查看: 291|回复: 0
[PADS VX.2.4][2层]CT316S-Z机顶盒(9701+HY57V641620HG+S25FL004+FMS6143+LD1117...
发表于 2020-2-27 16:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
3 [8 a+ W' o( Z! B# k! R; C8 H0 v: W. @$ W1 P. q( W7 x+ e
作品名字:[pads  VX.2.4][2层]CT316S-Z机顶盒(9701+HY57V641620HG+S25FL004+FMS6143+LD1117A+XS3045B)原理图+PCB' J0 _9 W+ V% ?- X$ D- ~
( P7 n+ x3 R! b% _文件描述9 j9 G, O1 D4 A" E. I, C) f
7 ^" I6 ^, e& {/ j0 D6 V3 D1.功能描述:机顶盒
+ ?6 F! v/ ]# F9 r7 X , }8 I" r: `0 i( Y' T# h2 k, Q( ~" m
2.软件版本:PADS  VX.2.4
' J' N6 U9 _) h4 q# S* e# D, U 3 X* g+ x& P6 E1 Y' d: {  ?$ L
3.层数:2层板9 I& }; O4 ^) Z" V: M( x  D
( l: d, Y8 X6 W9 m" X
4.用到的主要芯片:HY57V641620HG+S25FL004+FMS6143
% r' C! q$ [( p# W5.PCB板尺寸:115mm*105mm
6 A4 Z. ?+ E7 n+ i4 q+ U ( G( r# u0 K/ H( l! a0 A
作品截图如下:        ' p, F9 Y0 `! }3 o
, Y' C, A: U, @5 k% y$ {8 B- ^6 g
顶层截图:" z/ H" k7 T8 b$ n/ B  C% j
* N( w9 b& _# v) t# N; p. {1 |
底层截图:
8 J2 {/ H, Z0 |  c9 E6 N
& B/ k" @! n: G# I& X; Y6 a. J' t: Y, S7 W全层截图:5 m& C& r, Y. N! O
4 V0 E+ b  B8 S" g叠层截图:, J" Q4 I. V4 c4 K5 l9 l* ]5 B
BOM:
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
C1CAP0603473
C2CAP06030.1UF
C3CAP0603270pF
C4CAP0603270pF
C5CAP06030.1uF
C6CAP0603104
C7CAP0603104
C8CAP06030.1UF
C9CAP0603103pF
C10CAP06030.1UF
C11CAP06030.1UF
C12CAP06030.1UF
C13CAP06030.1uF
C14CAP08054.7uf
C15CAP08054.7uf
C16CAP080510uF
C17CAP080510uF
C18CAP080510uF
C19CAP06031nF
C20CAP06030.1UF
C21CAP0603104
C22CAP0603104
C23CAP0603104
C24CAP0603104
C25CAP0603104
C26CAP0603104
C27CAP0603104
C28CAP0603104
C29CAP0603104
C30CAP060327P
C31CAP060327P
C32CAP0603104
C33CAP0603102
C34CAP0603104
C35CAP0603102
C36CAP0603104
C37CAP0603104
C38CAP0603104
C39CAP06030.1uF
C40CAP0603104
C41CAP0603104
C42CAP080510uF
C43CAP0603104
C44CAP080510uF
C45CAP080510uF
C46CAP0603104
C47CAP0603104
C48CAP0603104
C49CAP0603104
C50CAP0603104
C51CAP0603100n,NI
C52CAP0603104
C53CAP0603102
C54CAP0603102
C55CAP0603104
C56CAP0603104
C57CAP0603270pF
C58CAP0603100nF
C59CAP060322P
C60CAP060310P
C62CAP0603100P
C63CAP0603100nF
C64CAP0603100nF
C65CAP0603100nF
C66CAP0603100nF
C67CAP0603100nF
C68CAP0603100nF
C69CAP08054.7uF
C70CAP0603104
C71CAP060310P
C72CAP0603100nF
C73CAP060310P
C74CAP0603100nF
C84CAP0603390
C85CAP0603390
C87CAP06031000P
C88CAP06031000P
C91CAP0603104pF
C111CAP060310nF/NC
C112CAP0603100nF/NC
C114CAP0603104
C115CAP0603104
C117CAP060347P
C118CAP060356P
C119CAP060356P
C120CAP060310nF
C121CAP0603220P
C122CAP060322P
C123CAP0603104
C124CAP0603102
C125CAP0603A1P
C126CAP06031uF
C127CAP0603103
C128CAP0603100P
C129CAP0603A1P
C130CAP060310P
C131CAP060322P
C132CAP060310P
C133CAP060322P
C134CAP060310nF
C135CAP060310nF
C136CAP0603104
C137CAP060310P
C138CAP060322P
C139CAP060310nF
C140CAP060322P
C141CAP060310P
C142CAP060310nF
C143CAP060310P
C144CAP060310P
C145CAP06034.7k
C146CAP06031nF
C147CAP06032.2nF
C148CAP0603A47P
C149CAP0603A47P
C150CAP06031nF
C151CAP06031nF
C153CAP0603220nF
C154CAP060310nF
C170CAP0603104
C171CAP0603104
C172CAP0603104
C173CAP06031uF
C174CAP0603102
C201CAP0603NC
C302CAP0603NC/1000P
C303CAP0603100nF
C30580510uF
C307CAP08054.7uF
C503CAP060347pF
C701CAP06030.1uF
CE6CAPE/2.5/6220uF/16V
CE7CAPE/2/510uF/10V
CE8CAPE/2/547uF/25V
CE9CAPE/2/5100uF/16V
CE10CAPE/2/5100u/16V
