作品名:[AD 15][4层] STM8L1526_EVAL MB818(TFDU4300+BNX002-01+TS461CLT)原理图、PCB源文件$ t! Q7 H4 a9 j L4 p( a
; N1 ^9 N& h8 F5 L5 w
( c7 V) o9 U4 E: U0 Y文件描述
4 c: l5 r0 C6 P' T1. 作品用途:STM8L1526_EVAL MB818+ f8 s1 H) w" s
2. 软件版本:AD 15
5 f7 @3 F4 r* \/ }; x; R$ x A" }3. 层数:4层板! [$ q7 C$ b/ u5 M7 y
4. 用到的主要芯片:TFDU4300+BNX002-01+TS461CLT# q: a* a4 t' Y3 W5 R/ G
5. PCB尺寸:172mm*114mm1 c. \& f3 ~0 S
- I% X' e6 X7 O0 p3 @7 E
) _$ u+ L. y6 h$ [6 k$ A7 r作品截图如下:0 M+ q' Q2 b6 e$ k5 }: S' Q6 m
顶层截图:- \# |* x- o2 @2 c" w7 C
8 ? l- F: x1 D; i* a7 a底层截图:5 m6 [4 I5 x' S- p7 G
1 m0 @( K9 r/ }( ^7 p0 d
全层截图:! K# o, e6 I1 Z+ y* p( J/ h& o" F
% C' V U4 N3 u, f叠层信息截图如下:3 \2 x. h" \3 D" B6 A$ N8 o) l( O
8 W; L: I) C, |& u4 o0 ?$ a
BOM:1 [$ x- j! ]$ c1 C9 j
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | RESET (Black) | B1 | PB10 | 1 | USER (Blue) | B2 | PB10 | 1 | 100nF | C1, C3, C4, C5, C6, C9, C10, C14, C15, C16, C18, C21, C23, C24, C31, C33, C34, C40, C49, C50, C51, C52, C55, C56, C57, C58, C59, C61, C62, C63, C65, C68, C69, C70, C71, C74, C76, C78, C79, C80, C81, C82, C83, C84 | 0603C | 44 | 4.7uF | C2, C7, C13, C27 | TAN-A | 4 | 220uF | C8 | C310M-6 | 1 | 47pF | C11 | 0603C | 1 | 10uF | C12, C19, C20, C22 | TAN-A | 4 | [N/A] | C17, C39, C41, C42, C44, C46, C47, C54, C64, C72, C86 | 0603C | 11 | 6.8pF | C25, C32 | 0603C | 2 | 2.2uF | C26 | TAN-A | 1 | 1uF | C28, C37, C48, C53, C67, C85 | TAN-A | 6 | 180pF | C29 | 0603C | 1 | 20pF | C30, C38 | 0603C | 2 | [N/A] | C35, R40, R59, R68, R74, R82, R96, R98, R99 | 0603R | 9 | 10nF | C36 | 0603C | 1 | 470nF | C43 | 0603C | 1 | 330pF | C45 | 0603C | 1 | 1uF | C60 | 0603C | 1 | 1nF | C66, C73 | 0603C | 2 | 20P | C75, C77 | 0603C | 2 | DB9-male UART2 | CN1 | DB9/M | 1 | DC-10B | CN2 | DC10B | 1 | 2.4" LCD connector (MB542 with AM240320L8TNQW-00H) | CN3 | MB542 | 1 | Header 13X2 on the left | CN4 | 2*13P | 1 | Header 18X2 | CN5 | 2*18P | 1 | Header | CN6 | 2*18P | 1 | MC_connector | CN7 | IDC34S | 1 | QTH-030-01-L-D-A | CN8 | QTH-030-01-L-D-A | 1 | JTAG | CN9 | JTAG | 1 | Header 13X2 on the right | CN10 | 2*13P | 1 | USB-typeB connector | CN11 | USB-B | 1 | 609-1306-ND(2.54mm) | CN12 | SIP4 | 1 | ST-613 | CN13 | PJST-613 | 1 | PJS008-2000 (SMS064FF or SMS128FF) | CN14 | MSD(PJS008) | 1 | VB334 | CN15 | VB334 | 1 | 214017 | CN16 | SMD214012 | 1 | BAT60 | D1 | SOD-323 | 1 | | JP1, JP5, JP6, JP7, JP10, JP11, JP13 | SIP3 | 7 | Header 3X2 | JP2 | 2*3P | 1 | | JP3, JP4, JP8, JP9, JP14, JP15 | SIP2 | 6 | BEAD | L1 | 0603L | 1 | Green | LD1 | 0603D | 1 | Orange | LD2 | 0603D | 1 | Red | LD3, LD7, LD8, LD9 | 0603D | 4 | Blue | LD4 | 0603D | 1 | L-317EGW-SS | LD5 | D0.1 | 1 | SFH409-2 | LD6 | D0.1L | 1 | 22 | R1, R107, R108 | 0603R | 3 | 680 | R2, R22, R41, R93, R101 | 0603R | 5 | 5 | R3 | 0603R | 1 | 300 | R4, R5 | 0603R | 2 | 1K | R6, R9, R15, R19, R81, R86, R87, R97 | 0603R | 8 | 47 | R7, R100, R121 | 0603R | 3 | 1.2K | R8 | 0603R | 1 | 10K | R10, R17, R30, R45, R46, R57, R61, R65, R67, R70, R78, R89, R117, R119, R123, R124 | 0603R | 16 | 2.2K | R11 | 0603R | 1 | 100 | R12, R72, R104, R122 | 0603R | 4 | 500 | R13 | 0805R | 1 | 40.2[1%] | R14 | 0603R | 1 | 0 | R16, R27, R32, R37, R38, R44, R48, R50, R51, R52, R53, R56, R60, R63, R71, R73, R76, R77, R83, R85, R94, R126, R127 | 0603R | 23 | 100K | R18, R21, R64, R88, R105 | 0603R | 5 | 15K | R20, R90 | 0603R | 2 | 124[1%] | R23 | 0603R | 1 | 82K | R24 | 0603R | 1 | 18K | R25 | 0603R | 1 | 60 | R26 | 0603R | 1 | 0 | R28, R31, R34, R35, R39, R42, R55, R58, R62, R66, R69, R75, R80, R111, R115, R116 | 0805R | 16 | [N/A] | R29 | 0805R | 1 | 22K | R33, R36 | 0603R | 2 | 330 | R43 | 0805R | 1 | 680 | R47, R49, R54 | 0805R | 3 | 4K7 | R79, R102, R106, R112, R113, R114, R118, R120 | 0603R | 8 | 30K | R84 | 0603R | 1 | 2K[1%] | R91 | 0603R | 1 | 2[1%] | R92 | 0603R | 1 | 3.3K | R95 | 0603R | 1 | 510 | R103 | 0603R | 1 | 1K5 | R109 | 0603R | 1 | 50 | R110 | 0603R | 1 | 2K2[1%] | R125 | 0603R | 1 | 3386P-201H[5%] | RV1 | 3296W | 1 | 10K | RV2 | 3296W | 1 | [N/A] | RV3 | 3314-J | 1 | | SB1, SB2, SB5, SB6 | JP2_SMD | 4 | solder bridge | SB3, SB4, SB7 | JP3_SMD | 3 | 9013 | T1, T4, T8 | SOT-23 | 3 | STT5PF20V | T2, T3 | SOT23-6L | 2 | [N/A] | T5, T6 | SOT-23 | 2 | 9012 | T7 | SOT-23 | 1 | Ground | TP1 | TP | 1 | VDD_ADJ | TP2 | TP | 1 | +3V3 | TP3 | TP | 1 | 5V | TP4 | TP | 1 | AIN- | TP5 | TP | 1 | MIC_OUT | TP6 | TP | 1 | MIC+ | TP7 | TP | 1 | AIN+ | TP8 | TP | 1 | CCO | TP9 | TP | 1 | BSN20 | TR1, TR2 | SOT-23 | 2 | SN74LVC2T45DCUT | U1, U10, U11, U19, U22, U26 | VSSOP8 | 6 | TFDU4300 | U2 | IR_VISHAY3 | 1 | BNX002-01 | U3 | BNX001 | 1 | KECG2740TBL | U4 | KEC2740 | 1 | ZEN056V130A24LS | U5 | polyzen | 1 | LM393PT | U6 | TSSOP8(6.4) | 1 | ZYMG12232B-GB1 | U7 | LCD12232-GB1 | 1 | ST3241EBPR | U8 | SSOP28 | 1 | TS461CLT | U9 | SOT-23-5L | 1 | LD1086D2M | U12 | D2PAK/A | 1 | LD1086D2M33 | U13 | D2PAK/A | 1 | STM8L152C6T6 | U14 | LQFP48 | 1 | TS4990IST | U15 | MSOP8 | 1 | STM8L152C6T6 | U16 | IC234-0484-039 | 1 | MT008-A | U17 | JOY | 1 | M25P128-VME6G | U18 | VDFPN8(8*6) | 1 | MAX9938FEUK+ | U20 | SOT-23-5L | 1 | SN74LVC1G66DCKT | U21 | PDSO-G5 | 1 | 74LV4060PW | U23 | TSSOP16 | 1 | KDMG15008-03 | U24 | KS1508 | 1 | SN74LVC1G04DCKT | U25 | PDSO-G5 | 1 | STM32F103C8T6 | U27 | LQFP48 | 1 | STLM75M2E | U28 | SO8 | 1 | M24C64-FDW5TP | U29 | TSSOP8(6.4) | 1 | 16MHz (with socket) | X1 | XTAL_SOCKET | 1 | MC306-G-06Q-32.768 (manufacturer JFVNY) | X2 | SM8 | 1 | 8MHz | X3 | XTAL1 | 1 | SMAJ5.0A-TR | Z1 | 1R1C | 1 | 附件:# U( u; {) K3 h! c9 n
原理图和PCB源文件如下:' a0 ~7 \# @' G# b
8 B1 C5 n* Z8 L8 M' |& c4 [+ @
# \ e' v, M$ y
