VIC2C14; C15
402CAP NP_0402_NINIIC4C16; C17; C178; C567
402CAP NP_0402_10NF10nFIC2C19; C21
402CAP NP_0402_390PF390pFIC10C24; C25; C27; C28; C30; C31; C34; C35; C170; C171
402CAP NP_0402_15PF15pFIC4C42; C43; C555; C559
402CAP NP_0402_470NF470nFIC2C117; C137
402CAP NP_0402_1NF1nFIC2C121; C141
402CAP NP_0402_3.3NF3.3nFIC1C156
402CAP NP_0402_220PF220pFIC1C160
402CAP NP_0402_33NF33nFIC1C161
402CAP NP_0402_22NF22nFIC1C179
402CAP NP_0402_100NF_NI100nF_NIIC12C541; C542; C543; C544; C545; C546; C547; C548; C549; C550; C551; C552
402CAP NP_0402_NI_180PFNI_180pFIC1C804
402R_0402_1K1KIC31R1; R2; R5; R6; R7; R32; R35; R39; R40; R41; R42; R80; R109; R508; R509; R510; R511; R512; R513; R514; R515; R516; R605; R614; R802; R809; R812; R813; R822; R847; R875
402R_0402_499R499RDISCRETE11R10; R11; R12; R13; R14; R15; R16; R17; R91; R156; R157
402R_0402_4.53K4.53KIC1R18
402R_0402_NINIDISCRETE36R19; R23; R75; R76; R77; R112; R115; R116; R119; R121; R123; R143; R144; R159; R160; R518; R519; R551; R593; R811; R841; R844; R849; R850; R852; R854; R856; R858; R860; R861; R864; R866; R868; R871; R872; R874
402R_0402_75R75RIC2R20; R22
402R_0402_100K100KIC8R24; R129; R800; R808; R816; R821; R836; R837
402R_0402_12K12KIC1R25
402R_0402_19.6K19.6KIC1R26
402R_0402_27K27KIC2R27; R838
402R_0402_402R402RIC2R30; R810
402R_0402_1.7K1.7KIC2R31; R34
402R_0402_200R200RIC1R33
402R_0402_0R0RDISCRETE27R38; R69; R72; R73; R74; R85; R111; R113; R114; R118; R120; R122; R127; R552; R598; R851; R853; R855; R857; R859; R862; R863; R865; R867; R869; R870; R873
402R_0402_49R949R9IC25R43; R44; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R61; R62; R64; R65; R137; R138; R139; R140; R817; R818; R819; R820; R842
402R_0402_220R220RIC9R45; R56; R86; R87; R88; R89; R90; R141; R142
402R_0402_4.7K4.7KIC10R67; R68; R78; R79; R81; R92; R93; R94; R95; R96
402R_0402_NCNCIC1R82
402R_0402_6.19K6.19KIC1R83
402R_0402_20K20KIC1R124
402R_0402_2.5K2.5KIC1R126
402R_0402_10K10KIC9R128; R586; R587; R591; R801; R805; R824; R843; R848
402R_0402_49.9K49.9KIC2R130; R845
402R_0402_100R100RIC2R148; R835
402R_0402_1.1K1.1KIC1R158
402R_0402_11K11KIC2R265; R823
402R_0402_4.02K4.02KIC1R266
402R_0402_2.49K2.49KIC1R517
402R_0_0402_47K47KIC4R530; R531; R553; R554
402R_0402_470R470RIC1R534
402R_0402_357R357RIC2R535; R548
402R_0_0402_499R499RIC12R536; R537; R538; R539; R540; R541; R542; R543; R544; R545; R546; R547
402R_0_0402_0R0RIC21R549; R557; R558; R559; R561; R562; R563; R564; R565; R566; R567; R572; R573; R574; R575; R576; R577; R578; R580; R582; R584
402R_0_0402_510K510KIC1R550
402R_0_0402_4.7K4.7KIC2R555; R556
402R_0402_10M10MIC1R560
402R_0_0402_2K2KIC6R568; R569; R570; R571; R594; R595
