作品名:[AD 10][4层]STM32F407最小系统PCB文件+原理图 四层板 主要走线Top和Bottom层+ L3 N' S+ B) L6 X1 M
) W* ?, d9 ?& K9 R' _. r) ]文件描述: W# p3 T* H; V
1. 软件版本:AD 10
2 u" C% c. d# {5 a C4 @2. 层数:4层板" C2 o$ z7 Y3 k' N0 |
3. 用到的主要芯片:STM32F407
/ g6 [. A1 G( I6 {4. PCB尺寸:121.1mm*90.7mm. j5 `3 b7 t* q8 i2 D8 b
8 c0 y! E, l f& s8 d. i/ E
作品截图如下:. J4 e0 e$ n% D, o) f5 J
顶层截图:. ^ w# C( U' z5 ~; m
' Z. P) A4 o2 Q) e9 s/ J
5 N/ r5 d0 Q, W$ Y& o底层截图:
( A6 @* N3 `; a
& C) m2 ~; t" t' \: g5 U" v' C4 {
全层截图:
2 Z% U+ o% c" {5 e
: T: b9 }" O% d! p: U
W1 g+ c* J4 b1 v: e6 n& `; V7 y, f$ k
叠层信息截图如下:
3 _ |* x) E; N& V- Z4 O
- E% _) z/ k! ^/ Y; \
0 k0 u# m, \! G8 ]BOM:
$ O8 J$ ?' }$ _* aComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | BEEP | B1 | BEEP 5x9x5.5 | 1 | 6P | C1, C2 | C 0603 | 2 | 20P | C3, C4 | C 0603 | 2 | 225 | C5, C6 | C 0603 | 2 | 106 | C7, C21, C27, C31, C44, C47, C48 | C 0603 | 7 | 104 | C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C19, C20, C22, C23, C24, C25, C26, C28, C29, C30, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C45, C46, C49, C50, C51, C52, C53, C54, C55, C56, C57, C58 | C 0603 | 44 | 103 | C18 | C 0603 | 1 | 3.5*1.3 | CON1 | DC_5.5MM | 1 | Battery | CR1 | CR1220_A | 1 | 5.0V | DZ1 | MINI_MELF (LL34) | 1 | 220uF/16V | E1 | CM D(6.3*7.7) | 1 | 10UF/16V | E2 | C 1206 | 1 | 1A | F1, F2 | L 1206 | 2 | W25Qxx | IC1 | SOP8W_L | 1 | 24Cxx | IC2 | SOP8_L | 1 | MAX232 | IC3 | SOP16_L | 1 | DS18B20 | IC4 | TO92A | 1 | JATG | J1 | HDR-10X2 | 1 | TFTLCD | J2 | HDR-16X2 | 1 | RJ45 | J3 | HR911105A | 1 | DB9 | J4 | DB9/P_A | 1 | SDCARD-M | J5 | Micro TF/SD | 1 | USB | J6 | USB-A/S_A | 1 | Header3X2 | JP1, JP15 | HDR-3X2 | 2 | HDR-1X2 | JP2 | KF301-2P | 1 | Header 4X2 | JP3, JP8, JP12 | HDR-4X2 | 3 | Header 2X11 | JP4 | HDR-13X2 | 1 | HDR-1X4 | JP5, JP7, JP9 | HDR-1X4 | 3 | Header2X2 | JP6 | HDR-2X2 | 1 | HDR-1X6 | JP10 | HDR-1X6 | 1 | Header 2X10 | JP11 | HDR-10X2 | 1 | Header 9X2 | JP13 | HDR-9X2 | 1 | Header 2X11 | JP14 | HDR-18X2 | 1 | 5向按键 | K1 | 五向按键 | 1 | 4.7uH | L1 | L 0603 | 1 | 10uH | L2 | L 0603 | 1 | 100uH | L3 | L 0603 | 1 | 红色 | LED1, LED2, LED3, LED4 | LED 0603R | 4 | HS0038 | P1 | VS1838B-A | 1 | SS8050 | Q1 | SOT23-3L | 1 | 1M | R1 | R 0603 | 1 | 10R | R2, R19, R20, R64, R66 | R 0603 | 5 | 0R | R3, R4 | R 0603 | 2 | 10K | R5, R6, R7, R8, R11, R12, R33, R52, R55, R57, R59 | R 0603 | 11 | 100K | R9, R10, R14 | R 0603 | 3 | 9.53K | R13 | R 0603 | 1 | 49.9K | R15 | R 0603 | 1 | 510R | R16, R62, R63, R65 | R 0603 | 4 | 4.7K | R17, R18, R50, R51 | R 0603 | 4 | 360R | R21, R22 | R 0603 | 2 | 120R | R23, R37, R61 | R 0603 | 3 | 49.9R | R24, R25, R26, R27 | R 0603 | 4 | 33R | R28, R29, R31, R36, R38, R39 | R 0603 | 6 | 470R | R30, R35 | R 0603 | 2 | 2.2K | R32, R34, R40, R41, R42, R43, R44, R45, R46, R47 | R 0603 | 10 | 4.87K | R48 | R 0603 | 1 | 1K | R49 | R 0603 | 1 | 47K | R53, R54, R56, R58, R60 | R 0603 | 5 | SK-22D02 | S1 | KFT DIP-8X8 | 1 | STM32F407ZGT6 | U1 | TQFP144 20x20_L | 1 | MP2359 | U2 | MP2359 | 1 | IS62WV51216 | U3 | IS62WV51216 | 1 | MAX485 | U4 | MAX485 | 1 | DP83848IV | U5 | LQFP48 7X7_L | 1 | TJA1050 | U6, U7 | TJA1050 | 2 | USB-5P | USB1 | USB-MINI-A | 1 | AMS1117-3V3 | V1 | SOT223_L | 1 | 1N4148 | VD1, VD2 | MINI_MELF (LL34) | 2 | SS14 | VD3, VD4 | SOD-123 | 2 | 32.768K | X1 | XTAL-4S8 | 1 | 8M | X2 | XTAL-49S SMD | 1 | XTAL | Y1 | XTAL-5032 | 1 | 5 L9 q3 C( Z1 H8 X3 D
附件:
& l7 d7 s ]" g原理图和PCB源文件如下:6 O$ t- Q* W/ ?0 X; w
' ~" ?+ Q: y A: y0 n7 f6 I# ~# A* e) I! Y" P P
