查看: 195|回复: 0
[AD 10][2层]XC4VSX35通信设备主板(LFCSP64+D2PAK-5+SDRAM)PCB文件分享下载
发表于 2020-2-25 15:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 10][2层]XC4VSX35通信设备主板(LFCSP64+D2PAK-5+SDRAM)PCB文件分享下载
  D! y! ?$ n# r* B% _
5 v* m: q2 M$ b  X& H1 r文件描述+ ~# [* P7 n9 r/ ~
1. 作品用途:通信设备主板
7 z  @* O& U' _3 V2. 软件版本:AD 10
% m. y3 e; N  ~) q$ K3. 层数:2层板5 u) T, e) L# i: p
4. 用到的主要芯片:LFCSP64+D2PAK-5+SDRAM+BGA252+BGA4841 N5 d2 j( s+ ~2 H% R
5. PCB尺寸:200.2mm*140.8mm- o' \: Q6 n7 }- ^1 E
. l/ d) {5 X- y6 ?% d/ w" ~作品截图如下:8 U* O! w8 b+ r
顶层截图:' Q) N  P! R5 G
! `1 ]: r3 p0 p  U  V8 m
) [. p+ j; S: }, V, Z$ w# L$ Y
底层截图:
1 |# z+ _* q% k9 k * ?& s- I$ I% N' z
2 i' w2 Y- ~) t全层截图:( m9 L+ d2 ?  N
8 y3 b8 J2 @# G0 _! Q" M0 \2 b+ H: j2 s
叠层信息截图如下:) C1 d# R: f" ~5 _
  u) c$ e( m7 [; Q- d1 }
4 W: ~% t  I, }7 f9 C$ ]7 \BOM:; A# P( A4 J1 m/ x; K: Z
Comment(属性)
Designator(位号)
Footprint(封装)
Quantity(数量)
B1
HC49
C1, C2, C3, C4, C5,  C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21,  C22, C23, C24, C25, C26, C27, C28, C29, C30, C31, C32, C33, C34, C35, C36,  C37, C38, C39, C40, C41, C42, C43, C44, C45, C46, C47, C48, C49, C50, C53,  C54, C55, C56, C57, C58, C59, C60, C62, C63, C64, C65, C66, C67, C68, C69,  C70, C71, C72, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C83, C84,  C85, C86, C87, C88, C89, C92, C93, C94, C95, C96, C97, C98, C99, C100, C101,  C102, C103, C104, C105, C106, C107, C108, C109, C110, C111, C112, C113, C114,  C115, C116, C117, C118, C119, C120, C121, C122, C123, C124, C125, C126, C127,  C128, C129, C130, C131, C132, C133, C134, C135, C136, C137, C138, C139, C140,  C141, C142, C143, C144, C145, C146, C147, C148, C149, C150, C151, C152, C153,  C154, C155, C156, C157, C158, C159, C160, C161, C162, C163, C164, C165, C166,  C171, C172, C173, C174, C175, C176, C177, C178, C179, C180, C181, C182, C183,  C184, C185, C186, C187, C188, C189, C190, C191, C192, C193, C194, C195, C196,  C197, C198, C199, C200, C201, C202, C203, C204, C206, C207, C208, C209, C210,  C211, C212, C213, C214, C216, C217, C218, C219, C220, C221, C222, C223, C224,  C225, C229, C230, C232, C233, C238, C241, C242, C243, C246, C247, C248, C249,  C250, C251, C252, C253, C254, C255, C256, C257, C258, C259, C260, C261, C262,  C263, C264, C265, C266, C267, C268, C269, C270, C271, C272, C273, C274, C275,  C276, C277, C278, C279, C280, C281, C282, C284, C285, C286, C287, C289, C290,  C291, C292, C293, C294, C295, C296, C297, C298, C299, C300, C301, C302, C303,  C304, C305, C306, C307, C308, C309, C310, C312, C313, C314, C315, C317, C318,  C319, C323, C324, C325, C342, F1, F3, F30, F31, J1, J2, J3, J4, R1, R2, R3,  R4, R5, R6, R7, R8, R9, R10, R11, R12, R13, R14, R15, R16, R17, R18, R19,  