作品名:[AD 10][2层](MB86391+TVP5146PFP+PCM1800E)做的一个PCB文件共享# `+ w* ?$ l M0 H: x& n' R
$ h4 j& D+ q- v0 d文件描述
/ M' i6 \9 E, J# ^* t0 d1. 软件版本:AD 10
* D8 \& g% A/ I: x+ c% \6 e2. 层数:2层板1 `- C" H7 L8 Y
3. 用到的主要芯片:MB86391+TVP5146PFP+PCM1800E+PCM1723E+EPM3064A
2 N% W( `/ x' e+ H4. PCB尺寸:72mm*65.8mm
$ I4 Q! H( |0 e+ e
& v+ H4 {/ Y! F9 ]4 A5 V+ ^( K: u作品截图如下:
5 Z. f E: c! g# ~顶层截图:
9 o B2 E( w2 O$ j1 E' C. W
6 s. M& ^# `- W* j
9 S; T; c s! D7 N3 b" o9 }底层截图:+ I. M9 v- T+ [
; _! J1 a! N6 ]# A9 D2 S3 ]
( l8 N& W$ _6 E" x$ @全层截图:
5 R4 L7 Y* {% s. {. o# z* l
. w/ N/ W' ]# W$ d! S3 u* p, F( o; G
叠层信息截图如下:- ~# k! a, n3 |' `0 C! C1 O
6 I9 O( z9 `$ w$ S0 @3 i: @
8 ^: W; c+ W1 ]$ W1 X- e6 g1 p
BOM:
) T: a9 E/ R/ c' m# Y8 xComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 100NF | C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, C22, C23, C24, C25, C29, C30, C33, C35 | 0505 | 29 | 30PF | C26, C27, C31, C32 | 0505 | 4 | 500PF | C28, C36 | 0505 | 2 | 50PF | C34 | 0505 | 1 | 100PF | C37 | 0505 | 1 | | CN1 | DIP-16J | 1 | | CN2 | SIP-4 | 1 | | CN3 | SIP-3B | 1 | 2PIN | CN4, CN6 | SIP-2C | 2 | 3PIN | CN5 | SIP-3B | 1 | IN4007 | D1 | 1/2WA | 1 | 106C U525 | E1, E2, E3, E4, E5, E6, E7, E9, E10, E11, E12 | 1206F | 11 | MB86391 | IC1 | QFP-208 | 1 | | J1, J2 | DIP-10B | 2 | 6UH | L1, L2, L3, L4 | 0805 A | 4 | 14.318G1 | OSC1 | XTAL5 | 1 | 11.0592 | OSC2 | XTAL5 | 1 | 6.0000 | OSC3 | XATL10 | 1 | V27.000 | OSC4 | XATL10 | 1 | | OSC14 | SOP-24J | 1 | 75R | R2, R3, R6 | 0505 | 3 | 3.3K | R4, R17 | 0505 | 2 | 200R | R5, R16 | 0505 | 2 | 1K | R7, R8, R9 | 0505 | 3 | 5.1K | R10, R12, R13, R18, R20, R27 | 0505 | 6 | 100R | R11 | 0505 | 1 | 10K | R15, R21, R26 | 0505 | 3 | 2.2K | R19, R23 | 0505 | 2 | 1M | R22 | 0505 | 1 | 2.7K | R28 | 0505 | 1 | AT89S52 | T2 | QFP-44A | 1 | EPM3064A TC44-10N | U1 | QFP-44 | 1 | PCM1723E | U3 | SOP-24A | 1 | S29AL008D70TF102 737BBM72 | U4 | SOP-48B | 1 | HY57V653220B | U5, U6 | SOP-86 | 2 | TVP5146PFP | U7 | QFP-80 | 1 | PCM1800E | U8 | SOP-24A | 1 | PC11 | U9 | SOP-5A | 1 |
O8 |- l5 f% q4 i% S附件:
8 [, I8 z6 I/ o; J0 J, [PCB源文件如下:/ O! q, ? o" a1 Z
% p: J5 {8 d. X& g
4 ?+ u& [+ R7 T* C( K |
