Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
2X5HDR5 | A91836-068 | 2X5-KP5 | IO | 1 | J6D1 |
2X5HDR9 | D20962-001 | USB_2X5-Header | IO | 4 | J7H2; J7H3; J7H4; J8H1 |
2X30_XDP_CONN-B | C21100-002 | CONN60_ITP-XDP | IO | 3 | J1C1; J1D3; J8H3 |
3GIO_X1 | C35285-001 | PCIE_X1 | IO | 6 | J6C1; J6C2; J6D2; J7C1; J7D2; J8C1 |
3GIO_X16 | C35285-004 | PCIE_X16 | IO | 2 | J5C1; J8C2 |
156_SPOKE | MOUNT156 | MT156 | IC | 9 | MT1B1; MT1F1; MT1J1; MT5A1; MT5F1; MT5J1; MT9A1; MT9F1; MT9J1 |
102276-001 | A91829-020 | CON2_HDR | IO | 3 | J1C2; J8D1; J8D2 |
102276-001 | A91829-004 | CON2_HDR | IO | 43 | J1D1; J1D2; J1D4; J1E1; J1E2; J1F1; J2A1; J2J9; J3B1; J3B2; J3J3; J3J5; J4B1; J4B2; J5F1; J5F2; J6B1; J6E1; J6F2; J6F3; J6G1; J7H1; J8F3; J8F5; J8F6; J8F7; J8G1; J8G4; J8G5; J8G6; J8H4; J9E1; J9E6; J9F1; J9F2; J9G1; J9G3; J9G4; J9H1; J9H2; J9H3; J9H4; J9H5 |
102276-003 | A91829-009 | CON3_HDR | IO | 21 | J1J2; J2J3; J2J4; J2J5; J2J6; J2J7; J2J8; J2J10; J2J11; J2J12; J3J4; J4J1; J6A2; J6A3; J7B1; J7B2; J7D1; J8C3; J8D3; J8H2; J9E2 |
102276-003 | 102276-328 | CON3_HDR | IO | 1 | J6A1 |
102276-100 | D32780-001 | 1Pin_HDR | IC | 25 | TP1D1; TP1D2; TP1D3; TP1D4; TP1D5; TP2B1; TP2B2; TP5C1; TP5C2; TP5C3; TP5C4; TP5E1; TP5E2; TP5F1; TP5F2; TP5F3; TP5G1; TP7G1; TP8C1; TP8C2; TP9B1; TP9B2; TP9F1; TP9H1; TP9H2 |
102283-004 | C77978-003 | 8Pin HDR | IO | 5 | J1J1; J2J1; J2J2; J8E1; J9C1 |
102283-004 | A91836-014 | 8Pin HDR | IO | 2 | J8G3; J9E7 |
102283-008 | C77978-006 | 2X8_HDR | IO | 2 | J2B1; J2C1 |
109717-022 | C77978-002 | 2X2HDR | IO | 1 | J3A4 |
109717-120 | A91836-010 | 2x10-HDR_P4KEY | IO | 1 | J9A1 |
109717-748 | C77978-005 | 2X8_HDR_KEY12 | IO | 3 | J8F1; J8F4; J9E4 |
109728-038 | C77962-001 | 6Pin_HDR | IO | 2 | J3J1; J5A2 |
201082-563 | C77887-001 | 60Pin_CardCon | IO | 1 | J8F2 |
201377-001 | 201377-004 | DUAL_PS2 | IO | 1 | J1A1 |
639823-001 | C77978-004 | HDR_2x8 | IO | 1 | J5J1 |
650520-001 | C77993-001 | CON20_PWR | IO | 1 | J4H1 |
650520-010 | C77993-002 | SATA_POWER_CONNECTOR | IO | 1 | J6H1 |
672681-002 | 672681-002 | Push_Button | IC | 2 | SW1E1; SW1E2 |
700000-631 | 700000-631 | 5Pin_JACK | IO | 11 | J4C2; J4C3; J4C4; J4C5; J4C6; J4C7; J5C2; J5C3; J5C4; J5D1; J5H1 |
700000-662 | 700000-662 | 3Pin_Recepticle | IO | 1 | J3A1 |
700000-669 | 700000-669 | SPDT_SLIDE | IC | 3 | SW9H1; SW9H2; SW9H3 |
700000-970 | C77954-001 | CON3,HDR,Shrouded | IO | 1 | J3J2 |
752402-009 | 752402-015 | 90@100MHz | DISCRETE | 6 | L3B1; L4B1; L4B2; L4B3; L4B4; L4B5 |
A28952-001 | A28952-005 | 2IN1 | IO | 1 | J1A2 |
A71107-001 | A96814-001 | SATA_Signal_Plug | IO | 2 | J7G1; J7G2 |
A74307-003 | C73572-001 | RJ45 1000 WITH DUAL USB | IO | 1 | J4A1 |
A80568-006 | A80568-015 | 2X12-HDR_SHRD | IO | 1 | J9E5 |
AUB_34X28MM_1288P | IC_AUB_ECC_BGA_R0P5_AUB_34X28MM | IC_AUB_ECC_BGA_R0P5 | IC | 1 | U3E1 |
BATT_HLDR_2P1N | C68619-001 | Battery_Holder | IC | 1 | BT5G1 |
BGA4_1_05MM | D30400-001 | CM1230_02 | IC | 10 | U3A2; U4A1; U4A2; U4A3; U4B1; U4B2; U5A1; U5A2; U5A3; U5A4 |
BGA176_0_8MM | D75942-001 | H8S2117 BGA176 | IC | 1 | U9G4 |
BGA1071_PCH09M_27X25MM | IBEXPEAK-M | IbexPeak-M_Rev0_9 | IC | 1 | U7F1 |
C18987-001PRE | C18987-001 | CON3_HDR | IO | 2 | J5D2; J6F1 |
C42687-001 | C42687-001 | CON_1X7_156mil_HDR | IO | 2 | J1H1; J1H2 |
CONN24_PCIE_GEN2_LAI | CONN24,PCIE8,GEN2,MIDBUSPROBE_C | PCIE_GEN2 | IO | 2 | J5T1; J5T2 |
CONN78_NVM_SO_RT | CONN78,NVRAM,RA,1.8V,30U_CONN78 | NVRAM Connector | IO | 1 | J6G2 |
CONN240_VERT_DDR3_1SPKTH | D92964-001 | CONN240_DDR3_DIMM | IO | 2 | J4V1; J4V2 |
CP-HD20-30P | C75466-001 | 2x15-SHD-HDR | IO | 1 | J9E3 |
D58558-001 | CON19,HDMI,RA,TH,D58558-001_D58 | HDMI | IO | 1 | J3A2 |
D93370-001 | CON100,AVMC,THM,D93370-001_D933 | tyco104078 | IO | 1 | J1J3 |
DOCKING172 | D32233-001 | PCI-E DOCKING CONN | IO | 1 | J9C2 |
E35729-001 | CON20,DSP_PRT,RA,TH,E35729-001_ | DisplayPort | IO | 1 | J5A1 |
E-SATA_CONN | D83369-001 | eSATA_Signal_Plug | IO | 2 | J6J1; J7J1 |
GTL-E-M-6828 | D75938-001 | PWR_JACK | IO | 1 | J1F2 |
HSDL3003 | D29005-001 | HSDL-3021_021 | IC | 1 | U8A1 |
LCC20_5MM_4MMSQ_M | D82951-001 | 9DBL411 | IC | 1 | EU5D1 |
LCC24_P5MM_SQ4MM_MBL | D71812-001 | JASPERSI_0X | IC | 1 | EU1G1 |
LCC40_4MM_138DIE | IC,ISL62883,LIN,QFN40,CNTL,R511 | ISL62883_REV5.11 | IC | 1 | EU3B1 |
LVDS_50 | D27654-002 | LVDS,CONN50 | IO | 1 | J7D3 |
MAX1908_BATCHG | D69591-001 | MAX8632 | IC | 1 | EU3W1 |
MFG_MODE_JMPR | 726841-001 | MFG-TEST-JUMPER | IO | 1 | J9J1 |
MICROPAK6 | D33602-001 | NC7SV125L | IC | 3 | U8E1; U9D1; U9E1 |
MIC_AKU2002B | MIC,MEMS,HD,AKU2002B_MIC_AKU200 | MEMS | IC | 1 | U4B3 |
MOLEX-53398-0419 | A36295-009 | CON4_HDR | IO | 2 | J2G1; J4C1 |
MOLEX-85510-0027 | CON6,RJ11,SM,VT,1.27,D80742-001 | RJ-11_JACK_Vertical-Mount | IO | 1 | J5B1 |
MOLEX_SD_67492_001 | C47552-002 | Serial ATA Recepticle | IO | 1 | J8J1 |
MSOP8 | E18523-001 | LM95245C | IC | 1 | U5C1 |
MSOP10 | D34772-001 | ESD DIODE ARRAY | IC | 3 | U1M1; U5A5; U5M1 |
MSOP10 | D46790-001 | ADT7481ARMZ-1 TEMP MON | IC | 1 | U5C2 |
PCIEDGE_UNIV_5V | PCI_FINGERS_5V | PCI_EXTENSION_GOLDFINGERS_5V | IC | 1 | S9B1 |
PICO_GSG_A | GSG_RF | TP | IC | 18 | TP3C1; TP3E1; TP3R1; TP4P1; TP6F1; TP6F2; TP6H1; TP6H2; TP6H3; TP6H4; TP43; TP44; TP45; TP46; TP56; TP57; TP60; TP61 |
POWER562 | D80667-001 | FDMS8690 | IC | 2 | Q1E2; Q6R1 |
PQFP64_4MM_R75X09 | C85360-003 | SIO1007-JV | IC | 1 | U9A1 |
QFN10_3MMX3MM | TBD | SMB380_SENSOR_NEW | IC | 1 | U6A1 |
QFN24_P5MM_S4MM_DIE | E20275-001 | TPS51125 | IC | 1 | EU5G1 |
QFN32_5MMX5MM | E31504-001 | MAX17028 | IC | 1 | EU1E1 |
QFN48_5MM | IC,TRANSLATOR,PI3VDP411,QFN48_Q | HDMI_LS_PERICOM | IC | 1 | EU2A1 |
QFN48_6X6_4MM | IC,82577LM_LC,48QFN,LAN_QFN48_6 | HANKSVILLE | IC | 1 | EU7M1 |
QUAD_STACK_USB | C34929-001 | QUAD_stack_USB | IO | 1 | J3A3 |
RJK_COMMON | XSTR,RJK0364,FET,NCH,COMMON_RJK | RJK0364 | IC | 8 | Q2C1; Q2P1; Q3C1; Q3C2; Q3P1; Q3P2; Q4F3; Q4U1 |
RJK_COMMON | XSTR,RJK0346,FET,NCH,COMMON_RJK | RJK0346 | IC | 10 | Q2C2; Q2P2; Q3C3; Q3C4; Q3P3; Q3P4; Q4F4; Q4U2; Q6E2; Q6T4 |
SBHEADER | A80568-014 | LPC Sideband Header | IO | 1 | J9G2 |
SC70-6PIN-1_25MM | E47385-001 | ISL90727 | IC | 1 | U2F3 |
SC70-6PIN-1_25MM | E18644-001 | ISL90728 | IC | 1 | U2U1 |
SC70-6PIN-1_25MM | IC,BUFF_DRVR,NC7WV17P6X,SC70_SC | NC7WV17P6X | IC | 1 | U7V1 |
SMA_19S101-40M | SMP | SMP | IO | 2 | J5R1; J5R2 |
SMC0402 | A36095-031 | 33pF | DISCRETE | 3 | C1B3; C1B4; C2B3 |
SMC0402 | A36098-005 | 0.1uF | DISCRETE | 91 | C1B5; C1N3; C1N4; C1N5; C1W4; C1W7; C1Y2; C2H5; C3N1; C3N3; C4A1; C4B4; C4B7; C5C1; C5H6; C5M2; C5M3; C5M4; C5M5; C5M6; C5P1; C5P2; C5P10; C5W8; C6C3; C6C4; C6C5; C6C6; C6C7; C6D2; C6D7; C6E2; C6M2; C6M3; C6M5; C6M7; C7A2; C7C7; C7N5; C7P1; C7P2; C7P3; C7R1; C7R2; C7R3; C7R8; C7R9; C7R10; C7R11; C7T1; C7V1; C8A8; C8F2; C8F3; C8F4; C8G1; C8M3; C8M4; C8M9; C8M10; C8T1; C8T4; C8W2; C9A1; C9A2; C9A3; C9B4; C9B5; C9C1; C9C2; C9C3; C9C4; C9D1; C9E3; C9F1; C9F2; C9G2; C9J2; C9J3; C9M1; C9M2; C9M3; C9M4; C9M5; C9M6; C9P1; C9R1; C9T1; C9U1; C9U2; C9V1 |
SMC0402 | C25529-001 | 0.22uF | DISCRETE | 2 | C1E1; C2C5 |
SMC0402 | A36096-045 | 0.01uF | DISCRETE | 45 | C1E2; C1E3; C1E12; C1E13; C1E14; C2C3; C2C4; C2F1; C2P2; C2P3; C3C2; C3C3; C3P1; C3P2; C3P3; C3P4; C4C1; C4C3; C7E9; C7G3; C7G4; C7G5; C7G6; C7G8; C7G9; C7G10; C7G11; C7G12; C7G13; C7G14; C7G15; C7G16; C7G17; C7G18; C7G19; C7G20; C7G21; C7G22; C7G23; C7G24; C7G25; C7G26; C7G27; C7U2; C7U3 |
SMC0402 | A36096-044 | 1.0uF | DISCRETE | 149 | C1E4; C1T1; C2F5; C2F6; C2F7; C2G1; C2G2; C2G7; C2G8; C2G9; C2G10; C2G14; C2G15; C2U7; C2U8; C2U9; C3R14; C3R15; C3R16; C3R17; C3R18; C3R19; C3R20; C3R21; C3R22; C3R23; C3R24; C3R25; C3R26; C3R27; C3R28; C3R29; C3R30; C3R31; C3R32; C3R33; C3R34; C3R35; C3R36; C3R37; C3R38; C3R39; C3R40; C3R41; C3R42; C3R43; C3R44; C3R45; C3R46; C3R47; C3R48; C3R49; C3R50; C3R51; C3R52; C3R53; C3R54; C3R55; C3R56; C3R57; C3R58; C3R59; C3R60; C3R61; C3R62; C3R63; C3R64; C3R65; C3T1; C3T2; C3T3; C3T4; C3T5; C3T6; C3T7; C3T8; C3T9; C3T10; C3T11; C3T12; C3T13; C3T14; C3T15; C3T16; C3T17; C3T18; C3T19; C3T20; C3T21; C3T22; C3T23; C3T24; C3T25; C3T26; C3T27; C3T28; C3T29; C3T30; C3T31; C3T32; C3T33; C3T34; C3T35; C3T36; C3T37; C3T38; C3T39; C3T40; C3T41; C3T42; C3T43; C3T44; C3T45; C3T46; C3T47; C3T48; C3T49; C3T50; C3T51; C3T52; C3T53; C3T54; C3T55; C3T58; C3T59; C3T60; C3T61; C3T62; C5G3; C6E7; C6E8; C7E8; C7G2; C7U1; C7U4; C7U5; C7U7; C7U9; C7U10; C7U11; C7U12; C7U13; C7U15; C7U16; C7U19; C7U20; C7U22; C7U23; C7U28 |
SMC0402 | A36096-043 | 0.1uF | DISCRETE | 213 | C1E5; C1E9; C1E10; C1G10; C1P1; C1P2; C1R1; C1R2; C1T3; C2A3; C2E11; C2G13; C2M1; C2M2; C2M3; C2W2; C3A1; C3B1; C3B2; C3G2; C3G3; C3G11; C3G12; C3G17; C3G18; C3G25; C3G27; C3H1; C3M1; C3N2; C3N4; C3N8; C5A1; C5A2; C5A3; C5A4; C5A5; C5A6; C5A7; C5A8; C5A9; C5A10; C5A11; C5A12; C5A13; C5A14; C5A15; C5A16; C5B4; C5B5; C5B6; C5D1; C5D2; C5D3; C5D4; C5P3; C5P4; C5P5; C5P6; C5P7; C5P8; C5P9; C5P11; C5P12; C5P13; C5P14; C5P15; C5R1; C5R2; C5R3; C5R4; C5R5; C5R6; C5R7; C5R8; C5R9; C5R10; C5R11; C5R12; C5R13; C5R14; C5T1; C5T2; C5T3; C5T4; C5T5; C5T6; C6B11; C6B12; C6B14; C6B15; C6B16; C6C1; C6C2; C6C10; C6C11; C6D4; C6D5; C6D6; C6D9; C6D10; C6G2; C6G3; C6G4; C6G5; C6G6; C6G7; C6G8; C6G9; C6G10; C6G12; C6G13; C6G14; C6G15; C6H1; C6U8; C6W2; C7A3; C7A4; C7B8; C7B11; C7B12; C7C1; C7C2; C7C3; C7C5; C7C6; C7C8; C7C9; C7C11; C7C12; C7C15; C7C16; C7C17; C7C18; C7C19; C7C20; C7C21; C7D1; C7D2; C7D3; C7D4; C7D5; C7D7; C7D8; C7D9; C7D10; C7D12; C7D13; C7D14; C7D15; C7D16; C7E5; C7F1; C7H4; C7M2; C7M9; C7R4; C7R5; C7T2; C7U6; C7U8; C7U14; C7U17; C7U18; C7U21; C7U24; C7U25; C7U26; C7U27; C7U29; C7U30; C7U31; C7U32; C7U33; C7U34; C7V2; C7W2; C8B6; C8B10; C8B11; C8B13; C8B14; C8C1; C8C3; C8C4; C8C5; C8C6; C8C7; C8C8; C8C9; C8C10; C8J4; C8J5; C8J6; C8M5; C8M8; C8P1; C8P2; C8P3; C8R1; C8R2; C8R3; C8T3; C8V1; C9F4; C9H5; C9V2; C9V4; C9V5; C9V6; C9W2; C9W3 |
SMC0402 | A36096-046 | 1000pF | DISCRETE | 3 | C1E7; C1G2; C3N13 |
SMC0402 | A36094-025 | 10pF | DISCRETE | 7 | C1M1; C1N2; C2M4; C2M5; C2N3; C2N4; C7A7 |
SMC0402 | A36095-030 | 22pF | DISCRETE | 4 | C1N1; C2B1; C2N1; C2N2 |
SMC0402 | A36096-073 | 0.022uF | DISCRETE | 2 | C2U6; C5G6 |
SMC0402 | A36096-024 | 390pF | DISCRETE | 2 | C3N9; C3N12 |
SMC0402 | A36096-022 | 2200pF | DISCRETE | 1 | C3N10 |
SMC0402 | C96005-001 | 0.1uF | DISCRETE | 4 | C7M6; C7M8; C8M6; C8M7 |
SMC0603 | 603275-169 | 47pF | DISCRETE | 2 | C1B1; C1B2 |
SMC0603 | 626747-055 | 1000pF | DISCRETE | 5 | C1E6; C4G3; C5B7; C6D11; C6D13 |
SMC0603 | 603275-159 | 100pF | DISCRETE | 1 | C1E8 |
SMC0603 | 602433-023 | 0.22uF | DISCRETE | 10 | C1E11; C2C2; C3B5; C3B6; C3C1; C3N6; C3N15; C4V1; C5G7; C6R2 |
SMC0603 | 602433-020 | 0.1uF | DISCRETE | 50 | C1F1; C1V2; C1V3; C1V12; C1V13; C2U1; C2U2; C2U3; C2U4; C4B5; C4G9; C4V2; C4V4; C4V5; C4W1; C5B1; C5G5; C5V2; C6B5; C6B7; C6B9; C6B10; C6C9; C6D1; C6F2; C6F3; C6T2; C6U2; C6U3; C6U4; C6U5; C7B5; C7B6; C7B7; C7C13; C7C14; C7H1; C7R7; C7V4; C7Y1; C8B4; C8B5; C8B7; C8B9; C8M1; C8M2; C8M11; C8V2; C9B2; C9W4 |
