Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BGA-13X13-225P-0_8 | CS8030_BGA-13X13-225P-0_8_CS803 | CS8030 | IC | 1 | U1 |
C0402 | CAP NP_0_C0402_104/K/1608 | 104/K/1608 | IC | 4 | C1; C2; C54; C128 |
C0402 | CAP NP_0_C0402_105/Z/1005 | 105/Z/1005 | IC | 29 | C5; C6; C7; C24; C25; C34; C46; C47; C105; C106; C112; C119; C122; C123; C144; C151; C155; C166; C167; C168; C169; C170; C172; C173; C192; C194; C195; C196; C198 |
C0402 | CAP NP_0_C0402_104/K/1005 | 104/K/1005 | IC | 26 | C8; C9; C10; C11; C12; C13; C14; C15; C26; C27; C28; C32; C35; C36; C37; C48; C49; C50; C51; C90; C91; C94; C96; C97; C99; C135 |
C0402 | CAP NP_0_C0402_103/K/1005 | 103/K/1005 | IC | 33 | C16; C17; C18; C19; C20; C21; C22; C23; C29; C30; C31; C38; C39; C40; C41; C42; C43; C44; C52; C93; C101; C102; C103; C107; C108; C109; C110; C111; C140; C159; C171; C190; C191 |
C0402 | CAP NP_5_C0402_NIL/C/47PF/NPO/0 | NIL/C/47pF/NPO/0402 | IC | 2 | C56; C70 |
C0402 | CAP NP_4_C0402_C/103K/25V/X7R/0 | C/103K/25V/X7R/0402 | IC | 2 | C58; C72 |
C0402 | CAP NP_5_C0402_C/3.3NF/6.3V/NPO | C/3.3nF/6.3V/NPO/0402 | IC | 1 | C59 |
C0402 | CAP_NP_C0402_C/103K/16V/X7R/040 | C/103K/16V/X7R/0402 | IC | 6 | C60; C63; C64; C74; C77; C79 |
C0402 | CAP NP_5_C0402_C/104M/10V/X5R/0 | C/104M/10V/X5R/0402 | IC | 3 | C65; C66; C80 |
C0402 | CAP NP_5_C0402_C/104K/6.3V/X7R/ | C/104K/6.3V/X7R/0402 | IC | 1 | C78 |
C0402 | C_0402_C0402_0.1UF | 0.1uF | IC | 6 | C84; C85; C86; C87; C254; C256 |
C0402 | CAP NP_0_C0402_C104K/16V | C104K/16V | IC | 16 | C113; C114; C115; C116; C117; C118; C201; C202; C203; C205; C206; C208; C209; C210; C211; C212 |
C0402 | CAP NP_0_C0402_104/Z/1608 | 104/Z/1608 | IC | 1 | C150 |
C0402 | CAP NP_0_C0402_105/Z/1608 | 105/Z/1608 | IC | 3 | C153; C154; C156 |
C0402 | CAP NP_0_C0402_104/K/1608_NC | 104/K/1608_NC | IC | 1 | C158 |
C0402 | CAP NP_0_C0402_27PF/J/1005/NI | 27pF/J/1005/NI | IC | 2 | C161; C200 |
C0402 | CAP NP_0_C0402_104/K/1005/NI | 104/K/1005/NI | IC | 1 | C162 |
C0402 | CAP_0_C0402_0.1UF/NC | 0.1uF/nc | IC | 5 | C181; C184; C185; C186; C187 |
C0402 | CAP NP_0_C0402_27PF/J/1005 | 27pF/J/1005 | IC | 2 | C193; C197 |
