查看: 247|回复: 0
[PADS VX.2.4][2层]ES8381方案DVD+DVB车载(AT24C01A+RT9701+78L05+MP1541+AM6928...
发表于 2020-2-28 11:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名字:[pads  VX.2.4][2层]ES8381方案DVD+DVB车载(AT24C01A+RT9701+78L05+MP1541+AM6928)原理图+PCB文件
% R9 u: d& U& S: E( l* ^ 2 k* O7 u# p) F+ l5 M# ^1 ^
文件描述
( V/ |3 ?, {" k. y$ @ 1 ~" Y% P6 ^/ C& Y) e* E% V. a
1.功能描述:DVD+DVB车载
" d0 |7 f3 U( _( ?" Z8 j+ U 4 Z0 w$ O, ?4 W6 y+ B
2.软件版本:PADS  VX.2.44 C2 _5 z& x" g$ Q" r* b2 r: D
* A' N( z2 C0 x! W3.层数:2层板! B; _1 H; T, d; v% U8 |& ^3 f
+ F: v1 M* Q4 K& i) U$ P
4.用到的主要芯片:AT24C01A+RT9701+78L05
: ]: l9 X2 v! `9 L  Y# m$ H& z5.PCB板尺寸:90mm*125mm
9 q) R1 Y/ g0 j1 I4 h8 k6 L5 R 0 L" x5 P3 w% w( X- ?; r5 c
作品截图如下:
' ^/ k, R* c1 ^5 i7 \2 `
: ]3 u: P* t. G" i% \* W. ^顶层截图:8 J5 I: B* A# B- n5 F
4 }) J6 A- v: L+ R8 A
  T6 G& d: _3 A$ [/ j8 `' _$ p底层截图:
+ b4 }! x- H9 T" u
1 c( z2 {% D, j全层截图:3 _9 N7 h. F& o
9 y% g$ j' S' A) S% G" N; x- l0 Z
叠层截图:
1 e# M2 v- q( [: |  S( I
BOM:
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
C10603-CAP
C2CAP-4.0-2.0
C30603-CAP
C4CAP-4.0-2.0
C50603-CAP
C6CAP-4.0-2.0
C70603-CAP
C80603-CAP
C9CAP-4.0-2.0
C100603-CAP
C110603-CAP
C120603-CAP
C13CAP-4.0-2.0
C140603-CAP
C150603-CAP
C160603-CAP
C170603-CAP
C180603-CAP
C200603-CAP
C210603-CAP
C220603-CAP
C230603-CAP
C240603-CAP
C250603-CAP
C260603-CAP
C270603-CAP
C280603-CAP
C290603-CAP
C300603-CAP
C310603-CAP
C320603-CAP
C33CAP-4.0-2.0
C340603-CAP
C350603-CAP
C360603-CAP
C370603-CAP
C380603-CAP
C390603-CAP
C40CAP-4.0-2.0
C410603-CAP
C420603-CAP
C430603-CAP
C440603-CAP
C450603-CAP
C460603-CAP
C470603-CAP
C48CAP-4.0-2.0
C490603-CAP
C500603-CAP
C510603-CAP
C520603-CAP
C530603-CAP
C540603-CAP
C550603-CAP
C560603-CAP
C570603-CAP
C580603-CAP
C590603-CAP
C610603-CAP
C620603-CAP
C640603-CAP
C650603-CAP
C66CAP-4.0-2.0
C67CAP-4.0-2.0
C700603-CAP
C71CAP-5.7-2.5
C720603-CAP
C731210
C740603-CAP
C750603-CAP
C76CAP-5.7-2.5
C770603-CAP
C79CAP-4.0-2.0
C80CAP-5.7-2.5
C810603-CAP
C820603-CAP
C830603-CAP
C840603-CAP
C850603-CAP
C86CAP-5.7-2.5
C870603-CAP
C88CAP-4.0-2.0
C890603-CAP
C900603-CAP
C910603-CAP
C920603-CAP
