查看: 213|回复: 0
[PADS VX.2.4][2层]CXA2069带GPS车载(REM3310+ET312+78D05+LM2575+TDA7419+4558+...
发表于 2020-2-28 10:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名字:[pads  VX.2.4][2层]CXA2069带GPS车载(REM3310+ET312+78D05+LM2575+TDA7419+4558+LM1117)原理图+PCB文件
% {1 S9 u% Z7 F. J+ x+ l : [2 j; S2 T+ R9 O7 t
文件描述6 i$ w# B1 O7 }% Y& x' |6 j& [
1 Y2 T. A+ e: Y0 A# A1.功能描述:GPS车载  O/ k" V4 Y8 q8 F
4 b1 d1 t+ ?' K" [3 H
2.软件版本:PADS  VX.2.4$ r( R) p3 R! w  Y3 o* j- _
+ B! M, {8 v2 B9 _4 D3.层数:2层板$ s# {2 j2 Y! Z8 w# W8 e0 g; [
" s2 a$ O/ q+ m3 d3 K# `- s
4.用到的主要芯片:REM3310+ET312+78D05
1 Y: W" V0 N" l% }
5.PCB板尺寸:160mm*140mm2 o6 p9 o, G' r8 ^
1 O: {& l6 L: Y: f
作品截图如下:
! C: {, P" P8 p3 ~! b1 f 4 D# h( Y+ u3 V# r( ^/ U! p
顶层截图:
0 s# h7 o6 g3 M; E0 D + A  j$ p, s5 P% Y
底层截图:7 f! L+ D0 o% R$ v+ k
! X4 C2 d( T2 }; c( X2 L7 O全层截图:
0 `. Y2 c0 U: ^3 A/ f6 r; n
" W# ^: ~, J; X) C- d7 t叠层截图:
) A' O* s; {( v
BOM:
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
A1VIA1.0DR
A2VIA1.0DR
A3VIA1.0DR
A4VIA1.0DR
A5VIA1.0DR
A6VIA1.0DR
A7VIA1.0DR
A8VIA1.0DR
A9VIA1.0DR
A10VIA1.0DR
A11VIA1.0DR
A12VIA1.0DR
A13VIA1.0DR
A14VIA1.0DR
A15VIA1.0DR
A16VIA1.0DR
A17VIA1.0DR
A18VIA1.0DR
A19VIA1.0DR
A20VIA1.0DR
A21VIA1.0DR
A22VIA1.0DR
A23VIA1.0DR
A24VIA1.0DR
A25VIA1.0DR
A26VIA1.0DR
A27VIA1.0DR
A28VIA1.0DR
A29VIA1.0DR
A30VIA1.0DR
A31VIA1.0DR
A32VIA1.0DR
A35VIA1.0DR
A36VIA1.0DR
A37VIA1.0DR
A38VIA1.0DR
A39VIA1.0DR
A40VIA1.0DR
A41VIA1.0DR
A42VIA1.0DR
A43VIA1.0DR
ANT1CON_GPS_ANT_4PGPS_ANT
C1C0603103
C2C0603104
C3C0603104
C4C0603104
C5C0603104
C6C0603104
C7C0603224
C8C0603224
C9C0603224
C10C0603104
C11C0603103
C12C0603104
C13C0603104
C14C0603104
C15C0603104
C16C0603103
C17C0603103
C18C0603104
C19C0603224
C20C0603104
C21C0603102
C22C0805105
C23C0603103
C24C0603104
C25C0805225
C26C0603104
C27C0603104
C28C0603103
C29C0603102
C30C0603103
C31C0603102
C32C0805225
C33C0603103
C34C0603105
C35C0603104
C36C0603103
C37C0603104
C38C0603102
C39C0603100P
C40C0603100P
C41C0603104
C42C0603103
C43C0603103
C44C0603103
C45C0603103
C46C0603103
C47C0805474
C48C0603103
C49C0603221
C50C0603102
C51C0805105
C52C0603104
C53C0603102
C54C0603221
C55C0805105
C56C0603104
C57C0603221
C58C0603102
C59C0603102
C60C0603221
C61C0805105
C62C0603104
C63C0603104
C64C0603102
C65C0603103
C66C0603103
C67C0603104
C68C0603104
C69C0603103
C70C0603104
C71C0603224
C72C0603100P
C73C0603100P
