作品名:[AD 10][4层]用到OPA227 ADR421 THS4131 74LVXC4245信号处理+PCB文件分享下载
5 ~; } ?( k' X% d" N s3 m! Z
; b9 a' d U' x5 J4 N9 O文件描述8 T/ ^1 d" `5 L2 [/ d# G1 a9 M+ [
1. 作品用途:信号处理
7 n9 P# G1 h6 d; }! T* I' t2. 软件版本:AD 10# D) @# j/ e, t: A! u
3. 层数:4层板
. C1 r# s4 g; l. J$ y5 p4. 用到的主要芯片:OPA227 ADR421 THS4131 74LVXC4245
+ ^* b. Z9 y# l- I8 Q" P# h$ C! R' y5. PCB尺寸:100mm*100mm
1 @) D" J) `9 v
) h; d1 ~8 g: X D" I作品截图如下:/ }6 b* U5 q8 a; K7 p
顶层截图:7 m7 H: n- e" u6 ^; I
) q7 C( _% r5 l7 s6 c
$ Y- `# G" Y& H5 y% h- c底层截图:7 _1 o8 O. @( U
! n* ], U( p4 J& b
. l+ ?1 T/ Y5 f5 t
全层截图:
* [; p' _& l1 t) x+ w9 G
5 b8 l/ M6 e8 o- ?
$ o) j& p A1 n叠层信息截图如下:
( U7 r+ s5 D9 Y9 k2 J# H3 @
! u5 d: g* V7 D N4 M ~6 L5 Y
, Z7 i" U/ q3 G( p: S% vBOM:' \/ x6 w7 L2 h* c: D, h0 E/ Z
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1u | C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C18, C19, C21, C23 | 0603 | 19 | 0.1u | C16, C17, C25, C26 | 0805 | 4 | Cap Pol3 | C20, C22, C24 | 1206 | 3 | 1u | C27 | 0805 | 1 | Cap | C28, C29, C30, C31, C32, C33 | 0805 | 6 | 220uF | C34, C35 | CR6332-2512 | 2 | 1uF | C36, C37, C39, C40 | 0805 | 4 | 0.1uF | C38, C41, C42, C43 | 0805 | 4 | 1nF | C44, C45 | 0603 | 2 | 0.1uF | C46, C48, C50, C51, C53, C54, C56, C57, C58, C2109 | 0603 | 10 | Cap Pol3 | C47, C49 | CC2012-0805 | 2 | 1uF | C52 | 0603 | 1 | CAP | C55 | 0603 | 1 | | CS, DIN, DOUT, DRDY, R1, RES, SCLK | 0603 | 7 | Header 7X2A | DATA INF | HDR2X7_CEN | 1 | Socket | J1, J2, J3, J4, J5 | Keystone_575-4 | 5 | J3 | JP2, P5, P6 | idc.3 | 3 | AIN | JP3 | SMA | 1 | J2 | JP4, JP5, JP6, JP7, JP8, JP9, JP10, JP11, JP12 | CON2 | 9 | biar | L1, L2, L3 | 0805 | 3 | Plug | P0, P1 | PIN1 | 2 | Header 3 | PW1 | IDC3L | 1 | 10K | R2, R3, R4, R5, R6, R7, R8, R9, R32, R34 | 0603 | 10 | 50 | R10, R11, R12, R13, R14, R15, RT | 0603 | 7 | 10K | R16, R17, R21, R22, R23 | 0805 | 5 | 1K | R18, R19, R20 | 0805 | 3 | 0R | R24 | 0805 | 1 | 390 | R25, R26, R28, R29 | 0603 | 4 | xx | R27 | 0603 | 1 | 20 | R30, R31 | 0603 | 2 | 3k | R33, RCLK, RCSI, RSDI | 0603 | 4 | 100ohm | R35 | 0603 | 1 | SW-SPST | S1 | IDC2 | 1 | | U1 | SSOP-28 | 1 | ADP3339 | U2, U3 | SOT-223 | 2 | ADR421 | U4, U8 | SOIC-8 | 2 | OP07 | U5, U7 | SOIC-8 | 2 | OPA2227 | U6, U10 | SOIC-8 | 2 | DAC8811 | U9 | MSOP8 | 1 | THS4131 | U11 | MSOP8 | 1 | 74LVXC4245_B-A | U16 | TSSOP-24 | 1 | 74LVXC4245_A-B | U17 | TSSOP-24 | 1 | 24MHZ | Y1 | EU | 1 | 8 z+ h! p" M6 d! ?+ ^$ r
附件:
7 o! d' X2 L" v9 }PCB源文件如下:
0 y( M2 a( W P2 x4 f+ {7 a$ H$ [; [7 a/ [6 v
' U+ z3 _3 e# H |
