查看: 270|回复: 1
[allegro15.2][6层]at91rm9200-dk评估板(SO16L01+QFP144+TQFP32+RJ45+SDRAM+FLASH...
发表于 2020-2-27 18:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
: D  x, v# `1 I+ m$ f4 x1 h
% T7 Y& b+ t  s! q$ m" L( G" p' X[allegro15.2][6层]at91rm9200-dk评估板(SO16L01+QFP144+TQFP32+RJ45+SDRAM+FLASH+DB9)PCB文件
8 b* Y6 o' T4 N1 x! ]! d  {
( ]" C5 O9 |! l! y" S. U; Z% U4 V; h
" w4 z- I* s6 V( v/ f
文件描述:0 n( p. Q# L) i, M
1. 作品用途:at91rm9200-dk评估板/ I! z; b3 f* g5 K0 e
2. 软件版本:allegro15.2, d* h5 E( S" H1 W# K
3. 层数:6层) t* f8 p. U2 y9 V; q8 e: Y: P, E
4. 用到的主要芯片:SO16L01+QFP144+TQFP32+RJ45+SDRAM+FLASH+DB9% J/ M. T5 e# X) ^3 h& W6 U$ o5 z
5. pcb尺寸: 179.8146*179.2308 mm
% o: ^# G  ^7 U! g$ q. T
9 `( q! D6 \# x, ]/ G
4 X2 j/ s' \& @9 `  A7 K作品截图如下:. t/ H) S# Y2 y# b. R5 S  a" ^
顶层截图:4 D, ?; ?% W6 ^  r
) O  `- A7 m% K9 L( J2 E
底层截图:! O# o" X  h# Y( W1 x9 |. m( N( @
* T  C" C  O* k0 X4 b) I1 R全层截图:
( L/ i2 r% T5 j$ t% y
& c3 w0 m- N" D! LBOM:: A: T/ A0 g( `
Bill of Material Report (Condensed)
名称类型属性类别数量位号
BAR2PTS02BAR2PTS02IO6J2; J10; J11; J12; J13; J18
BAR3PTS02BAR3PTS02IO1J9
BGA96_01BGA96_01IC4MN7; MN8; MN18; MN20
BGA256_PAS08BGA256_PAS08IC1MN4
BUZZER10BUZZER10DISCRETE1LS1
C0603C0603DISCRETE213C5; C9; C10; C14; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C118; C119; C121; C122; C123; C125; C126; C127; C128; C129; C130; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C154; C155; C156; C157; C161; C162; C163; C164; C165; C166; C167; C168; C171; C173; C174; C175; C179; C180; C181; C183; C184; C186; C189; C194; C195; C197; C198; C199; C206; C207; C209; C210; C211; C212; C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C229; C231; C232; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C247; C248; C249; C255; C256; C258; C259; C261; C262; C263; C264; C265; C266; C267; C268; C269; C270; C271; C272; C274; C277; C278; C279; C280
C0805C0805DISCRETE14C2; C6; C11; C15; C115; C116; C117; C201; C202; C203; C204; C208; C226; C227
C1206C1206DISCRETE36C62; C63; C120; C124; C131; C153; C158; C159; C160; C169; C170; C172; C185; C188; C191; C193; C196; C200; C205; C224; C225; C228; C230; C233; C245; C246; C250; C251; C252; C253; C254; C257; C260; C273; C275; C276
C1812C1812DISCRETE4C178; C187; C190; C192
CAFE02_NFCAFE02_NFIO36S1; S3; S4; S6; S7; S9; S10; S11; S12; S13; S14; S15; S16; S17; S18; S19; S20; S21; S22; S23; S24; S25; S26; S27; S28; S29; S30; S31; S32; S33; S34; S35; S36; S37; S39; S40
CAFE02_NOCAFE02_NOIO3S5; S8; S38
CON-CN015R-3013-2CON-CN015R-3013-2IO1J17
CON-FPS009-3203CON-FPS009-3203IO1J24
CON-SIM-S-3M_N7E50CON-SIM-S-3M_N7E50IO1J16
CONNECT3PTS03CONNECT3PTS03IO1J1
CONNECT_CCM02_2504CONNECT_CCM02_2504IO1J26
CON_DF11_30DP2DSACON_DF11_30DP2DSAIO1J33