C931210
C940603-CAP
C950603-CAP
C980603-CAP
C1001210
C1010603-CAP
C1021210
C1030603-CAP
C1041210
C1050603-CAP
C106CAP-5.7-2.5
C1070603-CAP
C1080603-CAP
C1090603-CAP
C1100603-CAP
C1110603-CAP
C1120603-CAP
C113CAP-4.0-2.0
C1140603-CAP
C1150603-CAP
C116CAP-5.7-2.5
C117CAP-5.7-2.5
C1180603-CAP
C119CAP-4.0-2.0
C1200603-CAP
C1210603-CAP
C122CAP-4.0-2.0
C123CAP-4.0-2.0
C1240603-CAP
C1250603-CAP
C126CAP-4.0-2.0
C127CAP-4.0-2.0
C1280603-CAP
C129CAP-4.0-2.0
C1300603-CAP
C1310603-CAP
C1320603-CAP
C1330603-CAP
C134CAP-5.7-2.5
C1350603-CAP
C136CAP-5.7-2.5
C1370603-CAP
C1380603-CAP
C1390603-CAP
C1440603-CAP
C1450603-CAP
C1460603-CAP
C1470603-CAP
C1480603-CAP
C149CAP-5.7-2.5
C1500603-CAP
C151CAP-5.7-2.5
C1520603-CAP
C1530603-CAP
C1540603-CAP
C1550603-CAP
C156CAP-5.7-2.5
C157CAP-4.0-2.0
C1580603-CAP
C1590603-CAP
C1600603-CAP
C1610603-CAP
C1620603-CAP
C164CAP-4.0-2.0
C1650603-CAP
C1670603-CAP
C168CAP-4.0-2.0
C169CAP-5.7-2.5
C1700603-CAP
C1710603-CAP
C1720603-CAP
C1730603-CAP
C1740603-CAP
C1750603-CAP
C1770603-CAP
C178CAP-8.0-3.5
C1790603-CAP
C180CAP-4.0-2.0
C1810603-CAP
C182CAP-4.0-2.0
C183CAP-4.0-2.0
C1840603-CAP
C185CAP-4.0-2.0
C1860603-CAP
C187CAP-4.0-2.0
C1880603-CAP
C1890603-CAP
C1900603-CAP
C1930603-CAP
C198CAP-5.7-2.5
C206CAP-5.7-2.5
C2110603-CAP
C2120603-CAP
C2130603-CAP
C2140603-CAP
C2180603-CAP
C2190603-CAP
C2200603-CAP
C225CAP-5.7-2.5
C2260603-CAP
C2270603-CAP
C228CAP-5.7-2.5
C229CAP-5.7-2.5
C2330603-CAP
C2340603-CAP
C2350603-CAP
C2370603-CAP
C2400603-CAP
C2410603-CAP
C2420603-CAP
C2480603-CAP
C2490603-CAP
C2500603-CAP
C252CAP-5.7-2.5
C2530603-CAP
C254CAP-5.7-2.5
C2550603-CAP
C256CAP-4.0-2.0
C2570603-CAP
C258CAP-4.0-2.0
C261CAP-4.0-2.0
C2620603-CAP
C2630603-CAP
C264CAP-4.0-2.0
C265CAP-4.0-2.0
C2660603-CAP
CON1HEAD9-50
CON2USB-M
CON3PWRJACK
CON4HEAD3-80
CON5EG1213
CON6CON-24-0.5-SMD\FPC
CON7CON-24-0.5-SMD\FPC
CON8CON-24-0.5-SMD\FPC
CON9CON-13-1.0-SMD\FPC
CON10HEAD6-80
CON11CK-3.5-21
CON12AV-SMD
CON13TUNER-H
CON14VOL-2
CON153IN1_CARD
CON16CON-26-0.5-SMD\FPC
CON17HEAD2-50
CON18HEAD2-50
CON19CON-8-1.0-SMD\FPC
CON20PHONES
D2D5817
D3D5817
D4D5817
