Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BGA2X4-YZP | TXB0102_1_BGA2X4-YZP_TXS0102 (Y | TXS0102 (YZP) | IC | 1 | U9 |
BGA2X4-YZP | TXB0102_0_BGA2X4-YZP_TXS0102 (Y | TXS0102 (YZP) | IC | 1 | U11 |
BGA5X5-4MM | USB3319_0_BGA5X5-4MM_USB3319 (C | USB3319 (CSP) | IC | 1 | U7 |
BGA515-CBB | OMAP3430_ES2_5.0_BGA515-CBB_OMA | OMAP35xx_ES2.0 | IC | 1 | U3 |
BGA-ZXN-209 | TWL4030_6_BGA-ZXN-209_FBGA209_1 | FBGA209_15-74_280x280 | IC | 1 | U5 |
C402-25 | CAP_0402_0R1UF_X7R_10V_C402-25_ | 0.1uF | IC | 81 | C1; C3; C4; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C46; C50; C73; C74; C75; C78; C79; C80; C81; C82; C84; C86; C87; C88; C89; C90; C91; C92; C93; C94; C96; C98; C99; C100; C103; C105; C107; C110; C111; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126 |
C402-25 | 207-0229-000_0_C402-25_DISCRETE | 150pF | DISCRETE | 2 | C5; C6 |
C402-25 | 100NF-16V X7R_2_C402-25_DISCRET | 0.1uF | DISCRETE | 2 | C7; C8 |
C402-25 | CAP_0402_0R1UF_X7R_10V_C402-2_1 | 0.22uF | IC | 2 | C44; C45 |
C402-25 | CAP_207-0009-000_C402-25_DISCRE | 100PF | DISCRETE | 6 | C51; C60; C61; C62; C63; C70 |
C402-25 | 0402_0R01UF_X7R_16V_10_C402-25_ | 0.1uF | IC | 1 | C52 |
C402-25 | CAPACITOR NON-POL_C402-25_100PF | 100pF | IC | 2 | C58; C59 |
C402-25 | CAP_0402_0R1UF_X7R_10V_C402-2_2 | 0.1uF,CER | IC | 2 | C64; C65 |
C402-25 | CAP_207-0009-000_C402-25_DISC_1 | 22PF | DISCRETE | 2 | C68; C69 |
C402-25RD | 0402C-47P_1_C402-25RD_47PF | 47pF | IC | 4 | C56; C57; C66; C67 |
C603-35X45 | 7343L_100UF_TANT_10V_10_C603-35 | 1uF | IC | 1 | C2 |
C603-35X45 | 0402_0R01UF_X7R_16V_10_C603-35X | 1uF | IC | 3 | C47; C48; C49 |
C603-35X45 | 207-0000-075_1UF_C603-35X45_DIS | 1UF | DISCRETE | 1 | C55 |
C603-35X45 | 207-0000-075_0_C603-35X45_DISCR | 1UF | DISCRETE | 1 | C71 |
C1210-70X102 | 1812-X5R-10V-47UF_C1210-70X102_ | 47uF,CER | IC | 2 | C53; C54 |
C1210-70X120 | C_47UF25V_POL_3528_C1210-70X120 | C47uf, 25V | IC | 1 | C101 |
C3216-35X55 | 0603C-2U2_0_C3216-35X55_2.2UF | 2.2uF | IC | 1 | C72 |
C3216-35X55 | 10UF-10V-293D-C_1_C3216-35X55_D | 10UF | DISCRETE | 7 | C76; C77; C83; C85; C95; C97; C112 |
C3216-35X55 | CAP3528 | 4.7uF | DISCRETE | 3 | C102; C104; C106 |
CONN3-PWR-PJ102A | CONN JACK PWR_1_CONN3-PWR-PJ102 | PJ-002A | IC | 1 | J1 |
CONN4-DIN-RT | SVIDEOCONN_0_CONN4-DIN-RT_SVIDE | SVideoConn | IC | 1 | P4 |
CONN-6N1-MMC-SD | MMC4_2.0_CONN_CONN-6N1-MMC-SD_M | MHC-W21-601 | IC | 1 | P8 |
CUI-SJ1-3513-SMT | PHONOJACK STEREO-R_CUI-SJ1-3513 | PHONOJACK STEREO-R | IC | 2 | P5; P6 |
