查看: 388|回复: 2
[PADS VX.2.4][2层] ES6461 PCB文件+原理图 支持高清HDMI 多媒体广告机 硬件开发
发表于 2020-2-26 15:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名字:[pads  VX.2.4][2层] ES6461 PCB文件+原理图 支持高清HDMI 多媒体广告机 硬件开发
# d8 K8 V" t2 }/ s: H
* @2 M# M9 o" v# Z- |, z( C5 J文件描述% W- |( \6 }4 T
7 {  {2 R/ L/ R. l3 D# z5 V8 e
1.功能描述:支持高清HDMI 多媒体广告机
2 [& A( J+ F3 ?$ q9 z  v1 B2 {- a 2 n  u0 g. f2 w1 ?6 C8 T9 J
2.软件版本:PADS  VX.2.44 \. q' Y0 X8 h8 y5 G$ P
' d% k  ~4 G* H
3.层数:2层板
- m* o9 {7 P0 c
* U: m( Y) _( t: H/ I
4.用到的主要芯片:ES6461
& v/ x. ~: @* N: h
5.PCB板尺寸:74mm*135mm
3 Y& @* E( Z% h $ ]1 ~! x4 I5 ]2 Q' l* y1 y
作品截图如下:
) R3 r* P3 _) S9 U0 n
6 C& l3 f: b* k) P+ }顶层截图:
5 [9 m- C( x! A% D, d2 e" G 5 N# q) }# C4 k9 {+ w* K0 Z$ h
底层截图:
  N% y5 H; p# G $ Z' ]7 R7 }0 k$ _) P
. Q9 S) H' ]. X, H/ V) i/ R- c
全层截图:9 s* b7 }  z) e( q, h5 Q) Y
  S/ Q  v/ S! \  e叠层截图:
6 W3 e: p9 @/ d2 J
BOM:
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
C1TAJA10UF/10V
C20603-CAP27PF
C30603-CAP27PF
C4TAJA10UF/10V
C50603-CAP0.1UF
C6TAJA10UF/10V
C80603-CAPNC
C90603-CAPNC
C110603-CAP10PF
C120603-CAP0.1UF
C130603-CAPNC
C140603-CAP1000PF
C150603-CAP0.1UF
C160603-CAP0.1UF
C170603-CAP0.1UF
C180603-CAP0.1UF
C190603-CAP0.1UF
C200603-CAP0.1UF
C210603-CAP0.1UF
C220603-CAP0.1UF
C230603-CAP0.1UF
C240603-CAP0.1UF
C250603-CAP0.1UF
C260603-CAP0.1UF
C270603-CAP0.1UF
C280603-CAP0.1UF
C29TAJA10UF/10V
C300603-CAP0.1UF
C31TAJA10UF/10V
C320603-CAP0.1UF
C340603-CAP0.1UF
C35TAJA10UF/10V
C360603-CAP0.1UF
C380603-CAP0.1UF
C39TAJA10UF/10V
C400603-CAP0.1UF
C420603-CAP0.1UF
C430603-CAP0.1UF
C440603-CAP0.1UF
C450603-CAP0.1UF
C460603-CAP0.1UF
C47TAJA10UF/10V
C480603-CAP0.1UF
C490603-CAP0.1UF
C500603-CAP0.1UF
C510603-CAP0.1UF
C520603-CAP0.1UF
C530603-CAP0.1UF
C540603-CAP20PF
C550603-CAP20PF
C56TAJA10U/10V
C57TAJA10U/10V
C590603-CAP0.01UF
C60TAJA10U/10V
C61TAJA10U/10V
C620603-CAP0.01UF
C63TAJA10U/10V
C640603-CAP0.01UF
C650603-CAP0.01UF
C660603-CAP1UF
C670603-CAP0.1UF
C680603-CAP0.1UF
C690603-CAP0.1UF
C700603-CAP0.1UF
C710603-CAP0.1UF
C720603-CAP0.1UF
C730603-CAP0.1UF
C740603-CAP0.1UF
C750603-CAP0.1UF
C760603-CAP1000PF
C770603-CAP0.1UF
C780603-CAP0.1UF
C790603-CAP1000PF
C800603-CAP0.1UF
C810603-CAP0.1UF
C820603-CAP1000PF
C830603-CAP0.1UF
C840603-CAP0.1UF
C850603-CAP1000PF
C860603-CAP0.1UF
C870603-CAP0.1UF
C88TAJA10UF/10V
C890603-CAP1000PF
C900603-CAP0.1UF
C910603-CAP0.1UF
C920603-CAP0.1UF