C0402 | CAP NP_0_C0402_10PF/NI | 10pF/NI | IC | 32 | C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C224; C225; C226; C227; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C246; C247; C248; C249; C250 |
C0402 | C_0402_C0402_C/104K/25V/X5R/040 | C/104K/25V/X5R/0402 | IC | 1 | C257 |
C0603 | CAP NP_5_C0603_C/104M/10V/X5R/0 | C/104M/10V/X5R/0603 | IC | 2 | C55; C69 |
C0603 | CAP NP_3_C0603_C/104Z/25V/Y5V/0 | C/104Z/25V/Y5V/0603 | IC | 2 | C57; C68 |
C0603 | CAP NP_3_C0603_C/104K/16V/X7R/0 | C/104K/16V/X7R/0603 | IC | 1 | C71 |
C0603 | CAP NP_5_C0603_C/3.3NF/6.3V/X7R | C/3.3nF/6.3V/X7R/0603 | IC | 1 | C73 |
C0603 | CAP NP_5_C0603_NIL/C/105M/10V/X | NIL/C/105M/10V/X5R/0603 | IC | 2 | C120; C124 |
C0603 | CAP NP_0_C0603_105 | 105 | IC | 1 | C149 |
C0805 | CAP NP_0_C0805_10UF/10VK/3216 | 10uF/10VK/3216 | IC | 12 | C3; C4; C33; C45; C53; C95; C98; C126; C152; C163; C164; C199 |
C0805 | CAP NP_C0805_C/106K/10V/0805 | C/106K/10V/0805 | IC | 4 | C62; C67; C76; C81 |
C0805 | CAP NP_C0805_10UF | 10uF | IC | 1 | C127 |
C-7_62X2_54-5_08 | CAP NP_0_C-7_62X2_54-5_08_1000P | 1000pF/2K/3216 | IC | 5 | C104; C121; C160; C204; C207 |
C-7_62X2_54-5_08 | CAP NP_3_C-7_62X2_54-5_08_1000P | 1000pF/2K/3216 | IC | 3 | C230; C232; C251 |
C-D6-2_54 | CAPACITOR POL_0_C-D6-2_54_220UF | 220uF,±20%,16V,LowESR | IC | 3 | C61; C75; C231 |
C-D6-2_54 | CAPACITOR POL_0_C-D6-2_54_NI/22 | NI/220uF,±20%,16V,LowESR | IC | 2 | C82; C83 |
C-D10XH16-5 | CAPACITOR POL_0_C-D10XH16-5_NC/ | NC/1000uF/16V | IC | 1 | C233 |
C-H25X13-5 | CAPACITOR POL_0_C-H25X13-5_3300 | 3300UF/16V | IC | 1 | C125 |
CN-3P-2_54S1 | CN_3P-2_0_CN-3P-2_54S1_J/3PIN,2 | J/3Pin,2.54mm | IC | 1 | J7 |
CN-4P-2_54 | HDR1X4_CN-4P-2_54_KPA1X4A1 | KPA1X4A1 | IC | 1 | J1 |
FILDMC_40 | MARK_FILDMC_40_MARK | MARK | IC | 6 | M1; M2; M3; M4; M5; M6 |
GMPTH120R276 | HOLE1_GMPTH120R276_GND_TERMINAL | gnd_terminal | IC | 4 | H1; H2; H3; H4 |
JACK-14_9X9-3P | CON-RCA-VERT-J_JACK-14_9X9-3P_J | J/DCJack/2.0 | IC | 1 | J3 |
L0603 | BEAD FILTER_0_L0603_600 OHM | 600 OHM | IC | 3 | BF1; BF6; BF8 |
L0603 | BEAD FILTER_0_L0603_300/1608 | 300/1608 | IC | 4 | BF11; BF12; BF13; BF14 |
L0805 | BEAD FILTER_0_L0805_600 OHM | 600 OHM | IC | 1 | BF7 |
L0805 | BEAD FILTER_0_L0805_0 OHM | 0 OHM | IC | 1 | BF9 |
