查看: 533|回复: 5
[AD 15][8层] 值得学习的8层板 (CAT811R+TPS54331DDA )PCB源文件
发表于 2020-2-26 17:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 15][8层] 值得学习的8层板 (CAT811R+TPS54331DDA )PCB源文件. V- {, _+ v1 V. D; u9 u
: i- l! n6 a7 V( W
# a' F- N, F, R  }9 r* U% _9 P4 I文件描述
0 m: l0 g: t: A4 z7 A# s- q8 ~6 t) O$ Y1. 作品用途:
$ E. [7 i% i9 V2. 软件版本:AD 15* \  ]/ O7 k( ]$ n( @4 `
3. 层数:8层板
5 m$ L, A3 x/ w& U  ~* B4. 用到的主要芯片:
1 x5 n! J5 R, r1 {, h5. PCB尺寸:205mm*189mm; ?2 A8 M' H1 G  C" Y+ f* ]; c
, Q- U9 F" P, _4 ?- d
) `  L" @, z4 M4 q, n9 e! H作品截图如下:
  S# d7 [: M* m4 i: h4 K顶层截图:
- z7 S& w5 T( T6 k' m9 V 8 w3 t: l4 C& x5 L. \' z
底层截图:7 i- l' o# R8 h% M5 b" l& S& N3 d
9 e; Y5 o- V5 |2 X全层截图:
1 {( _0 y( y- }9 R* X3 ?# D% w* _
+ x5 j1 M: C2 {5 z! L0 \叠层信息截图如下:+ H& c. B. u$ N0 Z' O- l1 f
% l0 q. E# T) J1 @BOM:1 v% }) ?9 P% Q3 G
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
10UF/6.3V/20%C1, C33C0603
100NF/50V/10%C2, C21, C22, C34, C72, C73, C74, C75, C79, C88, C109, C110, C112, C123, C124, C126, C134, C135, C136, C149, C151, C152, C168, C169, C170, C171, C172, C173, C174, C175, C176, C177, C178, C179, C182, C184, C185, C186, C187, C188, C189, C190, C191, C192, C194, C195, C196, C197, C198, C199, C200, C201, C202, C203, C204, C205, C206, C207, C208, C209, C210, C211, C212, C214, C215, C218, C219, C220, C221, C222, C344, C345, C351, C443, C469, C470, C471, C472, C473, C474, C475, C476, C477, C478, C479, C480, C483, C485, C486, C487, C488, C489, C490, C491, C492, C494, C496, C497, C498, C499, C500, C501, C502, C503, C504, C505, C506, C507, C508, C509, C510, C511, C512, C513, C514, C516, C517, C520, C521, C522, C523, C524, C645, C646, C652, C738, C764, C765, C766, C767, C768, C769, C770, C771, C772, C773, C774, C775, C778, C780, C781, C782, C783, C784, C785, C786, C787, C789, C791, C792, C793, C794, C795, C796, C797, C798, C799, C800, C801, C802, C803, C804, C805, C806, C807, C808, C809, C811, C812, C815, C816, C817, C818, C819, C940, C941, C947, C1033, C1059, C1060, C1061, C1062, C1063, C1064, C1065, C1066, C1067, C1068, C1069, C1070, C1073, C1075, C1076, C1077, C1078, C1079, C1080, C1081, C1082, C1084, C1086, C1087, C1088, C1089, C1090, C1091, C1092, C1093, C1094, C1095, C1096, C1097, C1098, C1099, C1100, C1101, C1102, C1103, C1104, C1106, C1107, C1110, C1111, C1112, C1113, C1114, C1230, C1235, C1236, C1242C0603
230
10NF/200V/10%C15, C16, C19, C20, C47, C49, C55C0603
1UF/16V/10% X7RC65, C66, C76, C77, C80, C81, C82, C83, C181, C482, C777, C1072C0603
12
10UF/10V/10% X7RC68, C69, C70, C71, C183, C193, C213, C484, C495, C515, C779, C790, C810, C1074, C1085, C1105C0805
16
1UF/25V/5%C78C0603
10UF/16V/10%C84, C85C0603
220UF/35V/20%C89, C90EC6.5/8.5X10.5/S
47UF/16V/10%C108, C122, C133C/C6032
10UF/50V/10%C113, C127, C137, C150C/B3528
10NF/50V/10%C114, C128, C138, C154C0603
56PF/10V/5%C115, C131, C139C0603
1NF/50V/10%C116, C132, C140C0603
22UF/16V/10%C153, C167, C468, C763, C1058C/B3528
470PF/50V/10%C155C0603
8.2NF/50V/10%C156C0603
100PF/50V/5%C157C0603
18PF/25V/5% NPOC216, C217, C518, C519, C813, C814, C1108, C1109C0603
8
47UF/10V/10%C1229C0603
22UF/16V/10%C1327C0603
30P板对板连接器公座CON1, CON2SIP2X15/2.0/S/V/F
NCD1SMA
SM340AD2, D4, D7, D8, D9, D10, D11, D13, D15, D17, D19, D21, D22, D23, D24, D25, D26, D27, D28SMA
19
1N4148D3SOT-23
P6SMB15CAD5, D6SMB
LED/REDD16LED/0603