SMC0603 | CAPC,X7R,0603,16V, 10%,0.1UF_SM | 0.1uF | DISCRETE | 59 | C1F2; C1F3; C1G6; C1G8; C1G9; C1H2; C1T2; C1W1; C1W3; C1W5; C1W6; C1W8; C2B4; C2G3; C2G5; C2G6; C2G12; C2G16; C2H4; C2V2; C2W1; C2W3; C2W4; C2W5; C3B4; C3G16; C3H8; C3N5; C3N7; C3W2; C3W4; C3W8; C4G1; C4G2; C4G8; C4U2; C5E4; C5U2; C5V4; C5V6; C5W9; C5Y1; C6E1; C6M1; C6M4; C6M8; C6M9; C6T1; C7N1; C7N2; C7N3; C7N4; C8A3; C8A4; C8A5; C9H1; C9H2; C9H3; C9H4 |
SMC0603 | 602433-052 | 1uF | DISCRETE | 11 | C1H1; C2H1; C3B10; C3W5; C4A2; C4F2; C4G4; C6D12; C6E4; C7A5; C7V3 |
SMC0603 | 602431-033 | .01uF | DISCRETE | 2 | C1P3; C2N5 |
SMC0603 | CAPC,Y5V,0603,25V,80/-20%,.33UF | 0.33uF | DISCRETE | 5 | C1T4; C3H2; C5N1; C5N2; C5N3 |
SMC0603 | 202341-010 | 0.33uF | DISCRETE | 1 | C1V1 |
SMC0603 | 602431-004 | 220PF | DISCRETE | 3 | C2B2; C6M6; C9F3 |
SMC0603 | 602433-026 | 2.2uF | DISCRETE | 8 | C2F2; C2G4; C2G11; C3G14; C3G28; C4G5; C4G7; C5V7 |
SMC0603 | 603275-163 | 220pF | DISCRETE | 4 | C2H2; C2H3; C4H1; C5H7 |
SMC0603 | 602431-026 | 1000pF | DISCRETE | 11 | C2N6; C3B7; C4C2; C4P1; C6W4; C6Y1; C7R6; C7W1; C8H2; C8W3; C9H6 |
SMC0603 | 603269-058 | 0.01UF | DISCRETE | 11 | C2N7; C3B11; C3W7; C4V3; C5F1; C5U1; C5V1; C5W10; C7A6; C7C4; C7D17 |
SMC0603 | 603269-061 | 4700PF | DISCRETE | 2 | C2U5; C3W3 |
SMC0603 | 602433-019 | .068uF | DISCRETE | 1 | C3B8 |
SMC0603 | 602433-075 | 10uF | DISCRETE | 36 | C3G1; C3G4; C3G5; C3G6; C3G8; C3G9; C3G10; C3G13; C3G15; C3G19; C3G20; C3G21; C3G23; C3G24; C3G26; C3G29; C3R10; C3R11; C3R12; C3R13; C4D4; C4D5; C4D6; C4D7; C4R2; C4R3; C4R4; C5V3; C5V5; C6F4; C6F5; C6F6; C6U6; C7E6; C7E7; C7G7 |
SMC0603 | 602433-021 | 0.22uF | DISCRETE | 2 | C3H4; C3H5 |
SMC0603 | 602431-005 | 470PF | DISCRETE | 10 | C3M2; C3M3; C4N1; C4N2; C4N3; C4N4; C7V5; C7W3; C8W1; C8W4 |
SMC0603 | CAPC,X5R,0603,10V,10%,0.33UF_SM | 0.33uF | DISCRETE | 1 | C3N11 |
SMC0603 | 602433-038 | 4.7uF | DISCRETE | 6 | C4D1; C6G1; C6G11; C6U7; C7M3; C7M4 |
SMC0603 | 603275-162 | 22pF | DISCRETE | 1 | C5E2 |
SMC0603 | 202341-026 | 1uF | DISCRETE | 2 | C5G1; C5G2 |
SMC0603 | 603269-050 | 100pF | DISCRETE | 1 | C5H3 |
SMC0603 | 108425-108 | 470pF | DISCRETE | 5 | C5J1; C5J2; C5J3; C5J4; C5J5 |
SMC0603 | 603275-166 | 33pF | DISCRETE | 2 | C5W6; C6W3 |
SMC0603 | 603275-161 | 18PF | DISCRETE | 6 | C7E3; C7E4; C7F2; C7G1; C9V3; C9W1 |
SMC0603 | 603275-165 | 27pF | DISCRETE | 2 | C7M5; C7M7 |
SMC0805 | 108426-155 | 0.1uF | DISCRETE | 2 | C1F5; C2E6 |
SMC0805 | 644066-066 | 0.47uF | DISCRETE | 2 | C1V6; C2E10 |
SMC0805 | 644066-070 | 22uF | DISCRETE | 44 | C2A1; C2A2; C2D1; C2P6; C2R1; C3D1; C3D2; C3D3; C3D4; C3D5; C3D6; C3D7; C3D8; C3D9; C3D10; C3D11; C3D12; C3D13; C3D14; C3P13; C3P15; C3P19; C3R1; C3R2; C3R3; C3R4; C3R5; C3R6; C3R7; C3R8; C3R9; C3T56; C3T57; C4D2; C4D3; C4D8; C4D9; C4D10; C4R1; C5M1; C5M7; C6U1; C7T4; C7T5 |
SMC0805 | 644066-099 | 10uF | DISCRETE | 26 | C2C9; C2C10; C2P7; C2P8; C2P9; C2P10; C3C6; C3C7; C3C8; C3C9; C3C10; C3C11; C3C12; C3C13; C3P7; C3P8; C3P9; C3P10; C3P11; C3P12; C3P14; C3P16; C3P17; C3P18; C5D5; C5E1 |
SMC0805 | 644066-065 | 1uF | DISCRETE | 4 | C2N9; C3B9; C3H3; C3N14 |
SMC0805 | 644066-038 | 10uF | DISCRETE | 14 | C3H6; C3H7; C3H9; C3W6; C4R5; C4R6; C4R7; C5G4; C5W1; C6V1; C6W1; C7A1; C7M1; C8A1 |
SMC0805 | 644066-033 | 4.7uF | DISCRETE | 1 | C3W1 |
SMC0805 | 644066-075 | 1.0uF | DISCRETE | 2 | C7E1; C8T2 |
SMC1206 | 644066-068 | 4.7uF | DISCRETE | 1 | C1G3 |
SMC1206 | 644066-059 | 4.7uF | DISCRETE | 3 | C1G5; C1V10; C9G1 |
SMC1206 | 644066-026 | 1.0uF | DISCRETE | 2 | C2B6; C3B12 |
SMC1206 | C34226-002 | 4.7uF | DISCRETE | 5 | C2C1; C2P1; C3B13; C3B15; C3N17 |
SMC1206 | 108426-197 | 10uF | DISCRETE | 8 | C2E4; C2E5; C2E8; C2E9; C4F1; C4U1; C6E3; C6R1 |
SMC1206 | 644066-023 | 3.3uF | DISCRETE | 1 | C2V1 |
SMC1210 | 202170-026 | 10uF | DISCRETE | 7 | C1G4; C1W2; C1Y1; C3W9; C4W2; C4W3; C9B3 |
SMC1210 | 644066-020 | 1uF | DISCRETE | 3 | C1U2; C1V4; C2F3 |
SMC1812 | 644066-045 | 22uF | DISCRETE | 4 | C1F4; C1V5; C1V7; C1V8 |
SMC3528 | 202244-073 | 22UF | DISCRETE | 33 | C1V14; C2V3; C6B1; C6B13; C6B17; C6B18; C6B19; C6D3; C6D8; C6H2; C7B3; C7B9; C7B10; C7B13; C7D6; C7D11; C7D18; C7G29; C7H2; C7T3; C8A7; C8B12; C8C2; C8E1; C8E2; C8F1; C8H1; C8J1; C8J3; C9B1; C9B6; C9E1; C9E2 |
SMC3528 | C19323-003 | 6.8uF | DISCRETE | 2 | C8A2; C8A6 |
SMC7343 | 724613-038 | 15uF | DISCRETE | 6 | C1F6; C1G1; C1U1; C2F4; C5H8; C9J1 |
SMC7343 | 724613-024 | 220uF | DISCRETE | 14 | C3A2; C3A3; C3B3; C4B1; C4B2; C4B3; C5H4; C5W2; C5W3; C5W5; C7G30; C7H5; C7H6; C8G2 |
SMC7343 | 201062-039 | 22UF | DISCRETE | 15 | C4B6; C5B2; C6B2; C6B3; C6B4; C6B6; C6B8; C6C8; C7B1; C7B2; C7B4; C7C10; C8B1; C8B2; C8B3 |
SMC7343 | 660676-047 | 22UF | DISCRETE | 2 | C4G6; C5H1 |
SMC7343 | 660676-044 | 100uF | DISCRETE | 4 | C5B3; C7H3; C8B8; C8J2 |
SMC7343 | 724613-025 | 220uF | DISCRETE | 2 | C5H5; C5W7 |
SMC7343_75H | 724613-039 | 330uF | DISCRETE | 4 | C3G7; C3G22; C3U1; C4E3 |
SMC7343_75H | 724613-005 | 100uF | DISCRETE | 1 | C7G28 |
SMC7343_82H | 699013-021 | 330uF | DISCRETE | 11 | C4E1; C4E2; C4T1; C4T2; C4T3; C4T4; C4T5; C5E3; C5T7; C6E5; C7E2 |
SMC7343_82H | A77670-008 | 220uF | DISCRETE | 2 | C6E6; C6F1 |
SMC7343_91H | CAPS,AL-P,V,2.0V,20%,470UF_SMC7 | 470uF | DISCRETE | 6 | C2C7; C2C12; C2P11; C3C4; C3C5; C3P20 |
SMC7343_110H | CAPT,TANT,D,20V,20%,47UF_SMC734 | 47uF | DISCRETE | 12 | C1G7; C1V9; C2B5; C2N8; C2P4; C2P5; C3B14; C3N16; C3P5; C3P6; C4P2; C4P3 |
