作品名:[AD 10][2层]CTB-D-IP120Z-1C 120W功放 PCB
+ _5 F" K7 k/ _) m
8 Y8 f8 s5 ]6 A6 G0 I文件描述
9 d- p# S* G- Q; }5 W4 d1. 作品用途:120W功放' q, D4 |1 j; k
2. 软件版本:AD 104 p/ |* A7 M7 M3 r. T/ g
3. 层数:2层板) x1 ?8 o3 n! _& g, I
4. 用到的主要芯片:IRS2092S
' v0 |5 [% u- r( {5 n' @/ t5. PCB尺寸:197.3mm*91.9mm
) ]1 v; R8 f/ A/ t# X1 E0 N$ G
: L: h/ x' `4 z7 g, v作品截图如下:
* }( b6 d7 z8 N" ]: H# z3 B顶层截图:% s) \0 M) f# e8 n
" x3 [4 r' U: X8 \
0 ^7 _( i" M- b1 A底层截图:
. S" U( y8 [6 o6 H0 F3 C0 f
, R- H A" t) w+ p. J
; k9 u; E5 S3 H9 w/ u
全层截图:
) _7 B0 X& Q( _: h4 S
2 r, J5 H9 d1 }$ C$ x/ r( o6 I
6 _7 b/ Q# }2 K7 z+ m. O叠层信息截图如下:
9 |- B& o' i! i9 Z: z1 M: r4 N
8 D, |8 L3 Y# h
- x1 b d7 q, L5 R* k2 o% nBOM:- ?+ T2 b# K+ m) N1 g- k3 x
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 6.3焊片 | AC1, AC2, AC3, AC4, AC5, SP1, SP2 | RES1.0 | 7 | D15XB60 | BR1 | RBV401 | 1 | S1WBS60 | BR2 | S1WB6048 | 1 | BUZZER9 | BZ1 | BUZZER9*4 | 1 | 1nF | C2, C4, C6, C7 | C1206 | 4 | 0.1uF,100V | C3, C10, C11, C14 | MET5/2.5 | 4 | 150pF,250V | C5, C9 | C1206 | 2 | 0.47uF, 400V | C12 | MET6-18-14.5 | 1 | 0.1uF, 100V | C13 | MET5/2.5 | 1 | 103/1KV | C17, C625, C626 | AC C | 3 | 1000uF,50V | C18, C19 | RB5/13 | 2 | 103/100V | C23, C24 | C1206 | 2 | 470U/25V | C26 | RB1000 | 1 | 104 | C27 | C1206 | 1 | 100U/25V | C29, C658, C659 | RB6.5/3A | 3 | 220uF/25V | C31 | RB3.5/8 | 1 | 2.2uF/50V | C32 | C1206 | 1 | 104/16V | C33, C36 | C0805 | 2 | 220uF/16V | C34 | RB6.5/3A | 1 | 10U | C39, C40 | 1210 | 2 | 22U/50V | C41 | RB2.5/5 | 1 | 104 | C70, C654, C655, C656, C677, C679, C680, C681, C682 | 0805 | 9 | 0.1uF | C100 | C0805 | 1 | 100/25 | C101, C906 | RB6.5/3A | 2 | 22/50 | C500, C503 | RB2.5/5 | 2 | 22P | C501, C502, C674 | C0805 | 3 | 10u/50V | C601, C602, C610, C614, C615, C616 | RB2.5/5 | 6 | 101 | C619, C664, C665 | C0805 | 3 | 47P | C620 | C0805 | 1 | 33P | C624, C649, C650, C651, C652, C668, C675 | C0805 | 7 | 106 | C653, C660, C661, C669, C671, C672 | 0805 | 6 | 10U | C657 | 0805 | 1 | 682 | C662, C663 | C0805 | 2 | 22u/25V | C666, C667 | RB2.5/5 | 2 | 200p | C670 | C0805 | 1 | 51p | C673 | C0805 | 1 | 100p | C676 | 0805 | 1 | 10u/25V | C800 | 0805 | 1 | 