查看: 228|回复: 0
[AD 10][4层]RK2818 +ES8328+ENC28J60+000-7090-37R+MAX13085EESA 做的PCB和原理图
发表于 2020-2-19 14:35 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 10][4层]RK2818 +ES8328+ENC28J60+000-7090-37R+MAX13085EESA 做的PCB和原理图共享
. X) U6 r* Q7 T7 X: G2 b5 F& _0 k: e4 @$ g
文件描述
0 Z6 u8 F  X' Q9 S, e# K" s1. 软件版本:AD 10
# ~% }0 k0 [( ?; J, [- {2. 层数:4层板
0 S2 D8 L) L% l5 ~+ X3. 用到的主要芯片:RK2818 +ES8328+ENC28J60+000-7090-37R+MAX13085EESA2 o2 O4 E5 B/ Q  s
4. PCB尺寸:201.1mm*106.6mm2 [( M0 g. @: a0 M0 w( p) t
  B6 m4 \3 ^! [. Z7 I8 ~作品截图如下:$ H2 S& j( E1 H7 q7 l* S: L* ^
顶层截图:7 n: w3 U! S! _) C7 G) s& l
. y( p0 s' p" @) V0 X" R- C
' M- U% _4 n  k
底层截图:# W. `- J" L5 l' [/ v0 i5 [) z
" G) F8 X7 Y2 y+ ~. R* \% O( P$ N
全层截图:1 |) m( l. O& \/ A' Y  o
* n& j7 N$ ]3 V: m
! V$ Y" X% n1 n6 d
叠层信息截图如下:
  |1 p' z2 R; \- O3 A" X, |+ [; t! O
1 m" C/ \# T! X- ~/ }! w+ \# g, z
3 h4 B( q" G6 k4 s/ sBOM:
$ ?5 l( J, b: f( p2 H. _- r! k
Comment(属性)
Designator(位号)
Footprint(封装)
Quantity(数量)
472
*C29
333-0603-ECM3048
*C30
333-0603-ECM3048
10U/10V
*C233, *C233, C147,  C147, C166, C166, C167, C167, C231, C231
C0805
10
18K%1
*R22
18K-0603-ERM3118
8_2K%1
*R23
8_2K-0603-ERM3070
6_8K%1
*R28
8_2K-0603-ERM3070
27K%1
*R31
27K-0603-ERM3034
270K%1
*R74
270K-0603-ERM3078
100K%1
*R75
270K-0603-ERM3078
0R
*R142, *R142, *R143,  *R143, *R144, *R144, *R145, *R145, *R146, *R146, *R147, *R147, *R148, *R148,  *R149, *R149, *R150, *R150, *R151, *R151, *R152, *R152, *R153, *R153, *R154,  *R154, R18, R18, R22, R22, R23, R23, R122, R122, R123, R123, R130, R130,  R132, R132, R133, R133, R167, R167, R168, R168
0R-0603-ERM3001
46
104
C1, C1, C3, C3, C5,  C5, C6, C6, C7, C7, C8, C8, C9, C9, C19, C19, C20, C20, C23, C23, C24, C24,  C25, C25, C27, C27, C31, C31, C36, C36, C37, C37, C42, C42, C51, C51, C99,  C99, C105, C105, C137, C137, C157, C157, C165, C165
C0603
46
10U/16V
C2, C2, C158, C158
1206
220uF/6.3V
C4, C4, C39, C39,  C40, C40
SE6.3-5.8(7.7)
C10, C10, C11, C11,  C13, C13, C50, C50, C71, C71
106-0805-ECM0047
10
104-0402
C12, C12, C48, C48,  C49, C49, C52, C52, C53, C53, C54, C54, C55, C55, C58, C58, C59, C59, C62,  C62, C63, C63, C69, C69, C70, C70
C0402
26
101
C14, C14, C33, C33,  C64, C64, C148, C148
101-0603-ECM3009
8
476
C15, C15, C16, C16,  C134, C134, C162, C162