DBV6-27X39-6 | SN74LVC2G07DCKR_DBV6-27X39-6_IC | SN74LVC2G07DCKR | IC | 1 | U4 |
DGN-16X60 | TPS2061_2_DGN-16X60_TPS2061 (DG | TPS2061 (DGN) | IC | 1 | U6 |
DRB8-14X33-PAD | TPS73701_0_DRB8-14X33-PAD_TPS73 | TPS73701 | IC | 1 | U2 |
F603-41X39 | DIODE BI-DIR TRIG_F603-41X39_PG | PGB0010603MR | IC | 2 | D1; D15 |
F603-41X39 | DIO_V5.5MLA0603_F603-41X39_PG_1 | PGB0010603MR,DNI | IC | 1 | D2 |
F603-41X39 | DIO_V5.5MLA0603_F603-41X39_PGB0 | PGB0010603MR | IC | 4 | D3; D4; D13; D14 |
F603-41X39 | DIO_V5.5MLA0603_F603-41X39_DIO_ | DIO_V5.5MLA0603 | IC | 4 | D8; D9; D10; D11 |
HDMI-SMT-W-FLANGE | HDMI_CONN_3_HDMI-SMT-W-FLANGE_H | HDMI_Conn | IC | 1 | P10 |
IND603-24X32 | INDUCTOR_IND603-24X32_FERRITE, | FERRITE, MMZ1608R301A | IC | 3 | L4; L5; L6 |
IND-LPS3010 | INDUCTOR 1.0UH_IND-LPS3010_1UH | 1uH | IC | 1 | L2 |
IND-LPS3015 | INDUCTOR 1.0UH_IND-LPS3015_1UH, | 1uH,2A | IC | 2 | L1; L3 |
JUMP2-6040 | JUMPER_0_JUMP2-6040_JUMPER | JUMPER | IC | 1 | J2 |
JUMP2X5-6040 | HEADER 5X2_1_JUMP2X5-6040_HEADE | HEADER 5X2 | IC | 1 | P9 |
JUMP2X7-6040-K6 | JUMP_0_JUMP2X7-6040-K6_IO_76385 | 76385-407LF | IO | 1 | P2 |
JUMP2X14-6040-1 | HEADER 14X2_JUMP2X14-6040-1_HEA | HEADER 14X2 | IC | 1 | J3 |
LED1206-59X59 | LED_LTST-C150GKT_0_LED1206-59X5 | LTST-C150CKT | DISCRETE | 4 | D5; D6; D7; D12 |
PAP64-12X70 | TFP513_1_PAP64-12X70_TFP410 | TFP410 | IC | 1 | U8 |
POLYSW200-5638-310 | PTC_POLYSW200-5638-310_RXEF010 | RXEF010 | IC | 1 | RT1 |
PWP14-12X70 | TPS21XX_1_PWP14-12X70_TPS2141 | TPS2141 | IC | 1 | U1 |
R402-25RD | RES_0_R402-25RD_DISCRETE_56.2K, | 56.2K,0603 | DISCRETE | 1 | R7 |
R402-25RD | RES_272-0065-000_R402-25RD_DISC | 33 | DISCRETE | 1 | R10 |
R402-25RD | RES_0_R402-25RD_DISCRETE_10K_1% | 10K | DISCRETE | 23 | R11; R12; R13; R14; R36; R49; R51; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R66; R82; R98; R101; R102; R109 |
R402-25RD | RESISTOR_R402-25RD_10K | 10K | IC | 4 | R15; R16; R22; R37 |
R402-25RD | RESISTOR_R402-25RD_100K | 100K | IC | 5 | R17; R18; R19; R20; R21 |
R402-25RD | RES_272-0065-000_R402-25RD__1.6 | 1.65K | IC | 2 | R27; R28 |
R402-25RD | RES_0_R402-25RD_DISCRETE_33_1% | 33 | DISCRETE | 3 | R38; R40; R42 |
R402-25RD | R_R402-25RD_10K | 10K | IC | 1 | R39 |
R402-25RD | 0402_4R7K_1_R402-25RD_DISCRETE_ | 4.7K | DISCRETE | 3 | R41; R45; R47 |
R402-25RD | 272-0067-000_0_R402-25RD_DISCRE | 33 | DISCRETE | 2 | R44; R46 |
R402-25RD | RES_0_R402-25RD_DISCRETE_1K_1% | 1K | DISCRETE | 2 | R96; R99 |
R402-25RD | RES_0_R402-25RD_DISCRETE_4.7K_1 | 4.7K | DISCRETE | 2 | R97; R100 |