C93TAJA10UF/10V
C940603-CAP33PF
C950603-CAP0.1UF
C96TAJA10UF/10V
C97TAJA10UF/10V
C980603-CAP470PF
C99TAJA10UF/10V
C100TAJA10UF/10V
C1010603-CAP4700PF
C1020603-CAP4700PF
C1030603-CAP0.1UF
C1040603-CAP1000PF
C1050603-CAP470PF
C106TAJA10UF/10V
C107TAJA10UF/10V
C1080603-CAP4700PF
C1090603-CAP4700PF
C1100603-CAP1000PF
C111CE6X11100UF/10V
C112EC100UF/10V
C113TAJA10UF/10V
C1140603-CAP0.1UF
C115TAJA10UF/10V
C1160603-CAP0.1UF
C117TAJA10UF/10V
C118TAJA10UF/10V
C1190603-CAP33PF
C1200603-CAP82PF
C121EC100UF/10V
C1220603-CAP22PF
C1230603-CAP0.1UF
C1240603-CAP1UF
C1250603-CAP33PF
C1260603-CAP82PF
C1270603-CAP33PF
C1280603-CAP82PF
C1290603-CAP33PF
C1300603-CAP82PF
C131TAJA10UF/10V
C1320603-CAP0.1UF
CN12IN1_CARDSD_MMC_CARD
CN2GM-POW-AARCA
CN3PHONEPJK-614
CN4PHONEPJK-614
CN63IN1-MSD0193IN1_CARD
D1IN4148IN4148
D2IN4148IN4148
D3SMBAIN5819/5822
D4SMBAIN4001
D5SMBAIN4001
D6IN4148-LYHNC
D7IN4148-LYHNC
D8IN4148-LYHNC
FB1L\0603FB
FB2L\0603FB
FB3L\0603FB
FB4L\0603FB
FB5L\0603FB
FB6L\0603NC
FB7L\0603FB
FB8L\0603NC
FB9L\0603FB
FB10L\0603FB
FB11L\0603FB
FB12L\0603FB
FB13L\0603FB
FB14L\0603FB
IR1IR1IR
J1CON5/1.25S5P_1.25MM
J2CON2.0-3NC
J3CON2.0-6NC
J4SATA2.5HDD-LYH-SMT-ASATA_HOST_CON
J5SIP\2P
L1L\06030.47UH
L2L\06030.22UH
L3SD354.7UH/0.6A/SD35
L4L\06030.47UH
L5L\06030.22UH
L6L\06030.47UH
L7L\06030.22UH
L8L\06030.47UH
L9L\06030.22UH
LED1LED2ALED_DAUL
P1HDMI-CON-HOLEHDMI-A
P2SANYOFMTT
P3SANYOFMTT
P4E-SATA-1.27A
Q1SOT238050
Q2SOT23A3401
Q3SOT238050
Q4SOT238050
Q5SOT238050
Q6SOT23NC
Q7SOT23NC
Q8SOT-89XP162A(NC)
R10603-RESNC
R20603-RES10K
R30603-RES10K
R40603-RESNC
R50603-RES100K
R60603-RES10K
R70603-RESNC
R80603-RES10K
R90603-RESNC
R100603-RES10K
R110603-RES15K
R120603-RES15K
R130603-RESNC
R140603-RESNC
R150603-RES10K
R160603-RESNC
R170603-RES10K
R180603-RES10K
R190603-RESNC
R200603-RES10K
R210603-RESNC
R220603-RES15K
R230603-RES15K
R240603-RES10K
R250603-RES10K
R260603-RES10K
R270603-RES1K
R280603-RES10K
R290603-RES10K
R300603-RESNC
R310603-RES10K
R320603-RES390
R330603-RESNC
R340603-RESNC
R350603-RESNC
R360603-RESNC
R370603-RES10K
R380603-RES10K
R390603-RES10K
R400603-RES4.7K
R410603-RES100
R420603-RES2.2K
R430603-RES2.2K
R440603-RES33
R450603-RES33
R460603-RES1.8K
R470603-RES1K
R480603-RES4.7K
R490603-RES1.5K
R500603-RES2.2K
R510603-RES3.9K
R520603-RES10K
R530603-RES10K
R540603-RES10K
R550603-RES10K
R560603-RES10K
R570603-RES5.6K
