作品名字:[pads VX.2.4][2层] ES6461 PCB LAYOUT文件 原理图
' I5 {5 M9 w3 L/ f
. Y* d( t ^8 D2 `文件描述* ~( n! E( k, l4 Q
: N3 @3 Z8 h! L# y( l; L
1.功能描述:PCB原理图) O) \- J# X @% T5 B
" y2 x9 D/ V9 M D E+ X8 G' M
2.软件版本:PADS VX.2.4, Y( ?3 j v8 V7 E: T# @. P
& G1 M+ I( f- ^
3.层数:2层板
6 R8 u7 U" o' _' k7 J1 T. ~ . N) B6 Q& k& Z' I* k: y3 D
4.用到的主要芯片:ES6461
2 P. V& a2 A( I$ y5.PCB板尺寸:135mm*121mm
- k5 E, \: Z% V5 h! T . M1 \. {% J& V& v+ J
作品截图如下: $ \* u* u: ?" ^# ]' z) d
v" G, f. V4 S, y' n0 E
顶层截图:
: q% a+ h U! r$ B0 h' I0 Z2 _
7 u+ Q" h$ m5 {' l
底层截图:
" D7 f' [0 E, ^4 i z; f1 P
$ }# }; V! f8 Y: e' h
全层截图:/ K8 J7 h6 V/ t: A, \) ?$ z
5 V% ^* y$ {" S7 r9 F5 n( \叠层截图:7 _) L: }7 f$ ]" G
BOM: REFDES | COMP_DEVICE_TYPE | COMP_VALUE | 位号 | 类型 | 属性 | C1 | 0603-CAP | | C2 | 0603-CAP | | C3 | 0603-CAP | | C4 | 0603-CAP | | C5 | 0603-CAP | | C6 | 0603-CAP | | C7 | 0603-CAP | | C8 | 0603-CAP | | C9 | 0603-CAP | | C10 | TAJAJOE | | C11 | TAJAJOE | | C12 | 0603-CAP | | C13 | 0805-CAP | | C14 | CAPUF | | C15 | 0603-CAP | | C16 | TAJAJOE | | C17 | TAJAJOE | | C18 | 0603-CAP | | C19 | 0603-CAP | | C20 | 0603-CAP | | C21 | TAJAJOE | | C22 | TAJAJOE | | C23 | SMB-PANASONIC | | C24 | TAJAJOE | | C25 | 0603-CAP | | C26 | TAJAJOE | | C27 | TAJAJOE | | C28 | TAJAJOE | | C29 | TAJAJOE | | C30 | 0603-CAP | | C31 | 0603-CAP | | C32 | 0603-CAP | | C33 | 0603-CAP | | C34 | TAJAJOE | | C35 | 0603-CAP | | C36 | TAJAJOE | | C37 | TAJAJOE | | C38 | 0603-CAP | | C39 | TAJAJOE | | C40 | 0603-CAP | | C41 | 0603-CAP | | C42 | SMB-PANASONIC | | C43 | 0603-CAP | | C44 | 0603-CAP | | C45 | 0603-CAP | | C46 | 0603-CAP | | C47 | 0603-CAP | | C48 | 0603-CAP | | C49 | 0603-CAP | | C50 | 0603-CAP | | C51 | 0603-CAP | | C52 | TAJAJOE | | C53 | 0603-CAP | | C54 | 0603-CAP | | C55 | 0603-CAP | | C56 | 0603-CAP | | C57 | 0603-CAP | | C58 | 0603-CAP | | C59 | 0603-CAP | | C60 | 0603-CAP | | C61 | 0603-CAP | | C62 | TAJAJOE | | C63 | TAJAJOE | | C64 | 0603-CAP | | C65 | 0603-CAP | | C66 | 0603-CAP | | C67 | TAJAJOE | | C68 | 0603-CAP | | C69 | 0603-CAP | | C70 | 0603-CAP | | C71 | 0603-CAP | | C72 | 0603-CAP | | C73 | 0603-CAP | | C74 | 0603-CAP | | C75 | TAJAJOE | | C76 | TAJAJOE | | C77 | 0603-CAP | | C78 | 0603-CAP | | C79 | 0603-CAP | | C80 | 0603-CAP | | C81 | 0603-CAP | | C82 | 0603-CAP | | C83 | 0603-CAP | | C84 | TAJAJOE | | C85 | TAJA | | C86 | TAJA | | C87 | SMB-PANASONIC | | C88 | SMB-PANASONIC | | C89 | TAJAJOE | | C90 | 0805-RES | | C91 | 0805-CAP | | C92 | 0805-CAP | | C93 | 1206 | | C94 | SMD-PANASONIC | | C95 | 0603-CAP | | C96 | 0805-CAP | | C97 | 1206 | | C98 | SMD-PANASONIC | | C99 | 0603-CAP | | C100 | 0805-CAP | | C101 | TAJAJOE | | C102 | 0603-CAP | | C103 | 0805-CAP | | C104 | 0603-CAP | | C105 | 0805-CAP | | C106 | 1206 | | C107 | SMD-PANASONIC | | C108 | SMD-PANASONIC | | C109 | 0603-CAP | | C110 | 0805-CAP | | C111 | 0603-CAP | | C112 | 0805-CAP | | C113 | 0603-CAP | | C114 | 0805-CAP | | C115 | 0805-CAP | | C116 | 0805-CAP | | C117 | 0603-CAP | | C118 | 0805-CAP | | C119 | 0603-CAP | | C120 | 0805-CAP | | C121 | 0603-CAP | | C122 | 1206-CAP | | C123 | 0603-CAP | | C124 | SMD-PANASONIC | | C125 | 0805-CAP | | C126 | 0603-CAP | | C127 | 0805-CAP | | C128 | 0603-CAP | | C129 | 0805-CAP | | C130 | 0603-CAP | | C131 | 0805-CAP | | C132 | 0603-CAP | | C133 | 0805-CAP | | C134 | 0603-CAP | | C135 | 0805-CAP | | C136 | 0603-CAP | | C137 | 0603-CAP | | C138 | 1206-CAP | | C139 | 1206-CAP | | C140 | TAJAJOE | | C141 | 0805-CAP | | C142 | 1206 | | C143 | 0805-CAP | | C144 | 0805-CAP | | C145 | 0805-CAP | | C146 | 0805-CAP | | C147 | 0603-CAP | | C148 | 0603-CAP | | C149 | SMB-PANASONIC | | C150 | TAJAJOE | | C151 | 0603-CAP | | C152 | 0603-CAP | | C153 | 0603-CAP | | D1 | DIODE\SMD | | D2 | SOT-23 | | D3 | DSS-12 | | D4 | DSS-12 | | D5 | DSS-12 | | D6 | DSS-12 | | D7 | SOT-23 | | D8 | DIODE | | D9 | DIODE | | D10 | DSS-12 | | D11 | DSS-12 | | D12 | DIODE | | D13 | SOT-23 | | D14 | DIODE\SMD | | D15 | DIODE\SMD | | D16 | LED-SMT-0805 | | F1 | FUSE\.4 | | FB1 | L\SMD | | FB2 | L\SMD | | FB3 | L\SMD | | FB4 | L\SMD | | FB5 | L\SMD | | FB6 | L\SMD | | FB7 | L\SMD | | FB8 | L\SMD | | FB9 | L\SMD | | FB10 | L\SMD | | FB11 | 1812-IND | | FB12 | L\SMD | | FB13 | L\SMD | | FB14 | L\SMD | | FB15 | L\SMD | | FB16 | L\SMD | | IR1 | IR | | J1 | PWRJACK-WITHSLOT | | J2 | HDR4-2MM | | J3 | PJ-307H | | J4 | SMD-3P | | JP1 | SIP-3P | | JP2 | SW0603 | | JS1 | HDR6-2MM | | JS2 | HDR2-SHRD | | JS3 | HDR6-2MM | | JS4 | HDR13-2MM | | L1 | IND-SMT-SD7030 | | L2 | L\SMD | | L3 | L\SMD | | L4 | 1812-IND | | L5 | L\SMD | | L6 | L\SMD | | L8 | IND-SMT-SD7030 | | L9 | IND-SMT-SD7030 | | P1 | CF_CARD | | P2 | 4IN1_MSX039_LYH | | P3 | USB-M | | P4 | USB_MINI_5P_SMT_REV1 | | P5 | CON30P-ALT | | P6 | CONN-FH28-60S-0.5SH(51) | | P7 | CON30P-ALT | | PO1 | AV_JACK4 | | POT1 | POT-3MM-SMD-TC33 | | Q1 | TRA\SMD | | Q2 | SOT23 | | Q3 | SOT23 | | Q4 | SOT-223 | | Q5 | TO-92\LINE\OP1 | | Q6 | TO-92\LINE\OP1 | | Q7 | SOT-223 | | Q8 | TO-92\LINE\OP1 | | Q9 | SOT-23 | | Q10 | SOT-23 | | Q11 | SOT-23 | | Q12 | SOT-23 | | Q13 | SOT-23 | | R1 | 0603-RES | | R2 | 0603-RES | | R3 | 0603-RES | | R4 | 0603-RES | | R5 | 0603-RES | | R6 | 0603-RES | | R7 | 0603-RES | | R8 | 0603-RES | | R9 | 0603-RES | | R10 | 0603-RES | | R11 | 0603-RES | | R12 | 0603-RES | | R13 | 0603-RES | | R14 | 0603-RES | | R15 | 0603-RES | | R16 | 0603-RES | | R17 | 0603-RES | | R18 | 0603-RES | | R19 | 0603-RES | | R20 | 0603-RES | | R21 | 0603-RES | | R22 | 0603-RES | | R23 | 0603-RES | | R24 | 0603-RES | | R25 | 0603-RES | | R26 | 0603-RES | | R27 | 0603-RES | | R28 | 0603-RES | | R29 | 0603-RES | | R30 | 0603-RES | | R31 | 0603-RES | | R32 | 0603-RES | | R33 | 0603-RES | | R34 | 0603-RES | | R35 | 0603-RES | | R36 | 0603-RES | | R37 | 0603-RES | | R38 | 0603-RES | | R39 | 0603-RES | | R40 | 0603-RES | | R41 | 0805-RES | | R42 | 0603-RES | | R43 | 0603-RES | | R44 | 0603-RES | | R45 | 0603-RES | | R46 | 0805-RES | | R47 | 0603-RES | | R48 | 0603-RES | | R49 | 0603-RES | | R50 | 0603-RES | | R51 | 0603-RES | | R52 | 0603-RES | | R53 | 0603-RES | | R54 | 0603-RES | | R55 | 0603-RES | | R56 | 0603-RES | | R57 | 0603-RES | | R58 | 0603-RES | | R59 | 0603-RES | | R60 | 0603-RES | | R61 | 0603-RES | | R62 | 0603-RES | | R63 | 0603-RES | | R64 | 0603-RES | | R65 | 0603-RES | | R66 | 0603-RES | | R67 | 0603-RES | | R68 | 0603-RES | | R69 | 0603-RES | | R70 | 0603-RES | | R71 | 0603-RES | | R72 | 0603-RES | | R73 | 0603-RES | | R74 | 0603-RES | | R75 | 0603-RES | | R76 | 0603-RES | | R77 | 0603-RES | | R78 | 0603-RES | | R79 | 0603-RES | | R80 | 0603-RES | | R81 | 0603-RES | | R82 | 0603-RES | | R83 | 0603-RES | | R84 | 0603-RES | | R85 | 0603-RES | | R86 | 0603-RES | | R87 | 0603-RES | | R88 | 0603-RES | | R89 | 0603-RES | | R90 | 0603-RES | | R91 | 0603-RES | | R92 | 0603-RES | | R93 | 0603-RES | | R94 | 0603-RES | | R95 | 0603-RES | | R96 | 0603-RES | | R97 | 0603-RES | | R98 | 0603-RES | | R99 | 0603-RES | | R100 | 0603-RES | | R101 | 0603-RES | | R102 | 0603-RES | | R103 | 0603-RES | | R104 | 0603-RES | | R105 | 0603-RES | | R106 | 0603-RES | | R107 | 0603-RES | | R108 | 0603-RES | | R109 | 0603-RES | | R110 | 0603-RES | | R111 | 0603-RES | | R112 | 0603-RES | | R113 | 0603-RES | | R114 | 0603-RES | | R115 | 0603-RES | | R116 | 0603-RES | | R117 | 0603-RES | | R118 | 0603-RES | | R119 | 0603-RES | | R120 | 0603-RES | | R121 | 0603-RES | | R122 | 0603-RES | | R123 | 0603-RES | | R124 | 0603-RES | | R125 | 0603-RES | | R126 | 0603-RES | | R127 | 0603-RES | | R128 | 0603-RES | | R129 | 0603-RES | | R130 | 0805-RES | | R131 | 0603-RES | | R132 | 0603-RES | | R133 | 0805-RES | | R134 | 0805-RES | | R135 | 0603-RES | | R136 | 0603-RES | | R137 | 0805-RES | | R138 | 0603-RES | | R139 | 0603-RES | | R140 | 0603-RES | | R141 | 0603-RES | | R142 | 0603-RES | | R143 | 0603-RES | | R144 | 0603-RES | | R145 | 1206 | | R146 | 0805-RES | | R147 | 0603-RES | | R148 | 0603-RES | | R149 | 0603-RES | | R150 | 0603-RES | | R151 | 0603-RES | | R152 | 0603-RES | | R153 | 0603-RES | | R154 | 0603-RES | | R155 | 0603-RES | | R156 | 0603-RES | | R157 | 0603-RES | | R158 | 0603-RES | | R159 | 0603-RES | | R160 | 0603-RES | | R161 | 0603-RES | | R162 | 0603-RES | | R163 | 0603-RES | | R164 | 0603-RES | | R165 | 0603-RES | | R166 | 0603-RES | | R167 | 0603-RES | | R168 | 0603-RES | | R169 | 0603-RES | | R170 | 0603-RES | | $ R' U( K+ z, O7 W% \8 M% u6 n
y5 L" R @5 k2 n0 b0 b7 x/ W
$ Q& I# w P: X9 T4 n, ^
, @. `- [3 E4 e附件: % h: K2 N5 r) Y) g% R9 l
