作品名:[AD 15][4层] 数字交错反激逆变电源(MCP14E4+MCP9700)PCB源文件# m3 ~: T8 ]# n; d' V/ J7 h) I' K* U% T
7 w9 H3 p5 F- q4 v9 W' |' W* a' G
2 e; d* c9 N/ @* E3 D8 |( f& v; z文件描述9 v( u. d6 x( z2 b- e
1. 作品用途:数字交错反激逆变电源
5 z* |9 m5 {" _ X8 `2 n. H, H( \7 ~2. 软件版本:AD 15
: |6 w7 \; c) Q/ S- }3. 层数:4层板* m0 j7 V4 _8 g, \- s; |
4. 用到的主要芯片:MCP14E4+MCP9700
) v& N( Z O9 K9 V) K4 C# h5 a9 l5. PCB尺寸:231mm*124mm. J3 h+ |, F( ?% J7 [* K
& n% O" k9 ~( K `
2 X& y2 x: X$ |/ V" a3 {
作品截图如下:
+ h5 j+ S6 P& X1 g" `4 m! g顶层截图:
( ?- O; D: A1 p' P) ]; I& [) ]# t1 R/ _) H$ I/ X ~" H; Q( D9 g; ^
, @% h& u; ]& N* [8 z: @底层截图:3 o6 F- e6 Y5 _
* e) M0 [$ o/ V5 }4 f% e
0 S5 Q( j5 h% D2 y1 T* B
全层截图:% e. P/ O6 ]8 e8 {/ {/ ^: D! ]2 S! g0 H
& d6 B5 m# Q* R" n: n" e2 m$ G" E- n9 p& d9 g, f2 ]7 v
叠层信息截图如下:
& R) O% U B" c$ ~/ [1 b7 R% d4 o7 W2 l* I% k' |2 i
" T5 j# B3 C! B6 \) K5 M2 L F( S/ l
BOM:
7 S6 i; k- A, V! j5 r6 I# _2 h- KComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | CAP1206_1uF_100V | C1 | CAP1206 | 1 | CAP0805_0.1uF_100V | C2 | CAP0805 | 1 | CAP0603_0.01uF | C3, C32, C44, C45, C46, C47, C80, C81 | CAP0603 | 8 | CAP0603_0.1uF_50V | C4, C7, C8, C9, C11, C14, C21, C22, C23, C24, C28, C35, C40, C54, C57, C74, C75, C77, C78, C82, C89 | CAP0603 | 21 | CAP0603_1uF_16V | C5, C20, C25, C29, C39, C55, C76, C79 | CAP0603 | 8 | CAP2917_TANT_100uF_16V | C6 | CAP2917(7343) | 1 | CAP0805_10uF_16V | C10, C13, C16, C17, C18, C19 | CAP0805 | 6 | DNP | C12, C15, C26, C31, C34, C36, C38 | CAP0603 | 7 | CAP0603_8200pF | C27, C33, C37 | CAP0603 | 3 | CAP0603_2.2nF | C30 | CAP0603 | 1 | CAP0603_470pF | C41, C42, C43 | CAP0603 | 3 | CAP_TH_4.7nF | C48, C49, C52, C53 | CAP_TH_7.5MM | 4 | CAP_TH_BFC238330153 | C50, C51, C88 | CAP_TH_15MM | 3 | CAP0603_1nF | C56 | CAP0603 | 1 | CAP_TH_BFC233920104 | C58, C69 | CAP_TH_10MM | 2 | CAP1210_2200pF | C59, C70 | CAP1210 | 2 | CAP2220_10uF_100V | C60, C71 | CAP2220 | 2 | CAP2220_2.2uF_250V | C61, C62, C72, C73, C83, C84, C85, C86 | CAP2220 | 8 | CAP_TH_UPW1J222MHD | C63, C64, C65, C66, C67 | CAP_TH_7.5MM_ALUM | 5 | CAP0603_120pF | C68 | CAP0603 | 1 | DNP | C87 | CAP_TH_7.5MM | 1 | CAP0603_220pF | C90 | CAP0603 | 1 | DIODE_SS16 | D1 | DIODE_DO-214AC | 1 | DIODE_1N4148WX | D2 | SOD323 | 1 | DIODE_CDBU0520 | D3, D9, D11 | DIODE_0603 | 3 | LED_0603_RED | D4, D26, D27 | LED_0603_RED | 3 | LED_0603_GRN | D5 | LED_0603_GRN | 1 | LED_0603_YEL | D6 | LED_0603_YEL | 1 | DIODE_BAR43S | D7, D8, D10, D12, D28 | SOT23-3 | 5 | DIODE_ZTL431AFFTA | D13 | SOT23-3 | 1 | DIODE_MBR0540 | D14, D15, D16, D17, D20, D21, D22, D23, D24, D25 | SOD123 | 10 | DIODE_C2D05120E | D18, D19 | TO-252-3 | 2 | DIODE_1SMA10CAT3 | D29 | DIODE_DO-214AC | 1 | FUSE_RST 6.3 | F1, F2 | FUSE_TH_RST | 2 | RJ11 | J1 | CONN_RJ11_6P_RA_STEP | 1 | HDR_2X6_TH | J2 | HDR_2X6_TH | 1 | HDR_TSW-102-07-F-S | J3 | HDR_TSW-102-07-F-S | 1 | CONN_38720-6303 | J4 | CONN_38720-6303 | 1 | HDR_TH_63824-1 | J5, J6 | HDR_TH_63824-1_200MILS | 2 | IND_MSS7341-224ML | L1 | IND_MSS7341 | 1 | IND_ME3220-223KLB | L2 | IND_ME3220 | 1 | IND_ME3220-103KLB | L3 | IND_ME3220 | 1 | JW Miller A Bourns Company | L4, L7 | IND_2100LL-100-H-RC | 2 | IND_BLM41PG600SN1L | L5, L8 | RES1806 | 2 | TRANS_FE2X03-4-3NL | L6 | FE2X | 1 | IND_0.22uH | L9 | Ind_HC1 | 1 | Short | L10, L11 | IND_CUSTOM | 2 | MH_440 | MH1, MH2, MH3, MH4, MH5, MH6, MH7, MH8, MH9 | HW_4-40 screw | 9 | MH_440_PLATED | MH10 | HW_4-40 screw - Plated | 1 | CAP_TH_VAR_S14K275E2 | MOV1, MOV2 | CAP_TH_7.5MM#2 | 2 | HDR_PIM_100P_M | P1 | HDR_TH_100P_M | 1 | TRANSISTOR_BC817-16LT1G | Q1 | SOT23-3 | 1 | TRANSISTOR_IPB60R190C6 | Q2, Q3, Q4, Q5 | DPACK | 4 | SI7115DN | Q6, Q8 | PowerPAK | 2 | TRANSISTOR_IRFS4321TRLPBF | Q7, Q9 | DPACK | 2 | RES0603_10K | R1, R10, R52, R57, R64, R69, R78, R80, R86, R88, R93, R94, R104, R107, R110, R111, R118, R119, R126, R127 | RES0603 | 20 | RES0603_3.3K | R2, R32, R37, R38, R39, R41, R42, R44, R45, R141 | RES0603 | 10 | | R3, R6, R7, R9, R21, R23, R36, R108, R109 | RES0603 | 9 | RES0603_10.2K | R4 | RES0603 | 1 | | R5 | RES1206 | 1 | RES1206_0R | R8, R133, R134, R137, R138 | RES1206 | 5 | DNP | R11, R12, R33, R51, R53, R63, R65 | RES0603 | 7 | RES0603_0R | R13, R22, R43, R47, R56, R59, R68, R70, R112, R117, R120, R125, R135, R136 | RES0603 | 14 | RES0603_4.7K | R14 | RES0603 | 1 | RES0603_470R | R15 | RES0603 | 1 | RES0603_330R | R16, R17, R18, R71, R129, R130 | RES0603 | 6 | RES0603_100K | R19, R25, R28, R34 | RES0603 | 4 | RES 1.60K OHM 1/10W 1% 0603 SMD | R20, R27 | RES0603 | 2 | RES0603_27K | R24, R31 | RES0603 | 2 | RES0603_1.69K | R26, R30, R128 | RES0603 | 3 | RES0603_1K | R29, R73, R91, R92, R113, R115, R121, R123 | RES0603 | 8 | RES 0603 | R35 | RES0603 | 1 | RES0603_470K | R40 | RES0603 | 1 | RES0603_7.5K | R46, R55, R58, R67, R74 | RES0603 | 5 | RES0603_3.01K | R48, R50, R60, R62 | RES0603 | 4 | RES0603_120R | R49, R61 | RES0603 | 2 | RES0603_15R | R54, R66 | RES0603 | 2 | RES0603_120K | R72 | RES0603 | 1 | RES0603_11R | R75, R76, R83, R84, R95, R96, R114, R116, R122, R124 | RES0603 | 10 | RES0603_1R | R77, R79, R85, R87 | RES0603 | 4 | RES0603_270R | R81, R82, R89, R90 | RES0603 | 4 | RES1206_150K | R97, R99, R101 | RES1206 | 3 | RES1206_240K | R98, R100 | RES1206 | 2 | RES1206_300K | R102 | RES1206 | 1 | RES0603_100R | R103 | RES0603 | 1 | RES0603_30K | R105 | RES0603 | 1 | RES0603_5.1K | R106 | RES0603 | 1 | DNP | R131, R132, R139, R140 | RES1206 | 4 | SW_TACT_TH_VM | SW1 | SW_PTS645 | 1 | TP-115*50_SMT | TP1, TP2, TP3, TP4, TP5, TP7, TP8, TP9, TP10, TP11, TP15, TP16, TP17, TP18, TP19, TP20, TP21, TP22, TP23, TP24, TP25, TP26, TP27 | TP_115*50_SMT | 23 | GND_ANA | TP6, TP28 | TP_115*50_SMT | 2 | +12V | TP12 | TP_115*50_SMT | 1 | +5V | TP13 | TP_115*50_SMT | 1 | +3.3V | TP14 | TP_115*50_SMT | 1 | GND_DIG | TP29 | TP_115*50_SMT | 1 | GND_PV | TP30, TP31 | TP_115*50_SMT | 2 | TRANS_DPC-10-90 | TR1 | TRANS_DPC_8PIN | 1 | TRANS_DA2320-AL | TR2, TR3 | TRANS_ PA100 | 2 | TRANS_RM14 | TR4, TR6 | TRANS_RM14 | 2 | TRANS_B82801B305A125 | TR5, TR7 | TRANS_ PA1005 | 2 | DSPIC33FJ16GS504T-I/PT | U1 | TQFP44PIN | 1 | LM5008AMM | U2 | MSOP-8 EP | 1 | MCP16301 | U3 | SOT23-6 | 1 | MCP1700T-3302E/MB | U4 | SOT89-150P410X160-3N | 1 | MCP6022-I/SN | U5, U6, U7 | SOIC-8-Step | 3 | MCP9700 | U8 | SC70-5 | 1 | | U9, U10, U12 | SMD-4 | 3 | OPTO_FOD817DSD | U11 | SMD-4 | 1 | MCP14E4 | U13, U16, U17 | SOIC-8-Step | 3 | IC_ACS712ELCTR-05B-T | U14 | SOIC-8-Step | 1 | OPTO_FOD2741B | U15 | SMD-8 | 1 | DNP | Y1 | CRYSTAL_SMT_HC49/US | 1 | 附件:
9 h8 F1 o5 F+ D1 b7 a PCB源文件如下:
2 P4 _6 T: v( |/ t* `. _ |
