作品名:[AD 10][2层]友善之臂TinySDK-1309+DM9000AE+USB2514BQFN36+AT24LC04+PCB文件分享下载 6 Z1 n+ i2 @: D3 f
: I: r! b. f( r9 X) K" e; W: z! H文件描述' K6 M4 p$ k. Z
1. 作品用途:友善之臂TinySDK-13091 x4 @9 x$ j" o
2. 软件版本:AD 101 O& n9 l; G: k. L6 ]+ t0 T9 O: J
3. 层数:2层板- y0 m$ \. ?* d" Z7 l$ F: L! ^
4. 用到的主要芯片:DM9000AE+USB2514BQFN36+AT24LC049 j# c# l" y" k. W% Q# G
5. PCB尺寸:180mm*130mm; [) h" ?9 D2 \6 v
$ A, p9 I4 r5 P, ?& T
作品截图如下:1 ^# t3 ]& t% O8 s& v& K
顶层截图:( k5 g; o( I, N; S0 t/ ?! m) X
2 F$ N: n. @* e6 {# U6 \+ \0 W2 t, M w) M5 N6 L& H" B" s
底层截图:8 e3 b' ~2 A$ x
% e' ^) l# ?. Q3 ]
7 u- k! s8 _6 o8 Q; P全层截图:" c" f% |0 A, x b0 k; Z
. D: {; W) c, U( g. I- ]) G# U" c: j: Z/ W3 H2 D
叠层信息截图如下:& T' L9 k! y9 L5 m! V4 y
2 K; r) d4 m0 o4 O+ U# n9 M& p/ O8 a h s- g
BOM:7 h M! s' }$ a& D
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | BATTERY_3_BAT600_BATTERY | BAT1 | BAT600 | 1 | SPEAKER_SPEAKER_SPEAKER | BUZZER1 | SPEAKER | 1 | CAP_CAPSOP_100UF/35V | C8 | CAPSOP | 1 | CAP NP_C0603_104 | C9, C11, C12, C16, C17, C18, C21, C23, C24, C25, C26, C29, C31, C35, C39, C40, C49, C50, C52, C58, C60, C61, C62, C64, C68, C80, C82, C83, C84, C85, C86, C87, C88, C89, C91 | C0603 | 35 | CAP_C0805_10UF | C10 | C0805 | 1 | CAP_C0805_10UF/16V | C15, C22, C51, C67 | C0805 | 4 | CAP NP_C0603_15PF | C19, C20 | C0603 | 2 | CAP NP_C0805_10UF | C30, C32, C54, C55, C56, C57, C59 | C0805 | 7 | CAP NP_C0603_100PF | C33, C34, C37, C38, C47, C48 | C0603 | 6 | CAP NP_C0603_1UF | C36, C42, C43, C44, C45, C46 | C0603 | 6 | CAP NP_C0603_220PF | C41 | C0603 | 1 | CAP NP_C0805_10U | C73, C74, C96, C97 | C0805 | 4 | C_C0603_33PF_1104.00100 | C81, C95 | C0603 | 2 | CAP0402 | C90, C92 | C0603 | 2 | CAP0603 | C93 | C0603 | 1 | C_C0603_1UF_1104.00100 | C94 | C0603 | 1 | CON20A_SDWIFI-NH_CON20A | CAMERA | SDWIFI-NH | 1 | CON3_3_DC023B_DC_JACK | CN1 | DC023B | 1 | CONNECTOR DB9_2_DB9RA_M_CONNECT | COM0, COM3 | DB9RA_M | 2 | CON4_SIP4-FA2_CON4 | CON1, CON3, CON4 | SIP4-FA2 | 3 | CON6_SIP6-FA2_CON6 | CON2 | SIP6-FA2 | 1 | CON4_CON4-B_CON4 | CON5 | CON4-B | 1 | CON14A_SIP7X2-2_CON14A | CON6 | SIP7X2-2 | 1 | SD_0_SDCARD_SD/MMC CARD | CON10 | SDCARD | 1 | J1X4_1_SIP4-FA_J1X4_2.0PH | CON12 | SIP4-FA | 1 | CON20A_5_SIP30S_CON20A | CON13 | SIP30S | 1 | DIODE_D1206_4148 | D1 | D1206 | 1 | INDUCTOR_L0603_0R/NC | FB1 | L0603 | 1 | INDUCTOR_L0603_0R | FB2, FB3, FB5 | L0603 | 3 | CON1_H1_CON1 | H1, H2, H3, H4, H5, H6, H7, H8, H9, H10, H11, H12, H13, H14 | H1 | 14 | ID-BOARD_FM4P_ID-BOARD | ID1, ID2, ID3, ID4, ID5, ID6, ID7, ID8 | FM4P | 8 | SW PUSHBUTTON_0_KEY-A06_SW PUSH | K1, K2, K3, K4, RST | KEY-A06 | 5 | HR911105A_HR911105A_HR911105A | LAN1 | HR911105A | 1 | LCD-888_1_CON-FPC-P05-45P_LCD-8 | LCD1 | CON-FPC-P05-45P | 1 | LCD-888_2_CON-FPC-P05-40P_LCD-8 | LCD2, LCD3 | CON-FPC-P05-40P | 2 | TP_TPC1_TP | LCDCLK, TPSCL, TPSDA | TPC1 | 3 | LED_LED_RED | LED_3.3 | LED | 1 | MIC_MIC2_MIC | MIC1 | MIC2 | 1 | PHONEJACK STEREO SW_EARJACK5_PH | MIC2, SPK1 | EARJACK5 | 2 | USB_A/B_2_MINIUSB_ANT_USBOTG | MINIUSB1 | MINIUSB_ANT | 1 | NPN-BEC_SOT-23-Q_3904 | Q2 | SOT-23-Q | 1 | R_R0603_0R | R1, R2, R3, R7, R11, R57, R58, R63, R82, R92, R96, R118, R119 | R0603 | 13 | R_R0603_1K | R4, R6, R20, R21 | R0603 | 4 | R_R0603_10K | R5, R9, R10, R12, R13, R14, R15, R16, R18, R19, R23, R27, R28, R34, R35, R37, R38, R39, R40, R41, R42, R43, R46, R47, R60, R64, R65, R66, R71, R72, R73, R74, R77, R111, R114, R115, R116, R117, R128, R129, R131, R132, R133 | R0603 | 43 | R_R0603_6.8K,1% | R8 | R0603 | 1 | R_R0603_51R | R24, R25, R26, R29 | R0603 | 4 | R_R0603_100K | R49 | R0603 | 1 | R_R0603_2.2K | R59 | R0603 | 1 | R_R0603_47K/NC | R62 | R0603 | 1 | R_R0603_100R | R67 | R0603 | 1 | R_R0603_22R | R89, R90, R95, R97, R98, R100, R110, R112 | R0603 | 8 | R_R0603_NC | R91, R93, R94, R99, R101, R102, R107, R108, R109, R113, R126, R127, R134, R135, R136 | R0603 | 15 | RES0603 | R121 | R0603 | 1 | R_R0603_1M | R130 | R0603 | 1 | CON5_SW35_SW-DIP4 | S1, S2 | SW35 | 2 | TINYCORE_TINY6410_2_TINYCORE | TINYBOARD | TINY6410_2 | 1 | AMS1117_TO-252_AMS1086CM-3.3 | U2 | TO-252 | 1 | DM9000AEP_LQFP48FA_DM9000AEP | U4 | LQFP48FA | 1 | AT24LC04_SOP8_AT24LC04 | U5 | SOP8 | 1 | WM8960GEFL_0_QFN32-19P7-TH_WM89 | U6 | QFN32-19P7-TH | 1 | SP3232_SOP16_SP3232 | U8 | SOP16 | 1 | USB2514BQFN36 | U11 | QFN36-19P7 | 1 | USBPORT_0_USB-A2_USB A | USBH1, USBH2, USBH3, USBH4 | USB-A2 | 4 | RESISTOR VAR_0_VR3_7X7_10K | W1 | VR3_7X7 | 1 | CRYSTAL_OSC2PR-1_25MHZ | Y1 | OSC2PR-1 | 1 | CRYSTAL_OSC2PR-1_24MHZ | Y3 | OSC2PR-1 | 1 | : i0 e/ t6 U2 l4 ~' M
附件:9 J0 C$ i& X0 C7 F% }
PCB源文件如下:# [: {0 T* z ~6 d1 l: [
! }. U$ [8 O- J$ S9 M; \1 F
. d. \6 d/ f( N1 {2 u! H( z |
