作品名:[AD 15][2层] 2.1输出的soundbar(SGM2019/NC+PT2313+SGM4812)PCB源文件
9 w. S* p8 ^: n+ l$ P( r) K' i+ |) x$ w5 s. u' a, H1 Z7 z
文件描述4 v1 _9 O( y- l4 }' w0 `$ j/ q8 k
1. 作品用途:2.1输出的soundbar! |( v7 N3 Q4 O8 |9 V
2. 软件版本:AD 15
1 C" I5 Y! j8 p; {2 r3 s h' }' b, \3. 层数:2层板
+ } W9 T2 A- P& G: ^4 L4. 用到的主要芯片:SGM2019/NC+PT2313+SGM4812/ Y; s- S* c- V, P. k. t1 R
5. PCB尺寸:105mm*83mm
6 ?1 H# D: O! t- D0 f$ e o) _2 K8 _- o8 E! G5 W
作品截图如下:
5 y3 I; D( J2 J+ t, P$ Z0 q( c5 p顶层截图:
0 k3 V# S6 r1 `: a1 r& X
; j. H9 r! e9 |& }3 n1 @6 f底层截图:
' l6 X9 Q% L* e" g8 ^8 G
8 i! c, Q5 e7 _6 i! |* R
全层截图:
, D3 h1 z9 y+ s! M4 O: m
. N2 x: I# t0 _- g. ^) r/ M
叠层信息截图如下:& z! d/ K% o: Y( q, U* p" O
! ]0 Y3 C, O! {3 NBOM:
% b% e9 l2 X) o! v6 Q" v+ AComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | ANT | ANT4 | F | 1 | AV2-8.4-13 | AV1 | AV2-8.4-13 | 1 | AV-8.4-08 | AV2 | AV-8.4-08 | 1 | 0.01uFNC | BC10 | C0603 | 1 | 1500pFNC | BC11 | C0603 | 1 | CON7 | BM1 | EC1102 | 1 | 681 | C1, C2 | C603 | 2 | 10uF/10V | C3, C7, C33, C38, CE3, CE9, CE10, CE12 | CD10 | 8 | 1uF | C5, C64 | C603 | 2 | 101 | C6, C26, C27, C63, C65, C69, C70, C91, C92 | C603 | 9 | 104 | C8, C16, C20, C21, C24, C35, C55, C56 | C0603/SMD | 8 | 103/NC | C9 | C0603/SMD | 1 | 823 | C10 | C603 | 1 | 224 | C11 | C603 | 1 | 104 | C12, C18, C19, C34, C49, C54, C62, C73, C79 | C603 | 9 | 1u | C13, C23, C53, C80, C85, C87 | C603 | 6 | 102 | C14, C32, C47, C51, C66, C81, C83, C89 | C603 | 8 | 103 | C15, C48, C50, C67, C76, C82, C84, C88 | C603 | 8 | 2u2 | C17, C40, C41, C42, C43, C68 | C603 | 6 | 4u7/10V | C22 | CD10 | 1 | 1uF | C25, C36, C46 | C0603/SMD | 3 | 4u7/16V | C28, C29, C30, C31 | CD10 | 4 | 2700pF | C39, C44 | C0603/SMD | 2 | 100uF/25V | C45 | CD220 | 1 | 220nF | C52, C57, C58, C59 | C805 | 4 | 4u7/10V | C60, C61 | DC10A | 2 | 47uF/16V | C71, CE13, CE14 | CD100 | 3 | 470nF | C72, C74, C75, C77 | CL7.5 | 4 | NC | C78, C86 | C603 | 2 | 0.01uFNC | C90 | C603 | 1 | 15pF | CB61 | C0603/SMD | 1 | 100uF/10V | CE1 | CD100 | 1 | 10u/10V | CE2, CE6 | CD10 | 2 | 220uF/10V | CE4 | CD220 | 1 | 47u/10V | CE5 | CD10 | 1 | 47uF/10V | CE7 | CD10 | 1 | 47u/10V | CE8 | CD47 | 1 | 470u/10V | CE11, CE18 | CD470 | 2 | 47uF/10V | CE15 | CD47 | 1 | 220uF/16V | CE16, CE17 | CD470 | 2 | 47uF | CE19 | CD10 | 1 | 100u/10V | CE20 | DC10A | 1 | | CN1 | CN2-2A | 1 | 4148 | D1, D2, D3, D6, D7 | D1812 | 5 | RED | D4 | LED1 | 1 | Blue | D5 | LED1 | 1 | SS24 | D8 | SS24 | 1 | 10uF/25V | EC1 | CD10 | 1 | 2108 | IC1 | SOP8 | 1 | TAS3118 | IC2 | IDC32 | 1 | 4558 | IC3 | SOP8 | 1 | BT1609E | IC4 | SOP14 | 1 | MIC9 | J1 | MIC9 | 1 | SIP7 | J3 | SIP7-2 | 1 | CON2 | J4 | DC_016 | 1 | 80R | L1, R5, R6, R20, R110, R111 | R603 | 6 | 80R | L2, L3, L9 | 0805 | 3 | D/NC | L4 | ESD0603/SMD | 1 | 22uH | L5, L6, L7, L8 | L5Y | 4 | 22uH | L10 | L150 | 1 | FB | L65 | L2 | 1 | 9014 | Q1, Q2, Q6, Q7 | SOT-23 | 4 | 3906 | Q3 | SOT-23 | 1 | 2301 | Q4 | TO-23 | 1 | 9014 | Q5 | TO-23 | 1 | 8550 | Q8, Q9 | SOT-23 | 2 | 5551 | Q10 | SOT-23 | 1 | 100K | R1, R3, R21, R32, R38, R78, R87, R106, R112 | R603 | 9 | 100 | R2, R4, R79, R100 | R603 | 4 | 4K7 | R7 | R0603/SMD | 1 | 22 | R11, R88 | R603 | 2 | 10K | R12, R14, R35, R36, R41, R48, R55, R80, R92, R94, R95, R98, R101, R117 | R603 | 14 | 5K6 | R13, R26 | R0603/SMD | 2 | 7K5 | R15, R16 | R0603/SMD | 2 | 1K | R17, R27, R31, R33, R39, R51, R53, R60, R72, R82, R83, R91, R93, R102, R103 | R603 | 15 | 10 | R18 | R603 | 1 | 47K | R19, R42, R67, R71, R74 | R603 | 5 | 1K | R24, R52, R75, R76 | R0603/SMD | 4 | 100K | R25, R50, R77 | R0603/SMD | 3 | 4K7 | R28, R34, R54, R97 | R603 | 4 | NC | R29, R63, R66 | R603 | 3 | 20K | R30, R56, R57, R58, R59 | R603 | 5 | 33K | R40 | R603 | 1 | 0 | R43, R118 | R603 | 2 | 47K | R44, R45, R69 | R0603/SMD | 3 | 22K | R46, R47, R64, R65 | R603 | 4 | 100 | R61, R62 | R0603/SMD | 2 | 27K | R68, R81, R85, R86 | R603 | 4 | 5K1 | R70, R73 | R603 | 2 | 3R3 | R84, R104, R105, R108 | R603 | 4 | 10K | R89 | R0603/SMD | 1 | 10K | R90 | RN0603/SMD | 1 | 330 | R96 | R603 | 1 | 2K | R99 | R603 | 1 | 470K | R107 | R603 | 1 | 150 | R109 | R603 | 1 | 43.2K | R113 | R603 | 1 | 49.9K | R114, R116 | R603 | 2 | 75K | R115 | R603 | 1 | 2K | R120 | R0603 | 1 | 6.2K | R121 | R0603 | 1 | 15KNC | R122 | R0603 | 1 | 100K | R163 | R0603 | 1 | J06 | SP2 | SIP7-2 | 1 | | SP3 | SIP2 | 1 | SGM2019/NC | U1 | SOT25 | 1 | PT2313 | U2 | PT2314 | 1 | 78L09 | U3 | TO-92B | 1 | SGM4812 | U4 | MSOP10 | 1 | TD1410 | U4_1 | SOP8 | 1 | 24C02/NC | U5 | SOP8 | 1 | FW3517 | U19 | FW3517 | 1 | USB | USB1 | USB | 1 | 附件:
H2 d5 K( }- N原理图和PCB源文件如下:
( Z8 x( D5 M/ s( m3 X# {7 Q- O" h! O- c' _0 Z2 {: N
% E0 |" t6 r) Q3 T4 {8 [
