作品名:[AD 10][2层] 高端新消毒柜原理图、PCB全套资料原理图和PCB源文件' b) Z# t2 N; [4 O8 D8 v; w' p; N
! v k# Z$ \/ {: e' g8 g
文件描述9 u5 c2 c9 |! w
1. 作品用途:高端新消毒柜: [ f i7 Y6 ~+ `- Y. E7 w( O& I2 E
2. 软件版本:AD 10, k9 d* `/ E) j) a
3. 层数:2层板
+ ] w' F8 M6 } h% I1 J* o9 l. |4. 用到的主要芯片:30210 T+ U; u5 d6 O) X
5. PCB尺寸:175.4mm*133.3mm
* ~/ w A# ~; ~3 G5 k- g* [" q9 N
3 j7 q& ]/ J9 K! K! p& ]作品截图如下:
6 P* N6 Y+ W! Y* [. I8 ?# m顶层截图:+ p! Z* E4 x. X+ K5 R. B
( q9 ^* b- X, r$ {. V5 V1 P5 T) _
* k. U( o9 [: F f7 Q6 p
底层截图:
9 ~' [# G8 _, j- _
- o# h7 G0 e* a% l- H' |- U
( l1 G4 t B3 V7 s& j
全层截图:6 n3 v! p) F2 z1 b% g
3 I, s: N2 a# h5 v+ B& x3 n$ S
9 ]3 f0 k7 \- W4 j$ `
叠层信息截图如下:
: g! x4 }- X/ J2 }. g) @
+ }5 U/ o& [% }# R3 p }6 d. a1 V) E
& o0 p8 @0 Z3 G9 B4 _BOM:6 ^* a6 d. p' p
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | +5V | +5V | TEST | 1 | 进气 | B1 | CON2-4.1MM | 1 | 放汽 | B2 | CON2-4.1MM | 1 | 锅内进水 | B3 | CON2-4.1MM | 1 | 真空 | B4 | CON2-4.1MM | 1 | 排水 | B5 | CON2-4.1MM | 1 | 104 | C1, C2, C3, C4, C5, C12, C14, C15, C16, C17, C18, C23, C24, C25, C26, C27, C29, C30, C33, C34, C37, C38 | 0805C | 22 | 103/400V | C6, C7, C9, C13, C19 | C1206-2 | 5 | 22pF | C8, C10 | 0805C | 2 | 102 | C11 | 0805C | 1 | 103 | C21 | 0805C | 1 | 105 | C22 | 0805C | 1 | 680uF | C28 | CAP7343 | 1 | 22uF | C31, C35 | C1210 | 2 | 220uF | C32 | CAP7343 | 1 | 2200/50V | C36 | RB.3/.8 | 1 | SC-70 | CN1 | ISP-10PIN | 1 | CN | CN2, CN5 | CON2-4.1MM | 2 | 20PIN-JTAG | CN3 | HEADER2X10-2.54MM | 1 | CON5 | CN4, CN6 | XH-5-L | 2 | 0.1UF X | CX1 | CBB-10MM | 1 | 4007 | D1, D2, D3, D4, D5 | DO-214C | 5 | | D6, D7, D8, D9, D10, D11, D13, D16, D18, D19, D20 | 0805LED | 11 | DB107 | D12 | DB207S | 1 | 1N4148 | D14, D15 | LL34 | 2 | M7 | D17 | DO-214C | 1 | IN5824 | D21 | DO-214C | 1 | RS406 | DB1 | BRIDGE1 | 1 | RS206 | DB2 | RS206-HY | 1 | Comment | Designator105 | DANGER | 1 | Comment | Designator106 | NO TOUCH | 1 | Comment | Designator107, HIGH VOLTAGE, Solenoid valve | FANGXIANG | 3 | GND | GND | TEST | 1 | PC817XI | IC1 | SOP4 | 1 | UART | J1 | XH2.54-4P | 1 | USB | J2 | USB-B | 1 | 继电器 | K1, K2 | SRU-05VDC-SL-C | 2 | 10UH | L1 | 0805N | 1 | 33uH | L2 | IND_12X12 | 1 | U4 | LM358 | SO8M1 | 1 | | NTC1, NTC2, PT1000 | XH-2-L | 3 | 铜插片 | P1, P2, P3, P4, P5, P6, P7, P8, P9, P10, P11, P12, P13, P14 | CP6.3 | 14 | 8050 | Q1, Q2, Q3, Q4, Q5, Q6, Q7 | SOT23-EBC | 7 | 8550 | Q8 | SOT23-EBC | 1 | 360 | R1, R21, R32, R40, R48 | 1206- | 5 | 220 | R2, R22, R33, R41, R49 | 0805N | 5 | 3.3K | R3, R23, R34, R42, R50 | 0805N | 5 | 330 | R4, R24, R35, R44, R53 | 1206- | 5 | 1K | R5, R6, R7, R8, R9, R10, R11, R12, R13, R14, R15, R25, R30, R31, R37, R39, R45, R51, R54, R55, R62, R63, R64, R65, R66, R69, R71, R72 | 0805N | 28 | 10K | R16, R17, R18, R19, R20, R26, R27, R28, R29, R36, R38, R43, R70 | 0805N | 13 | 1.2k | R46, R47 | 0805N | 2 | 4k | R52, R56 | 0805N | 2 | 1.5k | R57, R58 | 0805N | 2 | 1.3k | R59, R60, R61 | 0805N | 3 | 0 | R67, R68 | 0805N | 2 | 20/2W | RZ1, RZ2, RZ4, RZ6, RZ7 | 1206- | 5 | 2/1W 5.6 | RZ3 | 2512- | 1 | 100K/1W | RZ5 | 1206- | 1 | KEY | S1 | SW-7 | 1 | FAN | SR1 | TO90 | 1 | MJD122 | T1, T2, T3, T4, T5 | TO-252 | 5 | BTA41-600B | T6, T7 | BTA4 | 2 | BT137S | T8, T10, T11 | SOT-428 | 3 | MJD122 | T9 | TO-252-2L | 1 | Trans3 | TR1 | CON4-4.1MM | 1 | 3021 | U1, U2, U4, U5, U6 | SOP6 | 5 | STM32F103RBT6 | U3 | LQFP64 | 1 | MPX5700 | U7 | MPX5500 | 1 | LM2596S-5.0 | U8 | TO-263 | 1 | LM1117 3.3 | U9 | TO-252AA | 1 | 8M | Y1 | XTAL2 | 1 |
: E: t) B' G6 f) U附件:! E- F' i- k5 k5 K
原理图和PCB源文件如下:* b# S. r6 `+ Q2 n6 A
" B: N I) H% h
6 w; \* p3 Y8 X4 j+ Z0 n# H
