查看: 180|回复: 0
[AD 10][4层] TMS320C5535 430BOOST核心板TS3A225E+SN74AVC4T245+TPS77801+PCB文件
发表于 2020-2-26 14:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 10][4层] TMS320C5535 430BOOST核心板TS3A225E+SN74AVC4T245+TPS77801+PCB文件! f6 t2 ?8 l. [# E% o
( K) a; V# T$ Z2 L  \
文件描述
$ U) S1 F# M, L( k6 D1. 作品用途:TMS320C5535 430BOOST核心板
2 o; [, m9 z, I, s2. 软件版本:AD 10
1 N  N9 Z! u( H& R- c8 c3. 层数:4层板- X5 a2 G4 r0 {4 k" i  u. |
4. 用到的主要芯片:TS3A225E+SN74AVC4T245+TPS77801: w' u- x% I" b3 [
5. PCB尺寸:51mm*85mm
! M$ f+ L  J0 K  J; I+ w  Q+ w. e0 A* N3 H- G+ n1 u
作品截图如下:
# h6 i5 c, s  A9 d9 ^8 k; l6 r. ]顶层截图:( ]9 N+ t# h: ]
$ P( O$ m5 ~9 [! B- b+ [) [
& K8 [: {# x1 R9 A" a+ J0 y底层截图:1 v, y8 [: \4 s/ b2 Q
1 ]# ~3 x* U5 `4 _; [$ D; ~4 D2 @5 z
全层截图:: L& F1 Q3 v& _- w
. [9 v8 X. c* s
/ r6 M8 r! V: s$ [$ d3 Y& U0 t6 y叠层信息截图如下:
4 X" d% ?* A- M: r
- @+ n+ z- J1 Y3 z
$ G# ]# J. X9 Y( L9 h0 c* RBOM:) a6 m# G: O) {6 s  a$ Q
Comment(属性)
Designator(位号)
Footprint(封装)
Quantity(数量)
10uF
C1, C2, C6, C7, C16,  C18, C21, C29, C56, C62, C74, C102, C206
0805-c
13
NO_POP
C3, C106
0402-C
0.1uF
C4, C5, C8, C9, C14,  C17, C19, C22, C25, C27, C30, C32, C33, C34, C41, C44, C46, C47, C48, C49,  C50, C57, C59, C60, C61, C63, C64, C65, C66, C67, C68, C70, C71, C75, C80,  C88, C108, C200, C201, C202, C210
0402-C
41
0.47uF
C10, C12, C111
0402-C
22pF
C11, C107
0402-C
100uF
C13, C15
SMD-C
1000pF
C20, C31, C45, C58
0402-C
33pF
C23, C24, C79
0402-C
1uF
C26, C35, C37, C39,  C40, C43, C52, C54, C69, C81, C82, C87, C89, C104, C109, C110, C203, C208,  C209, C211
0603-C
20
0.01uF
C28, C36, C38, C42,  C51, C53, C55, C83
0402-C
8
2200pF
C72
0402-C
4.7uF
C73, C76, C77, C78,  C85
0805-c
2.2uF
C100, C101
0603-c
10pF
C103
0402-C
10uF/16V
C105
0805-c
0.022uF
C220
0402-C
MBR0520
D1, D4, D5
SOD-123-1
6.2V
D2
SOD-123-1
LED_GREEN
D3
0603-1
LED8
D6
1206-W
LED7
D7
1206-W
LED5
D8
1206-W
LED6
D9
1206-W
LED2
D10
1206-W
LED3
D11
1206-W
LED1
D12
1206-W
LED4
D13
1206-W
LED9
D14
1206-W
SD CARD
J1
microsd-TF2
OSD9616
J2
LCD-UG-9616TLBBG02
PAD
J3, J4, J5, J6, J7,  J8
SIP1-TEST
JUMPER
JP1, JP2, JP3, JP5
SIP2-2.54
NO_POP
JP6
SIP2-2.54
BLM21AG151SN1D
L1, L2
0603-L
BLM18AG601SN1D
L3, L4, L5, L6, L7,  L8
0603-L
2.2uH
L9, L11
VLF3010A
NO_POP
P1
SIP10-2.0
Header 10
P3, P4
SIP10-2.54MM-SMD
APM2309A-TRL
Q1
SOT-23-3P
NO_POP
R1, R2, R8, R24, R29,  R32, R42, R43, R62, R63, R65, R66, R69, R75, R76, R96, R97
0402-R
17
0
R3, R4, R7, R21, R23,  R26, R28, R31, R44, R45, R46, R57, R58, R59, R79, R89
0402-R
16
10K
R5, R13, R30, R33,  R34, R35, R38, R39, R41, R47, R64, R67, R68, R70, R71, R72, R73, R82, R93
0402-R
19
4.7K
R6, R16, R22, R56
0402-R
47K
R9, R10
0402-R
R11, R48
0402-R
2.2K
R12
0402-R
1K
R14
0402-R
R15, R17, R18, R78,  R83, R84, R85, R86, R87
0402-R
9
100
R19
0402-R
14K  1%
R20
0402-R
100K
R25, R36, R37, R91
0402-R
10K  1%
R27
0402-R
R40
0402-R
18.2K  1%
R49
0402-R
3.3K  1%
R50
0402-R
10.7K  1%
R51
0402-R
110K  1%
R52
0402-R
250K
R53
0402-R
30K  1%
R54
0402-R
NOP_POP_4.7K
R55
0402-R
392K  1%
R77
0402-R
1.6M  1%
R80
0402-R
180K  1%
R81
0402-R
1  1%
R90
0402-R
220K
R92
0402-R
20K
R94
0402-R
39.2K
R95
0402-R
SIP
SILP
PAD-28MM
GND
TP1, TP4
SIP1-TEST
VBUS
TP2
SIP1-TEST
CLKOUT
TP3
SIP1-TEST
VCC_3V6_TP
TP5
SIP1-TEST
VCC_1V3_TP
TP6
SIP1-TEST
TextPoint
TP7, TP10, TP11, TP12
SIP1-TEST
VCC_3V3_TP
TP8
SIP1-TEST
RTC_CLKOUT
TP9
SIP1-TEST
VCC_1V8_TP
TP13
SIP1-TEST
TPS77801
U1
SOIC-8P
TLV320AIC3204IRHBT
U2
QFN-32P-0.5MM
INA219IDCN
U3
SOT-23-8P
DSX321G 12MHZ
U4
SMD3225-4
TMS320C5535
U5
BGA-N144-0.8MM
TPS62260DDCT
U6
SOT-23-5P
TS3A225E
U7
QFN-16P-0.5MM
TPS79501DCQ
U8
SOT-223-6
TPS79533DCQ
U9
SOT-223-6
SST25VF016B
U10
son-8p
SN74AVC4T245
U11
TSSOP-16P
TPS61041DBV
U12
SOT-23-5P
Audio  Line Input
U13
KJ-355-X1
USB-MINI--F
USB1
USB-MIN-F
32.768KHz
Y1
SMD4015-2
& L, l- U3 H0 O  Y  Q" x附件:# O8 Z9 O0 p# D6 u6 G% V
原理图和PCB源文件如下:
* i; c* B) B. I8 X) Q5 T  A: n
游客,如果您要查看本帖隐藏内容请回复
" z  d1 y# e7 y& S6 q" \( ~& ^2 `
* q4 V; Y" ]  ~0 J6 q3 P- q; }
GMT+8, 2025-7-27 13:32 , Processed in 0.125000 second(s), 28 queries , Gzip On.