CON_DF11_32DP2DSACON_DF11_32DP2DSAIO1J29
CON_ILZ6PTS125TCON_ILZ6PTS125TIO1J31
CON_JACK_KLBR-4JCON_JACK_KLBR-4JIO2J21; J22
CON_MICTOR38PTSCON_MICTOR38PTSIO1J7
CON_S_FLE_2X25PTSCON_S_FLE_2X25PTSIO4J3; J4; J5; J6
CON_USB787780CON_USB787780IO1J28
CON_USBDUAL72309CON_USBDUAL72309IO1J27
CP-S-FC_H16-01CP-S-FC_H16-01DISCRETE1C1
CP-S-FE_G-01CP-S-FE_G-01DISCRETE8C3; C4; C7; C8; C12; C13; C16; C17
CP-S-VS_HB_A-01CP-S-VS_HB_A-01DISCRETE1C177
CP_TAJACP_TAJADISCRETE2C176; C182
CVARCMS_TZB4CVARCMS_TZB4DISCRETE1C30
DIL20_3DIL20_3IC1MN31
DIN6PTS_SDA87123DIN6PTS_SDA87123IO2J14; J15
DO214AADO214AADISCRETE8CR1; CR2; CR3; CR4; CR5; CR6; CR7; CR8
DO_SMP30DO_SMP30DISCRETE1CR16
ETOILE4ETOILE4IO1S2
FILTRE_BDS3_3_8_9FILTRE_BDS3_3_8_9DISCRETE3L14; L15; L16
FUSEMS06FUSEMS06DISCRETE3F1; F3; F4
FUSE_TS250FUSE_TS250DISCRETE1F2
HE10M2X10PTS02HE10M2X10PTS02IO1J8
LEDMS01LEDMS01DISCRETE5DS1; DS2; DS3; DS4; DS5
LEDMS04LEDMS04DISCRETE1MN30
OSCHC49SUB_01OSCHC49SUB_01DISCRETE2Y1; Y5
OSCMS03OSCMS03DISCRETE1Y4
OSCMS14OSCMS14DISCRETE1Y2
OSCMS_CSTCROSCMS_CSTCRDISCRETE1Y3
POTARMS12POTARMS12DISCRETE1R149
PULSE_P1172PULSE_P1172DISCRETE2L1; L2
QFP48_01QFP48_01IC2MN22; MN25
QFP144_07QFP144_07IC1MN32
R0805R0805DISCRETE159L3; L4; L5; L6; L7; L8; L9; L10; L11; L12; L13; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R75; R76; R77; R78; R79; R80; R81; R82; R86; R87; R88; R89; R90; R91; R92; R93; R94; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R160
R1206R1206DISCRETE10R1; R2; R3; R4; R72; R73; R74; R83; R84; R85
R2512R2512DISCRETE1R95
RJ6P01RJ6P01IO1J20
RJ45_PULSERJ45_PULSEIO1J19
SC70-3LSC70-3LDISCRETE1MN10
SC70-4LSC70-4LDISCRETE1MN6
SC70-5LSC70-5LDISCRETE1MN5
SMD200SMD200DISCRETE1F5
SO08SO08IC5MN1; MN2; MN3; Q1; Q2
SO14SO14IC3MN9; MN16; MN19
SO16SO16IC2MN15; MN26
SO16L01SO16L01IC1MN34
SO16_02SO16_02IC2MN23; MN24
SO20SO8SO20SO8IC1MN14
SO24SO24IC1MN33
SOD80CSOD80CDISCRETE3CR11; CR12; CR14
SOL28SOL28IC1MN28
SOT23T02SOT23T02DISCRETE18CR9; CR10; CR13; CR17; CR18; CR19; CR20; CR21; CR22; CR23; CR24; Q4; Q5; Q6; Q7; Q8; Q9; Q10
SOT223SOT223DISCRETE1Q3
SSOP16_03SSOP16_03IC1MN29
SUBD9M_H_CSUBD9M_H_CIO2J23; J25
SUBD15F01SUBD15F01IO1J30
SWITCHMS12SWITCHMS12DISCRETE1BP1
TM6CIR3_2TM6CIR3_2IO4Z3; Z4; Z6; Z7
TO269AATO269AADISCRETE1CR15
TPCMS5016TPCMS5016IO4TP1; TP2; TP3; TP4
TQFP32_01TQFP32_01IC1MN17
TSOP48_01TSOP48_01IC1MN21
TSOP48_02TSOP48_02IC1MN13
TSOP54_01TSOP54_01IC2MN11; MN12
TSSOP16_01TSSOP16_01IC1MN27
附件:# e& @  S- D: H! Y6 ?3 W. p
原理图和PCB文件如下:6 E: J, `6 {, I: G% g. a: `
游客,如果您要查看本帖隐藏内容请回复
# N+ Y! g# K# C* r9 g/ A! X5 v5 n/ ~2 A
发表于 2022-3-6 20:40 | 只看该作者
来学习啦,谢谢大佬# V. R4 ?0 ]+ E0 K  H
GMT+8, 2025-7-7 08:40 , Processed in 0.140625 second(s), 28 queries , Gzip On.