C1206
8
10UF/10V
C17, C17, C34, C34,  C38, C38, C65, C65, C66, C66, C67, C67, C98, C98, C102, C102, C106, C106,  C108, C108, C113, C113, C114, C114, C115, C115, C121, C121, C122, C122, C123,  C123, C128, C128, C161, C161, E3, E3
C0805
38
106/NC
C18, C18, C163, C163
106-0805-ECM0047
100NF
C21, C21, C101, C101,  C103, C103, C230, C230, C232, C232
C0603
10
*104
C22
C0603
10nF
C26
C0603
1.5nF
C28
C0603
C32
C0402
15P
C35, C35, C41, C41
18P-0603-ECM3086
C43, C43, C44, C44,  C45, C45, C46, C46, C47, C47
22/6_3-0805-ECM0057
10
104
C56, C56, C57, C57,  C60, C60, C61, C61, C68, C68, C72, C72, C73, C73, C74, C74, C75, C75, C76,  C76, C77, C77, C78, C78, C79, C79, C80, C80, C164, C164, C170, C170
104-0603-ECM3001
32
104
C81, C81, C82, C82,  C83, C83, C86, C86, C87, C87, C88, C88, C89, C89, C90, C90, C91, C91, C92,  C92, C93, C93, C94, C94, C95, C95
C0402
26
18P
C84, C84, C85, C85
C0603
C96, C96, C97, C97,  C112, C112, C125, C125
C0603
8
103
C100
103-0603-ECM3002
C104
C0603
C107, C107, C130,  C130, C131, C131
105-0603-ECM3013
C109, C109, C110,  C110, C145, C145
C0603
10uF/16V
C111, C111, C126,  C126, C156, C156
1206
C116, C116, C117,  C117
C0603
C118, C118, C119,  C119, C120, C120
C0603
100uF/16V
C124
SE6.3-5.8(7.7)-AK
220uF/16V
C127, C127, E1, E1
SE6.3-5.8(7.7)-AK
*47PF
C129
C0603
C132, C132, C133,  C133
102-0603-ECM3011
1NF/3KV
C135
RAD0.3
C136, C136, C138,  C138, C139, C139, C140, C140, C141, C141, C142, C142, C143, C143, C144, C144
104-0603-ECM3039
16
*56P
C146
C0603
C149
332-0603-ECM3061
C150, C150, C151,  C151, C152, C152, C153, C153
105-0603-ECM3053
8
473
C154
473-0603-ECM3006
C155
561-0603-ECM3074
4.7U/20V
C159, C159, C160,  C160
4_7U-3216-ECM6029
1u/16v
C168
C0603
120pF
C169
C0603
1N5819
D1
7227-12
MLVG0603
D2, D2, D3, D3, D4,  D4, D10, D10, D14, D14, D15, D15, D16, D16, D17, D17, D18, D18, D21, D21,  D22, D22, D23, D23, D24, D24, D25, D25, D35, D35, D36, D36, D39, D39, D40,  D40
0603
36
SS34
D5
7227-12
1N4007(M7)
D6
7227-12
*LED
D7, D7, D8, D8
0805AK
CP2046TS
D9
XPT2046
1N4148
D11
0805AK
*MLVG0603
D12, D12, D13, D13,  D31, D31, D38, D38, D41, D41, D42, D42, D43, D43, D44, D44
0603
16
D19
0805AK
P6K20CA
D20
P6KE6_8CA-DIODE0-EDD0018
BAV99
D26, D26, D27, D27
BAV99-SOT23-EQM0031
RB501V
D28
RB501V-SOD323-EDM0049
LL4148
D34
1206-12
SS14
D37
7227-12
220UF/16V
E2
SE6.3-5.8(7.7)
HR250-145
F1, F1, F2, F2
YMDZ-LB
50PIN_7DDFOG
FPC1
FPC-P50-0_5UP-ESC0800
MAX13085EESA
IC1
SOJ-8
POW
J1
PH2-2.5
*JTAG
J2
PH8-1_5
USB
J3
PH6-1_5
UPGRADE
J4
SIP2
ALARM
J5
PH10-2.5
J6
PH2-2_5
POW
J8
PH2-1_5
SPK
J9
PH2-1_5
*UART
J10
PH4-1_5
RES
J11
KAN0641-050B-KEY1-EK00034
EXT
J12
PH2-2.5
MIC
J13, J13, J17, J17
PH2-1_5
LCD-BL
J14
GH01
KEY
J15
FPC-P6-1_0UP-ESC0218
JUMP
J16
SIP2
TX2-12V
JD1
JDQ-TX
LAN_PORTB
J_LAN1
WLJK
ZH-P6-1_5
J_LED
ZH-P6-1_5-ESZH0008
TOUCHSCREEN
J_TS1
PIN4-1_0
22uH
L1, L1, L16, L16,  L18, L18
L-22UH
3_3UH/2A
L2, L2, L10, L10
SB6028
30Ω/0.45A
L3, L3, L4, L4, L5,  L5, L6, L6, L7, L7
0603L
10
47UH-?-EL00023
L8
47UH-?-EL00023
0R
L9, L9, L11, L11,  L12, L12
0603L
30Ω/0.45A
L13
30R-L0603-EL00030
0R
L14, L14, L17, L17,  R223, R223
0805
22UH
L15
22UH-L0302-EL00095
2SC2001
Q1
TO-92D2
AO3401
Q2
SOT-23PNP
MMBT3906
Q3, Q3, Q5, Q5
SOT-23B
MMBT3904
Q4, Q4, Q6, Q6, Q8,  Q8
SOT-23B
MMBT3904
Q10
SOT-23
22K
R1, R1, R155, R155
100K-0603-ERM3005
4.7K
R2, R2, R47, R47,  R52, R52, R58, R58, R71, R71, R79, R79, R80, R80, R93, R93, R94, R94, R95,  R95, R96, R96, R97, R97, R98, R98, R99, R99, R100, R100, R114, R114, R221,  R221, R222, R222
0603
36
10K
R3, R3, R8, R8, R33,  R33, R42, R42, R56, R56, R83, R83, R118, R118
0603
14
10R
R4
0603
1.5K%1
R5
100K-0603-ERM3005
*200K
R6
0603
15K
R7, R7, R59, R59
0603
33R
R9, R9, R10, R10,  R11, R11, R12, R12, R72, R72, R119, R119, R120, R120, R121, R121
0603
16
1K
R13, R13, R29, R29,  R34, R34, R35, R35, R36, R36, R37, R37, R38, R38, R53, R53, R84, R84, R140,  R140
0603
20
12K%1
R14
0603
4.7K%1
R15
0603
1.2K%1
R16
100K-0603-ERM3005
27K
R17
0603
2.2K
R19, R19, R27, R27,  R55, R55, R61, R61, R62, R62, R70, R70, R110, R110
0603
14
1K
R20, R20, R21, R21
4_7K-0603-ERM3022
*0R
R24
33K-0603-ERM3064
*0R
R25
4_7K-0603-ERM3022
0R
R26, R26, R46, R46
0603
2.7K 1%
R30
0603
100R
R32, R32, R44, R44,  R69, R69, R76, R76, R77, R77, R78, R78, R81, R81, R82, R82, R86, R86, R116,  R116, R117, R117
0603
22
*1K
R39, R39, R40, R40
0603
100K
R41
0603
R43
0603
*0R
R45
0603
2.2R
R48, R48, R73, R73
0805
47K
R49
0603
*10K
R50
100K-0603-ERM3005
10K
R51
100K-0603-ERM3005
150R
R54
150R-0603-ERM3149
150K
R57
0603
100R
R60
0805
R63, R63, R64, R64,  R65, R65, R68, R68
