作品名:[AD 10][4层]LTC1968+LTC2440+LTC6655做的一个功率表PCB原理图
! m1 K; O" \( `# U' c
! L' \# Y) c3 y$ o3 b: t文件描述
, o$ P6 d6 m0 A1. 作品用途:功率表
/ B! ?! S; A3 h0 l2. 软件版本:AD 10 I/ j$ D3 q% {. L& a3 h
3. 层数:4层板" {, t! B1 O! i) E6 p+ I, V% w
4. 用到的主要芯片:LTC1968+LTC2440+LTC6655+STM32F103VC+AD8629# e3 i1 _# @; u3 R( H0 _. C
5. PCB尺寸:100mm*100mm
+ v. d2 Q. f6 k' h4 z5 V; k$ a; M" J% ~$ I8 I
作品截图如下:1 r9 U$ o7 H0 Y# K
顶层截图:
5 [: n) }8 o+ z1 ?% J
" v7 E& M$ Z/ u
& }; K; [/ v0 N- J. q底层截图:
4 }- H% _. g" O% G
/ t2 O- O& P2 r6 |: Q
0 r( R7 C* `/ ?% @% W全层截图:
) l- `* I: S0 ]7 R
5 q' A: u' [! p7 O
: g) p* j- ?/ x4 e! B" k1 r叠层信息截图如下:
+ n" I2 x1 ^- T7 T" u
; G3 X# v$ S" K6 E8 d
" S- }/ P" U' MBOM:, D+ u0 q( G3 x# E) }- s# g M
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 1uF | C1, C2, C3, C9, C11, C12, C13, C14, C15, C20, C21, C22, C42, C51, C55, C56, C62, C63 | C_0603 | 18 | 10uF | C4, C28, C32, C37, C41, C49, C54 | C_0603 | 7 | 1uF | C5, C6 | C_CCB 12x5 | 2 | Cap | C7 | C_0402 | 1 | 100nF | C8 | C_0402 | 1 | Cap | C10, C35 | C_1206 | 2 | 100nF | C16, C26, C27, C30, C36, C45, C52, C57, C58, C59, C60, C61 | C_0603 | 12 | 22uF | C17, C50 | C_1206 | 2 | 4700uF/16V | C18, C46 | ALU-13x20 | 2 | 10nF | C19, C48 | C_0603 | 2 | Cap | C23, C29 | C_0603 | 2 | 100uF/16V | C24, C39 | C_TAJ-B | 2 | 4700uF/16V | C25, C47 | C_RB+ 8X11_3.5 | 2 | 22pF | C31, C34 | C_0603 | 2 | Cap | C33 | C_CCB 12x5 | 1 | 100uF/16V | C38, C44 | C_TAJ-D | 2 | Cap | C40 | C_TAJ-A | 1 | 10uF | C43, C53 | C_0805 | 2 | Cap | C65 | C_0805 | 1 | BZT52C5V1 | D1 | DO-214Ab_SMC_L | 1 | SMAJ16CA | D2, D3, D4 | SOD-123 | 3 | D Zener | D8 | SOT23 | 1 | divider resistance 9+1 | DR1, DR3 | HC-49U_4PIN | 2 | divider resistance 180+18+2 | DR2 | HC-49U_4PIN | 1 | Header -12 | J1 | DF37-24DS-0.4V | 1 | 0R | JUMP2 | JUMP_1 | 1 | | JUMP4, JUMP5, JUMP6, JUMP7, JUMP8 | JUMP_1 | 5 | Relay-DPDT_OMRON_G5V | K1 | TF2E-5V_SOP10 | 1 | Bell | LS1 | FMQ | 1 | studs | LT1, LT3, LT4 | Studs_weld M3*10 | 3 | Header 6 | P1 | PZ1.27-6 | 1 | Header 4 | P2, P4, P5, P11 | OUT-PORT | 4 | Header 2 | P3 | CH2.5-2 | 1 | Header 2 | P6, P7, P8 | HX25037-2A | 3 | Header 3 | P9 | HX25035-3A | 1 | Header 3 | P10 | VH396-3P_V | 1 | MOSFET-N | Q1, Q2, Q3, Q4 | SOT23 | 4 | 10K | R1, R2, R5, R8, R18, R19, R20, R21, R22, R24, R37 | R_0603 | 11 | Res2 | R3, R4, R6, R7 | R_0402 | 4 | 100K | R9, R10 | R_0603 | 2 | Res2 | R11, R16, R23 | R_0603 | 3 | 27R | R12, R13 | TO-220-2 | 2 | 9K | R14, R15 | R_0603 | 2 | 1K | R17, R36, R39 | R_0603 | 3 | 1MΩ | R25 | R_0603 | 1 | 1M | R26, R27, R28, R29, R30, R31, R32, R33, R34 | R_0805 | 9 | Res2 | R35 | R_0805 | 1 | 10R | R38, R41 | R_1206 | 2 | 200R | R40 | R_0805 | 1 | 10R | RN1, RN2 | AXIAL-0.8 | 2 | 15K | RN3, RN4 | R_0402 | 2 | 6*6 | S1, S2, S3, S4, S5, S6 | KEY-5×5 SMD | 6 | Splitter | SP1 | AZ-H2 | 1 | Trans Eq | T1 | Filter_WE-SL2 | 1 | SMAJ26CA | TV1 | DO-214AC_SMA_S1 | 1 | SM712 | TVS3 | sot23 | 1 | LTC2440 | U1, U2 | SSOP16 | 2 | MCP6002 | U3, U10 | SOP-8 | 2 | AD8629 | U4, U5 | MSOP8 | 2 | TS3A24159 | U6 | MSOP-UN10_M | 1 | XC6219B332MR | U7 | SOT23-5 | 1 | LM78M05 | U8, U9 | TO-252 -1 | 2 | TMP102 | U11 | SOT-5x3 | 1 | STM32F103VC | U12 | LQFP100-14X14 | 1 | LTC6655 | U13 | msop8 | 1 | LTC1968 | U14 | MSOP8 | 1 | OPA340 | U15 | SOP-8 | 1 | XC6219B302MR | U16 | SOT23-5 | 1 | 12MHz | Y1 | 2520_x | 1 | $ c/ J- M0 T ~, x; {
附件:4 R6 S& W5 V D
原理图和PCB源文件如下:
0 y% u$ h' n2 Y4 m
1 y) W5 m) L) s( x* [. e5 u
5 I7 w M" w* S+ L- l3 Y. k; c p |