402R_0_0402_NINIDISCRETE3R579; R581; R583
402R_0402_680R680RIC1R585
402R_0_0402_1K1KIC3R588; R592; R602
402R_0_0402_0/NC0/NCIC1R589
402R_0_0402_NI_0RNI_0RIC1R590
402R_0_0402_47K/NC47K/NCIC2R596; R597
402R_0_0402_NC/1KNC/1KIC1R599
402R_0402_0/NC0/NCIC2R600; R601
402R_0402_1.2K1.2KIC2R803; R804
402R_0402_5.1K5.1KIC2R806; R807
402R_0402_5R15R1IC2R814; R815
402R_0402_3R03R0DISCRETE8R827; R828; R829; R830; R831; R832; R833; R834
402R_0402_1.62K1.62KIC2R839; R840
402R_0402_33R33RIC1R846
402R_0402_137R137RIC1R876
402R_0402_53R653R6IC8R877; R878; R879; R880; R881; R882; R883; R884
603BEAD_0603_FERRITE 120R/2AFerrite 120R/2AIC10B13; B14; B15; B16; B17; B18; B19; B20; B21; B802
603TRISIL_BIDIR_0603_PGB1010603-MRPGB1010603-MRIC2ESD2; ESD3
603R_0603_100R100RIC2R110; R117
603R_0603_10R10RIC1R125
603R_0603_15R15RIC2R532; R533
603R_0603_0R0RIC2R606; R607
603R_0603_NINIIC4R610; R611; R612; R613
0603_LEDLED_0603_LED_LEDLEDIC9D5; D6; D7; D8; D9; D13; D14; D32; D803
0603_LED_ACLED_3_0603_LED_AC_LEDLEDIC1LED1
805BEAD_0805_BLM21PG600SN1BLM21PG600SN1IC2B800; B801
805BEAD_0805_NINIIC2B803; B804
805CAP NP_0805_100NF/63V100nF/63VIC1C501
805CAP NP_0805_10UF10uFIC11C512; C521; C525; C529; C531; C536; C538; C560; C800; C807; C817
805CAP NP_0805_1UF1uFIC6C515; C517; C540; C553; C805; C806
805CAP NP_0805_4.7UF4.7uFIC2C812; C813
805CAP NP_0805_2.2UF2.2uFIC1C814
805INDUCTOR_0805_BLM21PG600SN1BLM21PG600SN1IC1FB1
805INDUCTOR_0805_10UH10uHIC2L1; L800
805R_0805_100R100RIC1R155
100874479787210_1008_7447978721074479787210IC1FB2
1206CAP NP_1206_100NF/50V100nF/50VIC3C13; C38; C39
1206CAP NP_1206_1NF/2KV1nF/2KVIC1C18
1812CAP NP_1812_10NF/1.5KV10nF/1.5KVIC2C700; C701
1812R_1812_NINIIC2R825; R826
744273TRAN_HM33_0_744273_NI_744273801NI_744273801IC2CM500; CM501
AG6100-SIMAG6100_AG6100-SIM_AG6100Ag6100IC1PSE1
AG9605-SIMAG9605-2BR_AG9605-SIM_AG9605-2BAg9605-2BRIC1PD1
BGA-196VS100-SRC_BGA-196_VS100TXVS100TXIC1U1
CASE-BCAPACITOR POL_CASE-B_100UF100uFIC13C1; C20; C44; C47; C52; C66; C120; C138; C142; C172; C505; C713; C808
CASE-BCAP POL_CASE-B_100UF100uFIC4C116; C127; C153; C154
CASE-BCAP POL_CASE-B_22UF22uFIC2C118; C139
CASE-BCAP POL_CASE-B_47UF47uFIC1C157
CASE-DCAP POL_CASE-D_470UF470uFIC2C67; C181
CON-HDMI-19HDMI_A_0_CON-HDMI-19_HDMI_AHDMI_AIC2J2; J507
CONPWRCONN JACK PWR_0_CONPWR_PWR JACKPWR JACKIC1J11
DIPSW8-SMD-MSW DIP-8/SM_DIPSW8-SMD-M_SW DIPSW DIP-8/SMIC1SW500
DO1608CINDUCTOR_DO1608C_10UH/1A10uH/1AIC2L622; L623
DO1608CINDUCTOR_DO1608C_NINIIC2L624; L625
FIDUCIALHEADER 1_FIDUCIAL_FIDFIDIC8FD1; FD2; FD3; FD4; FD5; FD6; FD7; FD8
H7001NL_80MILH7001NL_H7001NL_80MIL_H7019FNLH7019FNLIC1TR1
HC49_USCRYSTAL_HC49_US_25MHZ25MHZIC1Y1
HC49_USCRYSTAL_HC49_US_24MHZ24MHzIC1Y3