SMC7343_158H | 724613-042 | 330uF | DISCRETE | 2 | C5H2; C5W4 |
SMCA1206 | 661870-020 | 47PF | DISCRETE | 1 | CP1M1 |
SMD1811 | C82435-001 | B320A | DISCRETE | 8 | CR1E1; CR1G1; CR1V1; CR2C1; CR3C1; CR3C2; CR4F1; CR6D2 |
SMESD0603 | A53075-002 | Clamping-Diode | DISCRETE | 2 | CR2A1; CR2A2 |
SMF0603 | 693286-001 | 60ohm@100MHz | IC | 6 | FB1A2; FB1A3; FB1A4; FB1A6; FB1A7; FB1A8 |
SMF0603 | 693286-006 | 47ohm@100MHz | DISCRETE | 6 | FB1A9; FB1B1; FB2A1; FB2A2; FB2B2; FB2B3 |
SMF0603 | 693286-021 | 30ohm@100MHz | IC | 1 | FB4E1 |
SMF0603 | 693286-026 | 180ohm@100MHz | IC | 3 | FB5D1; FB5D2; FB7E1 |
SMF1206 | 651080-001 | 31Ohm@100MHz | IC | 1 | FB1A1 |
SMF1206 | 651080-019 | 50OHM | IC | 11 | FB1B2; FB3N1; FB3N2; FB3N3; FB4N1; FB4N2; FB4N3; FB7J1; FB7V1; FB7W1; FB8V1 |
SMFA1206 | 657300-009 | 60OHM-100MHZ | IC | 2 | FB1A5; FB2B1 |
SML0603 | 202287-105 | 1uH | DISCRETE | 3 | L3E1; L6F2; L6F3 |
SML0603 | 202287-104 | 10uH | DISCRETE | 4 | L6E1; L6F1; L6G1; L7E1 |
SML0805 | 721891-052 | 0.10uH | DISCRETE | 1 | L6T1 |
SML2824 | SML2824 | 1k@100MHz | DISCRETE | 1 | L1F1 |
SML-LPS3015 | INDCT,PWR,LPS3015,2.2UH_SML-LPS | 2.2uH | DISCRETE | 1 | L5E1 |
SMLED0805 | C97278-001 | GREEN | DISCRETE | 20 | CR1B1; CR1B2; CR1B3; CR1B4; CR1B5; CR1B6; CR1B7; CR5G2; CR5G3; CR5G4; CR5G5; CR5G6; CR5G7; CR5G8; CR6D1; CR7G1; CR7G2; CR9G1; CR9G2; CR9G3 |
SML_10X11_5MM | C74675-002 | 0.45uH | DISCRETE | 5 | L1D1; L2C1; L3C1; L4C1; L4F1 |
SML_10X11_5MM | E28752-002 | 2.2uH | DISCRETE | 2 | L4H1; L5G1 |
SML_10X11_5MM | D25752-001 | 0.88uH | DISCRETE | 2 | L4H2; L6D1 |
SMR0402 | A93548-034 | 10K | DISCRETE | 8 | R1D10; R1H9; R1H10; R3M3; R3N11; R5E7; R6B1; R7G6 |
SMR0402 | A93549-019 | 3.3K | DISCRETE | 7 | R1E1; R8P3; R8P4; R8P5; R8P7; R8R6; R8R8 |
SMR0402 | A93549-023 | 10K | DISCRETE | 124 | R1E3; R1E5; R1E8; R1E12; R1J1; R1N2; R1N5; R1N7; R1N9; R1N12; R1N17; R1N21; R1T6; R1T18; R1U9; R1W7; R1W8; R1W9; R1W10; R1W11; R1W14; R1Y1; R1Y5; R2B20; R2H5; R2H16; R2H17; R2N1; R2T5; R2T8; R2W11; R4B2; R4D5; R4D6; R5B3; R5C15; R5D4; R5M11; R5M12; R5M13; R5M14; R5P1; R5P8; R5W2; R6C9; R6C10; R6C11; R6C15; R6E2; R6E4; R6G4; R6G11; R6G12; R6H1; R6V21; R6V22; R7A7; R7D7; R7F7; R7G5; R7G15; R7N5; R7N6; R7R1; R7T2; R7T4; R7T11; R7U13; R7V8; R7V15; R7Y1; R8A3; R8A5; R8A8; R8E7; R8E9; R8F3; R8F19; R8F23; R8G3; R8G6; R8G8; R8G12; R8G15; R8G16; R8G17; R8G19; R8G20; R8H2; R8H9; R8M2; R8M6; R8M7; R8M13; R8R12; R8V17; R8V19; R8V20; R8W1; R8W3; R8W4; R8W5; R8W6; R8W7; R8W8; R8W9; R8W10; R9G14; R9G20; R9H5; R9H10; R9H16; R9M4; R9M5; R9M7; R9P6; R9P7; R9R1; R9V2; R9V25; R9V26; R9W6; R9W7; R9W9 |
SMR0402 | A93548-214 | 68.1K | DISCRETE | 1 | R1E4 |
SMR0402 | A93549-001 | 0 | DISCRETE | 147 | R1E7; R1G13; R1N23; R1P4; R1P8; R1P22; R1R22; R1R24; R1R25; R1R27; R1R28; R1R33; R1T2; R1T14; R1V14; R1V16; R2B25; R2B30; R2B31; R2B32; R2B34; R2F4; R2M3; R2N5; R2P2; R2R3; R2R4; R2R6; R2R12; R2T1; R2T6; R2T9; R2T10; R2T11; R2U11; R3H2; R3N2; R3W6; R3W9; R3W10; R4B9; R4B10; R4N10; R4N12; R5A1; R5A2; R5C1; R5C3; R5C17; R5D3; R5E8; R5E9; R5E10; R5E11; R5E12; R5E13; R5E14; R5E15; R5E16; R5E17; R5E18; R5E19; R5E20; R5E21; R5E22; R5E23; R5F1; R5F2; R5F4; R5F5; R5F6; R5F7; R5F8; R5F10; R5F11; R5F12; R5F13; R5F14; R5F15; R5F16; R5F17; R5F20; R5F21; R5F22; R5G15; R5M16; R5P2; R5P5; R5P6; R5P7; R5R3; R5R4; R5R5; R5R6; R5R7; R5R8; R5U2; R5U4; R5U18; R6E3; R6E12; R6E13; R6F1; R6T3; R6U23; R7A13; R7G1; R7G2; R7G7; R7G14; R7T19; R7T22; R7T23; R7T24; R7T32; R7U12; R7U14; R7U15; R7V5; R7V7; R7V10; R8E4; R8E8; R8F4; R8F5; R8F7; R8F8; R8F10; R8F11; R8F13; R8F14; R8F17; R8F21; R8P6; R8P8; R8P9; R8R1; R8R2; R8U2; R8U4; R8U5; R8U6; R8U7; R8V21; R9P9; R9P10; R9P13 |
SMR0402 | A93549-002 | 10 | DISCRETE | 9 | R1E9; R1E10; R1T9; R1T19; R2F8; R2R10; R2R11; R2T15; R2U16 |
SMR0402 | A93548-023 | 1K | DISCRETE | 7 | R1E11; R1V12; R1V13; R3N25; R3W3; R7G8; R9F9 |
SMR0402 | A93549-020 | 4.7K | DISCRETE | 11 | R1F3; R1T5; R1W12; R1W13; R1W15; R1W16; R9H1; R9H3; R9V14; R9V15; R9V16 |
SMR0402 | A93549-027 | 100K | DISCRETE | 16 | R1G2; R1G10; R2B23; R2B36; R2V7; R2V10; R2V11; R5F3; R5G7; R5T2; R7D10; R8F18; R8M5; R9F4; R9F10; R9P12 |
SMR0402 | A93549-009 | 100 | DISCRETE | 5 | R1G4; R1V4; R2T16; R7T1; R8R4 |
SMR0402 | A93549-016 | 1K | DISCRETE | 41 | R1G7; R1N24; R1R10; R1R11; R1R12; R1T4; R2F11; R2G1; R3H11; R3N1; R3N3; R3N8; R3N9; R3W8; R4B4; R4B6; R4H9; R5G23; R6M3; R6M7; R6M8; R6M9; R7E1; R7E9; R7F5; R7G3; R7H2; R7H3; R7V12; R7V14; R7Y2; R7Y3; R8A4; R8F9; R8G4; R8H10; R8V13; R8V15; R9B6; R9D2; R9G5 |
SMR0402 | A93548-005 | 150 | DISCRETE | 6 | R1N1; R2N7; R2N8; R7T5; R7T6; R7T7 |
SMR0402 | A93549-003 | 22 | DISCRETE | 27 | R1T7; R1T10; R1V15; R3H6; R5R1; R5R2; R6M1; R6M2; R6M10; R6V6; R6V7; R6V8; R6V9; R6V20; R7E5; R7E6; R7M10; R7M11; R7T12; R7T21; R7T25; R7T27; R7T29; R7T30; R7T31; R7Y4; R7Y5 |
SMR0402 | A93548-128 | 100K | DISCRETE | 16 | R1V7; R1W6; R2E6; R2F1; R2G7; R2U8; R2V9; R3B1; R3B2; R3M4; R3M5; R5V16; R7C12; R7C14; R7P7; R7P9 |
SMR0402 | A93548-059 | 475 | DISCRETE | 2 | R1V10; R2V16 |
SMR0402 | A93548-276 | 80.6 | DISCRETE | 1 | R1V11 |
SMR0402 | A93549-028 | 1M | DISCRETE | 10 | R1W4; R1Y3; R2V14; R3B3; R7E4; R7W2; R7W3; R8W18; R8W20; R9H15 |
SMR0402 | A93548-044 | 3.32K | DISCRETE | 4 | R2B17; R3N5; R3N10; R3N14 |
SMR0402 | A93548-061 | 8.06K | DISCRETE | 1 | R2B24 |
SMR0402 | A93548-045 | 49.9 | DISCRETE | 28 | R2D15; R2D18; R2T7; R4D3; R4P8; R4P9; R4P11; R4P17; R4P23; R5H6; R6C18; R6C19; R6T5; R6T6; R6U1; R6U3; R6U6; R6U9; R7C17; R7C18; R7M7; R7M8; R7M12; R7M13; R8M11; R8M12; R8M14; R8M15 |
