( {7 i! Q. z9 Q1 ^; @7 W# l. a. u) T
[AD 10][2层]P89V51RD2智能车主板(P89V51RD2+HS0038+MQ-2)原理图和PCB文件: O3 U8 g, \5 n
/ _8 }) Q' [+ p9 q+ Y
文件描述# f! g3 \) C+ F. W" u5 ^
1. 作品用途:P89V51RD2智能车主板. ^. k" J" R3 Q: m3 ?0 p
2. 软件版本:AD 10
5 R9 O# n, Z7 ~* V7 t6 I3. 层数:2层板; `3 I6 H: n$ `+ i# i
4. 用到的主要芯片:P89V51RD2+HS0038+MQ-2
f: s5 c7 I7 \5. PCB尺寸:113*124mm5 x" j8 g' }6 G3 x* G
* |( D, K: T; R7 ]8 R
作品截图如下:/ B3 C6 O, x% D' B' W3 v
顶层截图:
$ @' E* a/ S5 j; S0 J# R# h9 E
# J9 H6 ~2 a# q+ z- T; d: o- H+ _4 W* y& \) q9 v+ g' ^" t
底层截图:
1 x1 S5 L" y1 { G' s4 S4 a% ]. `% r
/ K$ R( y' O; L$ y) ^
! W: L5 u7 }9 M全层截图:8 v( s" s; `$ c9 {' s8 L
9 E" W* F+ N' E/ ?叠层信息截图如下:5 E" \0 \, T- @7 {
1 H; s* l6 v) a7 V& O- W( A- LBOM:
: v) l2 r) Z" A# @" `4 mComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | Buzzer | BZ1 | RB7.6-15 | 1 | 0.1uF | C1, C2, C3, C6, C8, C11, C12 | RAD-0.3 | 7 | 20pF | C4, C5 | RAD-0.3 | 2 | 470uF | C7 | RAD-0.3 | 1 | 100uF | C9, C10 | RAD-0.3 | 2 | 4148 | D1 | DO-35 | 1 | CON8 | J1, J2, J4, J5 | SIP8 | 4 | CON6 | J3 | SIP6 | 1 | CON4 | J6, J7 | SIP4 | 2 | KEY | K1 | KEY-6*6 | 1 | LCD1602 | LCD1 | SIP16 | 1 | LED | LED1, LED2, LED3, LED4, LED5 | LED | 5 | S9013 | Q1, Q2, Q3 | TO-92 | 3 | 9012 | Q4, Q5 | TO-92 | 2 | 4.7K | R1, R2, R3, R4, R5, R6, R7, R8 | AXIAL-0.4 | 8 | 1K | R9, R14, R15, R16 | AXIAL-0.4 | 4 | 330 | R10, R11, R19 | AXIAL-0.4 | 3 | 100 | R12, R18 | AXIAL-0.4 | 2 | 10K | R13 | AXIAL-0.4 | 1 | 10K | R17 | VR5 | 1 | SW | S1 | DPDT-6 | 1 | P89V51RD2 | U1 | DIP40 | 1 | HC | U2 | SIP3 | 1 | HS0038 | U3 | SIP3 | 1 | 18B20 | U4 | TO-92 | 1 | MQ-2 | U5 | SIP4 | 1 | 11.0592M | Y1 | XTAL-2 | 1 | 附件:0 R( w$ ?& { g9 f# e5 f
原理图和PCB文件如下:& r2 T6 b( p. @- \) a
- b% A3 g) y! b9 y" Z
, x7 A' ]" g7 B8 s0 F |