L-11_5X6-2P | INDUCTOR IRON_L-11_5X6-2P_L/10U | L/10uH/10%/2A | IC | 2 | L4; L5 |
L-D7_5-5 | INDUCTOR_L-D7_5-5_NI/BEAD/DIP | NI/BEAD/DIP | IC | 2 | L29; L31 |
LED0603 | LED_1X_CATH1_AN2_HTMAX7-5_0_L_3 | LED/RED/207123000004L | IC | 1 | D23 |
LED-D4_2-2_54 | LED_1X_CATH1_AN2_HTMAX7-5_0_LED | LED/GREEN/207123000004L | IC | 6 | D15; D16; D17; D18; D19; D20 |
LED-D4_2-2_54 | LED_1X_CATH1_AN2_HTMAX7-5_0_L_1 | LED/RED/207123000004L | IC | 1 | D21 |
LED-D4_2-2_54 | LED_1X_CATH1_AN2_HTMAX7-5_0_L_2 | NI_LED/GREEN/207123000004L | IC | 1 | D22 |
OSC-7_5X5-4P | OSC-HALF_OSC-7_5X5-4P_25MHZ | 25MHz | IC | 1 | U5 |
OSC-11_4X5-3P | CRYSTAL_1_OSC-11_4X5-3P_25MHZ 1 | 25MHz 18pF | IC | 1 | Y2 |
QFP-16X16-128P-0_4-A | RTL8365MB_3_QFP-16X16-128P-0_4- | RTL8365MB-CG | IC | 1 | U10 |
R0402 | R_0_R0402_4.7K/J/1005 | 4.7K/J/1005 | IC | 32 | R1; R2; R3; R6; R13; R14; R15; R17; R18; R39; R40; R76; R78; R90; R91; R95; R97; R99; R100; R145; R161; R164; R181; R182; R184; R186; R188; R195; R196; R198; R199; R201 |
R0402 | R_1224_R0402_4K7 | 4K7 | IC | 12 | R4; R49; R50; R51; R52; R53; R58; R59; R60; R143; R158; R209 |
R0402 | R_0_R0402_22/J/1005 | 22/J/1005 | IC | 13 | R5; R7; R8; R9; R10; R11; R12; R16; R20; R22; R37; R38; R179 |
R0402 | R_0_R0402_2.8K/F/1005 | 2.8K/F/1005 | IC | 1 | R19 |
R0402 | R_0_R0402_5.76K/F/1005 | 5.76K/F/1005 | IC | 1 | R21 |
R0402 | R_0_R0402_100/F/1005 | 100/F/1005 | IC | 1 | R23 |
R0402 | R_0_R0402_R/22R/1%/0402 | R/22R/1%/0402 | IC | 14 | R24; R25; R57; R61; R73; R75; R87; R89; R93; R103; R104; R109; R110; R111 |
R0402 | R_0_R0402_0R/NC | 0R/NC | IC | 1 | R26 |
R0402 | R_0_R0402_R/10K/1%/0402 | R/10K/1%/0402 | IC | 1 | R27 |
R0402 | R_0_R0402_R/26.1K/1%/0402 | R/26.1K/1%/0402 | IC | 1 | R28 |
R0402 | R_0_R0402_R/100K/5%/0402 | R/100K/5%/0402 | IC | 2 | R29; R46 |
R0402 | R_0_R0402_R/6.98K/0402/1% | R/6.98K/0402/1% | IC | 1 | R30 |
R0402 | R_0_R0402_R/12K/1%/0402 | R/12K/1%/0402 | IC | 1 | R32 |
R0402 | R_0_R0402_R/1K/1%/0402 | R/1K/1%/0402 | IC | 1 | R33 |
R0402 | R_0_R0402_0 OHM | 0 ohm | IC | 1 | R34 |
R0402 | R_0_R0402_R/2.2K/0402/1% | R/2.2K/0402/1% | IC | 1 | R35 |
R0402 | R_1224_R0402_0 | 0 | IC | 3 | R43; R44; R55 |
R0402 | R_0_R0402_NI/R/100K/5%/0402 | NI/R/100K/5%/0402 | IC | 1 | R45 |