HOLE43PTEST POINT_HOLE43P_TPTPIC8TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP800
IRM0101PL-IRM0101-3_IRM0101_PL-IRM0101PL-IRM0101-3IC1IR1
LEDIRTXLED_1_LEDIRTX_NI_LED_IRNI_LED_IRIC1D801
LED_TH_90LED_0_LED_TH_90_LEDLEDIC4D1; D2; D3; D11
LQFP64-EPEP9142_LQFP64_0_LQFP64-EP_EP914EP9142_NIIC1U35
MH126PTEST POINT_MH126P_MHMHIC4MH1; MH2; MH3; MH4
PQFP-128175C_DEMO_MII_0_PQFP-128_IP175DIP175DIC1U8
QSOP-16MAX8505EEE_QSOP-16_MAX8505EEEMAX8505EEEIC1REG3
RCLAMP0524PRCLAMP0524_0_RCLAMP0524P_RCLAMPRclamp0524IC6U3; U4; U6; U803; U804; U805
RJ45X8_PCONN RECT 8_0_RJ45X8_P_RJ45RJ45IC1J3
RJ00812RJ45_TRNS_0_RJ00812_RJ45_TRNSRJ45_TRNSIC1J6
SJ1-3515-SMTPHONOJACK STEREO-15_2_SJ1-3515-CONN 3.5MM SWIC4J13; J501; J504; J506
SOD-923DIODE TS BI-DIR_SOD-923_ESD7951ESD7951ST5GIC4D33; D34; D35; D36
SOIC-824CXX_1_SOIC-8_24LC08BI_PREP24LC08BI_prepIC1U34
SOIC-14EP91H0_SOP14_SOIC-14_EP91H0EP91H0IC1U801
SOIJ-SOIC-825LC512-I-SN_SOIJ-SOIC-8_M95M02M95M02-DRMN6TPIC1U7
SON2X2-6-EPTPS60151DRVT_SON2X2-6-EP_TPS601TPS60151DRVTIC1U806
SOT23-5NC7SZ14/SOT23_SOT23-5_NC7S14M5XNC7S14M5XIC2U11; U13
SOT23-5NC7S08/SOT23_0_SOT23-5_NC7SZ08MNC7SZ08M5XIC1U12
SOT23-5AD820/SO_0_SOT23-5_ADCMP600BRJZADCMP600BRJZIC1U800
SOT23-5NC7SZ32/SOT23_0_SOT23-5_NC7SZ32NC7SZ32M5XIC2U802; U808
SOT23-5NC7SZ384/SOT23_0_SOT23-5_NC7SZ1NC7SZ126M5XIC1U807
SOT-23MMBT2907A/SOT_0_SOT-23_MMBT2907MMBT2907AIC1Q802
SOT-23DS1818-10_SOT-23_DS1818-10DS1818-10IC1U5
SOT-23-FETON-MOSFET-NTR4502_0_SOT-23-FET_NTR4502IC2Q10; Q800
SOT-23-SMALLBAT54C/SOT_0_SOT-23-SMALL_BAT54BAT54CIC4D4; D12; D37; D802
SOT-23-SMALLMMBT2222A/SOT_2_SOT-23-SMALL_MMMMBT2222AIC2Q1; Q801
SWSM_INDINDUCTOR_SWSM_IND_1UH/3A1uH/3AIC3L6; L7; L611
TDFN-EP-10MAX1556ETB_TDFN-EP-10_MAX1556ETMAX1556ETBIC2REG1; REG2
TPSMDT POINT S_TPSMD_TPSMDTPSMDIC16TP1; TP8; TP16; TP27; TP513; TP700; TP701; TP702; TP801; TP802; TP803; TP804; TP805; TP806; TP807; TP808
TQFP64_04EPF025A_0_TQFP64_04_EPF025A/021EPF025A/021A_prepIC1U36
TSSOP-1474HC74_0_TSSOP-14_MM74HC74AMTCMM74HC74AMTCIC1U809
TSSOP-16MAX3232_2_TSSOP-16_MAX3232CUEMAX3232CUEIC1U29
TSW-105HEADER 5X2_TSW-105_HEADER 5X2MHEADER 5X2MIC1J508
TSW-105-SCONN RCPT 5_TSW-105-S_NI_HEADERNI_HEADER 5IC1J500
TSW-105-SCONN RCPT 5_TSW-105-S_NI_HEAD_1NI_HEADER 5MIC1J503
UDFN-10RCLAMP0524_1_UDFN-10_RCLAMP2504RCLAMP2504NIC1U14
UDFN-10RCLAMP0524_2_UDFN-10_RCLAMP2504RCLAMP2504NIC1U15
VLF4012AINDUCTOR_VLF4012A_3.3UH/1.2A3.3uH/1.2AIC4L2; L3; L4; L5
附件:
/ r9 H( @, R9 K8 Q5 w( N- Z原理图和PCB文件如下:8 P) n  w  D5 |, J7 h& q, y; W
游客,如果您要查看本帖隐藏内容请回复
# ]- `# H8 B7 R% h* V) G
6 C% j) k- t) @/ _. {& F! G- n5 n
发表于 2025-5-23 18:28 | 只看该作者
参考了解一下,谢谢
! j- n# c7 V9 C% Y4 S
GMT+8, 2025-6-13 04:52 , Processed in 0.109375 second(s), 27 queries , Gzip On.