CE13CAPE/2/5100u/16V
CE14CAPE/2/5100UF/16V
CE20CAPE/2.5/610UF/50V
CE24CAPE/2/510uF/16V
CE25CAPE/2.5/6220uF/16V
CE27CAPE/2/5100uF/16V
CE101CAPE/2.5/6470uF/10V
CE104CAPE/2.5/6220uF/16V
CE304CAPE/2/522uF/50V
CE501CAPE/2/5100uF/16V
CE701CAPE/2/510uF/35V
CE702CAPE/2.5/6470uF/10V
CN1CON-5/2MM
CON101CON2.5-88Pin-2.54
D2DIO-1210M2
D3DIO-1210M2
D61608/8BAG63-03
D11DIO-3R2000
D12DIO-3FR104
D16DIO-3R2000
D17DIO-3R2000
D18DIO-1210M2
D19DIO-3IN4001
D701DIO-12061N4148
D702DIO-12061N4148
E1RES0603NC
E2RES0603NC
H2HOLE(F)NH
H7HOLE(F)NH
I1HOLE(5.0)
IC205SOP-8XS3045B
J1JACK-CABLEX4PRFIN
J2JACK-CABLEX4PRFOUT
J4SMART_CARD
J5AV4-8.4-10
J7USB-A-03BBLM21P221SG
J701DB9-HMDB9M
L1IND-08051.2uH
L2IND-08052.7uH
L3IND-08051.8uH
L4IND-0805FB
L5IND-0805FB
L6IND-0805FB
L7IND-08052.7uH/NC
L9IND-0805FB
L12IND-08051.8uH
L14IND-08051.2uH
L15IND-0603A4.7nH
MARK1MARK
MARK2MARK
MARK3MARK
MARK4MARK
MARK8MARK
MARK9MARK
N1ZL100395039
P1HOLE(2.0)
P2HOLE(2.0)
P3HOLE(2.0)
P4HOLE(2.0)
P11HOLE(0.5)
PA1HOLE(0.5)
PA2HOLE(0.5)
PA3HOLE(0.5)
PA4HOLE(0.5)
PA5HOLE(0.5)
PA6HOLE(0.5)
PA7HOLE(0.5)
PA8HOLE(0.5)
Q1TO-92(EBC)8550
Q2SOT-23NC
Q4SOT-233904
Q5SOT-233904
Q6SOT-233904
Q7SOT-23NC
Q9TO-92A
Q10SOT-233904
Q11SOT-23
Q12SOT-233906
Q16SOT-233904
Q18TO-92(EBC)8550
Q28SOT-233904
Q701SOT-233906
Q702SOT-233904
R1RES0603NC
R2RES0603NC
R3RES060310K,NC
R4RES060310k
R5RES0603100K
R6RES0603NC
R7RES0603NC
R8RES0603NC
R9RES0603NC
R10RES0603NC
R11RES06034.7K
R12RES06032k2
R13RES060312K
R14RES06033.3K
R15RES060320K
R16RES060320K
R18RES060310k
R19RES06034k7
R20RES06030
R22RES060333
R23RES060333
R24RES06032.7K
R25RES06031M
R26RES06034k7
R27RES060333
R28RES060333
R29RES0603220R
R30RES0603NC
R34RES060333
R35RES060333
R36RES06031K
R37RES060310K
R38RES06036.04K 1%
R39RES060310K
R45RES06032K2
R46RES06032K2
R49RES06031K
R50RES060333
R51RES060333
R52RES08051k8
R53RES06034.7K
R54RES060347R
R55RES060310K
R56RES060310K
R57RES06034k7
R66RES060333
R67RES060333
R75RES0603100
R79RES0603270K
R80RES0603270K
R81RES060315K
R82RES060315K
R83RES06034K7
R84RES06034K7
R85RES060320K
R86RES060320K
R87RES060351K
R88RES060351K
R89RES060375
R90RES060375
R99RES06031k
R100RES0603510
R101RES0603510
R103RES06032k2
R104RES06034K7
R106RES060347K
R107RES060347K
R108RES06034K7
R109RES060310K
R110RES060315R
R158RES0603200R
R159RES0603200R
R160RES0603200R
R171RES060310K
R172RES060310K
R175RES06034K7/NC
R176RES06034k7/NC
R177RES0603220/NC
R179RES0603150/NC
R180RES06038.2K
R181RES06038.2K
R182RES0603MBW1608-121
R183RES0603MBW1608-121
R184RES060351R
R185RES060351R
R186RES060351R
R187RES060351R
R188RES0603100R
R189RES0603100R
R190RES0603MBW1608-121
R220RES06031k
R221RES0603100
R306RES060310K
R307RES060333
R331RES06030R
R501RES060320K
R502RES060320K
R520RES060375R\NC
R535RES06032.2K
R701RES06031K
R702RES06034K7
R703RES06034K7
R704RES06032K2
R705RES06032K2
R706RES06032K2
RN1RN433
U1DPAKA1.8V
U2SO28
U4FP128M5GA
U5SOP8-300
U8DIP8\SOJRC4558
U10SOT-2233.3v
U15SDRAM54
X1XTAL27MHz
XS1XTAL10.111MHz
- z$ u6 d5 X& N0 K/ d
8 C4 {! G: y: ?% @) x' p8 o2 y  C. z
3 q% U; g* x6 ~, ]2 e) w
  J& ]5 A: z; q' ]7 p
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
+ \1 \: h/ n1 @
GMT+8, 2025-7-27 19:54 , Processed in 0.140625 second(s), 28 queries , Gzip On.