SMR0402 | A93548-053 | 20 | DISCRETE | 4 | R2D16; R2D17; R7E12; R7E13 |
SMR0402 | RESD,0402,1%,1/16W,3.01K_SMR040 | 3.01K | IC | 1 | R2E1 |
SMR0402 | RESD,0402,1%,1/16W,1.1K_SMR0402 | 1.1K | DISCRETE | 2 | R2E2; R3N27 |
SMR0402 | A93548-018 | 12.1K | DISCRETE | 4 | R2F5; R2F6; R2U12; R2U13 |
SMR0402 | A93549-051 | 2.2 | DISCRETE | 2 | R2F7; R2U14 |
SMR0402 | A93548-290 | 169K | DISCRETE | 1 | R2G5 |
SMR0402 | A93548-433 | 147K | DISCRETE | 3 | R2G9; R2N25; R5V13 |
SMR0402 | A93549-017 | 2.2K | DISCRETE | 20 | R2M1; R2M2; R2M4; R2M5; R2M10; R2M11; R4P2; R4P3; R5D1; R6C17; R7E17; R7G18; R7V3; R7V4; R8G21; R8H3; R8V18; R8W11; R9P8; R9P11 |
SMR0402 | A93549-022 | 8.2K | DISCRETE | 7 | R2N6; R2N9; R2N12; R2N15; R2N19; R2N24; R2N28 |
SMR0402 | RESD,0402,1%,1/16W,931_SMR0402_ | 931 | DISCRETE | 1 | R2N14 |
SMR0402 | A93548-221 | 32.4K | DISCRETE | 1 | R2V4 |
SMR0402 | A93548-186 | 200K | DISCRETE | 1 | R2V5 |
SMR0402 | A93548-210 | 1 | DISCRETE | 10 | R3B6; R3B7; R3B9; R3B10; R3B13; R3N13; R3N15; R3N17; R3N21; R7E10 |
SMR0402 | A93548-029 | 15 | DISCRETE | 5 | R3B17; R6G7; R7G9; R8P10; R8R3 |
SMR0402 | A93548-043 | 100 | DISCRETE | 8 | R3E1; R8A9; R8A10; R8A11; R9W1; R9W3; R9W5; R9W8 |
SMR0402 | A93548-067 | 24.9 | DISCRETE | 1 | R3E2 |
SMR0402 | A93548-078 | 130 | DISCRETE | 1 | R3E3 |
SMR0402 | A93548-011 | 649 | DISCRETE | 1 | R3N24 |
SMR0402 | A93548-072 | 51.1 | DISCRETE | 1 | R3N26 |
SMR0402 | A93548-227 | 11K | DISCRETE | 1 | R3N28 |
SMR0402 | A93548-138 | 2K | DISCRETE | 1 | R4V5 |
SMR0402 | A93549-036 | 20K | DISCRETE | 4 | R5B1; R8E2; R9R10; R9T2 |
SMR0402 | A93549-005 | 33 | DISCRETE | 21 | R5G13; R5G14; R5V15; R5V17; R6V10; R6V11; R6V12; R6V13; R6V14; R6V15; R6V16; R6V17; R6W2; R6W3; R6W4; R6W5; R6W6; R6W7; R8T2; R9R9; R9T3 |
SMR0402 | RESD,0402,1%,1/16W,110K_SMR0402 | 110K | DISCRETE | 1 | R5G18 |
SMR0402 | A93548-283 | 2.37K | DISCRETE | 2 | R5M3; R6F3 |
SMR0402 | A93548-201 | 806 | DISCRETE | 1 | R5M7 |
SMR0402 | A93549-076 | 56 | IC | 1 | R6G1 |
SMR0402 | A93548-192 | 3.24K | DISCRETE | 2 | R6M4; R8V14 |
SMR0402 | A93549-084 | 330K | DISCRETE | 1 | R7F6 |
SMR0402 | A93548-047 | 37.4 | DISCRETE | 1 | R7G10 |
SMR0402 | A93548-028 | 90.9 | DISCRETE | 1 | R7T28 |
SMR0402 | A93548-056 | 22.6 | DISCRETE | 1 | R7U10 |
SMR0402 | RESD,0402,5%,1/16W,200_SMR0402_ | 200 | DISCRETE | 3 | R7V6; R8V2; R8V3 |
SMR0402 | A93549-058 | 4.3 | DISCRETE | 1 | R8J1 |
SMR0402 | A93549-007 | 51 | IC | 1 | R8V10 |
SMR0603 | A93552-004 | 0 | DISCRETE | 447 | R1C1; R1C2; R1C3; R1C4; R1C5; R1C6; R1C7; R1D2; R1D3; R1D5; R1D6; R1D7; R1D9; R1D14; R1F2; R1G1; R1G12; R1H7; R1J2; R1J3; R1J4; R1J5; R1J6; R1R5; R1R6; R1R7; R1R8; R1R13; R1R14; R1R15; R1R16; R1R17; R1R18; R1R19; R1R20; R1R21; R1R23; R1R26; R1T3; R1T16; R1U2; R1V6; R1V8; R1W3; R1Y2; R1Y4; R1Y6; R1Y7; R1Y8; R2B1; R2B5; R2B9; R2B13; R2B15; R2B21; R2B28; R2B33; R2D1; R2D2; R2D5; R2D7; R2D9; R2D10; R2D12; R2D13; R2D14; R2E3; R2E4; R2E7; R2E8; R2E10; R2F9; R2F10; R2G6; R2G8; R2G11; R2G13; R2G16; R2G17; R2G19; R2G21; R2G22; R2H1; R2H3; R2H4; R2H9; R2H10; R2H11; R2H12; R2H14; R2H15; R2J1; R2J2; R2N11; R2N23; R2N30; R2P1; R2R7; R2R8; R2R9; R2T2; R2T3; R2T4; R2T12; R2T13; R2U15; R2U17; R2V2; R2V8; R2V15; R2W3; R2W4; R2W17; R2W18; R2W20; R2W21; R2W22; R3B21; R3H7; R3H8; R3H10; R3H14; R3J1; R3N6; R3N22; R3N30; R3N32; R3N33; R3N34; R3N35; R3P1; R3W1; R3W11; R3W12; R3W13; R3W14; R3W15; R3W16; R3W21; R3W22; R3W24; R4B11; R4C1; R4C2; R4D1; R4D2; R4D7; R4E2; R4E3; R4E5; R4E6; R4G4; R4N13; R4P1; R4P4; R4P5; R4P7; R4P10; R4P12; R4P13; R4P14; R4P15; R4P16; R4P18; R4P19; R4P20; R4P21; R4P22; R4R1; R4R8; R4T1; R4T2; R4T3; R4T4; R4T5; R4T6; R4T7; R4T8; R4T9; R4T10; R4V2; R4V3; R4V9; R5A3; R5C4; R5C5; R5C6; R5C7; R5C8; R5C9; R5C10; R5C11; R5C12; R5C13; R5C14; R5C16; R5C18; R5D2; R5D5; R5D8; R5D9; R5E4; R5E6; R5F25; R5F26; R5G8; R5G11; R5G16; R5G19; R5G21; R5H5; R5H9; R5H11; R5H12; R5H13; R5M1; R5M4; R5N4; R5N5; R5N6; R5T1; R5U9; R5U10; R5U13; R5V8; R5V11; R5V12; R5V14; R5V19; R5V21; R5V22; R5W3; R6A1; R6A2; R6B3; R6B4; R6C2; R6C3; R6C4; R6C5; R6C6; R6C7; R6C12; R6C13; R6C16; R6D1; R6D4; R6D7; R6E6; R6E7; R6E11; R6F2; R6F4; R6F5; R6F6; R6F7; R6F8; R6F9; R6F10; R6F11; R6F19; R6F21; R6F23; R6F24; R6F25; R6G2; R6G3; R6G10; R6H2; R6H3; R6P2; R6R3; R6R4; R6R5; R6R6; R6R9; R6T2; R6U4; R6U5; R6U7; R6U8; R6U18; R6U21; R6U22; R6U24; R6V27; R6V28; R6V29; R6W8; R6W11; R7A2; R7A3; R7A5; R7A6; R7A9; R7A11; R7A16; R7B1; R7B2; R7B3; R7B4; R7B5; R7C4; R7C5; R7C6; R7C7; R7C8; R7C9; R7C10; R7C11; R7C13; R7C15; R7C16; R7C19; R7C20; R7C21; R7D1; R7D2; R7D4; R7D6; R7E2; R7E3; R7E11; R7E14; R7E16; R7G4; R7G12; R7G13; R7M1; R7M2; R7N2; R7N3; R7N4; R7P3; R7P4; R7R6; R7R7; R7R8; R7R9; R7T13; R7T15; R7T16; R7T17; R7T18; R7T34; R7T35; R7U3; R7U4; R7U5; R7U6; R7U7; R7V9; R8A1; R8A2; R8A6; R8A7; R8B2; R8C2; R8E10; R8E11; R8E12; R8E14; R8F1; R8F2; R8F15; R8F16; R8F22; R8F27; R8G5; R8G11; R8G14; R8H1; R8H5; R8H6; R8H7; R8H8; R8H11; R8M3; R8M17; R8N2; R8P1; R8P2; R8R7; R8T6; R8U12; R8V5; R8V7; R8V8; R8V16; R8W12; R8W13; R8W14; R8W15; R8W16; R8W17; R8W19; R9A2; R9A3; R9B1; R9B2; R9B7; R9B8; R9C1; R9C2; R9C3; R9C4; R9C5; R9C6; R9C7; R9E2; R9E4; R9E5; R9E7; R9E8; R9E9; R9E10; R9F2; R9F5; R9F6; R9F8; R9F11; R9H2; R9H4; R9H8; R9N4; R9N5; R9N6; R9N7; R9P1; R9P2; R9P3; R9P4; R9P5; R9R3; R9R4; R9R8; R9T1; R9T4; R9T5; R9U1; R9V7; R9V9; R9V10; R9V11; R9V12; R9V17; R9W2 |
