查看: 236|回复: 1
分享S变换函数
发表于 2020-2-27 17:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract. y; A9 ~1 E3 h4 E' ~
The generalized S transform (GST), a family of reversible integer-to-integer transforms inspired by the S transform, is+ X. \* i2 `5 n
proposed. This family of transforms is then studied in detail, by considering topics such as GST parameter calculation, the
) d+ u* L: m0 |  Z5 `7 ^effects of using different rounding operators in the GST, and the relationship between the GST and the lifting scheme. Some
+ |6 `; m' e6 V8 s" Eexamples of specific transforms in the GST family are also given. In particular, a new transform in this family is introduced,
/ T0 m, Y+ W% Uand its practical utility demonstrated.
7 [# Q5 T0 F9 e  a3 T+ PI. I NTRODUCTION
% r' I/ L% ^+ D8 XReversible integer-to-integer transforms have become a popular tool for use in signal coding applications requir-* W" O/ k7 S! h5 i! e( G
ing lossless signal reproduction [1–5]. One of the best known transforms of this type is the S transform [3,4,6]. In* f, E6 N0 h" x2 W
this manuscript, we propose the generalized S transform (GST), a family of reversible integer-to-integer transforms. c" ~4 I  c1 d
based on the key ideas behind the S transform. We then study the GST in some detail. This leads to a number of
4 O2 r; ^" q# u% p, G+ A) {interesting insights about transforms belonging to the GST family (including the S transform amongst others) and& g& B$ E5 K& V6 G* r0 J: e
reversible integer-to-integer transforms in general.. _! y2 K5 a% \; N% f
The remainder of this manuscript is structured as follows. We begin, in Section II, with a brief discussion of
7 e  T4 p4 R9 y4 z8 i& D+ t" Ethe notation and terminology used herein. The S transform is then introduced in Section III, and the GST family) B  L$ ^' B" B% i+ K
of transforms is defi ned in Section IV. Sections V and VI proceed to examine GST parameter calculation and
' R3 L, a7 I& |: Nthe effects of using different rounding operators in the GST. Some examples of well known transforms belonging, G* \& `8 P( p$ [; T% @2 N
to the GST family are given in Section VII, and in Section VIII, we present a new GST-based transform, and2 S+ a9 d; O# p. l
demonstrate its utility for image coding applications. Finally, we conclude in Section IX with a summary of our
- L6 U. z# C( O3 j$ Uresults and some closing remarks., i4 G8 x# ]2 \( J
II. N OTATION AND T ERMINOLOGY
6 R, J' I6 q" x$ s) [' f' x$ r) H1 Z. l- `
, d+ Y1 X6 ]" S% J3 n/ O  t
游客,如果您要查看本帖隐藏内容请回复
& j  y* m: r9 c+ ~
2 F4 U( n* c, c. W
GMT+8, 2025-11-3 21:58 , Processed in 0.125000 second(s), 27 queries , Gzip On.