DC-044A ф2.0J2DC3/10.1X11.6/H
120R/100MHzL1, L5, L9, L10, L21, L22, L23, L24, L25, L34, L35, L36, L37, L38, L48, L49, L50, L51, L52, L62, L63, L64, L65, L66L0805
24
6.8UH/IHLM2525CZER6R8M01L13, L15, L16L/7X7/S
3.3UH/6A/MMD-06CZ-3R3M-V1-SRL18L/7X7/S
BSS123Q1, Q2, Q5, Q6, Q9, Q10, Q13, Q14, Q17, Q18SOT-23
10
2N3904Q3, Q8, Q12, Q16, Q20SOT-23
2N3906Q4, Q7, Q11, Q15, Q19SOT-23
49R9/1%R1, R2, R3, R4, R55, R56, R216R0603
75R/1%R11, R12, R13, R14, R58, R59, R72, R73R0603
8
0R/5%R21, R22, R63, R84, R150, R217, R249, R250, R434, R499, R500, R654, R727, R728, R874, R947, R948, R1094R0603
18
4K7/1%R105, R106, R111, R112, R113, R114, R118, R119, R120, R121, R131, R132, R135, R136, R137, R139, R143, R144, R146, R148, R194, R231, R232, R233, R234, R242, R243, R244, R245, R247, R248, R311, R313, R481, R482, R483, R484, R492, R493, R494, R495, R497, R498, R547, R548, R709, R710, R711, R712, R720, R721, R722, R723, R725, R726, R775, R776, R929, R930, R931, R932, R940, R941, R942, R943, R945, R946, R995, R996R0603
69
2K4/1%R108, R109, R138, R140R0603
10K/1%R115, R151, R158, R180, R192, R203, R219, R235, R238, R431, R432, R435, R485, R488, R651, R653, R655, R713, R716, R871, R873, R875, R933, R936, R1090, R1091, R1093, R1095R0603
28
NCR116, R117, R122, R123, R124, R125, R128, R149, R236, R486, R714, R934R0603
12
100K/1%R126, R133, R141, R145, R155, R240, R490, R718, R938R0603
9
10R/5%R127, R134, R142, R147, R241, R491, R719, R939R0603
8
1M/1%R129, R246, R496, R724, R944R0603
1K/1%R153, R154, R156, R237, R487, R715, R935R0603
4M7/%R157R0603
0R/5%R175, R178, R187, R191, R200, R202, R214, R218R1206
8
330K/5%R177, R190, R201R0603
68K/5%R182, R196, R204R0603
39K/1%R183, R197R0603
3.16K/1%R184, R199R0603
24K/1%R206R0603
1K87/1%R210R0603
68K/1%R215R0603
4.64K/1%R220R0603
7K5/1%R221R0603
47K/5%R222R0603
330R/1%R239, R489, R717, R937R0603
0R/5%R382, R388, R394, R403, R404, R418, R429, R638, R649, R869, R1089R0402
11
NCR383, R385, R389, R395, R419, R421, R639, R641R0402
8
10K/5%R441, R442, R443, R662, R663, R882, R883, R1099, R1100, R1102, R1103R0603
11
33R/5%RP1, RP2, RP3, RP4, RP5, RP6, RP7, RP8, RP9, RP10, RP11, RP12, RP13, RP14, RP15, RP16, RP17, RP18, RP19, RP20, RP21, RP22, RP23, RP24, RP25, RP26, RP27, RP28, RP29, RP30, RP31, RP32, RP33, RP34, RP35, RP36, RP37, RP38, RP39, RP40, RP41, RP42, RP43, RP44, RP45, RP46, RP47, RP488P4R-0603
48
SW-PBS1, S2, S3, S4SW4/4.4X3.2/S
SO-拨位开关SW2, SW3, SW4, SW5DSW2X2/2.54/S/V
H1102NLU1, U2, U5, U7PULSE16/1.27
Rclamp0524P.TCTU9, U10, U11, U24, U25, U27, U43, U44, U46, U61, U62, U64, U79, U80, U82SLP2510P8
15
SIL9287BU12QFN72/0.5/10X10-1
CAT811RU13SOT-143
TPS54331DDAU17, U19, U20SOIC8/1.27/6-1
TPS5432DDAU22SOIC8/1.27/6-1
MAX3815CCMU26, U45, U63, U81TQFP48/0.5/9X9-1
SIL9135U28, U47, U65, U83TQFP144/0.5/22X22-1
AT24C02BN-SH-TU29, U48, U66, U84SOIC8/1.27/6
TPS3808U33, U51, U69, U87SOT-23-6
TPS2080U86SOIC8/1.27/6
28.322MHz/2PinY5, Y8, Y11, Y14X2/5X3.2/S
附件:  p8 r  F5 F! E
PCB源文件如下:9 D: c5 ?' t0 b( f
游客,如果您要查看本帖隐藏内容请回复
( f$ Q7 H$ H. v
8 c# j! z& @4 u  _: R
    2024-6-2 15:34
  • 签到天数: 120 天
    [LV.7]常住居民III
    发表于 2020-11-4 20:21 | 只看该作者
    非常感谢,好
    2025-4-3 15:48
  • 签到天数: 280 天
    [LV.8]以坛为家I
    发表于 2024-7-26 14:26 | 只看该作者
    感谢分享,学习学习
    ' ^% \) B) }  G7 Z- G- F. K
    GMT+8, 2025-6-22 16:40 , Processed in 0.093750 second(s), 27 queries , Gzip On.