R0402 | R_1224_R0402_NI_0 | NI_0 | IC | 2 | R47; R54 |
R0402 | R_1224_R0402_30K | 30K | IC | 2 | R48; R228 |
R0402 | R_1224_R0402_22 | 22 | IC | 2 | R56; R159 |
R0402 | R_0_R0402_10K/J/1005 | 10K/J/1005 | IC | 5 | R66; R67; R106; R146; R162 |
R0402 | R_0_R0402_33/J/1608 | 33/J/1608 | IC | 1 | R69 |
R0402 | R_0_R0402_220 | 220 | IC | 6 | R72; R74; R77; R88; R101; R105 |
R0402 | R_0_R0402_NC/1005 | NC/1005 | IC | 20 | R79; R80; R81; R82; R85; R86; R96; R114; R115; R116; R117; R173; R180; R183; R185; R187; R191; R200; R202; R203 |
R0402 | R_0_R0402_4.7K/J/1005/NC | 4.7K/J/1005/NC | IC | 3 | R83; R92; R112 |
R0402 | R_0_R0402_4.7K/1005 | 4.7K/1005 | IC | 2 | R84; R98 |
R0402 | R_0_R0402_4.7K/1005/NC | 4.7K/1005/NC | IC | 1 | R94 |
R0402 | R_0_R0402_249/J/1005 | 249/J/1005 | IC | 1 | R102 |
R0402 | R_0_R0402_1K/J/1005 | 1K/J/1005 | IC | 7 | R107; R172; R175; R176; R177; R193; R197 |
R0402 | R_0_R0402_10K | 10K | IC | 1 | R108 |
R0402 | R_0_R0402_130/F/1005/NC | 130/F/1005/NC | IC | 2 | R118; R119 |
R0402 | R_0_R0402_22/J/1005/NC | 22/J/1005/NC | IC | 2 | R120; R151 |
R0402 | R_0_R0402_47K/J/1005 | 47K/J/1005 | IC | 1 | R121 |
R0402 | R_0_R0402_82/F/1005/NC | 82/F/1005/NC | IC | 2 | R122; R123 |
R0402 | R_0_R0402_33/J/1005 | 33/J/1005 | IC | 7 | R139; R163; R165; R166; R189; R190; R194 |
R0402 | R_1224_R0402_47K | 47K | IC | 1 | R142 |
R0402 | R_1224_R0402_0R/NC | 0R/NC | IC | 2 | R144; R147 |
R0402 | R_0_R0402_10K/NC | 10K/NC | IC | 1 | R148 |
R0402 | R_1_R0402_100K/J/1608 | 100K/J/1608 | IC | 1 | R149 |
R0402 | R_1224_R0402_220 | 220 | IC | 3 | R150; R168; R211 |
R0402 | R_0_R0402_2.4K | 2.4k | IC | 1 | R153 |
R0402 | R_0_R0402_5.1K | 5.1k | IC | 1 | R154 |
R0402 | R_0_R0402_4K7/J/1005 | 4K7/J/1005 | IC | 1 | R160 |
R0402 | R_0_R0402_NC/4K7/J/1005 | NC/4K7/J/1005 | IC | 1 | R167 |
R0402 | R_0_R0402_NC/4.7K | NC/4.7K | IC | 1 | R174 |
R0402 | R_0_R0402_4.7K | 4.7K | IC | 1 | R178 |
R0402 | R_0_R0402_2.49K/F/1005 | 2.49K/F/1005 | IC | 1 | R192 |
R0402 | R_0_R0402_0/J/1005 | 0/J/1005 | IC | 2 | R204; R205 |
R0402 | R_0_R0402_10K/J/1005/NC | 10K/J/1005/NC | IC | 1 | R206 |
R0402 | R_0_R0402_NC/0/J/1005 | NC/0/J/1005 | IC | 2 | R207; R208 |