R20, R21, R22, R23, R24, R25, R26, R27, R28, R29, R30, R31, R32, R33, R34,  R35, R36, R37, R38, R39, R40, R41, R42, R43, R44, R45, R46, R47, R48, R49,  R50, R51, R52, R53, R54, R55, R56, R59, R60, R61, R62, R63, R64, R65, R66,  R67, R68, R69, R70, R71, R72, R73, R74, R75, R76, R77, R78, R79, R81, R83,  R84, R85, R86, R87, R88, R89, R90, R91, R92, R93, R99, R100, R103, R105,  R106, R118, R119, R124, R125, R126, R127, R129, R130, R133, R134, R135, R136,  R137, R138, R141, R142, R143, R148, R156, R157, R158, R159, R160, R161, R162,  R163, R164, R165, R166, R167, R168, R169, R170, R171, R172, R173, R174, R175,  R176, R177, R178, R179, R182, R183, R184, R185, R186, R187, R188, R189, R190,  R191, R192, R193, R194, R195, R196, R197, R198, R200, R201, R202, R205, R206,  R207, R208, R209, R210, R211, R212, R213, R214, R217, R218, R219, R220, R221,  R222, R223, R224, R227, R228, R229, R230, R231, R232, R233, R234, R235, R236,  R237, R238, R239, R240, R241, R242, R243, R244, R245, R246, R247, R248, R249,  R250, R251, R252, R253, R254, R255, R256, R257, R258, R259, R260, R261, R263,  R264, R265, R266, R267, R269, R271, R272, R273, R274, R275, R276, R277, R278,  R279, R280, R281, R282, R283, R284, R285, R286, R287, R288, R289, R290, R291,  R292, R293, R294, R295, R296, R297, R298, R299, R300, R301, R302, R303, R304,  R305, R306, R307, R308, R309, R310, R311, R312, R313, R317, R318
0603
564
C51, C52, C61, C90,  C91, C167, C168, C169, C170, C228, C231, C234, C235, C236, C237, C239, C244,  C245, C321, C335, C336, C337
CAP-C-TAN
22
C205, C226, C227,  C240, C320
ALU-ELECTROLYTIC-CAP(8)
C283, C288, C311,  C322, C326, C327, C328, C329, C330, C331, C332, C333, C334, C338, C339, C340,  C341
CAP-A-TAN
17
D1
DIODE-0.4
F2, F5, F6, F7, F8,  F12, F13, F14, F15, F16, F17, F18, F19, F20, F21, F22, F23, F25, F26, F27,  F32, F33, F34, F35, F36, F37, L6, L7, L8, R58, R80, R82
0805
32
F9, F29
MSS1278
LED1, LED2, LED4,  LED5, LED6, LED7, LED8, LED9, LED10, LED13, LED14, LED15, LED16, LED19, LED20
R57
1206
S1, S2
ANJIAN
T1, T4
CD542
T2, T5
AT224
T3
PL-008
T6
SM-22
U1, U2
PE4302
U3
BGA484_1R00_23X23
U4
BGA668_1R00_27X27
U5, U17, U21, U25,  U36
D2PAK-5
U6
TSOP44_0R80_11R76
U7, U8, U12, U13
A01
U9
TSSO8X13-G28
U10
SOT-23
U11
QFP144_0R50_22X22
U16
SO8_6R00
U22
78L03
U23, U30
QFP100_0R50_16X16
U24
PDSS-T6
U26
LFCSP64
U31, U35
BGA252_1R00_17X17
X1, X2, X3, X4, X5,  X12
SMA
X7
IDC20-L
X8
IDC10-L
X9
HDR2X3
X10, X15
HDR2X8
X11
PWSIP3
X13
HDR1X4
6 U# e" {0 W. T
附件:9 U: a! \% {) @% R9 f9 e/ }
游客,如果您要查看本帖隐藏内容请回复
$ @0 h9 J5 \, A* V: E, v
8 @" m$ C, A9 S0 M4 D$ A! Y( W$ q
GMT+8, 2025-7-27 18:32 , Processed in 0.140625 second(s), 28 queries , Gzip On.