0805
8
10R
R66
10R-1206-ERM6001
3K%1
R85
0603
R87, R87, R88, R88,  R89, R89, R90, R90
0603
8
10K
R91, R91, R134, R134,  R169, R169
10K-0603-ERM3004
33K
R92, R92, R102, R102
33K-0603-ERM3064
4.7R
R101
0805
1K
R103, R103, R104,  R104, R105, R105, R106, R106, R107, R107, R108, R108, R109, R109, R160, R160,  R161, R161
1K-0603-ERM3002
18
300K
R111
300K-0603-ERM3077
51K
R112
47K-0603-ERM3048
360K
R113
360K-0603-ERM3054
220R
R115
1206
6.8K.1%
R124
6_8K-0603-ERM3162
5.6K,1%
R125
4_7K-0603-ERM3022
2.2K
R126
2_2K-0603-ERM3010
330R
R127
330R-0603-ERM3014
120R
R128
1206
47K
R129
47K-0603-ERM3048
33R
R131
33R-0603-ERM3013
R135
40_2K-0603-ERM3145
4K7
R136, R136, R141,  R141
4_7K-0603-ERM3022
4R7
R137
0805
6_8K
R156
6_8K-0603-ERM3071
NC
R157
0R-0603-ERM3001
4_7K
R158
4_7K-0603-ERM3022
1K%1
R159
100K-0603-ERM3005
1K%1
R162, R162, R163,  R163
1K-0603-ERM3002
15K%1
R164
15K-0603-ERM3008
10K/NC
R165
10K-0603-ERM3004
2K%1
R166
150K-0603-ERM3037
000-7090-37R
T1
T
TP1, TP1, TP2, TP2,  TP3, TP3, TP4, TP4, TP5, TP5, TP6, TP6, TP7, TP7, TP8, TP8, TP10, TP10, TP11,  TP11, TP12, TP12, TP13, TP13, TP14, TP14, TP15, TP15, TP16, TP16, TP17, TP17,  TP18, TP18, TP19, TP19, TP20, TP20, TP21, TP21, TP22, TP22, TP23, TP23, TP24,  TP24, TP25, TP25, TP26, TP26, TP28, TP28, TP29, TP29, TP30, TP30, TP31, TP31,  TP32, TP32, TP33, TP33, TP34, TP34, TP35, TP35, TP36, TP36, TP37, TP37, TP38,  TP38, TP39, TP39, TP41, TP41, TP42, TP42, TP43, TP43, TP44, TP44, TP45, TP45,  TP46, TP46, TP47, TP47, TP48, TP48, TP49, TP49, TP50, TP50
TP
94
P6KE6.8CA
TVS1, TVS1, TVS2,  TVS2, TVS3, TVS3
DIODE0_4-12
ACT4060
U1
SO-8
SY8009A
U2, U2, U4, U4
SOT25-RT8008
RK2818
U3
BGA324
ENC28J60-SSOP
U6
SOP28-1
SY7201
U8
PT5128E23F-B
ES8328-QFN28
U9
ES8238
LM386
U10
SOJ-8
LM2622
U11
LM2622-MSOP8-EUM0396
PT7M7823STAEX
U12
PT7M78
DDRII  64M*16bit
U13
FBGA60-9X15
FLASH
U15
TSOP1-48
24M
X1
CRISTAI-24M
25M
Y2
CRYSTAL9
5.6V
Z1
SOT-23Z
RL102-141N
Z2, Z2, Z4, Z4
D10B
Z18V
ZD1
Z15V-SOT23-EDM0021
Z6.2V
ZD2
Z6_8V-SOT23-EDM0027
6 p) V* N# I8 t4 X1 r% O: a# O2 J附件:
3 V4 H8 x! J! [7 u  L原理图和PCB源文件如下:* i; N9 u4 j/ i" ?1 N! k/ ]' S# G
游客,如果您要查看本帖隐藏内容请回复
# r1 N. }1 }9 ~: Y" D/ o
5 p; v4 U" Y3 h% D# ?
GMT+8, 2025-7-26 16:43 , Processed in 0.140625 second(s), 28 queries , Gzip On.