D5TRA\SMD
D6TRA\SMD
D7TRA\SMD
D8TRA\SMD
D9D5817
D12D5817
D13D5817
D16DIODE\SMD
D17DIODE\SMD
D18DIODE\SMD
D19DIODE\SMD
D20DIODE\SMD
D21DIODE\SMD
DMOTP-B
DRFNTP-B
DRFPTP-B
FB1FB-0805
FB2FB-0603
FB3FB-0603
FB4FB-0603
FB5FB-0603
FB6FB-0603
FB7FB-0603
FB8FB-0603
FB9FB-0805
FB10FB-0603
FB11FB-0805
FB12FB-0805
FB16FB-0603
FB17FB-0603
FB18FB-0805
FB19FB-0805
FB20FB-0603
FETP-B
FOOTP-B
FUSE11210
L1CDRH8D28
L2CDRH8D28
L3FB-0603
L4FB-0603
L5CDRH8D28
L6CDRH8D28
L7FB-0603
L8FB-0805
L9FB-0805
L10FB-0805
L11FB-0805
L12FB-0805
L13FB-0603
L14FB-0603
L15FB-0603
L16FB-0603
L17FB-0603
L18FB-0603
L19FB-0603
L20FB-0603
LJP1JUMP-3P-DIP
PITP-B
Q2TRA\SMD
Q3TRA\SMD
Q4TRA\SMD
Q9TRA\SMD
Q10TRA\SMD
Q11TRA\SMD
Q12TRA\SMD
Q13TRA\SMD
Q14TRA\SMD
Q15TRA\SMD
Q16TRA\SMD
Q17TRA\SMD
Q18TRA\SMD
Q19TRA\SMD
Q20TRA\SMD
Q21TRA\SMD
Q22TRA\SMD
Q23TRA\SMD
Q24TRA\SMD
Q25TRA\SMD
Q27SOT23
Q28TRA\SMD
Q29TRA\SMD
Q30TRA\SMD
Q31TRA\SMD
Q32TRA\SMD
R10603-RES
R20603-RES
R30603-RES
R40603-RES
R50603-RES
R60603-RES
R70603-RES
R80603-RES
R90603-RES
R100603-RES
R110603-RES
R120603-RES
R130603-RES
R140603-RES
R150603-RES
R160603-RES
R170603-RES
R180603-RES
R190603-RES
R200603-RES
R210603-RES
R220603-RES
R230603-RES
R240603-RES
R250603-RES
R260603-RES
R270603-RES
R280603-RES
R300603-RES
R310603-RES
R320603-RES
R330603-RES
R340603-RES
R350603-RES
R360603-RES
R370603-RES
R380603-RES
R390603-RES
R400603-RES
R410603-RES
R420603-RES
R430603-RES
R440603-RES
R450603-RES
R460603-RES
R470603-RES
R480603-RES
R490603-RES
R500603-RES
R510603-RES
R520603-RES
R530603-RES
R540603-RES
R550603-RES
R560603-RES
R570603-RES
R580603-RES
R590603-RES
R600603-RES
R610603-RES
R620603-RES
R630603-RES
R640603-RES
R650603-RES
R660603-RES
R670603-RES
R680603-RES
R690603-RES
R700603-RES
R710603-RES
R720603-RES
R730603-RES
R740603-RES
R750603-RES
R770603-RES
R780603-RES
R790603-RES
R800603-RES
; G/ N2 O( y6 [; p: S
6 p0 V/ l+ S! N! @
1 D+ I9 k0 @& w* Q; a) Z2 I
7 [' Q6 c/ q4 `: k6 n! X
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
% ]5 K; V9 w" m: j
GMT+8, 2025-7-27 19:15 , Processed in 0.140625 second(s), 28 queries , Gzip On.