R580603-RES2.2K
R590603-RES33
R600603-RES33
R610603-RES33
R620603-RES8.2K
R630603-RES33
R640603-RES33
R650603-RES33
R660603-RES3.3K
R670603-RES12K
R680603-RES18K
R690603-RES22K
R700603-RES150K
R710603-RES4.7K
R720603-RES4.7K
R730603-RES4.7K
R740603-RES10K
R750603-RES10M
R760603-RES5.1K
R770603-RES750
R780603-RESNC
R790603-RESNC
R800603-RES10K
R810603-RES10K
R820603-RES10K
R830603-RES10K
R840603-RES10K
R850603-RES10K
R860603-RES10K
R870603-RES10K
R880603-RES0
R890603-RES330
R900603-RES510
R910603-RES7.5K
R920603-RES15K
R930603-RES1K
R940603-RES510K
R950603-RES10K
R960603-RES560
R970603-RES0
R980603-RESNC
R990603-RES33
R1000603-RES4.7K
R1010603-RES4.7K
R1020603-RES4.7K
R1030603-RESNC
R1040603-RES4.7K
R1050603-RES4.7K
R1060603-RES15K
R1070603-RES2.2K
R1080603-RES2.2K
R1090603-RES4.7K
R1100603-RES2K
R1110603-RES1.5K
R1120603-RES1.5K
R1130603-RES100K
R1140603-RES4.7K
R1150603-RES2K
R1160603-RES1.5K
R1170603-RES1.5K
R1180603-RES100K
R1190603-RES10K
R1200603-RES100
R1210603-RES10K
R1220603-RES75
R1230603-RES300K
R1240603-RES300K
R1250603-RES75
R1260603-RES75
R1270603-RES75
R1280603-RES
R1290603-RES
R1300603-RES2.2K
R1310603-RES3.3K
R1320603-RES2.2K
R1330603-RES33
R1340603-RES10K
R1350603-RES10K
R1360603-RES0
R1370603-RESNC
R1380603-RESNC
R1390603-RES2K
R1400603-RES0
R1410603-RES10K
R1420603-RES10K
RN1RP4-065W-C100X4
RN2RP4-065W-C100X4
RN3RP4-065W-C100X4
RN4RP4-065W-C100X4
RN5RP4-065W-C33X4
RN6RP4-065W-C33X4
RN7RP4-065W-C33X4
RN8RP4-065W-C33X4
RN9RP4-065W-C33X4
RN10RP4-065W-C33X4
S1ANJIANCSW
S2ANJIANCSW
S3ANJIANCSW
S4ANJIANCSW
S5ANJIANCSW
S6ANJIANCSW
S7BUTSW
U1LQFP176/ES6811ES6461
U2SO8-WBN25P16
U3IRU1117NC
U4SO-8AT24C01A
U5TSOP54128MB
U6GL830GL830
U7SIL9030/ES7120CKD180/ES7120/7108
U8SOT-223LD1117-1.8V
U9SO-84558
U10IRU1117AMS1117-3.3V
U11V6300ACAT7101
USB1USB-AUSB_DIP
USB2SUBAAMINI_USB_5P
Y1HC-49/SM27MHZ
Y232.768KHZ-SMTNC
Y3HC-49/SM25MHZ
Z1PAABAAACAABAABBAPAD
Z2PAABAAACAABAABBAPAD
Z4ZZMTHA
Z5ZZMTHA
" e) a2 M; c: S* P0 `; |$ ?6 G
0 C6 ~, ]+ C2 Q/ g8 f. V+ D
* C% ~2 ^* m9 Y0 j$ m/ ]
, @/ t* V1 u9 M/ Y& n1 v" W0 A
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
游客,如果您要查看本帖隐藏内容请回复
; w9 U8 H2 J. Y3 n) ]
发表于 2020-11-30 22:26 | 只看该作者
啊啊啊啊啊啊啊啊啊啊啊啊1 N* @0 T: q- A# O
发表于 2020-11-30 22:33 | 只看该作者
好人一生平安
6 d7 [. X% v. c0 u/ v, I* f
GMT+8, 2025-9-14 02:40 , Processed in 0.156250 second(s), 27 queries , Gzip On.