SMR0603 | A93550-095 | 3.01k | DISCRETE | 13 | R1D1; R1D4; R1R2; R2D3; R2D4; R2D6; R2D8; R2R1; R2R2; R2R5; R7A14; R7M5; R7M6 |
SMR0603 | A93551-021 | 68 | DISCRETE | 4 | R1D8; R1D11; R2N21; R4N5 |
SMR0603 | A93550-089 | 2.49K | DISCRETE | 2 | R1D12; R1D13 |
SMR0603 | A93550-076 | 1.5K | DISCRETE | 1 | R1D15 |
SMR0603 | A93550-299 | 150K | DISCRETE | 1 | R1E6 |
SMR0603 | A93550-116 | 10K | DISCRETE | 19 | R1F1; R1T21; R2W7; R2W8; R2W10; R2W12; R3W17; R4H10; R5F19; R5H10; R5U11; R5U12; R5U14; R5W4; R5W7; R7H1; R7T3; R8T5; R9W13 |
SMR0603 | A93551-133 | 2.2 | DISCRETE | 1 | R1G5 |
SMR0603 | A93550-160 | 49.9K | DISCRETE | 10 | R1G6; R2E9; R2U3; R3B14; R3B15; R3W7; R4G5; R4V6; R6D8; R6D10 |
SMR0603 | A93551-073 | 10K | DISCRETE | 106 | R1G9; R1H1; R1H4; R1N3; R1N16; R1P10; R1T12; R1W1; R1W2; R2G2; R2G3; R2G12; R2G14; R2H6; R2H7; R2H18; R2V1; R2W9; R2W14; R2W15; R2W19; R3B22; R3H12; R3H13; R3W2; R3W4; R3W28; R4F6; R4H4; R4H5; R4H6; R4N4; R4V1; R4W1; R4W2; R4W4; R4W6; R5A4; R5J1; R5J4; R5M2; R5M6; R5M8; R5M9; R5M10; R5M15; R5P3; R5P4; R5U5; R5W5; R5W8; R5Y2; R5Y3; R6C8; R6D3; R6D6; R6M5; R6M6; R6P3; R6V26; R7A4; R7C2; R7C3; R7D5; R7M3; R7M9; R7N7; R7N8; R8G18; R8M1; R8T1; R9A1; R9B9; R9E11; R9F1; R9F3; R9F7; R9G9; R9G10; R9G11; R9G15; R9G16; R9G17; R9G18; R9G19; R9G21; R9G22; R9G23; R9G24; R9H6; R9H7; R9H9; R9H11; R9H12; R9M1; R9M2; R9M3; R9U2; R9V3; R9V4; R9V5; R9V6; R9V13; R9V22; R9V23; R9W10 |
SMR0603 | A93550-321 | 16.9K | DISCRETE | 1 | R1G11 |
SMR0603 | A93550-136 | 20K | DISCRETE | 6 | R1H2; R2A1; R3B5; R5G20; R5V18; R8T7 |
SMR0603 | A93551-049 | 1K | DISCRETE | 51 | R1H3; R1N15; R1N19; R1N20; R1P2; R1P3; R1P5; R1P6; R2B7; R2B11; R2B12; R2B16; R2B19; R2B22; R2B26; R2B27; R2B29; R2B35; R2N10; R2N13; R2N16; R2N18; R2N20; R2N22; R2N26; R2N31; R2V13; R5G2; R5J5; R5P9; R5W6; R6C1; R6D5; R6G9; R6M11; R6M12; R6R1; R6V19; R6V23; R6V25; R6W12; R7F1; R7P8; R8E5; R8E6; R8E13; R8H14; R8M16; R8W2; R8W22; R9N3 |
SMR0603 | A93551-097 | 100K | DISCRETE | 57 | R1H5; R1H8; R1T20; R1U7; R1U8; R1V2; R1V3; R2F2; R2H19; R2U7; R2V12; R2W5; R2W13; R2W16; R3W23; R4B3; R4B5; R4B7; R4B8; R4F2; R4F3; R4F4; R4F5; R4G6; R4G7; R4N2; R4N7; R4N14; R4V4; R4V10; R4V12; R4V13; R4V14; R5H8; R5U6; R5U7; R5U15; R5U16; R5U17; R5V1; R5V10; R5Y1; R6D2; R6E1; R6R2; R6T7; R7D9; R7P1; R7P2; R7R4; R7R5; R8V12; R9F12; R9G1; R9G2; R9G3; R9V24 |
SMR0603 | A93550-392 | 4.7K | DISCRETE | 2 | R1H6; R3N4 |
SMR0603 | A93551-037 | 330 | DISCRETE | 13 | R1N4; R1N6; R1N8; R1N10; R1N14; R1N18; R1N22; R5J2; R5J3; R7T9; R7V11; R7V13; R8M19 |
SMR0603 | A93550-067 | 1K | DISCRETE | 3 | R1N11; R1N13; R4P6 |
SMR0603 | A93551-071 | 8.2K | DISCRETE | 14 | R1P1; R1P7; R1P9; R1P11; R1P12; R1P13; R1P14; R1P15; R1P17; R8F25; R8M8; R8U8; R9V21; R9W4 |
SMR0603 | A93551-041 | 470 | DISCRETE | 4 | R1P18; R2T17; R4N8; R6T9 |
SMR0603 | A93551-017 | 47 | DISCRETE | 3 | R1P19; R1P20; R1P21 |
SMR0603 | A93551-018 | 51 | DISCRETE | 6 | R1R1; R1R3; R1R4; R1R9; R1R29; R1R30 |
SMR0603 | A93550-062 | 750 | DISCRETE | 2 | R1R31; R4R6 |
SMR0603 | A93551-121 | 1M | DISCRETE | 14 | R1R32; R2U9; R4N1; R5G4; R5U1; R6W19; R6W20; R6W21; R6W22; R7R3; R8H12; R8W21; R9W11; R9Y1 |
SMR0603 | A93550-108 | 6.81K | DISCRETE | 2 | R1T8; R1W5 |
SMR0603 | RESD,0603,1%,1/10W,14.3K_SMR060 | 14.3K | DISCRETE | 1 | R1T13 |
SMR0603 | A93550-146 | 30.1K | DISCRETE | 3 | R1T15; R1U3; R1U4 |
SMR0603 | A93550-126 | 13.7K | DISCRETE | 1 | R1T17 |
SMR0603 | A93550-174 | 100K | DISCRETE | 8 | R1U1; R2B10; R3H3; R3H4; R3N16; R3N20; R3W5; R5G12 |
SMR0603 | A93551-088 | 43K | DISCRETE | 3 | R1U5; R9H13; R9H14 |
SMR0603 | A93551-080 | 20K | DISCRETE | 6 | R1U6; R2U10; R5G3; R5G5; R7P6; R8C3 |
SMR0603 | A93551-111 | 390K | DISCRETE | 2 | R1V1; R5W10 |
SMR0603 | A93551-025 | 100 | DISCRETE | 12 | R1V5; R2N32; R2N34; R7F2; R7G11; R7T10; R8M18; R8T4; R9F13; R9G4; R9V1; R9W12 |
SMR0603 | A93550-154 | 40.2K | DISCRETE | 1 | R1V9 |
SMR0603 | A93551-065 | 4.7K | DISCRETE | 22 | R2A3; R2A4; R2A5; R2A6; R2B2; R2B3; R2B4; R2M6; R2M7; R2M8; R2M9; R2N2; R2N3; R2N4; R3M1; R3M2; R9G12; R9G13; R9V8; R9V18; R9V19; R9V20 |
SMR0603 | A93550-010 | 27.4 | DISCRETE | 2 | R2B6; R2B8 |
SMR0603 | A93550-123 | 12.4K | DISCRETE | 3 | R2B14; R2E5; R2W2 |
SMR0603 | A93550-098 | 4.02K | DISCRETE | 2 | R2B18; R2W1 |
SMR0603 | A93550-305 | 237K | DISCRETE | 1 | R2F3 |
SMR0603 | A93550-178 | 162K | DISCRETE | 1 | R2G10 |
SMR0603 | A93550-411 | 15K | DISCRETE | 3 | R2G18; R3N18; R3N23 |
SMR0603 | A93550-135 | 18.7K | DISCRETE | 1 | R2G20 |
SMR0603 | A93550-235 | 3.57K | DISCRETE | 1 | R2N17 |
SMR0603 | A93550-084 | 2K | DISCRETE | 2 | R2N27; R8H4 |
SMR0603 | A93550-053 | 499 | DISCRETE | 1 | R2N29 |
SMR0603 | A93550-119 | 11K | DISCRETE | 1 | R2P3 |
SMR0603 | A93550-017 | 49.9 | DISCRETE | 6 | R2U2; R2U4; R2U5; R2U6; R3C2; R6U12 |
SMR0603 | A93550-422 | 95.3K | DISCRETE | 1 | R2V3 |
SMR0603 | A93550-185 | 232K | DISCRETE | 1 | R2V6 |
SMR0603 | D76451-007 | 470 | DISCRETE | 2 | R2W6; RT3B1 |
SMR0603 | A93550-124 | 13K | DISCRETE | 4 | R3B4; R5F23; R5F24; R5G22 |
SMR0603 | A93550-157 | 45.3K | DISCRETE | 2 | R3B8; R3B11 |
SMR0603 | A93550-118 | 10.7K | DISCRETE | 3 | R3B12; R3N12; R3N19 |
SMR0603 | A93550-086 | 2.21K | IC | 2 | R3B16; R3B19 |
SMR0603 | A93550-036 | 200 | DISCRETE | 1 | R3B18 |
SMR0603 | A93551-001 | 10 | DISCRETE | 3 | R3H1; R4V8; R6D9 |
SMR0603 | A93550-347 | 11.3K | DISCRETE | 1 | R3H5 |
SMR0603 | A93550-001 | 10 | DISCRETE | 2 | R3N7; R3N36 |
SMR0603 | A93550-224 | 82.5 | DISCRETE | 1 | R3N29 |
SMR0603 | RESD,0603,1%,1/10W,1.54K_SMR060 | 1.54K | DISCRETE | 1 | R3N31 |
SMR0603 | D76451-006 | 470 | DISCRETE | 2 | R3U3; RT3P1 |
SMR0603 | A93550-251 | 71.5K | DISCRETE | 1 | R3W18 |
SMR0603 | A93553-053 | 38.3K | DISCRETE | 1 | R3W20 |
SMR0603 | A93551-013 | 33 | DISCRETE | 43 | R4E1; R4E4; R5D6; R5D7; R5H3; R6V1; R6V2; R6V3; R6V4; R6V24; R6W1; R6W9; R6W10; R6W13; R6W14; R6W15; R6W16; R8E3; R8F6; R8F20; R8F24; R8F26; R8F28; R8G1; R8G2; R8G7; R8G9; R8G10; R8G13; R8U9; R8U10; R8U11; R8V1; R8V4; R8V6; R8V9; R9D4; R9E1; R9E3; R9R2; R9R5; R9R6; R9R7 |
SMR0603 | A93550-182 | 200K | DISCRETE | 1 | R4G1 |
SMR0603 | A93550-139 | 22.1K | DISCRETE | 1 | R4G2 |
SMR0603 | A93550-196 | 634K | DISCRETE | 2 | R4G3; R6R7 |
SMR0603 | A93551-033 | 220 | DISCRETE | 1 | R4N9 |
SMR0603 | A93550-165 | 60.4K | DISCRETE | 1 | R4V7 |
SMR0603 | A93551-105 | 220K | DISCRETE | 1 | R4W7 |
SMR0603 | A93551-103 | 180K | DISCRETE | 1 | R5E2 |
SMR0603 | A93551-110 | 360K | DISCRETE | 1 | R5E3 |
SMR0603 | A93550-141 | 24.9K | DISCRETE | 1 | R5F18 |
SMR0603 | A93550-190 | 340K | DISCRETE | 1 | R5G9 |
SMR0603 | A93550-275 | 620k | DISCRETE | 1 | R5G10 |
SMR0603 | A93550-287 | 113K | DISCRETE | 1 | R5G17 |
SMR0603 | A93550-337 | 15 | DISCRETE | 1 | R5H2 |
SMR0603 | A93550-254 | 3.32k | DISCRETE | 1 | R5U8 |
SMR0603 | A93551-022 | 75 | DISCRETE | 7 | R5V2; R5V3; R5V4; R5V5; R5V6; R5V7; R5V9 |
SMR0603 | A93550-398 | 29.4K | DISCRETE | 1 | R5V20 |
SMR0603 | A93550-041 | 301 | DISCRETE | 1 | R6A3 |
SMR0603 | A93550-058 | 619 | DISCRETE | 1 | R6A4 |
SMR0603 | A93550-188 | 287K | DISCRETE | 1 | R6E5 |
SMR0603 | A93551-019 | 56 | DISCRETE | 2 | R6F17; R6F26 |
SMR0603 | A93550-216 | 32.4 | DISCRETE | 1 | R6G8 |
SMR0603 | A93550-162 | 54.9K | DISCRETE | 1 | R6R8 |
SMR0603 | A93550-169 | 75K | DISCRETE | 1 | R6T1 |
SMR0603 | A93550-176 | 110K | IC | 3 | R6T8; R6U2; R7T20 |
SMR0603 | A93551-057 | 2.2K | DISCRETE | 3 | R6V5; R7R10; R7R11 |
SMR0603 | A93550-102 | 4.99k_1% | DISCRETE | 1 | R7A15 |
SMR0603 | RESD,0603,0.5%,1/10W,1K_SMR0603 | 1K | DISCRETE | 1 | R7E7 |
SMR0603 | A93550-134 | 17.8K | DISCRETE | 1 | R7T8 |
SMR0603 | A93551-141 | 10M | DISCRETE | 1 | R7U16 |
SMR0603 | A93550-090 | 2.55K | DISCRETE | 1 | R8T3 |
SMR0603 | A93550-220 | 453_1% | DISCRETE | 1 | R8V11 |
SMR0603 | A93551-136 | 1 | DISCRETE | 1 | R8Y2 |
SMR0603 | A93551-034 | 240 | DISCRETE | 3 | R9G6; R9G7; R9G8 |
SMR0603 | A93551-139 | 5.1 | DISCRETE | 1 | R9Y2 |
SMR0603 | C14407-005 | 10K | DISCRETE | 2 | RT1D1; RT3C1 |
SMR0603 | C14407-003 | 100K | DISCRETE | 1 | RT1D2 |
SMR0603 | D83604-001 | 470K | DISCRETE | 1 | RT3C2 |
SMR0805 | A93556-247 | 97.6 | DISCRETE | 6 | R1P16; R4N3; R4N6; R4N11; R5U3; R6E10 |
SMR0805 | E41881-002 | 0.022 | DISCRETE | 35 | R2G4; R2G15; R6E9; R6F14; R6F16; R6F20; R6G5; R6U10; R6U11; R6U13; R6U14; R6U16; R6U17; R6U19; R6U20; R7A1; R7A8; R7A10; R7A12; R7E8; R7E15; R7F3; R7F4; R7G16; R7G17; R7T14; R7T33; R7U1; R7U2; R7U8; R7U9; R7U11; R7U17; R7V1; R8F12 |
SMR0805 | A93552-002 | 0 | DISCRETE | 5 | R2N33; R6F12; R6F15; R6F18; R7M4 |
SMR0805 | E41881-001 | 0.01 | DISCRETE | 1 | R3B20 |
SMR0805 | A93555-136 | 2.4M | DISCRETE | 1 | R5F9 |
SMR1206 | E41883-001 | 0.01_1% | DISCRETE | 4 | R1T11; R2H2; R2H13; R3H9 |
SMR1206 | E41883-003 | 0.002 | DISCRETE | 13 | R2A2; R5C2; R5N1; R6V18; R7D8; R7T26; R7V2; R8N1; R8N3; R8R5; R8U3; R9E6; R9T6 |
SMR1206 | A93552-001 | 0 | DISCRETE | 1 | R4B1 |
SMR1206 | C44740-006 | 0.002 | DISCRETE | 5 | R4D4; R4D9; R4D10; R4E7; R4R2 |
SMR1206 | E41883-002 | 0.004 | DISCRETE | 1 | R5G6 |
SMR1210 | A93561-059 | 4.7 | DISCRETE | 1 | R8M9 |
SMR1210 | A93561-058 | 3.9 | DISCRETE | 1 | R8M10 |
SMR2010 | A93563-031 | 180 | DISCRETE | 3 | R1T1; R5B2; R5N3 |
SMR2010 | C14411-050 | 0.002 | DISCRETE | 66 | R3A1; R3W19; R3W25; R3W26; R4H1; R4H7; R4H8; R4V11; R5B4; R5E1; R5E5; R5G1; R5H1; R5H4; R5N2; R5W1; R5W9; R5W11; R6B2; R6B5; R6C14; R6N1; R6N2; R6N3; R6P1; R6P4; R6T4; R6W17; R6W18; R7B6; R7C1; R7D3; R7D11; R7N1; R7P5; R7R2; R7R12; R7W1; R8B1; R8B3; R8B4; R8C1; R8D1; R8E1; R8H13; R8H15; R8M4; R8N4; R8N5; R8R9; R8R10; R8R11; R8T8; R8U1; R8W23; R8Y1; R9B3; R9B4; R9B5; R9D1; R9D3; R9M6; R9M8; R9M9; R9M10; R9N1 |
SMR2010_PS | SMR2010_PS | 0 | DISCRETE | 2 | R4H2; R5H7 |
SMR2512 | A93570-004 | 0.002 | DISCRETE | 7 | R1E2; R2D11; R3B23; R4F1; R6E8; R6F13; R6U15 |
SMR2512 | E41880-002 | 0.007 | DISCRETE | 1 | R1G3 |
SMR2512 | E41882-001 | 0.02 | DISCRETE | 1 | R1G8 |
SMR2512 | E41880-001 | 0.002 | DISCRETE | 3 | R2C1; R3C1; R4C3 |
SMR2512 | RESD,2512,5%,2W,3.0_SMR2512_3.0 | 3 | DISCRETE | 5 | R4H3; R4J1; R4J2; R4W3; R4W5 |
SMRA1206 | A93568-028 | 4.7K | DISCRETE | 2 | RP1B1; RP1M1 |
SMRA1206 | A93568-032 | 8.2K | DISCRETE | 5 | RP7E1; RP9B1; RP9C1; RP9P1; RP9R1 |
SMRT1812 | C94014-001 | 1.1A | IC | 10 | F1B1; F1N1; F2H2; F2H3; F2H5; F2H6; F2H7; F2W1; F3H1; F3H2 |
SMRT1812_48H | FUSE,SMT,1812,2A,8V,THRMSTR_SMR | 2A-8V | IC | 2 | F2H1; F2H8 |
SMY49S | A93545-003 | 14.318MHZ | IC | 1 | Y5H1 |
SMY49S | A93545-056 | 25.00MHz | IC | 2 | Y7A1; Y7E1 |
SMY49S | A93545-040 | 10MHZ | IC | 1 | Y9H1 |
SOD123 | C81938-001 | MBR0530 | DISCRETE | 1 | CR3H1 |
SOI8 | D84951-001 | FDS6679AZ | IC | 9 | Q1E6; Q1G1; Q1G4; Q4G4; Q4V4; Q5N1; Q5N2; Q6H2; Q8H1 |
SOI8 | D82003-001 | IRF7834 | IC | 1 | Q3H1 |
SOI8 | C81981-001 | IRF7811A | IC | 5 | Q3H3; Q4G3; Q4V3; Q5G6; Q5V7 |
SOI8 | C76239-001 | IRF7822 | IC | 9 | Q4G2; Q4H1; Q4W1; Q6A1; Q6E1; Q6W1; Q7C1; Q7D1; Q7M1 |
SOI8 | C81602-001 | SI4420DY | IC | 1 | Q9A1 |
SOI8 | D82000-001 | IRF7835 | IC | 1 | Q9Y1 |
SOI8 | D38205-001 | AD8552 | IC | 5 | U2E1; U2E2; U2G4; U3B2; U5F3 |
SOI8 | C76245-001 | ADM1032AR | IC | 1 | U2W2 |
SOI8 | D16443-001 | ISL6208 | IC | 1 | U3B3 |
SOI8 | D54801-001 | TPS2052B | IC | 7 | U3M1; U3N1; U4N1; U7G2; U7J1; U7W1; U8G2 |
SOI8 | IC,AT24C16B-10SU-27,SOI8,EEPROM | AT24C16B | IC | 1 | U9H1 |
SOI8_50IN_213X210 | D23556-001 | SST SPI FLASH | IC | 2 | U8C2; U8D2 |
SOI8_150MIL_68H | XSTR,FDS6681Z,MOSFET,PCH,SOI8_S | FDS6681Z | IC | 3 | Q1F6; Q1G2; Q1G3 |
SOI8_H69 | D72563-001 | IRF7425PBF | IC | 2 | Q5H1; Q7H1 |
SOI8_PWRPAK | D52392-001 | SI7336ADP | IC | 3 | Q1E3; Q1T1; Q6D2 |
SOI14 | C76312-001 | LM339 | IC | 2 | U1B1; U1B2 |
SOI14 | C81152-001 | AD5241 | IC | 1 | U3H6 |
SOI14 | 74HC04_SOI14 | 74HC04 | IC | 1 | U9G1 |
SOI16 | C76268-001 | LTC1444 | IC | 1 | U5F2 |
SOI16_7_6W | D64145-001 | 32Mb SPI FLASH | IC | 2 | U8C1; U8D1 |
SOL4_44MM | D18640-001 | TLP280 | IC | 1 | U8M2 |
SON6_6P5MM_S2MM_DIE | E19045-001 | TPS62290 | IC | 1 | EU5E1 |
SOT23 | C83455-001 | BAT54 | DISCRETE | 12 | CR1F1; CR1F2; CR2F1; CR2V1; CR4B1; CR5G1; CR5H1; CR5V1; CR5Y1; CR7T1; CR8F1; CR9H1 |
SOT23 | C81936-001 | BAR43S | DISCRETE | 1 | CR1F3 |
SOT23 | D78063-001 | CMPSH-3 | DISCRETE | 3 | CR1T1; CR2T1; CR3W1 |
SOT23 | C52251-001 | BAT54C | DISCRETE | 1 | CR1U1 |
SOT23 | C81409-002 | BAT54A | DISCRETE | 3 | CR1U2; CR2M1; CR4J1 |
SOT23 | C85537-001 | MMBZ5246BN | DISCRETE | 1 | CR2G1 |
SOT23 | D83736-001 | BZX84C2V4LT1 | DISCRETE | 1 | CR2H1 |
SOT23 | C81974-001 | BSS138 | IC | 106 | Q1C1; Q1C2; Q1C3; Q1C4; Q1D1; Q1D2; Q1E1; Q1E4; Q1E5; Q1E7; Q1F1; Q1F2; Q1F3; Q1F4; Q1F5; Q1G5; Q1H1; Q1V1; Q1V2; Q1Y1; Q1Y2; Q2F1; Q2F2; Q2F3; Q2G2; Q2H1; Q2H2; Q2U2; Q2W1; Q3B1; Q3B2; Q3B3; Q3H2; Q3H4; Q3W1; Q3W2; Q4B1; Q4B2; Q4B3; Q4B4; Q4B5; Q4B6; Q4B7; Q4B8; Q4B9; Q4C1; Q4F1; Q4F5; Q4G1; Q4N1; Q4P2; Q4V1; Q4V2; Q4V5; Q4W2; Q4W3; Q5B1; Q5E1; Q5F1; Q5F2; Q5G2; Q5G3; Q5G4; Q5G5; Q5H2; Q5N3; Q5U1; Q5U2; Q5U3; Q5V2; Q5V3; Q5V4; Q5V6; Q5W1; Q5W2; Q6C1; Q6D1; Q6E3; Q6F1; Q6M1; Q6R2; Q6T1; Q6T2; Q6T3; Q6U1; Q6V1; Q6W2; Q7C2; Q7D3; Q7T1; Q7T2; Q7V1; Q7W1; Q8H2; Q8T1; Q8W1; Q9F1; Q9G1; Q9G2; Q9G3; Q9G4; Q9H1; Q9H2; Q9U1; Q9U2; Q9W1 |
SOT23 | C79254-001 | 2N7002 | IC | 5 | Q2G1; Q2G3; Q2G4; Q6W3; Q8H3 |
SOT23 | C52245-001 | 2N3904 | IC | 6 | Q2U1; Q4C2; Q4F2; Q4P1; Q6H1; Q9N1 |
SOT23 | C81612-001 | SI2307DS | IC | 5 | Q5G1; Q5V1; Q5V5; Q7D2; Q8W2 |
SOT23 | D11613-002 | LM4040 | IC | 1 | U2G3 |
SOT23 | C76297-001 | MAX809 | IC | 1 | U2W1 |
SOT23_5 | E26068-001 | LM321MFX | IC | 3 | U2F2; U2G1; U2U2 |
SOT23_5 | D55690-001 | MAX999_COMP | IC | 1 | U3B1 |
SOT23_5 | C76252-001 | SC1563 | IC | 2 | U7E1; U8E2 |
SOT23_5 | D17399-001 | 74CBTLV1G125 | IC | 1 | U7T1 |
SOT23_6 | D12898-001 | TPS3808G30 | IC | 1 | U9G2 |
SOT23_6_39H | IC,LT6700-3,SOT23_6_SOT23_6_39H | LT6700-3 | IC | 2 | U2F1; U5G1 |
SOT143 | C76261-001 | MAX6816 | IC | 2 | U5H2; U9F3 |
SOT223 | C57519-001 | BCP69 | IC | 1 | Q7A1 |
SOT363 | C52264-001 | 3904 | IC | 1 | Q4H4 |
SSOP5 | C78568-001 | 74AHC1G08 | IC | 20 | U1E1; U1W2; U2B2; U2G2; U2H3; U3H1; U3H2; U3H3; U3H4; U3H5; U5F1; U5J1; U7D1; U7G1; U8G1; U9A2; U9A3; U9F1; U9M1; U9U1 |
SSOP5 | 74AHC1G02 | 74AHC1G02 | IC | 2 | U1W3; U2H4 |
SSOP5 | D11279-001 | 74AHC1G86 | IC | 2 | U2H1; U2H5 |
SSOP5_PA | D16449-001 | INVERTER | IC | 4 | U1H2; U6D2; U6W1; U7C1 |
SSOP6 | C81603-001 | SI3442BDV | IC | 2 | Q4H2; Q4H3 |
SSOP6_65MM | C78608-001 | NON-INV DMUX | IC | 1 | U8M1 |
SSOP8_65MM | D78796-001 | SN74CBTD3306C | IC | 4 | U2M1; U3A1; U6C2; U6D1 |
SSOP8_65MM | C78567-001 | 74CBT3306 | IC | 7 | U5C3; U6P1; U7C2; U8E3; U8E4; U8R1; U9F2 |
SSOP8_65MM_3W | D48131-001 | MAX4072 | IC | 1 | U1G1 |
SSOP10_5MM | TLV2463_MSOP10 | TLV2463 | IC | 2 | U2H2; U5H1 |
SSOP14_65MM | C88651-001 | GTL2005 | IC | 2 | U5A6; U6A3 |
SSOP14_65MM | C88127-001 | 74CBT3125 | IC | 1 | U8R2 |
SSOP16_65MM_45W | C94905-001 | PCA9557PW | IC | 2 | U6E1; U9G3 |
SSOP16_65MM_45W | C76254-001 | MAX3232_RS232_TRNCVR | IC | 1 | U7B1 |
SSOP20_65MM | D15619-001 | EXP. 5-CH-I2C HUB | IC | 2 | U1W1; U8H1 |
SSOP24_25IN | D29145-001 | PI3V512QE | IC | 1 | U6C1 |
SSOP24_65MM_45W | C88163-001 | SN74CBTD3384 | IC | 2 | U8A2; U9R1 |
SSOP28_65MM_53W | C76308-001 | MAX3243 | IC | 1 | U6A2 |
SSOP48_5MM | D17292-001 | 74CBT16209A | IC | 2 | U1C1; U2B1 |
SSOP64_5MM_CK505 | IC,CK505,TSSOP64,D85246-002_SSO | CK505 | IC | 1 | EU6V1 |
TDFN14_P4MM_S3MM_DIE | D88974-001 | MAX8792 | IC | 2 | EU4F1; EU6E1 |
TQFN56_LAN_SW | IC,MULTIPLEX,PI3VDP612,QFN56_TQ | PI3VDP612_Rev0_4 | IC | 1 | EU6D1 |
TQFN56_LAN_SW | D29149-001 | PI3L500 LAN Switch | IC | 1 | EU7A1 |
TXC_SMD_TA_TYPE | C13544-008 | 32.768KHZ | IC | 1 | Y7F1 |
TYCO_104652-1 | A95918-003 | 2X5-Header | IO | 1 | J8G2 |
VIA_20-10-30_SMB_T-POINT | TESTPOINT_0_VIA_20-10-30_SMB_T- | testpoint | IC | 72 | TP66; TP67; TP68; TP69; TP70; TP71; TP72; TP73; TP74; TP75; TP76; TP77; TP78; TP79; TP80; TP81; TP82; TP83; TP84; TP85; TP86; TP87; TP88; TP89; TP90; TP91; TP92; TP93; TP94; TP95; TP96; TP97; TP98; TP99; TP100; TP101; TP102; TP103; TP104; TP105; TP106; TP107; TP108; TP109; TP110; TP111; TP112; TP113; TP114; TP115; TP116; TP117; TP118; TP119; TP120; TP121; TP122; TP123; TP124; TP125; TP126; TP127; TP128; TP129; TP130; TP131; TP132; TP133; TP134; TP135; TP136; TP137 |
VSOP8 | D17403-001 | 1G D-FLIP FLOP | IC | 1 | U1H1 |
XDP | XDP_SHORT | XDP_SHORT | IC | 14 | SH1D1; SH1D2; SH1D3; SH1D4; SH1D5; SH1D6; SH1D7; SH1D8; SH1D9; SH1D10; SH1D11; SH1D12; SH1D13; SH1D14 |
