) t" ]7 ?% g0 u% v2 x6 s
3 N- s+ O$ z, H: P. f. o$ o& T( M, [
[AD 10][8层]S3C6410X无线WIFI主板(CAT3604VHV4-GT2+MAX8677A+XC6219B332MR)PCB文件
" N# c: e1 B4 o* d& _" `& g0 C2 i6 ]3 O1 _" g" {* s( a" P2 A
文件描述
+ S l# ?8 Z- c# ^9 v) a! n( ^1. 作品用途:S3C6410X无线WIFI主板
+ s7 h. Z9 N6 i1 K0 p6 [2. 软件版本:AD 10
/ L4 T$ C# X4 R" L* W7 d3. 层数:8层板: @, s0 A5 [/ `) ^, P. N0 q
4. 用到的主要芯片:CAT3604VHV4-GT2+MAX8677A+XC6219B332MR; D k6 G# q% A& @
5. PCB尺寸:212.45*48.8 mm: G. d1 m3 K4 V# d) ?
! F$ W# N, X1 t5 @3 O8 f0 i
作品截图如下:' N7 R4 l, D: V7 X3 Z! O2 e( f
顶层截图:
) m* N- w+ p5 e$ g8 {* P) g1 E' U& h2 E+ K
+ M$ b# X. |" I底层截图:
$ m9 m/ {3 Z; D2 ?' ^0 e7 b0 A
6 {( T8 W! u, W# q6 H
$ [, D# h5 \' G7 G, V/ u全层截图:
4 q: `- E' S8 t4 X/ w
$ ]4 ^* O1 i/ p% P- F0 D( R叠层信息截图如下:! k7 ^2 H7 v: l
) E9 h1 _$ h! O1 g6 X; C/ m ]
BOM:0 ]! b8 q( \/ U( \" F3 f9 q
| 1 | CREATOR-B | 1 | 3V | BT1 | MINI-BAT | 1 | 100nF | C1 | C0805 | 1 | 10nF | C2, C3, C4, C5, C27, C60, C72 | C0402 | 7 | 10uF | C6, C9, C10, C12, C13, C14, C23, C32, C33, C35, C36, C38, C39, C40, C43, C44, C45, C46, C47, C48, C49, C51, C56, C57, C65, C66, C68, C73, C77, C82, C83, C89, C105, C128, C129, C130, C131, C132, C133, C140, C154 | C0805 | 41 | 100nF | C7, C8, C16, C17, C21, C25, C28, C31, C34, C52, C53, C54, C55, C58, C59, C61, C62, C63, C64, C67, C69, C70, C71, C74, C75, C76, C78, C79, C80, C81, C84, C85, C86, C87, C88, C90, C91, C92, C93, C94, C95, C97, C98, C99, C100, C101, C102, C103, C104, C106, C108, C110, C111, C112, C113, C114, C115, C116, C117, C118, C119, C122, C123, C124, C125, C126, C127, C134, C136, C137, C138, C139, C141, C142, C143, C144, C145, C146, C148, C151, C152, C155 | C0402 | 82 | 1uF | C11, C37, C41, C42, C107, C121 | C0603 | 6 | 22pF | C15, C20, C22, C29, C30, C50, C149, C153 | C0402 | 8 | 12pF | C18, C19, C24, C26 | C0402 | 4 | 2.2uF | C96, C120, C150 | C0805 | 3 | 0.22uF | C109 | C0603 | 1 | 1.8nF | C135 | C0402 | 1 | 680pF | C147 | C0402 | 1 | AVLC5S02050 | D1, D2, D3, D4, D6, D10, D11, D12, D18, D19, D20, D21, D22, D23, D24, D25, D26, D27, D28 | R0402 | 19 | BAT54C | D5 | SOT-23 | 1 | AVRC18S05Q015100R | D7, D8, D9, D14, D15, D16, D17 | ESD-D | 7 | IN4148 | D13 | SOT-23 | 1 | Comment | Designator1, Designator2, Designator3, Designator4, Designator5, Designator6, Designator7, Designator9, Designator10, Designator12, Designator13, Designator14, Designator15, Designator16, Designator17, Designator19 | CON1 | 16 | Comment | Designator8, Designator11, Designator18, Designator20, Designator21, Designator22 | FPC-MARKS | 6 | MPZ1608S101A | FB1, FB2, FB3, FB4, FB5, FB6, FB7 | L0603 | 7 | DEBUG | J1 | SMD/16P/1.0 | 1 | JUMP2指拨开关 | J2 | SO-拨位开关-2 /间距2.54 | 1 | Battery | J3 | SIP4/1.27 | 1 | CON1 | J4, J5, J7, J8 | con1 | 4 | USB-MINIAB | J6 | USB/5P/梯型 | 1 | LT40400 | J9 | FPC39/0.6 | 1 | RESET | K1 | KEY | 1 | key4 | K2, K3, K4, K5, K6, K7, K8 | SW/4*4/S | 7 | 10uH | L1, L2, L4, L5 | L442 | 4 | 10uH/1A | L3 | L442 | 1 | GREEN | LED1, LED2, LED3, LED4, LED5, LED6, LED7, LED8, LED9, LED10, LED11, LED12, LED13, LED14 | LED/0603/AK | 14 | GREEN | LED15 | LED_0805 | 1 | 9013 | Q1, Q6 | SOT-23NPN | 2 | 2N3904 | Q2 | SOT-23NPN | 1 | IRLML6401 | Q3 | SOT-23 | 1 | 2N3906 | Q4, Q5 | SOT-23PNP | 2 | NC | R1, R7, R65, R69, R71, R95 | R0402 | 6 | 1.5K | R2 | R0402 | 1 | 3K | R3 | R0402 | 1 | 10K | R4, R11, R13, R14, R18, R19, R21, R22, R23, R25, R37, R48, R49, R58, R61, R77, R80, R81, R86, R87, R88, R89, R92, R94, R100, R102, R104, R110, R111 | R0402 | 29 | 100K | R5, R31, R38, R44, R45, R59, R79, R85 | R0402 | 8 | 1K | R6, R30, R97 | R0402 | 3 | 51K | R8 | R0402 | 1 | 0R | R9, R33, R34, R35, R36, R57, R60, R67, R68, R70, R72, R73, R78, R93, R101, R103 | R0402 | 16 | 4.1K/1% | R10 | R0603 | 1 | 4.7K | R12, R15, R28, R74 | R0402 | 4 | 300K/1% | R16, R51 | R0402 | 2 | 1M | R17, R20, R26, R53, R55 | R0402 | 5 | 5.1M | R24, R54, R56 | R0402 | 3 | 6.49K | R27 | R0402 | 1 | 220R | R29 | r0603 | 1 | 560K | R32, R40, R41, R42, R43 | R0402 | 5 | 200K | R39 | R0402 | 1 | 100R | R46, R47, R82, R83, R84, R107, R108 | R0402 | 7 | 100K/1% | R50, R106 | r0402 | 2 | 22.1K/1% | R52, R105 | r0402 | 2 | 3.3K | R62, R63, R64 | R0402 | 3 | 510K | R66 | R0402 | 1 | 120K | R75, R76 | R0402 | 2 | 44.2R | R90 | R0402 | 1 | 68K(1%) | R91 | R0402 | 1 | 15K(1%) | R96 | R0402 | 1 | 0R | R98 | R0603 | 1 | 510R | R99 | R0603 | 1 | 120K/1% | R109 | R0402 | 1 | 360K/1% | R112 | R0402 | 1 | CAT3604VHV4-GT2 | U1 | TQFN-16 | 1 | MAX8677A | U2 | QFN24 | 1 | XC6219B332MR | U3, U17, U20 | SOT23-5 | 3 | FDC6331L | U4 | SOT23-6 | 1 | Nano WiReach | U5 | NANOWIREACH | 1 | MP2104DJ | U6, U7, U15, U22, U23 | SOT23-5 | 5 | MAX811S | U8 | SOT143 | 1 | K4X1G163PC | U9, U18 | K4X1G163PC | 2 | ICM7555 | U10 | SO-8 | 1 | CD4023 | U11 | SO-14 | 1 | CD4052 | U12 | SO-16 | 1 | XC6202P332PR | U13 | SOT-89 | 1 | S3C6410X | U14 | FBGA424 | 1 | K9G8G08U0M | U16 | TSOP48 | 1 | BEEP-4 | U19 | BEEP-4 | 1 | XC6219B122MR | U21 | SOT23-5 | 1 | VDD_LED | V1 | TEST | 1 | mSPI1_CS | V2 | TEST | 1 | mSPI1_CLK | V3 | TEST | 1 | TOUCH_UP | V4 | TEST | 1 | mSPI1_MOSI | V5 | TEST | 1 | mVSYNC | V6 | TEST | 1 | mVDEN | V7 | TEST | 1 | VDDMAX | V8 | TEST | 1 | mVCLK | V9 | TEST | 1 | mHSYNC | V10 | TEST | 1 | PWM1 | V11 | TEST | 1 | ADC3 | V12 | TEST | 1 | VMAX | V13 | TEST | 1 | nTR | V14 | TEST | 1 | XXTO | V15 | TEST | 1 | VDD_WIFI | V16 | TEST | 1 | X27MXTO | V17 | TEST | 1 | XrtcXTO | V18 | TEST | 1 | XotgTO | V19 | TEST | 1 | VDD_IO | V20 | TEST | 1 | VDD_MEM1 | V21 | TEST | 1 | PWM0 | V22 | TEST | 1 | 12MHz | X1 | IT3205EE | 1 | 27MHz | X2 | IT3205EE | 1 | 32.768KHz | X3 | OSCHC49SUB_01 | 1 | 48MHz | X4 | IT3205EE | 1 | 附件:0 r. W; ^( r) I/ r
PCB文件如下:
# o% e6 M7 ]9 [6 |9 ?. k0 r
! P1 t P, q% ?: e: \7 T' h$ b. u9 x0 j a+ i7 c+ M7 U& u