4U7/25V | C802 | 0805 | 1 | 2200uF,63V | C907, C908 | RB8.0/18 | 2 | 2200uF/63V | C909, C910 | RB8.0/18 | 2 | 220/25 | C911, C944 | RB3.5/8 | 2 | 104 | C914, C943 | C0805 | 2 | 22uF | CP1, CP2, CP4, CP6 | RB2.5/5 | 4 | 10uF, 16V/399-1593-1-ND/ | CP3 | RB2.5/5 | 1 | 1N4148T-73 | D1 | 1N4148 1-2 | 1 | MUR120RLG | D3, D5, D6 | B | 3 | 陶瓷放电管 | D3A | AXIAL12.5 | 1 | BAV19WS-FDICT-ND | D4 | 1N4148 1-2 | 1 | 1N4007 | D11, D12, D13, D900, D901 | B | 5 | B340A | D16 | SMA | 1 | 4148 | D501 | 1N4148 | 1 | 1N4148 | D801 | 0805 | 1 | 机壳 | J6, J6A | JZ | 2 | | J8A | SMK2R5MM_B | 1 | ACTIVE | JK2 | MIC_6.35mm | 1 | U7=G2R-2-5VDC | KJ1 | G2R-2 | 1 | KSD95C | KT2 | KSD95C | 1 | 22uH | L1 | 22UH | 1 | 磁珠(直插) | L4 | 3.5X4.7 | 1 | | L5 | L10X10 | 1 | 2uHx2 | L6 | COLL1UHX2 L9*12 | 1 | LCR0201 | LCR5 | LCR0201 | 1 | 160-1600-ND | LED1 | LED1 | 1 | RED | LED800 | LED1 | 1 | YEL | LED801 | LED1 | 1 | BLUE | LED802 | LED1 | 1 | GRE | LED803 | LED1 | 1 | GREEN | LED804 | LED1 | 1 | 621KD20 | PR1A, PR2A, PR3A | 621KD20 | 3 | BD136 | Q5 | BD136 | 1 | 2N5551 | Q6, Q100, Q104, Q105, Q106, Q107 | TO-23-T | 6 | IRFI4020H | Q16F | TO-220-5 | 1 | 2SC5171 | Q17 | A940 | 1 | 2N5401 | Q102, Q103 | TO-23-T | 2 | 100k | R1, R12 | 0805-2 | 2 | 330 | R2 | 1206 | 1 | 100R | R3 | 0805-2 | 1 | *3.01K 1% | R7 | 1206 | 1 | *120k 1% | R8 | 0805-2 | 1 | 1K | R9 | AXIAL12.5 | 1 | 820 | R11 | 1206 | 1 | 10k | R13, R19, R22, R26, R27 | 0805-2 | 5 | 120k | R16 | 0805 | 1 | *47k | R17 | 1206 | 1 | *9.1k | R18 | 0805-2 | 1 | 4.7R | R20 | 1206 | 1 | 10k | R23 | 1206 | 1 | 20R | R24, R25 | 1206 | 2 | 10R | R28, R29, R37 | 1206 | 3 | 10, 1W | R30 | AXIAL12.5 | 1 | 1K | R31 | 7243 | 1 | 0R* | R32 | 1206 | 1 | 100R | R33, R34 | 1206 | 2 | 10K | R35, R55, R106, R107, R109, R110, R111, R112, R113, R503, R604, R605, R606, R608, R610, R620, R677, R681, R693, R694, R699, R800, R802 | 0805 | 23 | 22K(1%) | R36 | 0805 | 1 | 15K | R38 | 1206 | 1 | 560 | R42 | 0805-2 | 1 | 820/1w | R50 | AXIAL15 | 1 | 820 1W | R51 | AXIAL15 | 1 | 0Ω | R52 | 0805 | 1 | 5.6K | R53, R120 | 0805 | 2 | 33K | R54, R697 | 0805 | 2 | 22K | R56, R118, R121, R124, R513, R601, R603, R621, R625, R666, R668, R669, R672, R673, R687, R688, R821, R822, R916, R917 | 0805 | 20 | 47K | R108 | 1206 | 1 | 1K | R115, R123 | 1206 | 2 | 3.3K | R116 | 0805 | 1 | 68K | R117 | 0805 | 1 | 1K | R122, R674, R675, R676, R679, R680, R683, R684, R685, R695 | 0805 | 10 | 470K | R500 | 0805 | 1 | 18K | R501, R511 | 0805 | 2 | 6K8 | R502 | 0805 | 1 | 1K2 | R504 | 0805 | 1 | 27K | R505, R508, R510 | 0805 | 3 | 47K | R506, R609, R624, R686, R689, R690, R691, R808 | 0805 | 8 | 12K | R507, R602, R623, R692, R816 | 0805 | 5 | 330 | R509 | 0805 | 1 | 3K3 | R512 | 0805 | 1 | 100K | R611, R617, R618, R619 | 0805 | 4 | 1K/0.5W | R612, R613 | 1210 | 2 | 75K | R614, R615, R616 | 0805 | 3 | 1M | R626 | 0805 | 1 | 0 | R650, R651, R652, R653, R654, R803 | 0805 | 6 | 2.2K | R667 | 0805 | 1 | 4K7 | R671 | 0805 | 1 | 4.7K | R678, R696, R698 | 0805 | 3 | 5.1K | R682 | 0805 | 1 | 9.1K | R801 | 0805 | 1 | 8K2 | R804, R805, R807 | 0805 | 3 | 220 | R806 | 0805 | 1 | 10 | R809 | 0805 | 1 | 8.2K | R810 | 0805 | 1 | 2K | R820 | 0805 | 1 | 15K | R825 | 0805 | 1 | 270/2W | R951, R952, R953, R954 | AXIAL20 | 4 | RCA4 | RCA1 | RCA AV4-8.4-10 | 1 | ON | SW1 | CON2 | 1 | 测试点 | TP20, TP21 | TEST | 2 | IRS2092S | U1 | SO-16-T | 1 | PC817C | U2, U13 | PCBCOMPONENT_1 | 2 | MP2451 | U4 | SOT23_6 | 1 | PC817A | U5 | PCBCOMPONENT_1 | 1 | TL074 | U502 | SO-14 | 1 | CD4558 | U601, U602, U605, U800, U801 | SO-8 | 5 | CD4052 | U603 | SO-16 | 1 | TL072 | U604 | SO-8 | 1 | B10K | VR601, VR602 | VR097B10K | 2 | B50K | VR603 | VR097B10K | 1 | B500K | VR604, VR605 | VR097B10K | 2 | 104/250V | X1 | MET6-13-10 | 1 | AC 15V | XS1 | 2P2.54 | 1 | 4P(2.54XH) | XS4 | 4P(2.54) | 1 | 4P(2.54XH) | XS5 | SC988-HBV | 1 | 8P(2.54XH) | XS6, XS7 | CON8 | 2 | 5P(2.54XH) | XS8, XS9 | CON5 | 2 | CON2 | XS10, XS14, XS15 | CON2 | 3 | XS1 | XS11 | CON5 | 1 | XS2 | XS12 | CON5 | 1 | XS3 | XS13 | CON2 | 1 | 5.6V | Z103, Z104 | B - 1W | 2 | 13V* | Z105 | B | 1 | 1N4757(51V) | ZD100 | B - 1W | 1 | 6.8V | ZD603, ZD604 | 1N4148 | 2 | 15V/1W | ZD900, ZD901 | B | 2 | 7 I2 P* d i2 d+ t' J
附件:
& l( Z( Z1 k' x% U. j; PPCB源文件如下:0 d/ O: c/ H" A% k8 |
/ u& _- p1 v: |
9 d d2 u3 w+ c' S