R0402 | R_1224_R0402_NC | NC | IC | 1 | R210 |
R0402 | R_1224_R0402_20K | 20K | IC | 1 | R314 |
R0402 | R_1224_R0402_1K | 1K | IC | 1 | R321 |
R0402 | RES_0_R0402_NIL/R/270/1%/0402 | NIL/R/270/1%/0402 | IC | 4 | R337; R338; R343; R344 |
R0603 | R_0_R0603_75/F/1005 | 75/F/1005 | IC | 16 | R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R152; R155; R156; R157 |
R0603 | R_0_R0603_NC/0R | NC/0R | IC | 1 | R140 |
R0603 | R_0_R0603_0R | 0R | IC | 1 | R141 |
R1206 | R_0_R1206_R/0/5%/1206 | R/0/5%/1206 | IC | 4 | R31; R36; R41; R42 |
RJ45-37P-59_1X18_4 | RJ45_1_RJ45-37P-59_1X18_4_RJ45- | RJ45-1X4H-59X20_5 | IC | 1 | RJ1 |
SC70-5 | NC7SZ08P5X_AND_SC70_5_SC70-5_74 | 74LVC1G08DCK | IC | 1 | U19 |
SO-6X4_9-9P-1_27-A | MC34063A_0_SO-6X4_9-9P-1_27-A_L | LV7182SN | IC | 2 | U2; U6 |
SO-6X5-8P-1_27 | MAX708PCSA_3_SO-6X5-8P-1_27_MAX | MAX706RESR | IC | 1 | U7 |
SO-7_9X5_2-8P-1_27 | MX25L3235D_SO-7_9X5_2-8P-1_27_M | MX25L3206EM2I-12G | IC | 1 | U4 |
SOD123 | DIODE_2_SOD123_DIODE | DIODE | IC | 3 | D7; D8; D9 |
SOT23-5 | PAM3103_SOT23-5_AP133-WG-7 | AP133-WG-7 | IC | 1 | U8 |
SOT-23-3P | MOSFET P_0_SOT-23-3P_KRLML6401 | KRLML6401 | IC | 1 | Q1 |
SOT-23-3P | TR_NPN_BASEBIAS_0_SOT-23-3P_KMB | KMBT3904 | IC | 1 | Q2 |
SOT-23-3P | 2N1069_0_SOT-23-3P_BC846ALT1 | BC846ALT1 | IC | 1 | Q7 |
SOT-23-6P | SPD6PIN_SOT-23-6P_SPD6PIN | SPD6PIN | IC | 8 | U38; U39; U40; U41; U42; U43; U44; U45 |
SOT-353-5P | 74LVC1G32_SOT-353-5P_74LVC1G32G | 74LVC1G32GW | IC | 1 | U57 |
SOT-353-5P | 74LVC1G125_SOT-353-5P_74LVC1G12 | 74lvc1g125GW | IC | 1 | U58 |
SW-7_5X6_5-4PS1 | SW-PB-SPST-GG_2_SW-7_5X6_5-4PS1 | SW/PUSHBUTTON-SWITCH/DIP/4PIN | IC | 1 | SW7 |
SW-12_4X7_8-8PS1 | SW-DPDT-OXC-OXC-NN_0_SW-12_4X7_ | SW/POWER-Push | IC | 1 | SW1 |
T-28X12-48P-2 | XFMR-G2PM109N_T-28X12-48P-2_G2P | G2P109N LF | IC | 2 | TF1; TF2 |
TAN-A | CAP TANTALUM_0_TAN-A_10UF/16V | 10uF/16V | IC | 2 | CT2; CT3 |
TAN-A | CAP TANTALUM_0_TAN-A_10UF/10VK/ | 10uF/10VK/3216 | IC | 1 | CT5 |
TP_30 | TP_30_TP_30_TP_30 | TP_30 | IC | 5 | TP1; TP2; TP3; TP4; TP5 |
TP_30 | TP_1P_TP_30_3.3V | 3.3V | IC | 1 | TP6 |
TP_30 | TP_1P_TP_30_1.0V | 1.0V | IC | 1 | TP7 |
TV-PTB3I79-26PS1 | LTD34D3_TV-PTB3I79-26PS1_LTD34D | LTD34D3-SC+ | IC | 1 | U50 |
附件:
