Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
2_RJ45 | HR872130H_2_RJ45_HR872130H | HR872130H | IC | 1 | J6 |
4-SMD-3225 | OSC_27M_SMD3225_4-SMD-3225_27M | 27M | IC | 9 | X4; X5; X6; X7; X9; X11; X15; X16; X17 |
4-SMD-3225 | OSC_50M_SMD3225_4-SMD-3225_50M | 50M | IC | 1 | X12 |
4-SMD-3225 | F_CRYSTAL 4-PIN_4-SMD-3225_25M | 25M | IC | 1 | Y1 |
4_SMD_3225 | F_CRYSTAL 4-PIN_4_SMD_3225_27M | 27M | IC | 1 | Y4 |
32KCYR | CRYSTAL_32KCYR_38K | 38K | IC | 1 | Y2 |
32KCYR | CRYSTAL_32KCYR_VT-200-F_32.768K | VT-200-F_32.768k | IC | 1 | Y3 |
100LBGA | GV7601_100LBGA_GV7601/LBGA | GV7601/LBGA | IC | 4 | U35; U36; U37; U38 |
4526 | PTZ6.8B_4526_PTZ6.8B | PTZ6.8B | IC | 2 | D1; D2 |
4526 | DIODE_B_4526_4526_SS14 | SS14 | IC | 4 | D7; D8; D10; D11 |
4526 | DIODE_B_4526_4526_P6KE6.8CA | P6KE6.8CA | IC | 5 | D9; D12; D14; D15; D16 |
4526 | SCHOKKTY_DIODE_4526_SMBJ12CA | SMBJ12CA | IC | 2 | D17; D18 |
4526 | SCHOKKTY_DIODE_4526_SS12 | SS12 | IC | 4 | D19; D20; D21; D22 |
A6S-4104-H | SWITCH-4P_A6S-4104-H_SWITCH-4P | SWITCH-4P | IC | 5 | J2; J3; J4; J18; J24 |
ATX-20PIN | 20PIN-ATX-PWR_ATX-20PIN_20PIN-A | 20PIN-ATX-PWR | IC | 1 | JP1 |
B3F-4055 | KEY-4055_B3F-4055_KEY-4055 | KEY-4055 | IC | 2 | K1; K2 |
BNC_75R_DUAL | BNC_75R_DUAL_BNC_75R_DUAL_BNC_7 | BNC_75R_DUAL | IC | 2 | J11; J12 |
BUZZER | BUZZER_BUZZER_BUZZER | BUZZER | IC | 1 | BU1 |
CAP-A | CAP_10UF/16V_A_CAP-A_10UF/16V | 10UF/16V | IC | 44 | C623; C791; C822; C823; C836; C838; C844; C850; C852; C854; C865; C883; C887; C900; C906; C920; C930; C937; C940; C977; C1248; C1258; C1259; C1264; C1272; C1275; C1336; C1340; C1343; C1344; C1358; C1366; C1386; C1404; C1405; C1419; C1436; C1447; C1449; C1465; C1468; C1472; C1485; C1486 |
CE_2M54_6M | CAP_XUF/XV_CE_2M54_6M_10UF/50V | 10UF/50V | IC | 17 | C1004; C1006; C1013; C1015; C1026; C1029; C1036; C1040; C1047; C1048; C1051; C1052; C1087; C1089; C1110; C1114; C1140 |
CE_3M5_8M | CAP_CE_3M5_8M_220UF/25V | 220UF/25V | IC | 2 | C1204; C1232 |
CE_5M08_10M | CAP_XUF/XV_CE_5M08_10M_1000UF/1 | 1000UF/10V | IC | 2 | C1124; C1131 |
CE_5M08_10M | CAP_CE_5M08_10M_470UF/25V | 470UF/25V | IC | 4 | C1132; C1133; C1149; C1153 |
CMC_2012_A | CMC2012_CMC_2012_A_CMC2012 | CMC2012 | DISCRETE | 16 | I1; I2; I3; I4; I5; I6; I7; I8; I9; I10; I11; I12; I13; I14; I15; I16 |
CON1X2_2M54 | CON-2_CON1X2_2M54_CON-2 | CON-2 | IC | 3 | J33; J34; J43 |
CON1X2_2M54_FAN | CON-2_CON1X2_2M54_FAN_CON_2_FAN | CON_2_FAN | IC | 2 | J31; J32 |
CON1X4_2M54 | CON_4_CON1X4_2M54_CON_4 | CON_4 | IC | 4 | J35; J36; J38; J41 |
CON1X6_2M00 | CON-6_CON1X6_2M00_CON-6 | CON-6 | IC | 3 | J37; J39; J40 |
CON2X2_3M81 | CON_4_CON2X2_3M81_CON_4_2X2 | CON_4_2X2 | IC | 4 | J7; J28; J29; J30 |
CR-2032 | BATTERY_CR-2032_BATTERY | BATTERY | IC | 1 | B1 |
C_3528 | CAP_C_3528_47UF | 47uF | IC | 37 | C92; C93; C104; C116; C127; C137; C557; C558; C560; C569; C571; C574; C576; C591; C592; C594; C603; C605; C607; C609; C632; C662; C692; C722; C866; C888; C1125; C1207; C1209; C1211; C1239; C1240; C1251; C1252; C1260; C1341; C1453 |
C_3528 | CAP_C_3528_100UF | 100UF | IC | 15 | C205; C214; C235; C244; C927; C1173; C1177; C1181; C1192; C1199; C1200; C1222; C1266; C1313; C1334 |
C_3528 | CAP_C_3528_47UF/10V | 47UF/10V | IC | 2 | C1163; C1167 |
C_7343 | CAP_C_7343_100UF/16V | 100UF/16V | IC | 3 | C1129; C1477; C1478 |
C_EIA0201 | CAP_104_0201_C_EIA0201_104 | 104 | IC | 282 | C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C26; C27; C28; C60; C65; C67; C68; C72; C73; C74; C78; C79; C80; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126; C128; C129; C130; C131; C132; C133; C134; C135; C136; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C183; C184; C185; C186; C187; C188; C189; C190; C191; C192; C193; C194; C195; C196; C197; C198; C199; C200; C201; C202; C203; C204; C206; C207; C208; C209; C210; C211; C212; C213; C215; C216; C217; C218; C219; C220; C221; C222; C223; C224; C225; C226; C227; C228; C229; C230; C231; C232; C233; C234; C236; C237; C238; C239; C240; C241; C242; C243; C245; C246; C247; C248; C249; C250; C251; C252; C253; C254; C255; C256; C257; C258; C259; C260; C261; C262; C263; C264; C265; C266; C267; C268; C269; C270; C271; C272; C273; C274; C275; C377; C378; C379; C380; C381; C382; C383; C384; C385; C386; C387; C388; C389; C390; C391; C392; C393; C394; C395; C396; C397; C398; C399; C400; C489; C490; C491; C492; C493; C494; C495; C496; C497; C498; C499; C500; C501; C502; C503; C504; C505; C506; C507; C508; C509; C510; C511; C512; C513; C514; C515; C516; C517; C518; C519; C520; C521; C522; C523; C524; C525; C526; C527; C528; C529; C530; C531; C532; C533; C534; C535; C536; C537; C538 |
C_EIA0402 | CAP NP_C_EIA0402_0.1UF | 0.1uF | DISCRETE | 147 | C4; C5; C9; C25; C33; C35; C41; C45; C46; C50; C867; C868; C869; C870; C871; C872; C873; C874; C875; C876; C877; C878; C879; C880; C884; C885; C886; C889; C890; C891; C892; C893; C894; C895; C896; C897; C898; C901; C902; C907; C911; C915; C916; C917; C918; C919; C923; C928; C929; C931; C932; C933; C934; C935; C936; C938; C939; C941; C942; C943; C944; C1281; C1282; C1283; C1284; C1285; C1286; C1287; C1288; C1289; C1297; C1315; C1316; C1317; C1321; C1322; C1323; C1324; C1328; C1329; C1330; C1338; C1339; C1346; C1347; C1348; C1349; C1350; C1351; C1352; C1353; C1354; C1355; C1356; C1357; C1360; C1361; C1362; C1363; C1364; C1365; C1368; C1369; C1370; C1371; C1372; C1373; C1374; C1375; C1376; C1377; C1378; C1379; C1380; C1381; C1382; C1383; C1384; C1385; C1388; C1389; C1390; C1391; C1392; C1393; C1400; C1401; C1402; C1403; C1406; C1407; C1408; C1409; C1410; C1414; C1415; C1416; C1417; C1424; C1425; C1426; C1427; C1428; C1429; C1438; C1439; C1443 |
C_EIA0402 | CAP NP_C_EIA0402_0.01UF | 0.01uF | DISCRETE | 311 | C7; C8; C24; C44; C47; C61; C70; C76; C289; C290; C291; C292; C293; C294; C295; C296; C297; C298; C299; C300; C301; C302; C303; C304; C305; C306; C307; C308; C309; C310; C311; C312; C313; C314; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C325; C326; C327; C328; C329; C330; C331; C332; C333; C334; C335; C336; C337; C338; C339; C340; C341; C342; C343; C344; C345; C346; C347; C348; C349; C350; C351; C352; C353; C354; C355; C356; C357; C358; C359; C360; C361; C362; C363; C364; C365; C366; C367; C368; C369; C370; C371; C373; C374; C375; C401; C402; C403; C404; C405; C406; C407; C408; C409; C410; C411; C412; C413; C414; C415; C416; C417; C418; C419; C420; C421; C422; C423; C424; C425; C426; C427; C428; C429; C430; C431; C432; C433; C434; C435; C436; C437; C438; C439; C440; C441; C442; C443; C444; C445; C446; C447; C448; C449; C450; C451; C452; C453; C454; C455; C456; C457; C458; C459; C460; C461; C462; C463; C464; C465; C466; C467; C468; C469; C470; C471; C472; C473; C474; C475; C476; C477; C478; C479; C480; C481; C482; C483; C485; C486; C487; C635; C636; C637; C638; C641; C642; C643; C644; C647; C649; C650; C651; C656; C658; C659; C660; C665; C666; C667; C668; C671; C672; C673; C674; C677; C679; C680; C681; C686; C688; C689; C690; C695; C696; C697; C698; C701; C702; C703; C704; C707; C709; C710; C711; C716; C718; C719; C720; C725; C726; C727; C728; C731; C732; C733; C734; C737; C739; C740; C741; C746; C748; C749; C750; C924; C925; C926; C951; C952; C954; C955; C958; C959; C960; C961; C962; C963; C964; C965; C980; C981; C982; C983; C984; C985; C986; C987; C989; C990; C991; C992; C1123; C1298; C1299; C1301; C1302; C1303; C1304; C1318; C1325; C1326; C1331; C1332; C1394; C1395; C1396; C1397; C1398; C1399; C1411; C1412; C1413; C1418; C1420; C1421; C1422; C1430; C1431; C1432; C1433; C1434; C1435; C1440; C1441; C1444; C1445; C1493; C1494; C1495; C1496; C1497 |
C_EIA0402 | CAP NP_C_EIA0402_270PF | 270PF | DISCRETE | 2 | C39; C40 |
C_EIA0603 | CAP NP_C_EIA0603_0.1UF | 0.1uF | DISCRETE | 307 | C1; C2; C3; C6; C54; C58; C59; C277; C281; C282; C283; C284; C285; C539; C540; C541; C542; C543; C544; C545; C546; C549; C550; C551; C552; C553; C554; C555; C556; C559; C561; C562; C563; C564; C565; C566; C567; C568; C570; C572; C573; C575; C577; C579; C580; C581; C582; C583; C585; C586; C587; C588; C589; C590; C593; C595; C596; C597; C598; C599; C600; C601; C602; C604; C606; C608; C610; C611; C622; C624; C625; C626; C627; C628; C629; C630; C640; C670; C700; C730; C752; C753; C754; C763; C764; C765; C766; C767; C768; C777; C778; C779; C780; C781; C784; C785; C786; C787; C788; C790; C792; C795; C796; C797; C799; C800; C801; C802; C803; C804; C805; C807; C808; C809; C811; C812; C813; C814; C815; C816; C817; C818; C819; C820; C824; C826; C828; C830; C833; C834; C835; C837; C839; C840; C841; C842; C843; C845; C846; C847; C848; C849; C851; C853; C855; C856; C857; C858; C859; C860; C864; C881; C904; C908; C913; C914; C945; C946; C947; C949; C953; C967; C975; C976; C988; C993; C995; C996; C998; C999; C1000; C1021; C1022; C1033; C1044; C1055; C1058; C1059; C1065; C1066; C1067; C1069; C1074; C1077; C1079; C1080; C1082; C1083; C1084; C1085; C1092; C1093; C1099; C1100; C1104; C1105; C1107; C1108; C1109; C1111; C1115; C1116; C1117; C1120; C1121; C1122; C1126; C1130; C1135; C1137; C1139; C1141; C1142; C1144; C1146; C1148; C1150; C1151; C1152; C1155; C1156; C1159; C1165; C1166; C1168; C1169; C1171; C1172; C1176; C1180; C1182; C1187; C1189; C1190; C1191; C1203; C1205; C1206; C1208; C1210; C1212; C1213; C1214; C1215; C1216; C1217; C1218; C1220; C1221; C1223; C1227; C1228; C1229; C1230; C1234; C1236; C1238; C1241; C1242; C1243; C1244; C1245; C1246; C1247; C1249; C1250; C1253; C1254; C1255; C1256; C1257; C1261; C1265; C1271; C1274; C1335; C1337; C1342; C1345; C1359; C1367; C1387; C1423; C1437; C1448; C1451; C1454; C1455; C1459; C1460; C1461; C1462; C1463; C1464; C1466; C1467; C1469; C1470; C1471; C1473; C1481; C1487; C1488; C1498; C1499; C1500; C1501 |
C_EIA0603 | CAP NP_C_EIA0603_1UF | 1uF | IC | 57 | C10; C43; C49; C52; C53; C56; C63; C633; C639; C648; C652; C654; C655; C657; C661; C663; C669; C678; C682; C684; C685; C687; C691; C693; C699; C708; C712; C714; C715; C717; C721; C723; C729; C738; C742; C744; C745; C747; C751; C882; C899; C903; C905; C910; C1061; C1064; C1068; C1097; C1098; C1101; C1183; C1201; C1202; C1231; C1442; C1446; C1480 |
C_EIA0603 | CAP NP_C_EIA0603_1000PF | 1000pF | IC | 17 | C42; C48; C62; C64; C66; C69; C71; C75; C77; C81; C276; C279; C280; C286; C798; C810; C862 |
C_EIA0603 | CAP NP_C_EIA0603_22PF | 22pF | IC | 12 | C51; C57; C782; C783; C978; C979; C1045; C1046; C1049; C1050; C1086; C1088 |
C_EIA0603 | CAP NP_C_EIA0603_0.01UF | 0.01uF | IC | 16 | C55; C278; C613; C614; C615; C616; C618; C619; C620; C621; C806; C1119; C1138; C1160; C1179; C1452 |
C_EIA0603 | CAP_0603_C_EIA0603_10PF | 10pF | IC | 3 | C288; C1112; C1113 |
C_EIA0603 | CAP_18PF_0603_C_EIA0603_18PF | 18PF | IC | 4 | C547; C548; C578; C584 |
C_EIA0603 | CAP_33NF_0603_C_EIA0603_33NF | 33nf | IC | 6 | C634; C664; C694; C724; C861; C1237 |
C_EIA0603 | CAP_470NF_0603_C_EIA0603_470NF | 470nF | IC | 8 | C646; C653; C676; C683; C706; C713; C736; C743 |
C_EIA0603 | CAP NP_C_EIA0603_47PF | 47pF | IC | 16 | C755; C756; C757; C758; C759; C760; C761; C762; C769; C770; C771; C772; C773; C774; C775; C776 |
C_EIA0603 | CAP NP_C_EIA0603_NO POP | NO POP | IC | 2 | C793; C1233 |
C_EIA0603 | CAP NP_C_EIA0603_560PF | 560pF | IC | 3 | C794; C863; C948 |
C_EIA0603 | CAP_0603_C_EIA0603_4.7NF | 4.7nF | IC | 1 | C821 |
C_EIA0603 | CAP_0603_C_EIA0603_15PF | 15PF | IC | 3 | C956; C957; C1118 |
C_EIA0603 | CAP NP_C_EIA0603_3.9NF | 3.9NF | IC | 9 | C1002; C1005; C1011; C1012; C1024; C1027; C1035; C1039; C1320 |
C_EIA0603 | CAP NP_C_EIA0603_220PF | 220pF | IC | 6 | C1070; C1071; C1072; C1073; C1102; C1103 |
C_EIA0603 | CAP NP_C_EIA0603_3.3NF | 3.3NF | IC | 2 | C1164; C1295 |
C_EIA0603 | CAP NP_C_EIA0603_6.8NF | 6.8NF | IC | 3 | C1184; C1296; C1456 |
C_EIA0603 | R_C_EIA0603_50R | 50R | IC | 2 | R424; R425 |
C_EIA0805 | CAP NP_C_EIA0805_4.7UF | 4.7UF | IC | 41 | C11; C12; C372; C376; C484; C488; C831; C832; C909; C912; C921; C922; C1060; C1062; C1063; C1094; C1095; C1096; C1178; C1235; C1262; C1263; C1267; C1268; C1269; C1270; C1273; C1276; C1277; C1278; C1279; C1280; C1300; C1312; C1319; C1327; C1333; C1450; C1482; C1483; C1484 |
C_EIA0805 | CAP NP_C_EIA0805_10UF | 10uF | IC | 1 | C950 |
C_EIA0805 | CAP NP_C_EIA0805_470PF | 470PF | IC | 16 | C1001; C1003; C1007; C1008; C1009; C1010; C1014; C1016; C1023; C1025; C1028; C1030; C1034; C1037; C1038; C1041 |
C_EIA0805 | CAP_0805_C_EIA0805_0.1UF/16V | 0.1uF/16V | IC | 5 | C1128; C1134; C1158; C1161; C1196 |
C_EIA0805 | CAP NP_C_EIA0805_0.01UF | 0.01UF | IC | 2 | C1490; C1491 |
C_EIA1206 | CAP_104_1206_C_EIA1206_104 | 104 | IC | 1 | C617 |
C_EIA1206 | CAP NP_C_EIA1206_22UF/16V | 22UF/16V | IC | 21 | C1162; C1170; C1174; C1175; C1185; C1188; C1193; C1194; C1195; C1197; C1198; C1219; C1224; C1225; C1226; C1458; C1474; C1475; C1476; C1479; C1492 |
C_EIA1206 | CAP NP_C_EIA1206_1000PF | 1000pF | IC | 1 | C1489 |
D2PAK | LM337_D2PAK_LM337 | LM337 | IC | 1 | U105 |
DB9F_DUAL | DB9F_DUAL_DB9F_DUAL_DB9F_DUAL | DB9F_DUAL | IC | 1 | J10 |
DDPAK | LM317_DDPAK_LM317 | LM317 | IC | 2 | U103; U104 |
DIP10-SOCKET | JTAG-SOCKET_10_DIP10-SOCKET_JTA | JTAG10 | IC | 1 | J17 |
DIP14 | JTAG14_DIP14_JTAG14 | JTAG14 | IC | 1 | J1 |
DVI-I-DUALPORT | DVI-I-DUALPORT_DVI-I-DUALPORT_D | DVI-I-DUALPORT | IC | 1 | J19 |
F169 | EP4CGX15F169_F169_EP4CGX15F169 | EP4CGX15F169 | IC | 1 | U69 |
FBGA-144 | MDIN325_FBGA-144_MDIN325 | MDIN325 | IC | 1 | U68 |
FBGA-DDR3-78 | K4B2G0846D_FBGA-DDR3-78_K4B2G08 | K4B2G0846D | IC | 8 | U11; U12; U13; U14; U15; U16; U17; U18 |
FCBGA_1031_0M65 | DM8168_FCBGA_1031_0M65_TMS320DM | TMS320DM8168BCYG2 | IC | 1 | U1 |
FCQFN13L | MP8636GL-10_FCQFN13L_MP8636GL-1 | MP8636GL-10 | IC | 1 | U115 |
FDVE0630 | INDUCTOR IRON_FDVE0630_FDVE0630 | FDVE0630-H-3R3M/5.3A | IC | 3 | L25; L26; L27 |
FDVE1040 | INDUCTOR IRON_FDVE1040_FDVE1040 | FDVE1040-H-4R7M/8.0A | IC | 1 | L28 |
HDMI19 | HDMI-RA-19_0_HDMI19_HDMI-RA-19_ | HDMI-RA-19_0 | IC | 3 | J5; J15; J16 |
HEATSINK_I | HEATSINK_HEATSINK_I_HEATSINK | HeatSink | IC | 1 | J42 |
HOLE4PCB | SCREW-HOLE-3.2_HOLE4PCB_SCREW-H | SCREW-HOLE-3.2 | IC | 12 | SH2; SH3; SH4; SH5; SH6; SH7; SH8; SH9; SH10; SH11; SH12; SH13 |
LED0805 | LED_LIGHT_LED0805_LED | LED | IC | 1 | D13 |
LQFP-208 | SIL3826_LQFP-208_SIL3826 | SIL3826 | IC | 1 | U80 |
L_EIA0603 | INDUCTOR_6.2NH_0603_L_EIA0603_6 | 6.2nH | IC | 4 | FB26; FB27; FB29; FB30 |
L_EIA0805 | PZ2012D800-3R0TF_L_EIA0805_PZ20 | PZ2012D800-3R0TF | IC | 86 | FB1; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB11; FB12; FB13; FB14; FB15; FB16; FB17; FB18; FB19; FB20; FB21; FB22; FB24; FB25; FB32; FB33; FB35; FB36; FB38; FB39; FB41; FB42; FB44; FB47; FB48; FB49; FB50; FB51; FB52; FB53; FB54; FB55; FB56; FB57; FB58; FB59; FB60; FB61; FB64; FB65; FB66; FB67; FB68; FB69; FB70; FB72; FB73; FB74; FB75; FB76; FB77; FB78; FB126; FB127; FB128; FB142; FB143; FB144; FB145; FB146; FB147; FB148; FB149; FB150; FB151; FB152; FB153; FB154; FB155; FB156; FB157; FB158; FB159; FB160; FB161; FB162; FB163 |
L_EIA1806 | INDUCTOR IRON_L_EIA1806_BLM41PG | BLM41PG600SN1 | IC | 28 | L2; L3; L4; L5; L6; L7; L8; L9; L10; L11; L12; L13; L14; L15; L16; L17; L18; L19; L20; L21; L22; L23; L24; L29; L30; L31; L32; L33 |
L_SMD_7R3X7R3 | INDUCTOR_L_SMD_7R3X7R3_SD75NP-2 | SD75NP-220M/0.9A | IC | 1 | LW8 |
L_SMD_9R2X10R1 | INDUCTOR_L_SMD_9R2X10R1_DRH104R | DRH104RNP-330M/2A | IC | 1 | LW1 |
L_SMD_9R2X10R1 | INDUCTOR_L_SMD_9R2X10R1_DRH10_1 | DRH104RNP-150M/2.7A | IC | 1 | LW3 |
L_SMD_13R3X12 | INDUCTOR_L_SMD_13R3X12_TOKO FDU | TOKO FDU1250-1R0M 1UH | IC | 1 | LW7 |
MHC-W21-601 | SD_SLOT_HC-W21-601_MHC-W21-601_ | MHC-W21-601 | IC | 1 | J8 |
MLCC84 | ET1011C_1_MLCC84_ET1011C | ET1011C | IC | 2 | U21; U25 |
MSOP-10 | RCLAMP0514M_MSOP-10_RCLAMP0514M | RCLAMP0514M | IC | 20 | U5; U6; U7; U28; U29; U30; U31; U39; U40; U41; U42; U55; U56; U57; U58; U59; U60; U73; U74; U78 |
MSOP-10 | LMH1980_MSOP-10_LMH1980 | LMH1980 | IC | 2 | U49; U75 |
NSOIC-16 | SP3232_NSOIC-16_SP3232 | SP3232 | IC | 1 | U33 |
QFN64 | JMB393_QFN64_QFN64_JMB393_QFN64 | JMB393_QFN64 | IC | 1 | U83 |
QFN72 | SII9022ACNU_QFN72_SII9022ACNU | SiI9022ACNU | IC | 1 | U72 |
QFN-32 | CDCM61002_QFN-32_CDCM61002 | CDCM61002 | IC | 1 | U10 |
QFN-40 | TLV320AIC3256_QFN-40_TLV320AIC3 | TLV320AIC3256 | IC | 2 | U92; U95 |
QSOP-16 | PI3B3257_QSOP-16_PI3B3257 | PI3B3257 | IC | 5 | U63; U64; U65; U66; U67 |
QSOP-16 | ADM1030_QSOP-16_ADM1030 | ADM1030 | IC | 1 | U101 |
QSOP-16 | SN74CBTLV3257RGYR_QSOP-16_SN74C | SN74CBTLV3257RGYR | IC | 6 | U122; U123; U124; U125; U126; U127 |
RB_2L | CAP_RB_2L_47UF/25V | 47UF/25V | IC | 26 | C789; C825; C827; C994; C997; C1017; C1018; C1019; C1020; C1031; C1032; C1042; C1043; C1053; C1054; C1056; C1057; C1090; C1091; C1127; C1136; C1143; C1145; C1147; C1154; C1157 |
RB_2L | CAP_RB_2L_10UF/50V | 10uF/50V | IC | 5 | C1075; C1076; C1078; C1081; C1106 |
RCA-207 | RCA-213C_RCA-207_RCA | RCA | IC | 1 | J27 |
RN4_EIA0603 | RESAR_IS_4/SM_RN4_EIA0603_RPACK | RPACK4-22 | DISCRETE | 22 | RN6; RN7; RN8; RN9; RN10; RN11; RN12; RN14; RN15; RN16; RN17; RN26; RN27; RN28; RN29; RN30; RN31; RN32; RN33; RN35; RN37; RN38 |
RN4_EIA0603 | R-PAK4_0_RN4_EIA0603_47R | 47R | IC | 12 | RP1; RP2; RP3; RP4; RP5; RP6; RP7; RP8; RP9; RP10; RP11; RP12 |
R_EIA0402 | R_R_EIA0402_22 | 22 | DISCRETE | 10 | R61; R80; R81; R82; R83; R84; R236; R250; R264; R278 |
R_EIA0603 | CAP NP_R_EIA0603_OPT | opt | IC | 2 | C1186; C1457 |
R_EIA0603 | R_R_EIA0603_10K | 10K | IC | 152 | R2; R3; R4; R9; R11; R12; R16; R17; R23; R98; R99; R101; R102; R103; R108; R125; R126; R127; R128; R135; R136; R137; R139; R151; R155; R156; R157; R161; R162; R167; R178; R184; R189; R191; R193; R223; R224; R232; R234; R235; R246; R248; R249; R261; R262; R263; R275; R276; R277; R317; R318; R319; R320; R321; R337; R338; R345; R353; R359; R360; R378; R379; R380; R383; R387; R388; R389; R391; R407; R409; R410; R411; R412; R413; R415; R416; R420; R427; R428; R441; R443; R445; R453; R460; R475; R478; R479; R497; R499; R500; R501; R502; R503; R508; R510; R512; R513; R515; R527; R533; R544; R549; R560; R565; R573; R581; R591; R592; R602; R603; R616; R617; R622; R626; R630; R637; R643; R649; R650; R653; R667; R672; R686; R689; R692; R693; R696; R697; R698; R705; R708; R710; R711; R722; R724; R730; R733; R746; R753; R769; R770; R771; R773; R774; R775; R776; R777; R778; R782; R789; R790; R791 |
R_EIA0603 | R_R_EIA0603_1K | 1K | IC | 42 | R5; R28; R29; R30; R31; R32; R33; R34; R35; R36; R72; R92; R96; R97; R408; R414; R421; R426; R491; R493; R494; R495; R504; R645; R662; R663; R664; R665; R681; R694; R699; R719; R726; R729; R735; R737; R738; R741; R786; R798; R805; R810 |
R_EIA0603 | R_R_EIA0603_NO POP | NO POP | IC | 62 | R6; R15; R47; R48; R49; R50; R79; R100; R109; R129; R130; R131; R132; R133; R134; R163; R164; R182; R185; R186; R188; R190; R192; R322; R323; R367; R381; R382; R394; R395; R400; R401; R417; R418; R436; R440; R442; R444; R447; R448; R449; R450; R451; R507; R511; R514; R516; R517; R612; R635; R638; R644; R648; R714; R755; R763; R772; R779; R780; R781; R783; R787 |
R_EIA0603 | RES_2K_0603_R_EIA0603_2K | 2K | IC | 28 | R7; R68; R69; R93; R230; R231; R244; R245; R258; R259; R271; R273; R291; R292; R293; R294; R307; R308; R309; R310; R498; R682; R757; R762; R799; R801; R804; R807 |
R_EIA0603 | R_R_EIA0603_22 | 22 | DISCRETE | 35 | R8; R10; R13; R14; R21; R22; R46; R86; R87; R140; R141; R142; R143; R144; R146; R147; R148; R165; R168; R169; R170; R172; R173; R174; R175; R362; R364; R376; R377; R384; R385; R386; R398; R429; R431 |
R_EIA0603 | R_R_EIA0603_4.7K | 4.7K | IC | 79 | R18; R20; R24; R65; R216; R371; R372; R373; R374; R375; R390; R396; R397; R402; R405; R406; R432; R433; R434; R484; R486; R490; R492; R519; R522; R528; R532; R535; R538; R543; R548; R551; R554; R559; R564; R567; R572; R575; R580; R582; R583; R584; R585; R586; R588; R589; R593; R594; R595; R596; R597; R599; R600; R604; R605; R606; R607; R608; R609; R610; R611; R621; R623; R624; R627; R628; R631; R632; R633; R634; R666; R685; R716; R720; R796; R814; R815; R816; R817 |
R_EIA0603 | R_R_EIA0603_0 | 0 | DISCRETE | 95 | R19; R25; R62; R63; R95; R104; R105; R106; R107; R110; R111; R124; R138; R153; R154; R158; R166; R180; R181; R183; R225; R226; R237; R239; R251; R253; R265; R267; R279; R281; R325; R326; R327; R328; R329; R330; R339; R340; R341; R363; R368; R369; R370; R422; R430; R437; R438; R439; R452; R454; R455; R456; R461; R462; R463; R464; R466; R467; R470; R476; R482; R483; R489; R505; R506; R587; R590; R598; R601; R613; R618; R619; R620; R625; R629; R636; R639; R640; R641; R647; R652; R668; R671; R680; R684; R715; R736; R744; R748; R749; R758; R759; R788; R809; R813 |
R_EIA0603 | R_R_EIA0603_49.9 1% | 49.9 1% | IC | 22 | R26; R27; R120; R121; R122; R123; R194; R195; R196; R197; R198; R199; R200; R201; R205; R206; R207; R208; R209; R210; R211; R212 |
R_EIA0603 | RES_3K_0603_R_EIA0603_3K | 3k | IC | 10 | R37; R38; R39; R40; R41; R42; R43; R44; R45; R701 |
R_EIA0603 | R_R_EIA0603_47K | 47K | IC | 5 | R66; R446; R674; R676; R691 |
R_EIA0603 | R_R_EIA0603_1.20K 1% | 1.20K 1% | IC | 5 | R67; R71; R76; R150; R177 |
R_EIA0603 | R_R_EIA0603_10 | 10 | IC | 5 | R70; R75; R160; R187; R785 |
R_EIA0603 | R_R_EIA0603_15K | 15K | IC | 2 | R73; R792 |
R_EIA0603 | R_R_EIA0603_7.50K 1% | 7.50K 1% | IC | 1 | R74 |
R_EIA0603 | R_R_EIA0603_10K 1% | 10K 1% | IC | 3 | R85; R354; R357 |
R_EIA0603 | R_R_EIA0603_2.2K | 2.2K | IC | 7 | R88; R89; R90; R91; R366; R742; R795 |
R_EIA0603 | RES_220R_0603_R_EIA0603_220R | 220R | IC | 23 | R94; R202; R203; R213; R215; R393; R525; R530; R542; R547; R557; R563; R570; R579; R646; R658; R659; R660; R661; R673; R687; R718; R745 |
R_EIA0603 | R_R_EIA0603_240 1% | 240 1% | IC | 8 | R112; R113; R114; R115; R116; R117; R118; R119 |
R_EIA0603 | R_R_EIA0603_1.00K 1% | 1.00K 1% | IC | 3 | R145; R171; R485 |
R_EIA0603 | R_R_EIA0603_5.10K 1% | 5.10K 1% | IC | 2 | R149; R176 |
R_EIA0603 | RES_30_0603_R_EIA0603_30 | 30 | IC | 2 | R152; R179 |
R_EIA0603 | R_R_EIA0603_51K | 51K | IC | 6 | R217; R218; R219; R220; R221; R222 |
R_EIA0603 | R_120_0603_R_EIA0603_120 | 120 | IC | 2 | R227; R228 |
R_EIA0603 | R_R_EIA0603_100 | 100 | IC | 9 | R229; R243; R257; R272; R355; R457; R480; R683; R756 |
R_EIA0603 | R_R_EIA0603_75 | 75 | IC | 48 | R238; R240; R241; R242; R252; R254; R255; R256; R266; R268; R269; R270; R280; R282; R283; R284; R331; R332; R333; R334; R335; R336; R342; R343; R344; R346; R347; R348; R349; R350; R351; R352; R356; R458; R465; R468; R469; R471; R472; R473; R474; R678; R679; R732; R739; R797; R803; R811 |
R_EIA0603 | R_2.5K_0603_R_EIA0603_2.5K | 2.5k | IC | 12 | R285; R286; R287; R295; R296; R297; R301; R302; R303; R311; R312; R313 |
R_EIA0603 | R_175R_0603_R_EIA0603_175R | 175R | IC | 12 | R288; R289; R290; R298; R299; R300; R304; R305; R306; R314; R315; R316 |
R_EIA0603 | R_R_EIA0603_1.0M | 1.0M | IC | 3 | R324; R477; R496 |
R_EIA0603 | R_R_EIA0603_330 | 330 | IC | 1 | R358 |
R_EIA0603 | R_R_EIA0603_150 | 150 | IC | 1 | R361 |
R_EIA0603 | R_R_EIA0603_1.5K 1% | 1.5K 1% | IC | 4 | R365; R688; R700; R703 |
R_EIA0603 | RES_R/NOPOP_0603_R_EIA0603_20R | 20R | IC | 2 | R399; R488 |
R_EIA0603 | RES_R/NOPOP_0603_R_EIA0603_270R | 270R | IC | 3 | R403; R404; R487 |
R_EIA0603 | RES_R/NOPOP_0603_R_EIA0603_25R | 25R | IC | 1 | R419 |
R_EIA0603 | R_R_EIA0603_2.00K 1% | 2.00K 1% | IC | 1 | R423 |
R_EIA0603 | RES_R/NOPOP_0603_R_EIA0603_510R | 510R | IC | 2 | R435; R784 |
R_EIA0603 | RES_R/NOPOP_0603_R_EIA0603_10K/ | 10K/NC | IC | 1 | R459 |
R_EIA0603 | R_R_EIA0603_100K | 100K | IC | 6 | R481; R675; R677; R690; R752; R765 |
R_EIA0603 | RES_R/NOPOP_0603_R_EIA0603_3.9K | 3.9K | IC | 18 | R518; R521; R526; R531; R534; R537; R540; R545; R550; R553; R558; R561; R566; R571; R574; R577; R721; R794 |
R_EIA0603 | RES_R/NOPOP_0603_R_EIA0603_180R | 180R | IC | 16 | R520; R523; R524; R529; R536; R539; R541; R546; R552; R555; R556; R562; R568; R569; R576; R578 |
R_EIA0603 | R_R_EIA0603_20K | 20K | IC | 3 | R614; R615; R695 |
R_EIA0603 | R_R_EIA0603_9.1K | 9.1K | IC | 2 | R702; R704 |
R_EIA0603 | R_R_EIA0603_5.1K | 5.1K | IC | 3 | R706; R709; R723 |
R_EIA0603 | R_R_EIA0603_39K | 39K | IC | 3 | R707; R712; R731 |
R_EIA0603 | R_R_EIA0603_12.4K | 12.4K | IC | 2 | R713; R728 |
R_EIA0603 | R_R_EIA0603_470R | 470R | IC | 7 | R717; R727; R734; R800; R802; R806; R808 |
R_EIA0603 | R_R_EIA0603_33K | 33K | IC | 2 | R725; R793 |
R_EIA0603 | R_R_EIA0603_8.2K | 8.2k | IC | 1 | R740 |
R_EIA0603 | R_R_EIA0603_25K | 25K | IC | 1 | R743 |
R_EIA0603 | R_R_EIA0603_6.8K | 6.8K | IC | 1 | R747 |
R_EIA0603 | R_R_EIA0603_200K 1% | 200K 1% | IC | 4 | R750; R761; R766; R767 |
R_EIA0603 | R_R_EIA0603_150K 1% | 150K 1% | IC | 1 | R751 |
R_EIA0603 | R_R_EIA0603_30K | 30k | IC | 1 | R754 |
R_EIA0603 | R_R_EIA0603_50K | 50k | IC | 1 | R764 |
R_EIA0805 | RES_R/NOPOP_0805_R_EIA0805_100R | 100R | IC | 2 | R642; R651 |
R_EIA0805 | RES_R/NOPOP_0805_R_EIA0805_220R | 220R_0805 | IC | 4 | R654; R655; R656; R657 |
R_EIA0805 | R_R_EIA0805_2R | 2R | IC | 2 | R669; R670 |
R_EIA0805 | R_R_EIA0805_300K | 300k | IC | 1 | R760 |
R_EIA0805 | R_R_EIA0805_510K | 510K | IC | 1 | R768 |
SATA7_16_7M | SATA_PORT_SATA7_16_7M_SATA_PORT | SATA_PORT | IC | 4 | J20; J21; J25; J26 |
SC70-3 | SP1001-02_SC70-3_SP1001-02 | SP1001-02 | IC | 14 | Q4; Q8; Q9; Q10; Q11; Q12; Q13; Q14; Q15; Q17; Q19; Q25; Q26; Q27 |
SIP1 | TP_SIP1_TP | TP | IC | 42 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42 |
SIP-12 | CON_12_SIP-12_CON_12 | CON_12 | IC | 1 | J9 |
SLP1006P2 | RCLAMP0521PA_SLP1006P2_RCLAMP05 | RClamp0521PA | IC | 4 | D3; D4; D5; D6 |
SO-16 | 74HCT4052_SO-16_74HCT4052 | 74HCT4052 | IC | 3 | U46; U50; U99 |
SO-16W | EPCS128_SO-16W_EPCS128 | EPCS128 | IC | 1 | U70 |
SO-20 | 74HC244_SO-20_74HC244 | 74HC244 | IC | 1 | U128 |
SOIC8 | SP3485_SOIC8_SP3485 | SP3485 | IC | 1 | U32 |
SOIC8-POWERPAD | MP9415_SOIC8-POWERPAD_MP9415 | MP9415 | IC | 3 | U107; U109; U114 |
SOIC8-POWERPAD | MP8666_SOIC8-POWERPAD_MP8666 | MP8666 | IC | 1 | U110 |
SOIC8-POWERPAD | TJ2997_SOIC8-POWERPAD_TJ2997 | TJ2997 | IC | 1 | U111 |
SOIC8_A | NJM4558_SOIC8_A_NJM4558 | NJM4558 | IC | 7 | U86; U87; U88; U89; U90; U91; U94 |
SOIC-8 | AO4406B_SOIC-8_AO4406 | AO4406 | IC | 1 | Q39 |
SOIC-8 | SP706S_SOIC-8_SP706S | SP706S | IC | 1 | U2 |
SOIC-8 | AT24C04_SOIC-8_AT24C04 | AT24C04 | IC | 1 | U20 |
SOIC-8 | EPCS16_SOIC-8_EPCS16 | EPCS16 | IC | 1 | U71 |
SOIC-8 | 24LCXXX_SOIC-8_24LC512 | 24LC512 | IC | 1 | U81 |
SOIC-8 | 25LVXXX_SOIC-8_25LV512 | 25LV512 | IC | 1 | U84 |
SOIC-8 | PCF8563_SOIC-8_PCF8563 | PCF8563 | IC | 1 | U100 |
SOIC-8 | MP1482_SOIC-8_MP1482 | MP1482 | IC | 3 | U106; U108; U120 |
SOIC-14 | SP3491_SOIC-14_SP3491 | SP3491 | IC | 1 | U34 |
SOIC-14 | CD4069_SOIC-14_CD4069 | CD4069 | IC | 1 | U96 |
SOIC-16W | PI5V330S_SOIC-16W_PI5V330S | PI5V330S | IC | 3 | U44; U45; U47 |
SOT-23 | MT3405_SOT-23_MT3405 | MT3405 | IC | 2 | Q1; Q28 |
SOT-23 | BC817_SOT-23_BC817 | BC817 | IC | 14 | Q2; Q3; Q5; Q16; Q30; Q31; Q32; Q35; Q36; Q37; Q38; Q40; Q47; Q48 |
SOT-23 | NPN_BEC_SOT-23_PC817 | PC817 | IC | 2 | Q18; Q33 |
SOT-23 | PNP_BEC_SOT-23_2SA1037 | 2SA1037 | IC | 6 | Q20; Q21; Q22; Q23; Q24; Q34 |
SOT-23 | WNM2306_SOT-23_WNM2306 | WNM2306 | IC | 5 | Q42; Q43; Q44; Q45; Q46 |
SOT-23 | TCM809XXX_SOT-23_TCM809T | TCM809T | IC | 1 | U82 |
SOT-23-5 | 74LVC1G08_SOT-23-5_74LVC1G08 | 74LVC1G08 | IC | 3 | U3; U23; U27 |
SOT-23-5 | SN74LVC1G17_SOT-23-5_SN74LVC1G1 | SN74LVC1G17 | IC | 11 | U4; U51; U52; U54; U76; U77; U97; U98; U129; U130; U131 |
SOT-23-5 | TLV431ACDBVR_SOT-23-5_TLV431ACD | TLV431ACDBVR | IC | 1 | U8 |
SOT-23-5 | SP6205_SOT-23-5_SP6205 | SP6205 | IC | 3 | U9; U93; U119 |
SOT-23-5 | 74HC1G08_SOT-23-5_74HC1G08 | 74HC1G08 | IC | 1 | U102 |
SOT-23-5 | SGM2032_SOT-23-5_SGM2032 | SGM2032 | IC | 1 | U113 |
SOT-223 | BCP69T1_SOT-223_BCP69T1 | BCP69T1 | IC | 2 | U22; U26 |
SOT-223 | LM1117-ADJ_SOT-223_LM1117-ADJ | LM1117-ADJ | IC | 1 | U116 |
SOT-223 | LM1117_SOT-223_LM1117-1.8V | LM1117-1.8V | IC | 1 | U117 |
SOT-223 | LM1117_SOT-223_LM1117-3.3V | LM1117-3.3V | IC | 1 | U118 |
TO263-6 | XRP29302_TO263-6_XRP29302 | XRP29302 | IC | 1 | U112 |
TO-92B | NPN_BEC_TO-92B_KTD-1863 | KTD-1863 | IC | 1 | Q29 |
TO-252 | MJD210_TO-252_2SB1203 | 2SB1203 | IC | 2 | Q6; Q7 |
TQFP-48 | AK4358_TQFP-48_AK4358 | AK4358 | IC | 2 | U62; U85 |
TQFP-100-PP | TVP7002_TQFP-100-PP_TVP7002 | TVP7002 | IC | 1 | U53 |
TQFP-144 | SII9233A_TQFP-144_SII9233A | SiI9233A | IC | 1 | U61 |
TSOP48 | S34ML04G1_TSOP48_S34ML04G1 | S34ML04G1 | IC | 1 | U19 |
TSSOP-14 | DIO-2583_TSSOP-14_DIO-2583 | DIO-2583 | IC | 3 | U48; U79; U121 |
TSSOP-28 | XR20M1172IG28_TSSOP-28_XR20M117 | XR20M1172IG28 | IC | 1 | U43 |
VGA15_2 | HD15*2_VGA15_2_HD15*2 | HD15*2 | IC | 2 | J13; J14 |
XTAL-3P | XTAL-25M-3P_XTAL-3P_25M | 25M | IC | 4 | X2; X3; X13; X14 |
XTAL-3P | XTAL-3P_XTAL-3P_18.432M | 18.432M | IC | 1 | X8 |
