作品名:[AD 10][4层]一块4层由TMS2407A做的DSP板子原理图和PCB源文件/ j$ G8 z0 P) Z! X( U/ L3 X/ ^
- N, U* a" G) P9 I文件描述7 n0 d. e0 h2 R; O
1. 软件版本:AD 10. _1 y% [! Q: V( T, e5 S
2. 层数:4层板
Q4 h1 m! z- r" _3. 用到的主要芯片:TMS2407A
1 n9 S) B2 }+ L; C6 j+ m( v0 c4. PCB尺寸:216.6mm*129.1mm
& ^, S, N% f( s# a- s" d8 J5 p7 R9 g: \" |8 ^& l
作品截图如下:
, e y O! u. U* N8 r顶层截图:' Z! w1 y! _# X4 ^6 T
0 U, b1 T7 w. \+ Y+ ~ k# Y
, }, G* w, y8 P底层截图:" k0 E0 |+ t. V# t3 ^/ u
! i( k* I4 h0 Y/ D0 r% Y2 S
6 O9 y, x+ P- E0 k+ q* R6 h全层截图:$ [ v% b9 l7 h1 ^
( p+ `8 `: ~. D
# T5 G, F, T$ }0 K% J( e
叠层信息截图如下:
[ ~7 D3 x9 O# Q+ q$ o# d
g$ v, O+ O" _& X
7 P7 R: N- e7 t; wBOM:" d$ a' i P j2 ]7 Z/ u* Y2 l8 @. U
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1u | C1, C3, C7 | 0805 | 3 | 0.0033uf | C2 | 0805 | 1 | 0.15uf | C4 | 0805 | 1 | 0.1u | C8 | RAD0.1 | 1 | 104/35V | C9, C10 | RAD0.1 | 2 | 470uf/35V | C11, C12, C13 | RB.2/.4 | 3 | 0.33uF | C14, C15, C16 | RAD0.1 | 3 | 47uF | C17, C18, C19, C20, C21, C22 | RB.1/.2 | 6 | 104 | C23, C24, C25 | RAD0.1 | 3 | 10000uF | C26, C27 | RB.4/.8 | 2 | 10u | C28 | 1210 | 1 | 103 | C31, C32 | 0805 | 2 | 103 | C33, C34 | RAD0.1 | 2 | 0.1uf | C35, C36, C39, C40, C51, C52 | 0805 | 6 | 6p | C37, C38, C41, C42, C43, C44, C45, C46, C47, C48, C53 | 0805 | 11 | 1N4148 | D3, D4, D5 | DIODE0.4 | 3 | 1N4002 | D6, D34, D35, D36, D37, D38, D39, D40, D41 | DIODE0.4 | 9 | TVS | D7 | DIODE0.4 | 1 | DIODE | D8, D9, D10, D11, D12, D13, D14, D15, D16, D17, D18, D19, D20, D21, D22, D23, D24, D25, D26, D27, D28, D29, D30, D31, D32, D33 | 1206AD | 26 | LM7805CK | DU1 | TO-220H | 1 | LM79L15 | DU2 | TO-220H | 1 | LM7815 | DU3 | TO-220H | 1 | TPS77833 | DU4 | SO-8 | 1 | 10uF | E1, E2, E3, E4, E5, E6, E7, E8, E9, E10, E11, E12, E13, E14, E15, E16, E19, E20, E31, E32, E33, E34, E36, E38, E40, E41, E42, E43, E44, E45, E46, E47, E48, E49, E50 | 1210 | 35 | SLOT96 | J1 | HT96ML | 1 | CON4 | J9, J14 | CON4 | 2 | JTAG_PORT | J10 | IDC14 | 1 | SIP3 | J11 | SIP3 | 1 | IDC10 | J12 | IDC10 | 1 | 3.3uH | L1, L2, L3 | L_RAD0.2 | 3 | POWER | LED1 | LED | 1 | RUN_1 | LED2 | LED | 1 | SCAN_F1 | LED3 | LED | 1 | FAULT1 | LED4 | LED | 1 | NORMAL1 | LED5 | LED | 1 | RUN_2 | LED6 | LED | 1 | SCAN_F2 | LED7 | LED | 1 | FAULT2 | LED8 | LED | 1 | NORMAL2 | LED9 | LED | 1 | COM | LED10 | LED | 1 | LA_28NP | LEM1 | LA28-NP | 1 | 20MHz | OSC1 | OSC1 | 1 | 5.1K | R1, R2, R3, R4, R30, R37, R38, R41, R42 | 0805 | 9 | 2.2K | R5 | 0805 | 1 | 10K | R6, R7, R8, R9, R19, R23, R31, R32, R35, R44, R46, R48, R49, R53, R55, R58, R59, R63, R65, R68, R69, R70, R72, R73, R74, R79, R80, R81, R83, R84, R85, R91, R95, R97, R99, R101, R102, R104, R105, R106, R107, R109, R111, R112, R113, R114, R120, R121, R123, R124, R129, R130, R131, R134, R135, R136, R137, R140, R144, R145, R146, R147, R148, R149, R150, R151, R154 | 0805 | 67 | 1K | R10, R11, R12, R13, R14, R15, R16, R17, R18, R75, R76, R86, R87, R125, R132, R133, R152 | 0805 | 17 | 510 | R20, R22, R39, R40, R51, R61, R139 | 0805 | 7 | 100K | R21, R29, R50, R60, R138 | 0805 | 5 | 24 | R24 | 0805 | 1 | 120 | R27 | 0805 | 1 | 100 | R28 | AXIAL0.5 | 1 | 39K | R43, R100, R110 | 0805 | 3 | 47K | R45 | 0805 | 1 | 20K | R52, R56, R62, R66, R71, R82, R89, R90, R92, R93, R94, R96, R98, R108, R116, R119, R122, R127, R142 | 0805 | 19 | 2.4K | R54, R64, R141 | 0805 | 3 | 150 | R57 | AXIAL0.5 | 1 | 10 | R67, R78, R143 | 0805 | 3 | 75K | R103, R118 | 0805 | 2 | 75/2W | R115, R126 | AXIAL0.9 | 2 | 300 | R117, R128 | 0805 | 2 | 0 | R160, R170 | 0805 | 2 | SW DIP-4 | SW | SW DIP-4 | 1 | TRANS1 | T1 | TRANS1 | 1 | TMS2407A | U1 | QFP144 | 1 | HP200 | U2, U3 | SO-8 | 2 | 74LS139 | U4 | SO-16 | 1 | SN65HVD251 | U5 | SO-8 | 1 | TCM809 | U6 | SOT-23 | 1 | TL3474 | U7, U11, U12, U13, U14, U18 | SO-14 | 6 | LM239 | U8, U9 | SO-14 | 2 | 74HC245 | U15 | SO20W | 1 | LMV3241 | U16, U17 | SO-14 | 2 | EPM7032AE | U19 | PLCC44 | 1 | ' M0 b! w$ _! B0 Y7 r A! a
附件:- i u" m3 i! d* i! c
原理图和PCB源文件如下:
! l* O7 M9 j* G( w1 Q0 m
! L/ w i( G2 W' {# S0 B% b `# r6 x8 c0 I