C74C0603102
C75C0603102
C76C0603102
C77C0603102
C78C0805105
C79C0603102
C80C0603102
C81C0603102
C82C0603102
C83C0603102
C84C0603102
C85C0603102
C86C0603100P
C87C0603100P
C88C0603681
C89C0603102
C90C0603102
C91C0603102
C92C0805225
C93C0805225
C94C0805225
C95C0805225
C96C0805225
C97C0805105
C98C0603102
C100C0603ULCE10005A015FR(NC)
C102C0603104
C112C0603104
C113C0603105
C114C0603105
C115C0603105
C116C0603105
C117C0603474
C118C0603105
C119C0603104
C120C0603105
C121C0603474
C122C0603105
C123C0603105
C124C0603474
C125C0603105
C126C0603105
C127C0603474
C128C0603224
C129C0603224
C130C0805105
C132C0603104
C133C0603105
C134C0603474
C135C0603105
C136C0603105
C137C0603474
C150C0603105
C151C0603224
C152C0603224
C170C0603105
C171C0603104
C172C0603104
C173C0603104
C174C0603104
CD1CAP_SMD_C6.3220U/16V
CD2CAP_SMD_C6.3220U/16V
CD3CAP_SMD_C4.522U/16V
CD4CAP_SMD_C5.547U/16V
CD5CAP_SMD_C6.3220U/16V
CD6CAP_SMD_C6.3220U/16V
CD7CAP_SMD_C6.3220U/16V
CD8CT120610U/16V(3216)
CD9CAP_SMD_C6.3220U/16V
CD10CAP_SMD_C6.3220U/16V
CD11CAP_SMD_C6.3220U/16V
CD12CAP_SMD_C6.3220U/16V
CD13CAP_SMD_C4.547U/10V
CD14CAP_SMD_C4.547U/16V
CD15CAP_SMD_C6.3220U/16V
CD16CAP_SMD_C4.522U/16V
CD17CAP_SMD_C6.3220U/16V
CD18CAP_SMD_C6.3220U/16V
CD19CAP_SMD_C5.547U/16V
CD20CAP_SMD_C4.547U/10V
CD21CAP_SMD_C5.547U/16V
CD22CAP_SMD_C5.547U/16V
CD23CAP_SMD_C5.547U/16V
CD24CAP_SMD_C5.547U/16V
CD25CAP_SMD_C6.3100U/16V
CD26CAP_SMD_C6.3220U/16V
CD27CAP_SMD_C6.3220U/16V
CD28CAP_SMD_C4.510U/16V
CD29CAP_SMD_C4.510U/16V
CD30CAP_SMD_C4.510U/16V
CD31CAP_SMD_C6.3100U/16V
CD32CAP_SMD_C4.510U/16V
CD33CAP_SMD_C4.510U/16V
CD34CAP_SMD_C4.547U/16V
CD35CAP_SMD_C4.522U/16V
CD36CAP_SMD_C6.3220U/16V
CD37CAP_SMD_C6.3220U/16V
CD38CAP_SMD_C6.3220U/16V
CD39CAP_SMD_C6.3220U/16V(NC)
CD40CD7.5/173300U/25V
CD41CAP_SMD_C6.3220U/16V
CD43CAP_SMD_C6.3220U/16V
CD45CAP_SMD_C6.3220U/16V
CD61CAP_SMD_C4.522U/16V
CD63CAP_SMD_C6.3220U/16V
CD66CAP_SMD_C4.522U/16V
CD67CAP_SMD_C6.3220U/16V
CD80CAP_SMD_C4.522U/16V
CD81CAP_SMD_C4.522U/16V
CON5SIP2P_2.54SIP2P-2.54
D1SOT-23BAV99
D2LL-344148(NC)
D3DO-214IN5822
D4SOT-23BAV99
D5LL-344148
D6DO-214IN5822
D7LL-344148
D8DO-214IN4007
D9DO-214IN4007(SMD)
D10SOT-23BAV99
D11SOT-23BAV99
D12LL-344148
D14LL-344148
D15LL-344148
D16SOT-23BAV99
D18DO-214IN4007
D20DIODE_DIP_AIN5822
D21LL-346.8V
D22LL-344148
D23LL-344148
D24LL-344148
D25LL-344148
D26LL-344148
D27LL-344148
F2FUSE12102A
F3FUSE12102A
FB40FB080518UH(100mA)
FB41FB0805BEAD
GJ3FFC40_0.5
GPS1REM3310GM25
GPS2ET_312
GR40R060333R
GR41R060333R
J1CON6-1.25S/2
J2SIP7P-2.0
J3FFC7-1.0
J422PINDIPCON-JMR
J5CON8-1.25S
J7TL-22ETL-22E
J8CDC-CONCDC
J10SIP2P_VIA4
J11CON4-1.25S
J14CON5-1.25S/2
J17GPS_TWO_DIN/DIPDIP50Px2_1.27mm
J21CON2-1.25SSIP2P-1.25
J22FLC-BTMDC705-I2UFLC-BTMDC705-I2U
L1SMDL12MM100UH/2A
L2SMDL12MM33UH/2A
L3SMDL12MM100UH/2A
L4SMDL12MM100UH/2A
L5SMDL4.8X4.8.1.847UH/0.3A
L7SMDL12MM100UH/2A
L10EI-28AEI-28A
MARK1MARK
MARK2MARK
Q1SOT-892SA1797
Q2SOT-239014
Q3SOT-238550
Q4SOT-239014
Q5SOT-239014
Q6SOT-239014(NC)
Q7SOT-239014
Q8SOT-239014(NC)
Q9SOT-428C2SD1803
Q10SOT-239014
Q11SOT-239014
Q12SOT-239014
Q13SOT-239014
Q14SOT-239014
Q15SOT-239014
Q16SOT-892sc4672(NC)
Q17SOT-239014
Q18SOT-892SA1797
Q19SOT-239014
Q20SOT-239014
Q21SOT-892SA1797
Q22SOT-8978L05
Q23SOT-239014
Q24SOT-892SA1797
Q25SOT-239014
Q26SOT-239014
Q27SOT-239014
Q29SOT-239014
Q30SOT-239014
Q31SOT-239014
Q32SOT-239014
Q34SOT-239014
Q35SOT-238550
Q36SOT-239014
Q38SOT-239014
Q39SOT-239014
Q41SOT-239014
Q42SOT-892SA1797
Q43SOT-239014
Q44SOT-239014
Q45SOT-238550
Q46SOT-239014
Q49SOT-239014
Q50SOT-239014
Q51SOT-239014
Q52SOT-239014
R1R060310K
R2R0603100K(NC)
R3R06034.7K
R4R06034.7K
R5R06031.5K
R6R06034.7K
R7R06030R
R8R060347K
R9R06034.7K
R10R06036.8K
R11R060310K
R12R060320K
R13R06031K
R14R060310K
R15R06031K
R16R060333R
R17R06036.8K
R18R060310K
R19R060310K
R20R060310K
R21R06031K
R22R060375R
R23R0603100K
R24R060333K
R25R0603100K
R26R060310K
R27R0603100K
R28R06034.7K
R29R060310K
R30R06031K
R31R06031K
R32R060322K
R33R0603470K
R34R060310K
R35R0603200K
R36R08052.2R
R37R06031K
R38R06031K
R39R060310K(NC)
R40R060347K
R41R060310K
R42R0603680K
R43R0603470R
R44R060322K
R45R06034.7K
R46R08050R
R47R060320K
R48R06036.8K
R49R060333K
R50R060310K
R51R06036.8K
R52R060310K
R53R060310K
R54R060310K
R55R06031.5K
R56R06032.2K
R57R060310K
R58R06032.2K
R59R06031K
R60R06031K
R61R06030R
R62R060347K
R63R08052.2R
R64R060310R
R65R060310K(NC)
R66R0603100K(NC)
R67R06030R
R68R060310K
R69R0603100R
R70R06031K
R71R06031.5K
! B3 w, A+ i! I0 [4 ]
/ ]" s' t% R: p" R5 C
; V) {+ e( @0 `, V- t, }
; g% h. n2 N( c' d$ B
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
9 B! Y# ^  P4 r! T
GMT+8, 2025-7-27 20:02 , Processed in 0.125000 second(s), 28 queries , Gzip On.
