( X$ E% ]) j" Y6 H. ^8 y; \" p+ t) i! k( J4 }: K* ^ P
[AD 10][4层]RT5350SF以太网主板(MX25L3205DM21+RT5350SF+MAX809R)原理图和PCB文件
* K5 d5 G$ u" z1 `! s7 P( h
/ W9 d% x% s; I6 Z文件描述/ ]9 x4 |$ j* g9 {+ s* Z
1. 作品用途:RT5350SF以太网主板; o2 }; k" @) c& |9 u& H
2. 软件版本:AD 100 h0 U$ {, j. M- l1 i7 r* D
3. 层数:4层板8 l0 d& z/ i* x+ W+ H
4. 用到的主要芯片:MX25L3205DM21+RT5350SF+MAX809R' x* a6 M. I J+ Z7 X
5. PCB尺寸:72*63 mm) P5 V# f9 F: d% z" X' e
& k) Y9 O% X0 J0 ]! f4 P8 V
作品截图如下:
& A, r/ K4 }& s" ^, e' y顶层截图:
7 h. W8 [# G8 S$ j4 e
) z& U' q( I# t1 O! {/ k& @2 [# X. v
+ U2 Q/ s' m$ a" ~# s
底层截图:
* y8 b! g; B" E! R& i8 |, q- G
: ?. W6 h+ Y- [6 |3 X
% A: i3 w3 D( L! i8 R6 H
全层截图:
2 l" q5 n4 Z' d) g9 p
0 F. l# i8 e0 a) G6 J7 l% ^( X
叠层信息截图如下:
. l) Q# `* E' I; a B
! k' k* n9 S+ F4 w7 u& O! ?
BOM:
3 `% M3 T( N4 H; P' aComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 1.2pF/NI | C1, C5, C406 | RC0402 | 3 | 0 ohm | C3, L34, L53, R309 | RC0402 | 4 | 10nF | C4 | RC0402 | 1 | 10pF | C6, C17, C20, C252, C278, C384, C424, C429, C430 | RC0402 | 9 | 0.1uf | C7, C9, C10, C11, C12, C16, C43, C92, C98, C104, C108, C110, C111, C113, C114, C388, C389, C390, C391, C392, C414, C422, C445, CR1 | RC0402 | 24 | 4.7uF | C8, C42, C84, C90, C93, C107, C109, C112, C251 | RC0603 | 9 | 22pF | C13, C15 | RC0402 | 2 | 1uF | C14 | RC0402 | 1 | 22nF | C18 | RC0402 | 1 | 2.7pF | C35, C38 | RC0402 | 2 | 1.2pF | C36, C40, C409 | RC0402 | 3 | 1.5pF | C37 | RC0402 | 1 | 6.8nF | C100 | RC0402 | 1 | 10uF | C102, CP1, CP4 | RC0805 | 3 | 1.5nF | C105 | RC0402 | 1 | 68pF | C106 | RC0402 | 1 | 5.6nF | C284 | RC0402 | 1 | 2.2pF | C285 | RC0402 | 1 | 1.8pF | C286 | RC0402 | 1 | NI | C287 | RC0402 | 1 | 3.3nF | C381, C444 | RC0402 | 2 | 2.7nF | C382, L12 | RC0402 | 2 | 15pF | C405 | RC0402 | 1 | SMA/UFLR | CON1, CON2 | CON1 | 2 | 0.1uF | CP2, CP3, Cp5, Cp6, Cp7, Cp8, Cp9, Cp10, CP17, CP18, CP19 | RC0805 | 11 | 30pF | CP11, CP12 | RC0805 | 2 | 0.1uF | CP13, CP14, CP15, CP16 | RC0603 | 4 | LED | D1, D2 | RC0805 | 2 | ANT-RA-USB-1 | E1 | ANT_16 | 1 | 1A | FUSE | FUSE | 1 | Power_in | JP1 | POWER_IN | 1 | UART | JP2 | DB9 | 1 | HR911105A | JP3, JP4 | RJ45A | 2 | 2.2nF | L11 | RC0402 | 1 | 4.7uH | L14 | L55 | 1 | 0_0402 | L16, L17 | RC0402 | 2 | 0.8pF | L51 | RC0402 | 1 | 3.3pF | L52 | RC0402 | 1 | 12K | R1 | RC0402 | 1 | 100K | R3 | RC0402 | 1 | 8.2K | R8 | RC0402 | 1 | 4.7K | R18, R66, R71, R88, R94, R95, R107, R118, R119, R144, R146, R148, R150, R154, R188, R192, R293, R298, R308, R318, SR2 | RC0402 | 21 | 9.1K | R50 | RC0402 | 1 | 2K | R67, R284 | RC0402 | 2 | 47 | R68 | RC0402 | 1 | 16.9K | R70 | RC0402 | 1 | 4.2K | R142 | RC0603 | 1 | 1M | R211 | RC0402 | 1 | 0 | R280 | RC0402 | 1 | 33/NI | R295 | RC0402 | 1 | 51ohm | R300 | RC0402 | 1 | 1K | Rp4, Rp5, Rp6, Rp7 | RC0603 | 4 | 1K | RP1, RP20 | RC0805 | 2 | 470 | RP2, RP3 | RC0805 | 2 | 50 | RP12, RP13, RP14, RP15 | RC0603 | 4 | 100 | RP16, RP17, RP18, RP19 | RC0603 | 4 | 10K | RP21, RP22, RP23 | RC0805 | 3 | 100 | Rp8, Rp9, RP10, RP11 | RC0805 | 4 | SW4 | S1, S2, S3 | SW4 | 3 | S1 | SW | SWITCH | 1 | RT5350SF | U1 | RT5350F | 1 | MAX809R | U3 | MAX809R | 1 | APM2701AC | U8 | SOT23-6 | 1 | MX25L3205DM21 | U10 | SPI_FLASH | 1 | XTAL20M | U33 | XTAL20 | 1 | EM63A165TS-6G | U35 | EM63A165TS | 1 | 1117 | UP1 | 1117 | 1 | SP3232E | UP2 | SP3232 | 1 | CH340T | UP3 | CH340T | 1 | USB_A | USB_A | USB | 1 | USB_Micro | USB_Micro | USB_MICRO | 1 | 12M | X1 | XTAL12M | 1 | 附件:/ u% V* ]. M9 y& K
原理图和PCB文件如下:
# V4 [) W1 U, [2 c2 k4 Y8 W! _( R3 f
( k- z2 Z, t# i
