作品名字:[pads VX.2.4][2层]AR9331路由器官方DEMO(MX25L3205DM2I+HN1664C+AT34063I+RT8292A+RT8010)原理图+PCB
* |6 |& C) J! G8 e! E- T- n. P, k
' q. z( V* ~3 e# r+ w9 O文件描述 r# X |$ P, Y
( a, @7 ?& @, U0 X1.功能描述:路由器
( M) C- f5 k/ x$ ?" P6 J- _7 |1 f9 j - v# c: b+ t$ [# b& e
2.软件版本:PADS VX.2.4) f) i8 |# p9 |5 H0 ^5 y, L! u
1 h3 y7 E5 B; N6 l( E2 a( e: `
3.层数:2层板$ F; Z1 k6 H5 \6 e$ J/ |- J- r: v2 I
8 E( f4 x( O& N4.用到的主要芯片:MX25L3205DM2I+HN1664C+AT34063I # y$ W Y, R9 C3 x! x+ r. {
5.PCB板尺寸:120mm*90mm
: [; p0 o8 u/ ?1 Y2 m
$ \8 u+ y; Q( m C% V* e作品截图如下: 1 h: u: w0 m1 M
" r# }+ ~; n3 Q7 Q5 y; ^顶层截图:3 M9 `+ d, d0 t! K- e0 V o0 b
" H$ m. Y" y3 W0 H1 c4 x% w4 J5 p
底层截图:
# S. ~ A6 e; g( q( h
7 ^2 d& c* a! s' [3 J
全层截图:" n7 \) w" n9 J- d% K
. u9 l, V' Q4 I7 p! e+ ]
叠层截图:! }5 V9 D2 e7 b7 u% c
BOM: REFDES | COMP_DEVICE_TYPE | COMP_VALUE | 位号 | 类型 | 属性 | ANT0 | ANT-STAMP-CUS126 | | C1 | CAP-0805 | | C2 | CAP-0402 | | C3 | CAP-0402 | | C4 | CAP-0402 | | C5 | CAP-0402 | | C6 | CAP-0402 | | C7 | CAP-0402 | | C8 | CAP-0402 | | C9 | CAP-0402 | | C10 | CAP-0402 | | C11 | CAP-0402 | | C12 | CAP-0402 | | C13 | CAP-0402 | | C14 | CAP-0402 | | C15 | CAP-0402 | | C16 | CAP-0402 | | C17 | CAP-0402 | | C18 | CAP-0402 | | C19 | CAP-0402 | | C21 | CAP-0402 | | C22 | CAP-0402 | | C23 | CAP-0402 | | C24 | CAP-0402 | | C25 | CAP-0402 | | C26 | CAP-0402 | | C27 | CAP-0402 | | C28 | CAP-0805 | | C29 | CAP-0402 | | C30 | CAP-0603 | | C31 | CAP-0402 | | C32 | CAP-0402 | | C33 | CAP-0402 | | C34 | CAP-0402 | | C35 | CAP-0402 | | C36 | CAP-0402 | | C37 | CAP-0402 | | C38 | CAP-0402 | | C39 | CAP-0402 | | C40 | CAP-0402 | | C41 | CAP-0402 | | C42 | CAP-0402 | | C43 | CAP-0402 | | C44 | CAP-0402 | | C45 | CAP-0402 | | C46 | CAP-0402 | | C47 | CAP-0402 | | C48 | CAP-0402 | | C53 | CAP-0402 | | C54 | CAP-0201 | | C55 | CAP-0805 | | C56 | CAP-0402 | | C57 | CAP-0402 | | C58 | CAP-0402 | | C65 | CAP-0402 | | C66 | CAP-0402 | | C67 | CAP-0402 | | C68 | CAP-0402 | | C69 | CAP-0402 | | C70 | CAP-0402 | | C71 | CAP-0402 | | C72 | CAP-0402 | | C73 | CAP-0402 | | C74 | CAP-0402 | | C75 | IND-0402 | | C89 | CAP-0402 | | C90 | CAP-0402 | | C91 | CAP-0402 | | C92 | CAP-0402 | | C93 | CAP-0402 | | C94 | CAP-0402 | | C95 | IND-0402 | | C96 | CAP-0402 | | C97 | CAP-0402 | | C100 | CAP-0402 | | C101 | CAP-0402 | | C102 | CAP-0402 | | C103 | CAP-0402 | | C104 | CAP-0402 | | C105 | CAP-0402 | | C106 | CAP-0402 | | C107 | CAP-0402 | | C108 | CAP-0402 | | C109 | CAP-0402 | | C110 | CAP-0402 | | C111 | CAP-0402 | | C112 | CAP-0402 | | C113 | CAP-0402 | | C114 | CAP-0402 | | C115 | CAP-1812 | | C116 | CAP-1812 | | C117 | CAP-1812 | | C127 | CAP-ELECT-TH-100 | | C128 | CAP-0402 | | C129 | CAP-0402 | | C130 | CAP-ELECT-TH-100 | | C138 | CAP-0402 | | C139 | CAP-1206 | | C143 | CAP-0402 | | C144 | CAP-0402 | | C145 | CAP-0402 | | C146 | CAP-ELECT-TH-100 | | C147 | CAP-0402 | | C148 | CAP-0402 | | C149 | CAP-0805 | | C150 | CAP-0402 | | C151 | CAP-0805 | | C152 | CAP-0805 | | C153 | CAP-0402 | | C156 | CAP-0402 | | C157 | CAP-0402 | | C160 | CAP-0402 | | C161 | CAP-0402 | | C162 | CAP-0402 | | C163 | CAP-RAD-138-D315 | | C164 | CAP-0402 | | C167 | CAP-0402 | | C168 | CAP-RAD-138-D315 | | C169 | CAP-0805 | | C171 | CAP-0603 | | C172 | CAP-0402 | | C173 | CAP-0402 | | C174 | CAP-0402 | | C178 | CAP-0603 | | C179 | CAP-0402 | | C181 | CAP-0402 | | C182 | CAP-0402 | | C187 | CAP-0402 | | C188 | CAP-ELECT-TH-100 | | C192 | CAP-0402 | | C196 | CAP-0805 | | C197 | CAP-0805 | | C198 | CAP-0805 | | C200 | CAP-1206 | | C202 | CAP-0402 | | C203 | CAP-0402 | | C204 | CAP-0402 | | D9 | DO-214AC | | F5 | FUSE-MINISMDC | | J1 | HDR6X2 | | J2 | HDR7X2 | | J3 | USB-A-RT-90 | | J4 | CON-HRS-UFL | | J6 | CON-HRS-UFL | | J7 | CON-RJ45-3-WO | | J8 | CON-RJ45X4-3-WO | | J9 | CON-PWRJACK-ACT | | JP1 | HDR1X3 | | L1 | IND-0402 | | L2 | IND-0402 | | L5 | IND-0402 | | L6 | IND-0402 | | L12 | IND-2520 | | L14 | IND-SM-5.8X5.2 | | L15 | IND-0402 | | L16 | IND-0402 | | L17 | IND-0402 | | L18 | IND-0402 | | L19 | IND-0402 | | L20 | IND-0402 | | L21 | IND-0402 | | L22 | IND-RAD-200-570X280 | | L23 | IND-0402 | | L39 | IND-2520 | | L40 | IND-TH-315 | | L41 | IND-SM-SCD10085T | | LED1 | LED-0603 | | LED2 | LED-0603 | | LED3 | LED-0603 | | LED4 | LED-0603 | | LED5 | LED-0603 | | LED6 | LED-0603 | | LED7 | LED-0603 | | LED8 | LED-0603 | | LED9 | LED-0603 | | LED10 | LED-0603 | | Q1 | TRA-SOT23 | | Q2 | TRA-SOT23 | | Q3 | TRA-SOT23 | | Q4 | TRA-SOT23 | | Q7 | SO8NB | | R1 | RES-0402 | | R2 | RES-0402 | | R4 | RES-0402 | | R5 | RES-0402 | | R6 | RES-0402 | | R7 | RES-0402 | | R8 | RES-0402 | | R9 | RES-0402 | | R10 | RES-0402 | | R12 | RES-0402 | | R42 | RES-0402 | | R43 | RES-0402 | | R44 | RES-0402 | | R45 | RES-0402 | | R46 | RES-0402 | | R47 | RES-0402 | | R48 | RES-0402 | | R49 | RES-0402 | | R50 | RES-0402 | | R51 | RES-0402 | | R52 | RES-0402 | | R53 | RES-0402 | | R54 | RES-0402 | | R55 | RES-0402 | | R56 | RES-0402 | | R57 | RES-0402 | | R58 | RES-0402 | | R59 | RES-0402 | | R60 | RES-0402 | | R61 | RES-0402 | | R62 | RES-0402 | | R63 | RES-0402 | | R64 | RES-0402 | | R65 | RES-0402 | | R66 | RES-0402 | | R67 | RES-0402 | | R68 | RES-0402 | | R69 | RES-0402 | | R70 | RES-0402 | | R76 | RES-0402 | | R77 | RES-0402 | | R80 | RES-0402 | | R81 | RES-0402 | | R90 | RES-0402 | | R91 | RES-0402 | | R92 | RES-0402 | | R93 | RES-0402 | | R94 | RES-0402 | | R95 | RES-0402 | | R96 | RES-0402 | | R97 | RES-0402 | | R98 | RES-0402 | | R99 | RES-0402 | | R100 | RES-0402 | | R101 | RES-0402 | | R102 | RES-0402 | | R103 | RES-0402 | | R104 | RES-0402 | | R105 | RES-0402 | | R106 | RES-0402 | | R107 | RES-0402 | | R108 | RES-0402 | | R109 | RES-0402 | | R110 | RES-0402 | | R111 | RES-0402 | | R112 | RES-0402 | | R113 | RES-0402 | | R114 | RES-0402 | | R115 | RES-0402 | | R116 | RES-0402 | | R117 | RES-0402 | | R118 | RES-0402 | | R119 | RES-0402 | | R120 | RES-0402 | | R121 | RES-0402 | | R122 | RES-0402 | | R123 | RES-0402 | | R124 | RES-0402 | | R125 | RES-0402 | | R126 | RES-0402 | | R127 | RES-0402 | | R128 | RES-0402 | | R129 | RES-0402 | | R130 | RES-0402 | | R131 | RES-0402 | | R132 | RES-0402 | | R133 | RES-0402 | | R134 | RES-0402 | | R147 | RES-0402 | | R148 | RES-0402 | | R149 | RES-0402 | | R150 | RES-1206 | | R151 | RES-0402 | | R152 | RES-0402 | | R153 | RES-0402 | | R154 | RES-0402 | | R155 | RES-0603 | | R156 | RES-0402 | | R157 | RES-0402 | | R159 | RES-0402 | | R160 | RES-0402 | | R161 | RES-0402 | | R162 | RES-0402 | | R163 | RES-0402 | | R164 | RES-0402 | | R165 | RES-0402 | | R166 | RES-0402 | | R167 | RES-0402 | | R168 | RES-0402 | | R169 | RES-0402 | | R170 | RES-0402 | | R171 | RES-0402 | | R172 | RES-0402 | | R173 | RES-0402 | | R174 | RES-0402 | | R175 | RES-0402 | | R176 | RES-0402 | | R177 | RES-0402 | | R178 | RES-0402 | | R179 | RES-0402 | | R180 | RES-0402 | | R181 | RES-0402 | | R182 | RES-0402 | | R183 | RES-0402 | | R184 | RES-0402 | | R185 | RES-0402 | | R186 | RES-0402 | | R187 | RES-0402 | | R188 | RES-0402 | | R189 | RES-0402 | | R190 | RES-0402 | | R191 | RES-0402 | | R192 | RES-0402 | | R193 | RES-0402 | | R194 | RES-0402 | | R195 | RES-0402 | | R196 | RES-0402 | | R197 | RES-0402 | | R198 | RES-0402 | | R199 | RES-0805 | | R200 | RES-0805 | | R201 | RES-0402 | | R202 | RES-0402 | | R203 | RES-0402 | | R205 | RES-0402 | | R210 | RES-0402 | | R211 | RES-0402 | | R212 | RES-0402 | | R213 | RES-0402 | | R214 | RES-0402 | | R215 | RES-0402 | | R216 | RES-0402 | | S7 | SWI-TH-VT-PUSH | | SLOT1 | SLOT-47X20 | | SLOT2 | SLOT-47X20 | | SLOT3 | SLOT-47X20 | | SLOT4 | SLOT-47X20 | | SW6 | SW-PUSH-RT | | T1 | YCL20PMT04A | | T2 | HN2064C | | T3 | HN2064C | | TP1 | TESTPAD35A | | TP2 | TESTPAD35A | | TP3 | TESTPAD35A | | TP4 | TESTPAD35A | | TP5 | TESTPAD35A | | TP6 | TESTPAD35A | | TP7 | TESTPAD35A | | TP9 | TESTPAD35A | | U1 | QFN-DR-148-EP-2 | | U3 | TSOP-66 | | U4 | SO8-200 | | U5 | SO8NB-1GND | | U6 | SO8NB-1GND | | U10 | SOT23 | | VR1 | SO8NB | | VR2 | DFN-6 | | X1 | LOGO-NEW-500 | | Y1 | XTAL-HC49US | | Y2 | CRY-SMD4-3.2X2.5MM | | ZH1 | HOLE-175D197NP | | ZH2 | HOLE-175D197NP | | ZH3 | HOLE-175D197NP | | ZH4 | HOLE-175D197NP | |
! k! s& r) N8 w, H3 X ~/ Z$ f- {1 y7 Y/ L4 q% e+ s
& N* _" k q* u& ~+ ~ 7 M2 Z! h9 j, z# M4 K$ m
附件:
9 h7 f/ h6 P8 P: p# U% u( b |
