作品名字:[pads VX.2.4][4层]H26M41103HPR高清广告机MSH6000A+MSO9280+MX25L016+SGM810R+PCB文件* b. Y* }% v- Z5 V2 k; P: A1 Z
) A" _3 b. v% S G A9 R文件描述
: |, b0 }$ h# s; g; d& Y! [
* A7 `4 _8 E0 s2 E: \; `* [0 R. i1.功能描述:高清广告机7 R$ O( N! `3 \ Q
% D; O7 y9 K H
2.软件版本:PADS VX.2.4
3 {! D: _4 B- O& k; ~, | 3 P- s# t' S# R P& z- \4 D ~
3.层数:4层板- v5 p( j7 c8 h2 t M* }
2 U9 B9 D' j3 p2 z3 I3 q' ^4.用到的主要芯片:MSH6000A+MSO9280+MX25L016 ' b2 ^1 @9 e: C2 V$ s/ ^ w8 z4 k9 _
5.PCB板尺寸:120mm*94mm
' N( i4 J2 y4 B5 z9 L" `, K & C* x" d7 D n: O5 E4 X
作品截图如下: ) c0 L3 T& g" [ X( m8 j
* g7 o1 q$ s5 b8 n# h顶层截图:* K2 f! M5 c7 N& m! m
5 f* [1 i1 a! i- `% q3 N0 t底层截图:; U9 W: C, e- g& Z# k# ~* |( I
7 G" I7 `/ I( X8 d
全层截图:
& x9 _% x, _& [$ |: o
' a* K5 Q5 p+ a3 i6 m# \叠层截图:0 T8 F( M. X9 V4 R" `
BOM: REFDES | COMP_DEVICE_TYPE | COMP_VALUE | 位号 | 类型 | 属性 | C1 | C0402 | 33PF | C2 | C0402 | 33PF | C3 | C0402 | NC/100NF | C4 | C0603 | NC/4.7UF/X5R | C5 | C0402 | 10P | C6 | C0402 | 10P | C7 | C0402 | 10P | C8 | C0402 | 10P | C9 | C0402 | 10P | C10 | C0402 | NC/100PF | C11 | C0402 | 2.2UF | C12 | C0402 | 2.2UF | C13 | C0402 | 1NF | C14 | C0402 | 1NF | C15 | C0402 | 2.2UF | C16 | C0402 | 2.2UF | C17 | C0402 | 1UF | C18 | C0402 | NC/2.2UF | C19 | C0402 | NC/100NF | C20 | C0805 | 10UF | C21 | C0402 | 100NF | C22 | C0805 | 22UF | C23 | C0402 | 100NF | C24 | C0402 | 100NF | C25 | C0402 | 100NF | C26 | C0402 | 100NF | C27 | C0402 | 100NF | C28 | C0603 | 4.7UF/X5R | C29 | C0603 | 10UF | C30 | C0402 | 1UF | C31 | C0402 | 100NF | C32 | C0402 | 2.2UF | C33 | C0603 | 4.7UF/X5R | C34 | C0402 | 100NF | C35 | C0805 | 22UF | C36 | C0402 | 100NF | C37 | C0402 | 100NF | C38 | C0402 | 100NF | C39 | C0603 | 4.7UF/X5R | C40 | C0603 | 10UF | C41 | C0805 | 22UF | C42 | C0603 | 10UF | C43 | C0402 | 100NF | C44 | C0402 | 100NF | C45 | C0603 | 4.7UF/X5R | C46 | C0402 | 100NF | C47 | C0402 | 100NF | C48 | C0402 | 100NF | C49 | C0402 | 100NF | C50 | C0402 | 1UF | C51 | C0402 | 1uF | C52 | C0402 | 100NF | C53 | C0402 | 1uF | C54 | C0402 | 1uF | C55 | C0402 | 100NF | C56 | C0402 | 1uF | C57 | C0402 | 100NF | C58 | C0402 | 100NF | C59 | C0402 | 100NF | C60 | C0402 | 100NF | C61 | C0402 | 100NF | C62 | C0402 | 100NF | C63 | C0402 | 100NF | C64 | C0402 | NC/2.2UF | C65 | C0402 | 2.2UF | C66 | C0402 | 1UF | C67 | C0402 | 100NF | C68 | C0402 | 100NF | C69 | C0402 | 100NF | C70 | C0402 | 100NF | C71 | C0603 | 10UF | C72 | C0603 | 10UF | C73 | C0402 | 100NF | C74 | C0402 | 100NF | C75 | C0603 | 4.7UF | C76 | C0805 | 22UF | C77 | C0402 | 1UF | C78 | C0402 | 100NF | C79 | C0402 | 100NF | C80 | C0402 | 100NF | C81 | C0402 | 100NF | C82 | C0402 | 100NF | C83 | C0402 | 100NF | C84 | C0603 | 4.7UF/X5R | C85 | C0402 | 100NF | C86 | C0805 | 10UF | C87 | C0402 | 100NF | C88 | C0402 | 100NF | C89 | C0402 | 100NF | C90 | C0402 | 47PF | C91 | C0402 | 47PF | C92 | C0402 | 100NF | C93 | C0402 | 1UF | C94 | C0402 | 47PF | C95 | C0805 | 10UF | C96 | C0805 | 10UF | C97 | C0402 | 1NF | C98 | C0402 | 470PF | C99 | C0402 | 470PF | C100 | C0402 | 1NF | C101 | C0402 | 47PF | C102 | C0402 | 1UF | C103 | C0402 | NC/100NF | C104 | C0805 | 10UF | C105 | C0402 | 100NF | C106 | C0603 | 100NF | C107 | C0402 | 100NF | C108 | C0402 | 10NF | C109 | C0402 | 100NF | C110 | C0402 | 10NF | C111 | C0402 | 100NF | C112 | C1206 | 1NF/2KV/1206 | C113 | C0402 | 1UF | C114 | C0402 | 100NF | C115 | C0402 | 100NF | C116 | C0402 | 1UF | C117 | C0402 | 100NF | C118 | C0603 | 10UF | C119 | C0603 | 10UF | C120 | C0402 | NC/100PF | C121 | C0402 | 100PF | C122 | C0402 | 100PF | C123 | C0402 | NC/100NF | C124 | C0402 | 100NF | C125 | C0402 | 1UF | C126 | C0402 | 100NF | C127 | C0402 | 100NF | C128 | C0402 | 1UF | C129 | C0402 | 1UF | C130 | C0402 | 100NF | C131 | C0402 | 47PF | C132 | C0402 | 100NF | C133 | C0402 | 0.1UF | C134 | C0402 | 100NF | C135 | C0402 | 100NF | C136 | C0805 | 22UF | C137 | C0402 | 100NF | C138 | C0402 | 100NF | C139 | C0805 | 22UF | C140 | C0805 | 22UF | C141 | C0402 | 1UF | C142 | C0402 | 100NF | C143 | C0402 | 1UF | C144 | C0402 | 100NF | C145 | C0805 | 10UF | C146 | C0402 | 100NF | C147 | C0402 | 100NF | C148 | C0805 | 10UF | C149 | C0402 | 100NF | C150 | C0805 | 22UF | C151 | C0402 | 1UF | C152 | C0402 | 100NF | C154 | C0402 | 10NF | C158 | C0402 | 1UF | C336 | C0402 | 100NF | CE2 | CE8-3.5 | 470UF/16V | CL1 | CL-2M2012 | NC | CL2 | CL-2M2012 | NC | CL3 | CL-2M2012 | NC | CL4 | CL-2M2012 | NC | CL5 | CL-2M2012 | NC | CM1 | C0402 | 100NF | CM2 | C0402 | 100NF | CM3 | C0402 | 100NF | CM4 | C0402 | 100NF | CM5 | C0402 | 100NF | CM6 | C0402 | 100NF | CM7 | C0402 | 100NF | CM8 | C0402 | 100NF | CM9 | C0402 | 100NF | CM10 | C0402 | 100NF | CM11 | C0402 | 100NF | CM12 | C0402 | 100NF | CM13 | C0402 | 100NF | CM14 | C0402 | 100NF | CM15 | C0402 | 100NF | CM16 | C0402 | 100NF | CM17 | C0402 | 100NF | CM18 | C0402 | 100NF | CM19 | C0402 | 100NF | CM20 | C0402 | 100NF | CM21 | C0402 | 100NF | CM22 | C0402 | 100NF | CM23 | C0402 | 100NF | CM24 | C0402 | 100NF | CM25 | C0402 | 100NF | CM26 | C0402 | 100NF | CM27 | C0402 | 100NF | CM28 | C0402 | 100NF | CM29 | C0402 | 100NF | CN1 | CON16X2_100_FEMALE | 16X2_2.54MM_FEMALE | CN2 | USB-4P-A-90D-VT001 | USB-B | CN3 | USB5PA | USB_OTG/AB | CN4 | HDMIL25MR | HDMI_CON | CN60 | USB_MINI_4P | USB-A | CON1 | HEADER2X10 | 2.54MM/180D/MALE | CON2 | B2.0V-L4P | CON4-2.0 | CON3 | HEADER2X11 | 2.54MM/2*11/MALE | CON4 | JACK-12P-RJ45 | RJ45_1X1-90D | CON5 | SK10056619_WGQ | SK10056619 | CT1 | CE-2.54X6.5 | 100UF/16V/LOW_ESR | CT2 | CE-2.54X6.5 | 100UF/16V/LOW_ESR | CT3 | CE-2.54X6.5 | NC/100UF/16V/LOW_ESR | CT4 | CE-2.54X6.5 | 220UF/16V/LOW_ESR | D1 | D-SMB | NC/IN4001 | D2 | D0402 | NC | D3 | D0402 | NC | D4 | SOT-23 | BAV99 | D5 | D0402 | NC | D6 | D0402 | NC | D7 | SURGE-1.05X0.65 | NC | D8 | SURGE-1.05X0.65 | NC | D9 | C1206 | NC | D10 | SOT-23 | BAV99 | E1 | ESDX4_2510 | CDDFN10-0524P/L05ESDL5V0NA-4 | E2 | ESDX4_2510 | CDDFN10-0524P/L05ESDL5V0NA-4 | E3 | D0402 | NC | E4 | D0402 | NC | E5 | D0402 | NC | EC1 | ECD6.3-2.5 | 220UF | EC2 | ECD6.3-2.5 | NC/220UF | EC3 | CE-3.5X8 | 470UF/16V | ESD1 | D0402 | NC | ESD2 | D0402 | NC | F1 | R0603 | NC | F2 | FB-1210 | 0R/FUSE | F3 | FB0805 | 1A_FUSE | H1 | H-1 | DEO | J1 | DIP1X10PM-80-V | WAFER/2.0MM/1*10P/180D | J3 | AV_JACK | CKS_3.5-73 | J4 | SPDIF | SPDIFX2 | J5 | DIP1X04PM-80-V | CON4-2.0 | J6 | JACK\DC | DC-JACK | J502 | DIP1X04PM-80-V_A | CON4-2.0 | L1 | L0402 | FB/120R/300MA | L2 | L0402 | FB/120R/300MA | L3 | L0402 | FB/120R/300MA | L4 | L0402 | NC/FB/120R/300MA | L5 | L0603 | FB/60R/3A | L6 | L0402 | 0.39UH | L7 | L0402 | FB/120R/300MA | L8 | L0603 | 0R | L9 | FB0805 | 0R | L10 | FB0805 | FB/60R/3A | L11 | FB0805 | 0R | L12 | L-LQH6PPN | 4.7UH/3A | L13 | FB0805 | FB/60R/3A | L14 | FB0805 | FB/60R/3A | L15 | SMD05X05 | CH/2.2UH/3A | L16 | FB0805 | 0R | L18 | L0402 | FB/120R/300MA | L19 | L0402 | NC/FB120R/300MA | L20 | L-LQH6PPN | 4.7UH/3A | L21 | L0603 | NC/FB/60R/3A | L22 | L0603 | NC/FB/60R/3A | LED101 | LED | LED/GREEN | LED102 | LED | LED/RED | LED103 | LED | LED/G | Q1 | SOT-23 | MMBT3904 | Q2 | SOT-23 | MMBT3904 | Q3 | SOT-23 | MMBT2907 | Q4 | SOT-23 | NC/MMBT2907 | Q5 | SOT-23 | NC/MMBT2907 | Q6 | SOT-23 | NC/MMBT3906 | Q8 | SOT23-100-GDS | AO3401 | Q9 | SOT23-100-GDS | AO3401 | Q10 | SOT23-100-GDS | AO3401 | Q12 | SOT-23 | NC/2N7002 | Q13 | SOT-23 | NC/2N7002 | Q17 | SOT-23 | MMBT3904 | Q18 | SOT-23 | MMBT3904 | R1 | R0402 | 0R | R2 | R0402 | 200R | R3 | R0402 | 22R | R4 | R0402 | 0R | R5 | R0402 | 5.1R | R6 | R0402 | 5.1R | R7 | R0402 | 0R | R8 | R0402 | 5.1R | R9 | R0402 | 5.1R | R10 | R0402 | 22R | R11 | R0402 | 22R | R12 | R0402 | 1K | R13 | R0402 | 22R | R14 | R0402 | 0R | R15 | R0402 | NC/100R | R16 | R0402 | 5.1R | R17 | R0402 | 5.1R | R18 | R0402 | 5.1R | R19 | R0402 | 5.1R | R20 | R0402 | NC/1M | R26 | R0402 | 22R | R28 | R0402 | 22R | R30 | R0402 | 22R | R31 | R0402 | 1K | R32 | R0402 | NC/1K | R33 | R0402 | 1K | R34 | R0402 | 1K | R35 | R0402 | NC/1K | R36 | R0402 | 1K | R38 | R0402 | 22R | R39 | R0402 | 1K | R40 | R0402 | 22R | R41 | R0402 | 22R | R42 | R0402 | 75R_1% | R43 | R0402 | 47K | R44 | R0402 | 1K | R45 | R0402 | 0R | R46 | R0402 | 0R | R47 | R0402 | 10K | R49 | R0402 | NC/220K | R50 | R0402 | NC/0R | R51 | R0402 | 0R | R52 | R0402 | NC/220K | R53 | R0402 | 1K5 | R54 | R0402 | 0R | R55 | R0402 | 22R | R56 | R0402 | NC/0R | R57 | R0402 | NC/1K | R58 | R0402 | NC/1K | R59 | R0402 | NC/1K | R60 | R0402 | NC/4.7K | R61 | R0402 | 22R | R62 | R0402 | 4.7K | R63 | R0402 | NC/4.7K | R64 | R0402 | 4.7K | R65 | R0402 | 22R | R66 | R0402 | 22R | R67 | R0402 | 22R | R68 | R0402 | 22R | R69 | R0402 | 22R | R70 | R0402 | NC/4.7K | R71 | R0402 | 4.7K | R72 | R0402 | 4.7K | R73 | R0402 | NC/4.7K | R74 | R0402 | 510R | R75 | R0402 | 510R | R76 | R0402 | 0R | R77 | R0402 | 0R | R79 | R0402 | 200K | R80 | R0402 | 4.7K | R81 | R0402 | 4.7K | R82 | R0402 | 1K | R83 | R0402 | 51K | R84 | R0402 | 100R | R85 | R0402 | 100R | R86 | R0402 | 22R | R87 | R0402 | NC/1K | R88 | R0402 | 10K | R89 | R0402 | 4.7K | R90 | R0402 | 22R | R91 | R0402 | 510R | R92 | R0402 | NC/10K | R93 | R0402 | 22R | R94 | R0402 | 1K | R95 | R0402 | 510R | R96 | R0402 | NC/10K | R97 | R0402 | 4.7K | R98 | R0402 | NC/10K | R99 | R0402 | 4.7K | R100 | R0402 | 0R | R101 | R0402 | 4.7K | R102 | R0402 | 0R | R103 | R0402 | NC/0R | R105 | R0402 | 510R | R106 | R0603 | 0R | R107 | R0402 | 0R | R108 | R0402 | 22R | R109 | R0402 | 0R | R110 | R0402 | NC/0R | R111 | R0402 | NC/0R | R112 | R0402 | NC/0R | R113 | R0402 | NC/0R | R114 | R0402 | NC/4.7K | R115 | R0402 | NC/0R | R117 | R0402 | 22R | R118 | R0402 | 22R | R119 | R0402 | 0R | R120 | R0402 | 0R | R121 | R0402 | NC/0R | R122 | R0402 | 0R | R123 | R0402 | 0R | R124 | R0402 | 0R | R125 | R0402 | 100R | R126 | R0402 | 10K | R128 | R0402 | 0R | R129 | R0402 | 10K | R130 | R0402 | 100R | R131 | R0402 | NC/0R | R132 | R0402 | NC/0R | R133 | R0402 | 10K | R134 | R0402 | 10K | R135 | R0402 | 0R | R136 | R0402 | 5.1R | R137 | R0402 | 5.1R | R138 | R0402 | 0R | R139 | R0402 | 1K | " r4 k: Z# d- o) U0 r% }
, Y* i' o; ] H: Q
6 d- q) E, `: @( z5 u( H附件: ! ^4 T# ~0 K- h, K/ s% ~