R603-35X45 | RESISTOR2_R603-35X45_0,0603 | 0,0603 | IC | 1 | R1 |
R603-35X45 | RESISTOR_1_R603-35X45_620K,1%,0 | 620K,1%,0603 | IC | 1 | R3 |
R603-35X45 | RESISTOR_2_R603-35X45_200K,1%,0 | 200K,1%,0603 | IC | 1 | R4 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_10K,0 | 10K,0603 | DISCRETE | 8 | R5; R29; R30; R31; R32; R33; R64; R65 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_22.6K | 22.6K,0603 | DISCRETE | 1 | R8 |
R603-35X45 | 0805_200_1_V_R603-35X45_8,200,6 | 8,200,603 | IC | 1 | R9 |
R603-35X45 | RES_272-0065-000_R603-35X45__0_ | 0 | IC | 2 | R23; R26 |
R603-35X45 | 0805_200_1_V_R603-35X45_200.060 | 200.0603 | IC | 2 | R34; R35 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_0_1% | 0 | DISCRETE | 1 | R43 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_820_5 | 820 | DISCRETE | 1 | R48 |
R603-35X45 | R_R603-35X45_820,603 | 820,603 | IC | 1 | R50 |
R603-35X45 | 0402_10K_1_R603-35X45_DISCRETE_ | 8.064k | DISCRETE | 1 | R52 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_510_1 | 510 | DISCRETE | 1 | R95 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_1K,06 | 1K,0603 | DISCRETE | 4 | R103; R104; R105; R110 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_0,DNI | 0,DNI | DISCRETE | 2 | R106; R107 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_0.DNI | 0.DNI | DISCRETE | 1 | R108 |
R805-35X60 | RES_0_R805-35X60_DISCRETE_1.0,0 | 1.0,0805 | DISCRETE | 1 | R6 |
RPAK16-10X25-2HV | RPAK_RPAK16-10X25-2HV_DISCRETE_ | 10 | DISCRETE | 4 | RP1; RP2; RP3; RP4 |
SC88 | RN1907_SC88_RN1907 | RN1907 | IC | 1 | Q1 |
SW4-6040-PUSH | SW_KT11P2JM_4_SW4-6040-PUSH_DIS | B3F-1000 | DISCRETE | 2 | S1; S2 |
TP1-20SMT | TESTPT1_0_TP1-20SMT_TESTPT1 | TESTPT1 | IC | 15 | TP3; TP4; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP19; TP20; TP21; TP22; TP23 |
TP1-20SMT | TESTPT1_0_TP1-20SMT_TESTPT2 | TESTPT2 | IC | 2 | TP5; TP6 |
TP1-8040 | TESTPT1_0_TP1-8040_TESTPT1 | TESTPT1 | IC | 2 | TP1; TP2 |
TSSOP16-14X70 | MAX3221_1_TSSOP16-14X70_SN65C32 | SN65C3221EPW | IC | 1 | U10 |
USB-MINI-SMT-NUM | MINI-USB-AB-SOCKET_1_USB-MINI-S | UX60-MB-5ST, miniUSB Type AB | IC | 1 | P1 |
USB_A_SH | CONN_54819-0578_2_USB_A_SH_IO_U | USB-A Conn. - 87520-xx1xx | IO | 1 | P7 |
XTAL2_FX135 | QUARTZ-32KHZ-CM200S_0_XTAL2_FX1 | 32KHz,FX135 | DISCRETE | 1 | Y2 |
XTAL4-47X51-ECXO | OSC_230-0067-000_0_XTAL4-47X51- | ECLIPTEK_26MHZ | IC | 1 | Y1A |
XTAL4-SG210 | OSC_230-0067-000_0_XTAL4-SG210_ | ECLIPTEK_26MHZ | IC | 1 | Y1 |
附件:
